  4. Server (RPI) Temperatur Alarm Funktion
    5.4k
51 Beiträge 7 Kommentatoren 11.1k Aufrufe
    stephan61
    Hallo bekomme folgende Fehlermeldungen
    raspberrypi 2015-12-27 11:34:51 error host.raspberrypi instance system.adapter.rpi.0 terminated with code 6 (uncaught exception)
    host-raspberrypi 2015-12-27 11:34:15 error instance system.adapter.rpi.0 terminated with code 6 (uncaught exception)
    SyntaxError: 2015-12-27 11:34:15 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    SyntaxError: 2015-12-27 11:34:15 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    SyntaxError: 2015-12-27 11:34:15 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
    SyntaxError: 2015-12-27 11:34:15 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    SyntaxError: 2015-12-27 11:34:15 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    SyntaxError: 2015-12-27 11:34:15 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
    SyntaxError: 2015-12-27 11:34:15 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
    SyntaxError: 2015-12-27 11:34:15 error at Socket. (/opt/iobroker/node_modules/iobroker.rpi/main.js:45:13)
    SyntaxError: 2015-12-27 11:34:15 error at main (/opt/iobroker/node_modules/iobroker.rpi/main.js:80:5)
    SyntaxError: 2015-12-27 11:34:15 error at parser (/opt/iobroker/node_modules/iobroker.rpi/main.js:222:47)
    SyntaxError: 2015-12-27 11:34:15 error Unexpected token *
    uncaught 2015-12-27 11:34:15 error exception: Unexpected token *
    host-raspberrypi 2015-12-27 11:33:40 error instance system.adapter.rpi.0 terminated with code 6 (uncaught exception)
    SyntaxError: 2015-12-27 11:33:39 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    SyntaxError: 2015-12-27 11:33:39 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    SyntaxError: 2015-12-27 11:33:39 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
    SyntaxError: 2015-12-27 11:33:39 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    SyntaxError: 2015-12-27 11:33:39 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    SyntaxError: 2015-12-27 11:33:39 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
    SyntaxError: 2015-12-27 11:33:39 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
    SyntaxError: 2015-12-27 11:33:39 error at Socket. (/opt/iobroker/node_modules/iobroker.rpi/main.js:45:13)
    SyntaxError: 2015-12-27 11:33:39 error at main (/opt/iobroker/node_modules/iobroker.rpi/main.js:80:5)
    SyntaxError: 2015-12-27 11:33:39 error at parser (/opt/iobroker/node_modules/iobroker.rpi/main.js:222:47)
    SyntaxError: 2015-12-27 11:33:39 error Unexpected token *
    uncaught 2015-12-27 11:33:39 error exception: Unexpected token *
    Unter Objecte habe ich aber die Einträge
    Gruss Stephan
    Habe rpi2
    • V Offline
      V Offline
      versteckt
      Hallo, hey cool zumindest hast du schon Inhalt.
      Den Fehler schaue ich mir nachher an, bin grad nicht vor dem Rechner.
      Gesendet von meinem iPhone mit Tapatalk
      Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
      homegear für Homematic und MAX!
      occ, zWave, rpi, hmm und homekit Entwickler
      • V Offline
        V Offline
        versteckt
        Kannst du mal den Inhalt des Objekts "system.adapter.rpi.0" posten?
        Und zwar von dem Tab "raw (experts only)".
          stephan61
          Hallo hier der Inhalt
          [code{
          "common": {
          "name": "rpi",
          "title": "RPI-Monitor",
          "version": "0.0.2",
          "mode": "daemon",
          "platform": "javascript/Node.js",
          "loglevel": "info",
          "main": "main.js",
          "license": "MIT",
          "readme": "https://github.com/husky-koglhof/ioBrok … /README.md",
          "icon": "rpi-monitor.png",
          "type": "hardware",
          "extIcon": "https://raw.githubusercontent.com/husky ... onitor.png",
          "installedVersion": "0.0.2",
          "host": "raspberrypi",
          "schedule": "",
          "singletonHost": true,
          "enabled": true,
          "desc": {
          "en": "RPI-Monitor for ioBroker Installations",
          "de": "RPI-Monitor für ioBroker",
          "ru": "RPI-Монитор для ioBroker"
          "os": [
          "linux",
          "darwin"
          "keywords": [
          "ioBroker",
          "monitoring",
          "raspberry",
          "orangepi",
          "odroid",
          "bananapi"
          "authors": [
          "Christian Baumgartner",
          "husky-koglhof husky.koglhof@icloud.com"
          "native": {
          "interval": 60000,
          "c_cpu": true,
          "c_raspberry": true,
          "c_memory": true,
          "c_network": true,
          "c_sdcard": true,
          "c_swap": true,
          "c_temperature": true,
          "c_uptime": true,
          "c_wlan": true,
          "cpu": {
          "cpu_frequency": {
          "command": "cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq",
          "regexp": "(.*)",
          "post": "$1/1000"
          "load1,load5,load15": {
          "command": "cat /proc/loadavg",
          "regexp": "^(\S+)\s(\S+)\s(\S+)",
          "post": ""
          "scaling_governor": {
          "command": "cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor",
          "regexp": "(.*)",
          "post": ""
          "raspberry": {
          "cpu_voltage": {
          "command": "vcgencmd measure_volts core",
          "regexp": "(\d+.\d+)V",
          "post": ""
          "mem_arm": {
          "command": "vcgencmd get_mem arm",
          "regexp": "(\d+)",
          "post": ""
          "mem_gpu": {
          "command": "vcgencmd get_mem gpu",
          "regexp": "(\d+)",
          "post": ""
          "memory": {
          "memory_total": {
          "command": "cat /proc/meminfo",
          "regexp": "MemTotal:\s+(\d+)",
          "post": "$1/1024"
          "memory_free": {
          "regexp": "MemFree:\s+(\d+)",
          "post": "$1/1024"
          "memory_available": {
          "command": "/usr/bin/free -mk",
          "regexp": "^-\/\+ buffers\/cache:\s+\d+\s+(\d+)",
          "post": "$1/1024",
          "multiline": true
          "network": {
          "net_received": {
          "command": "cat /sys/class/net/eth0/statistics/rx_bytes",
          "regexp": "(.*)",
          "post": "$1*-1"
          "net_send": {
          "command": "cat /sys/class/net/eth0/statistics/tx_bytes",
          "regexp": "(.*)",
          "post": ""
          "sdcard": {
          "sdcard_root_total": {
          "command": "df /",
          "regexp": "\S+\s+(\d+).*\/$",
          "post": "$1/1024",
          "multiline": true
          "sdcard_boot_total": {
          "command": "df /boot",
          "regexp": "\S+\s+(\d+).*\/boot$",
          "post": "$1/1024",
          "multiline": true
          "sdcard_root_used": {
          "command": "df /",
          "regexp": "\S+\s+\d+\s+(\d+).*\/$",
          "post": "$1/1024",
          "multiline": true
          "sdcard_boot_used": {
          "regexp": "\S+\s+\d+\s+(\d+).*\/boot$",
          "post": "$1/1024",
          "multiline": true
          "swap": {
          "swap_total": {
          "regexp": "SwapTotal:\s+(\d+)",
          "post": "$1/1024",
          "multiline": true
          "swap_used": {
          "regexp": "SwapFree:\s+(\d+)",
          "post": "rpi.swap_total - ($1/1024)",
          "multiline": true
          "temperature": {
          "soc_temp": {
          "command": "cat /sys/devices/virtual/thermal/thermal_zone0/temp",
          "regexp": "(.*)",
          "post": "$1/1000"
          "uptime": {
          "uptime": {
          "command": "cat /proc/uptime",
          "regexp": "(^\S+)",
          "post": ""
          "wlan": {
          "wifi_received": {
          "command": "cat /sys/class/net/wlan0/statistics/rx_bytes",
          "regexp": "(.*)",
          "post": "$1*-1"
          "wifi_send": {
          "command": "cat /sys/class/net/wlan0/statistics/tx_bytes",
          "regexp": "(.*)",
          "post": ""
          "acl": {
          "object": 1638,
          "owner": "system.user.admin",
          "_id": "system.adapter.rpi.0",
          "type": "instance"
          • fischi87F Offline
            fischi87F Offline
            fischi87
            Also bei mir läuft der Adapter tadellos. Nur stellen nach dem Komma sind etwas viele :-)
            Mfg
            • V Offline
              V Offline
              versteckt
              @stephan61: Hast du WLAN und Network aktiviert?
              Wenn ja, hast du Ethernet und WLAN aktiv an deinem Raspberry?
              Für mich sieht das stark danach aus und eines der beiden liefert aber keine Werte.
              @fischi87: Ja ich weiss, das muss ich noch anpassen, aber ansonsten funktioniert alles?
              • fischi87F Offline
                fischi87F Offline
                fischi87
                Jap, bei mir füllt es alles und hab keine Fehler im log.
                Mfg
                • V Offline
                  V Offline
                  versteckt
                  Hab eine 0.0.3 Version hochgeladen.
                  ` > 0.0.3 (2015-12-28)
                  • (husky-koglhof) Fixed value calc.
                  Set Value to 2 digits `
                  LG Christian
                  • V Offline
                    V Offline
                    versteckt
                    Mein Adapter läuft jetzt schon länger und habe dadurch entdeckt, das die Temperatur durchgehend um die 55 Grad war.
                    Gehäuse aufgemacht, bin mittlerweile schon runter auf 46.
                    Hoch lebe mein neuer Adapter!
                    • fischi87F Offline
                      fischi87F Offline
                      fischi87
                      wer es auch möglich mit einem aktualisier button bei dem Reiter adapter?
                      mag
                      • V Offline
                        V Offline
                        versteckt
                        Geht erst wenn Bluefox ihn in die Liste der Adapter aufgenommen hat und ich in in npmjs drinnen hab. Mein Teil kommt morgen rein.
                        • fischi87F Offline
                          fischi87F Offline
                          fischi87
                          Grüße Christian,
                          bekomme seid ich den occ adapter installiert habe diese Fehlermeldung?!
