  4. Javascript startet nicht mehr, Fehler in der Installation
    6.0k
12 Beiträge 4 Kommentatoren 1.1k Aufrufe
  • hg6806H Offline
    hg6806H Offline
    hg6806
    leider habe ich auf einem Fehler im System.
    Hier mal ein Auszug aus dem Log:
    host.ioBroker-Pi 2018-06-04 09:00:42.295 error instance system.adapter.javascript.0 terminated with code 0 (OK)
    host.ioBroker-Pi 2018-06-04 09:00:42.295 error Caught by controller[1]: at Socket.emit (events.js:188:7)
    host.ioBroker-Pi 2018-06-04 09:00:42.295 error Caught by controller[1]: at emitOne (events.js:96:13)
    host.ioBroker-Pi 2018-06-04 09:00:42.295 error Caught by controller[1]: at Socket.socketErrorListener (_http_client.js:310:9)
    host.ioBroker-Pi 2018-06-04 09:00:42.295 error Caught by controller[1]: at ClientRequest.emit (events.js:188:7)
    host.ioBroker-Pi 2018-06-04 09:00:42.294 error Caught by controller[1]: at emitOne (events.js:96:13)
    host.ioBroker-Pi 2018-06-04 09:00:42.294 error Caught by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8)
    host.ioBroker-Pi 2018-06-04 09:00:42.294 error Caught by controller[1]: at Request.emit (events.js:188:7)
    host.ioBroker-Pi 2018-06-04 09:00:42.294 error Caught by controller[1]: at self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
    host.ioBroker-Pi 2018-06-04 09:00:42.293 error Caught by controller[1]: at Request._callback (script.js.common.Edimax.Edimax_ausschalten:11:38)
    host.ioBroker-Pi 2018-06-04 09:00:42.293 error Caught by controller[1]: TypeError: Cannot read property 'statusCode' of undefined
    host.ioBroker-Pi 2018-06-04 09:00:42.293 error Caught by controller[0]: at Socket.emit (events.js:188:7)
    host.ioBroker-Pi 2018-06-04 09:00:42.293 error Caught by controller[0]: at emitOne (events.js:96:13)
    host.ioBroker-Pi 2018-06-04 09:00:42.293 error Caught by controller[0]: at Socket.socketErrorListener (_http_clie
    Ich denke das schreit nach einer Neuinstallation, Backups habe ich.
    Das System befindet sich auf einer USB SSD "Platte".
    Weiß jemand wie ich hier ein Image aufspiele?
    Ich hatte beim Wechsel auf SSD ja nur dur meines Wissens der Inhalt der SD Karte überspielt.
    Kann ich hier mit Edger o.ä. einfach das neu aufspielen und bootet das dann direkt?
    Danke für Tipps
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @hg6806:
      Ich glaube eher da ist ein Fehler in deinem Skript "Edimax.Edimax_ausschalten" in Zeile 11. Du versuchst von irgendeiner nicht definierten Variable auf die Eigenschaft statusCode zuzugreifen.
      • hg6806H Offline
        hg6806H Offline
        hg6806
        Ja, ok, könnte es gewesen sein.
        Trotzdem würde ich gerne mal ein neues Image aufspielen.
        Kann mir jemand sagen wie man das mit einer SSD macht?
        • hg6806H Offline
          hg6806H Offline
          hg6806
          Nochmal die Frage, wie man ein von der iobroker Webseite geladenes Image auf eine SSD bring.
          Geht das einfach so mit Edger?
          • apollon77A Offline
            Keine Ahnung. Bin mir nicht socher ob das überhaupt so einfach geht
              AlCalzoneA Offline
              AlCalzone
              Nicht mal eben so. Die Images haben 2 Partitionen, eine Boot-Partition, und eine Datenpartition. Die Boot-Partition muss auf der SD-Karte verbleiben und wird weiterhin benötigt, außer man stellt seinen Pi3 dauerhaft auf USB-Boot um (zurück gehts dann nicht mehr). Die Datenpartition muss auf die SSD und in der Boot-Partition muss eine Anpassung vorgenommen werden, damit der Pi weiß, wo die Datenpartition zu finden ist.
              Am besten mal hier lesen: viewtopic.php?p=86763#p86763
              • hg6806H Offline
                hg6806H Offline
                hg6806
                Ja, der Pi ist ganz auf USB Boot umgestellt.
                D.h. einfach das Image auf SSD spielen und gut ist?
                  AlCalzoneA Offline
                  AlCalzone
                  Dann könnte das funktionieren. Solltest natürlich die Partition erweitern, damit die komplette SSD verwendet wird.
                  • paul53P Offline
                    @hg6806:
                    D.h. einfach das Image auf SSD spielen und gut ist? `
                    Ganz so einfach wohl nicht: Es müssen die Dateien /etc/fstab und /boot/cmdline.txt angepasst werden.
                    • hg6806H Offline
                      hg6806H Offline
                      hg6806
                      Stimmt, da hatte ich ja schon mal gemacht.
                      Also Image per Edger o.ä. drauf, Dateien anpassen, Hochfahren und über raspiconfig noch die Partition erweitern?
                      • paul53P Offline
                        @hg6806:
                        Also Image per Edger o.ä. drauf, Dateien anpassen, Hochfahren und über raspiconfig noch die Partition erweitern? `
                        Es könnte funktionieren. Probier es aus und berichte !
                        • paul53P Offline
                          Anmerkung: Bei einem neueren Image, bei dem in beiden Dateien anstelle von /dev/mmcblk0p2 UUID=… verwendet wird, könnte es auch ohne Anpassung in den beiden Dateien funktionieren. Einen Versuch ist es wert.
