  4. Modbus adapter
    5.8k
Modbus adapter
modbus adaptermodbus
981 Beiträge 141 Kommentatoren 484.1k Aufrufe 64 Beobachtet
    RS_Tobi
    #301
    Hi. Den Adapter habe ich schon 2x neu installiert.
    Von github habe ich es gestern versucht, da hagelte es nur Fehlermeldungen…
    Ich versuche es nochmal dann poste ich den log hier.
    Gesendet von meinem D5803 mit Tapatalk
    EDIT:
    hier der Log...
    ! host.Froeling 2017-09-20 14:44:31.752 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! iobroker 2017-09-20 14:44:30.295 info exit 0
    ! iobroker 2017-09-20 14:44:30.227 error Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter
    ! iobroker 2017-09-20 14:44:29.759 info npm ERR! code 1
    ! iobroker 2017-09-20 14:44:29.759 info ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ! iobroker 2017-09-20 14:44:29.728 info npm
    ! iobroker 2017-09-20 14:44:29.716 info
    ! iobroker 2017-09-20 14:44:25.400 info ERR! enoent and is related to npm not being able to find a file.npm ERR! enoent
    ! iobroker 2017-09-20 14:44:25.367 info npm
    ! iobroker 2017-09-20 14:44:25.367 info npm ERR! enoent This is most likely not a problem with npm itself
    ! iobroker 2017-09-20 14:44:25.367 info ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/minimist-f6e01a6b' -> '/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/
    ! iobroker 2017-09-20 14:44:25.346 info npm
    ! iobroker 2017-09-20 14:44:25.294 info npm ERR! syscall rename
    ! iobroker 2017-09-20 14:44:25.294 info code ENOENTnpm ERR! errno -2
    ! iobroker 2017-09-20 14:44:25.263 info npm ERR!
    ! iobroker 2017-09-20 14:44:25.263 info npm ERR! path /opt/iobroker/node_modules/.staging/minimist-f6e01a6b
    ! iobroker 2017-09-20 14:44:25.263 info ERR! node v6.11.3npm ERR! npm v3.10.10
    ! iobroker 2017-09-20 14:44:25.228 info npm
    ! iobroker 2017-09-20 14:44:25.228 info ERR! Linux 4.9.35+npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/ioBroker/ioBroker.mo … all/master" "--production" "--prefix" "/opt/iobroker"
    ! iobroker 2017-09-20 14:44:25.214 info npm
    ! iobroker 2017-09-20 14:34:18.258 info npm install https://github.com/ioBroker/ioBroker.mo ... all/master --production --prefix "/opt/iobroker" (System call)
    ! iobroker 2017-09-20 14:34:16.050 info install https://github.com/ioBroker/ioBroker.mo ... all/master
    ! iobroker 2017-09-20 14:34:09.093 info url "https://github.com/ioBroker/ioBroker.mo ... all/master" modbus
      RS_Tobi
      #302
      Hallo.
      Vielleicht sollte ich etwas über meine Konstellation erzählen.
      Ich habe einen Raspberry Pi 2 als Horst und habe den raspberry 1 im multi-host Verbund laufen.
      Auf dem raspberry 1 ist nur eine iobroker Instanz installiert und auf diese ist nur der Mode Bus installiert. Auf diesem raspberry 1 ist auch der serial Converter eingesteckt.
      Funktioniert eine solche Konstellation mit dem Adapter schon?
      Soll ich mal einen anderen raspberry pie ausprobieren?
      Ich habe nur diesen genommen da er mir zu schade warum einfache rumzuliegen. Somit hätte ich eine Aufgabe für ihn gehabt.
      Tobi
        RS_Tobi
        #303
        @apollon77:
        Du musst den Adapter neu installieren. Seialport als Library wird kompiliert und geht nach einem Node Upgrade kaputt weil es dann neu kompiliert werden muss. Entweder Adapter vom github drüber installieren oder im iobroker Verzeichnis das reinstall.sh aufrufen - dann wird alles neu gebaut. ` Hallo.
        Wie führe ich denn das reinstall.sh richtig auf?
        Ich habe es gerade ausprobiert daraufhin versuchte er als erstes IOBroker zu stoppen.
        Danach kam der Hinweis wie wir ihn alle kennen, wenn man einen falschen Befehl eingibt. Also ich meine diese Liste mit den ganzen IOBroker Start Stop restart Update und so weiter befehlen.
        Daraufhin endete das ganze wieder in einer neuen Eingabezeile.
        Von der Zeit her hätte ich gesagt dass es ca 10 Sekunden gedauert hat.
        Ich habe dieses auf dem Host ausgeführt auf diesem auch der RS232 Adapter eingesteckt ist und der Mod Bus Adapter installiert werden soll. Ist das richtig?
        • apollon77A Offline
          #304
          Hey,
          Github URL ist falsch!!
          https://github.com/ioBroker/ioBroker.modbus/
            RS_Tobi
            #305
            @apollon77:
            Hey,
            https://github.com/ioBroker/ioBroker.modbus/ `
            Ok. Danke…
            Habe es durchgeführt.
            Es lief ohne Fehler im log durch
            ABER der Adapter war weder bei Instanzen noch bei Objekte zu sehen.
            Ich habe daraufhin noch einmal ganz normal aus dem Admin heraus installiert. Daraufhin tauchte er wieder überall auf.
            Ich habe jetzt mal den test mit einem Downgrade versucht.
            Ich bin erst von 6.11.3 wieder zurück auf 4.x da sich dort aber nichts verändert hat zu 6.11.3 bin ich noch einen Schritt zurück gegangen und habe laut der Installationsanleitung wieder das Note 0.12 .6 installiert.
            Nun tauchen im Auswahl des Adapters wieder zum einen die ttyUSB0 und ttyAMA0 auf.
            Ich kann auch einen auswählen wie z.b. den ttyUSB0 und dann klicke ich auf Speichern.
            Nun kommt folgender lock.
            ! modbus.0 2017-09-21 00:09:58.849 error Cannot create modbus master!
            ! modbus.0 2017-09-21 00:09:58.838 error Cannot open port "/dev/ttyUSB0" [57600]: ReferenceError: serialport is not defined
            ! modbus.0 2017-09-21 00:09:58.280 info starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v0.12.6
            ! host.Froeling 2017-09-21 00:09:45.763 info instance system.adapter.modbus.0 started with pid 838
            ! host.Froeling 2017-09-21 00:09:43.298 info instance system.adapter.modbus.0 terminated with code 0 (OK)
            ! modbus.0 2017-09-21 00:09:43.238 info terminating
            ! host.Froeling 2017-09-21 00:09:43.154 info stopInstance system.adapter.modbus.0 killing pid 826
            ! host.Froeling 2017-09-21 00:09:43.150 info stopInstance system.adapter.modbus.0
            ! host.Froeling 2017-09-21 00:09:43.137 info object change system.adapter.modbus.0
            ! modbus.0 2017-09-21 00:09:13.442 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:08:12.416 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:07:11.396 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:06:10.370 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:05:09.341 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:04:08.311 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:03:07.285 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:02:06.258 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:01:05.271 info List of port: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"FTDI_USB_Serial_Converter_FT8VXGSB","pnpId":"usb-FTDI_USB_Serial_Converter_FT8VXGSB-if00-port
            ! modbus.0 2017-09-21 00:01:05.191 warn On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect"}
            ! modbus.0 2017-09-21 00:01:02.700 info starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v0.12.6
            ! host.Froeling 2017-09-21 00:00:49.457 info instance system.adapter.modbus.0 started with pid 826
            Ich erkläre auch noch einmal kurz was das Problem bei den anderen nur die Versionen ist
            Wenn ein 4. X bzw ein 6. X node installiert ist, dann kann ich im Mod Bus Adapter keine serielle Schnittstelle auswählen da dieses Feld ausgegraut ist.
            Noch einmal kurz zu meiner Konstellation. Ich habe einen Multi Host System aufgebaut.
            Master ist ein Raspberry Pi 2
            Und als Slave fungiert ein Raspberry Pi 1.
            Die Mod Bus Instanz möchte ich auf dem raspberry Pie 1 installieren und dort ist auch der USB 232 converter eingesteckt.
            An was glaubt ihr dass es liegt?
            An meiner alten Hardware oder sollte ich trotzdem ein issue auf github öffnen?
            Tobi
              #306
              Hast du nach JEDER nodejs-versions-Änderung den Adapter neu installiert?? Und natürlich auch iobroker gestoppt, vllt noch rebootet und gestartet?
                RS_Tobi
                #307
                @apollon77:
                Hast du nach JEDER nodejs-versions-Änderung den Adapter neu installiert?? Und natürlich auch iobroker gestoppt, vllt noch rebootet und gestartet? ` Ja.
                Immer alles neu gemacht . Und auch iobroker gestoppt . Und neu booten tue ich sowieso von Haus aus sehr gerne.
                Tobi
                  #308
                  Dann wären die Logs von den jeweiligen Adapter-Installs interessnt. Weil wenn serielle schnittstelle ausgegrautiost dann wurde serialport nicht korrekt installiert und damit kann nix tun
                  • wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    #309
                    Grundsätzlich läuft der Modbus Adapter bei mir seit beginn ohne Probleme auf einem PI3 der als zweiter Rechner in einer Multihost umgebung läuft.
                    Wenn nicht viel auf dem PI läuft würde ich vielleicht nochmal sauber neu aufsetzen.
                      RS_Tobi
                      #310
                      @wendy2702:
                      Wenn nicht viel auf dem PI läuft würde ich vielleicht nochmal sauber neu aufsetzen. ` Hallo.
                      Sauber neu aufsetzen habe ich mir für heute vorgenommen.
                      Dann gleich von grundauf mit node 4.x?
                      Denn dann kann ich für apollon77 auch gleich das log Posten wenn es wieder nicht geht
                      Tobi
                      • wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        #311
                        @RS_Tobi:
                        @wendy2702:
                        Tobi
                        Gesendet von meinem D5803 mit Tapatalk `
                        Bei mir läuft es so:
                        pi@pi-iobroker:~ $ node -v
                        v4.8.0
                        pi@pi-iobroker:~ $ npm -v
                        2.15.11
                          #312
                          node 6 geht auch. von node 8 würde ich noch die Finger weglassen
                            RS_Tobi
                            #313
                            habe es neu aufgesetzt und jetzt kommt dieser log.
                            ! modbus.0 2017-09-21 18:49:28.136 error Cannot create modbus master!
                            ! modbus.0 2017-09-21 18:49:28.121 error Cannot open port "/dev/ttyUSB0" [57600]: ReferenceError: serialport is not defined
                            ! modbus.0 2017-09-21 18:49:27.015 info starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v4.8.0
                            ! host.FroelingRPi 2017-09-21 18:49:17.550 info instance system.adapter.modbus.0 started with pid 1010
                            ! host.FroelingRPi 2017-09-21 18:49:15.129 info instance system.adapter.modbus.0 terminated with code 0 (OK)
                            ! modbus.0 2017-09-21 18:49:15.074 info terminating
                            ! host.FroelingRPi 2017-09-21 18:49:15.005 info stopInstance system.adapter.modbus.0 killing pid 981
                            ! host.FroelingRPi 2017-09-21 18:49:15.002 info stopInstance system.adapter.modbus.0
                            ! host.FroelingRPi 2017-09-21 18:49:14.999 info object change system.adapter.modbus.0
                            ! modbus.0 2017-09-21 18:49:01.186 info List of port: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"FTDI_USB_Serial_Converter_FT8VXGSB","pnpId":"usb-FTDI_USB_Serial_Converter_FT8VXGSB-if00-port[/spoiler]
                            danke für Eure hilfe
                            Tobi
                              #314
                              Das Installationslog vom Adapter ist interessant!!
                                RS_Tobi
                                #315
                                Woher bekomme ich den?
                                  #316
                                  /opt/iobroker/log/… sind die Logfiles der letzten 7 Tage. Da sollte es drin sein vom Zeitpunkt der Installation
                                    RS_Tobi
                                    #317
                                    @apollon77:
                                    /opt/iobroker/log/… sind die Logfiles der letzten 7 Tage. Da sollte es drin sein vom Zeitpunkt der Installation `
                                    Morgen,
                                    hier der log…
                                    ! 2017-09-21 18:35:31.459 - [32minfo[39m: host.FroelingRPi InMemoryDB 192.168.178.10:9001 connected
                                    ! 2017-09-21 18:35:31.898 - [32minfo[39m: host.FroelingRPi 18 instances found
                                    ! 2017-09-21 18:35:31.916 - [33mwarn[39m: host.FroelingRPi does not start any instances on this host
                                    ! 2017-09-21 18:36:08.728 - [33mwarn[39m: host.FroelingRPi some hosts are offline
                                    ! 2017-09-21 18:36:08.885 - [33mwarn[39m: host.FroelingRPi too delayed answer for IObroker
                                    ! 2017-09-21 18:36:10.977 - [32minfo[39m: iobroker _restart
                                    ! 2017-09-21 18:36:15.335 - [32minfo[39m: iobroker Starting node restart.js
                                    ! 2017-09-21 18:36:15.498 - [32minfo[39m: iobroker exit 0
                                    ! 2017-09-21 18:36:17.312 - [32minfo[39m: host.FroelingRPi received SIGTERM
                                    ! 2017-09-21 18:36:17.365 - [32minfo[39m: host.FroelingRPi terminated
                                    ! 2017-09-21 18:36:28.525 - [32minfo[39m: host.FroelingRPi iobroker.js-controller version 1.1.3 js-controller starting
                                    ! 2017-09-21 18:36:28.610 - [32minfo[39m: host.FroelingRPi Copyright © 2014-2017 bluefox, hobbyquaker
                                    ! 2017-09-21 18:36:28.619 - [32minfo[39m: host.FroelingRPi hostname: FroelingRPi, node: v4.8.0
                                    ! 2017-09-21 18:36:28.628 - [32minfo[39m: host.FroelingRPi ip addresses: 192.168.178.20 2003:48:4a3d:b00:93f0:b958:4889:8039 fe80::3708:fc86:21b1:a4c2
                                    ! 2017-09-21 18:36:30.498 - [32minfo[39m: host.FroelingRPi InMemoryDB 192.168.178.10:9001 connected
                                    ! 2017-09-21 18:36:31.139 - [32minfo[39m: host.FroelingRPi 18 instances found
                                    ! 2017-09-21 18:36:31.198 - [33mwarn[39m: host.FroelingRPi does not start any instances on this host
                                    ! 2017-09-21 18:37:04.614 - [32minfo[39m: iobroker add modbus
                                    ! 2017-09-21 18:37:14.049 - [32minfo[39m: iobroker npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
                                    ! 2017-09-21 18:39:41.632 - [32minfo[39m: iobroker node-pre-gyp
                                    ! 2017-09-21 18:39:41.672 - [32minfo[39m: iobroker ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.0 (node-v46 ABI) (falling back to source compile with node-gyp)
                                    ! 2017-09-21 18:42:58.137 - [32minfo[39m: iobroker host.FroelingRPi install adapter modbus
                                    ! 2017-09-21 18:42:58.242 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.modbus/admin
                                    ! 2017-09-21 18:42:58.290 - [32minfo[39m: iobroker upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                                    ! 2017-09-21 18:42:58.573 - [32minfo[39m: iobroker upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript
                                    ! 2017-09-21 18:42:58.783 - [32minfo[39m: iobroker upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript
                                    ! 2017-09-21 18:42:58.958 - [32minfo[39m: iobroker upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript
                                    ! 2017-09-21 18:42:59.049 - [32minfo[39m: iobroker upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript
                                    ! 2017-09-21 18:42:59.137 - [32minfo[39m: iobroker upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css
                                    ! 2017-09-21 18:42:59.233 - [32minfo[39m: iobroker upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css
                                    ! 2017-09-21 18:42:59.329 - [32minfo[39m: iobroker upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css
                                    ! 2017-09-21 18:42:59.499 - [32minfo[39m: iobroker upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css
                                    ! 2017-09-21 18:42:59.670 - [32minfo[39m: iobroker upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html
                                    ! 2017-09-21 18:42:59.845 - [32minfo[39m: iobroker upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png
                                    ! 2017-09-21 18:43:00.490 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus created
                                    ! 2017-09-21 18:43:00.593 - [32minfo[39m: iobroker host.FroelingRPi create instance modbus
                                    ! 2017-09-21 18:43:00.641 - [32minfo[39m: iobroker host.FroelingRPi object modbus.0.info.connection created
                                    ! 2017-09-21 18:43:00.692 - [32minfo[39m: iobroker host.FroelingRPi object modbus.0.info created
                                    ! 2017-09-21 18:43:00.750 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.outputCount created
                                    ! 2017-09-21 18:43:00.792 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.inputCount created
                                    ! 2017-09-21 18:43:00.839 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.uptime created
                                    ! 2017-09-21 18:43:00.882 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.memRss created
                                    ! 2017-09-21 18:43:00.928 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.memHeapTotal created
                                    ! 2017-09-21 18:43:00.974 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.memHeapUsed created
                                    ! 2017-09-21 18:43:01.017 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.connected created
                                    ! 2017-09-21 18:43:01.062 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0.alive created
                                    ! 2017-09-21 18:43:01.142 - [32minfo[39m: iobroker host.FroelingRPi object system.adapter.modbus.0 created
                                    ! 2017-09-21 18:43:01.167 - [32minfo[39m: host.FroelingRPi object change system.adapter.modbus.0
                                    ! 2017-09-21 18:43:01.278 - [32minfo[39m: host.FroelingRPi instance system.adapter.modbus.0 started with pid 964
                                    ! 2017-09-21 18:43:01.380 - [32minfo[39m: iobroker exit 0
                                    ! 2017-09-21 18:43:12.126 - [32minfo[39m: modbus.0 starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v4.8.0
                                    ! 2017-09-21 18:43:13.835 - [33mwarn[39m: modbus.0 On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                    ! 2017-09-21 18:43:15.203 - [32minfo[39m: modbus.0 List of port: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"FTDI_USB_Serial_Converter_FT8VXGSB","pnpId":"usb-FTDI_USB_Serial_Converter_FT8VXGSB-if00-port0","vendorId":"0x0403","productId":"0x6001"}]
                                    ! 2017-09-21 18:44:15.085 - [33mwarn[39m: modbus.0 On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                    ! 2017-09-21 18:45:16.108 - [33mwarn[39m: modbus.0 On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                    ! 2017-09-21 18:46:17.129 - [33mwarn[39m: modbus.0 On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                    ! 2017-09-21 18:47:18.150 - [33mwarn[39m: modbus.0 On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                    ! 2017-09-21 18:48:19.171 - [33mwarn[39m: modbus.0 On error: {"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                                    ! 2017-09-21 18:48:30.753 - [32minfo[39m: host.FroelingRPi object change system.adapter.modbus.0
                                    ! 2017-09-21 18:48:30.769 - [32minfo[39m: host.FroelingRPi stopInstance system.adapter.modbus.0
                                    ! 2017-09-21 18:48:30.773 - [32minfo[39m: host.FroelingRPi stopInstance system.adapter.modbus.0 killing pid 964
                                    ! 2017-09-21 18:48:30.848 - [32minfo[39m: modbus.0 terminating
                                    ! 2017-09-21 18:48:30.909 - [32minfo[39m: host.FroelingRPi instance system.adapter.modbus.0 terminated with code 0 (OK)
                                    ! 2017-09-21 18:48:33.345 - [32minfo[39m: host.FroelingRPi instance system.adapter.modbus.0 started with pid 981
                                    ! 2017-09-21 18:48:42.609 - [32minfo[39m: modbus.0 starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v4.8.0
                                    ! 2017-09-21 18:48:43.710 - [31merror[39m: modbus.0 Cannot open port "/dev/ttyUSB0" [57600]: ReferenceError: serialport is not defined
                                    ! 2017-09-21 18:48:43.724 - [31merror[39m: modbus.0 Cannot create modbus master!
                                    ! 2017-09-21 18:49:01.186 - [32minfo[39m: modbus.0 List of port: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"FTDI_USB_Serial_Converter_FT8VXGSB","pnpId":"usb-FTDI_USB_Serial_Converter_FT8VXGSB-if00-port0","vendorId":"0x0403","productId":"0x6001"}]
                                    ! 2017-09-21 18:49:14.999 - [32minfo[39m: host.FroelingRPi object change system.adapter.modbus.0
                                    ! 2017-09-21 18:49:15.002 - [32minfo[39m: host.FroelingRPi stopInstance system.adapter.modbus.0
                                    ! 2017-09-21 18:49:15.005 - [32minfo[39m: host.FroelingRPi stopInstance system.adapter.modbus.0 killing pid 981
                                    ! 2017-09-21 18:49:15.074 - [32minfo[39m: modbus.0 terminating
                                    ! 2017-09-21 18:49:15.129 - [32minfo[39m: host.FroelingRPi instance system.adapter.modbus.0 terminated with code 0 (OK)
                                    ! 2017-09-21 18:49:17.550 - [32minfo[39m: host.FroelingRPi instance system.adapter.modbus.0 started with pid 1010
                                    ! 2017-09-21 18:49:27.015 - [32minfo[39m: modbus.0 starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v4.8.0
                                    ! 2017-09-21 18:49:28.121 - [31merror[39m: modbus.0 Cannot open port "/dev/ttyUSB0" [57600]: ReferenceError: serialport is not defined
                                    ! 2017-09-21 18:49:28.136 - [31merror[39m: modbus.0 Cannot create modbus master![/spoiler]
                                    liegt der Fehler in 18.39.41
                                    danke
                                    tobi
                                      #318
                                      Steht zwischen 18:39 und 18:42 echt nichts im Log? Da fehlt das eigentlich interessante
                                        RS_Tobi
                                        #319
                                        sorry, Nein.
                                        Hab am log nichts verändert….
                                        steht genau so in der Datei...
                                        Vielleicht ist es problem mit ARM6 wenn es bei anderen mit node 4.8.0 funktioniert, dann wäre das für mich das einzige...
                                        tobi
                                          #320
                                          Geh mal Kommandozeile in /opt/iobroker
                                          Dort mach mal:
                                          sudo npm install iobroker.modbus –production --prefix "/opt/iobroker"
                                          und dann das Log bitte.
