  4. [gelöss] admin 3.3.1 adapter starten ständig neu
3 Beiträge 2 Kommentatoren 731 Aufrufe
    stephan61
    Habe heute admin 3.3.1 mit host 1.3.0 npm 5.7.1 und node v 6.13.1 upgedatet jetzt starten die adpter nacheinander immer wieder neu
    woran liegt das?
    host.linaro-alip
    2018-03-12 18:15:16.153
    error
    instance system.adapter.telegram.0 terminated with code 7 (Adapter already running)
    host.linaro-alip
    2018-03-12 18:15:16.152
    error
    Caught by controller[1]: 2018-03-12 18:15:16.108 - telegram.0 already running
    host.linaro-alip
    error
    Caught by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319\. at module.js:577:32
    host.linaro-alip
    error
    Caught by controller[0]: In the future, you will have to enable it yourself.
    host.linaro-alip
    error
    Caught by controller[0]: Mon, 12 Mar 2018 17:15:15 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
    host.linaro-alip
    2018-03-12 18:15:14.988
    info
    Restart adapter system.adapter.upnp.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.upnp.0 terminated with code 7 (Adapter already running)
    host.linaro-alip
    2018-03-12 18:15:14.987
    error
    Caught by controller[0]: 2018-03-12 18:15:14.925 - upnp.0 already running
    host.linaro-alip
    2018-03-12 18:15:14.646
    info
    instance system.adapter.unifi.0 started with pid 5219
    host.linaro-alip
    2018-03-12 18:15:12.842
    info
    Restart adapter system.adapter.systeminfo.0 because enabled
    host.linaro-alip
    2018-03-12 18:15:12.839
    error
    instance system.adapter.systeminfo.0 terminated with code 7 (Adapter already running)
    host.linaro-alip
    2018-03-12 18:15:12.834
    error
    Caught by controller[0]: 2018-03-12 18:15:12.738 - systeminfo.0 already running
    host.linaro-alip
    2018-03-12 18:15:11.125
    info
    Restart adapter system.adapter.hm-rega.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:15:11.124
    error
    by controller[0]: 2018-03-12 18:15:11.040 - hm-rega.0 already running
    host.linaro-alip
    2018-03-12 18:15:10.684
    info
    Restart adapter system.adapter.sonoff.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.sonoff.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:15:10.683
    error
    by controller[0]: 2018-03-12 18:15:10.646 - sonoff.0 already running
    web.1
    2018-03-12 18:15:10.657
    info
    2018-03-12T17:15:10.657Z Connected system.user.admin
    host.linaro-alip
    2018-03-12 18:15:10.184
    info
    Restart adapter system.adapter.web.1 because enabled
    host.linaro-alip
    2018-03-12 18:15:10.183
    error
    instance system.adapter.web.1 terminated with code 7 (Adapter already running)
    Caught
    error
    by controller[0]: 2018-03-12 18:15:10.115 - web.1 already running
    host.linaro-alip
    2018-03-12 18:15:09.784
    info
    Restart adapter system.adapter.socketio.0 because enabled
    host.linaro-alip
    2018-03-12 18:15:09.779
    error
    instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
    host.linaro-alip
    2018-03-12 18:15:09.755
    info
    Restart adapter system.adapter.simple-api.0 because enabled
    host.linaro-alip
    2018-03-12 18:15:09.754
    error
    instance system.adapter.simple-api.0 terminated with code 7 (Adapter already running)
    Caught
    error
    by controller[0]: 2018-03-12 18:15:09.550 - simple-api.0 already running
    host.linaro-alip
    2018-03-12 18:15:09.718
    info
    Restart adapter system.adapter.hue.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.hue.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:15:09.717
    error
    by controller[0]: 2018-03-12 18:15:09.647 - hue.0 already running
    host.linaro-alip
    2018-03-12 18:15:09.664
    info
    instance system.adapter.systeminfo.0 started with pid 5177
    host.linaro-alip
    2018-03-12 18:15:09.571
    info
    instance system.adapter.hm-rpc.0 started with pid 5162
    host.linaro-alip
    2018-03-12 18:15:09.029
    info
    instance system.adapter.hm-rega.0 started with pid 5156
    host.linaro-alip
    2018-03-12 18:15:08.415
    info
    instance system.adapter.sonoff.0 started with pid 5150
    host.linaro-alip
    2018-03-12 18:15:08.163
    info
    Restart adapter system.adapter.history.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    host.linaro-alip
    2018-03-12 18:15:08.099
    info
    Restart adapter system.adapter.node-red.0 because enabled
    host.linaro-alip
    2018-03-12 18:15:08.098
    error
    instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    Caught
    error
    by controller[0]: 2018-03-12 18:15:08.018 - node-red.0 already running
    host.linaro-alip
    2018-03-12 18:15:08.058
    info
    instance system.adapter.daswetter.0 terminated with code 0 (OK)
    host.linaro-alip
    2018-03-12 18:15:08.027
    info
    Restart adapter system.adapter.text2command.0 because enabled
    host.linaro-alip
    2018-03-12 18:15:08.026
    error
    instance system.adapter.text2command.0 terminated with code 7 (Adapter already running)
    Caught
    error
    by controller[0]: 2018-03-12 18:15:07.890 - text2command.0 already running
    host.linaro-alip
    2018-03-12 18:15:07.930
    info
    Restart adapter system.adapter.sayit.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:15:07.919
    error
    by controller[0]: 2018-03-12 18:15:07.849 - sayit.0 already running
    host.linaro-alip
    2018-03-12 18:15:07.270
    info
    Restart adapter system.adapter.paw.0 because enabled
    host.linaro-alip
    2018-03-12 18:15:07.259
    error
    instance system.adapter.paw.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:15:07.258
    error
    by controller[0]: 2018-03-12 18:15:07.178 - paw.0 already running
    host.linaro-alip
    2018-03-12 18:15:07.078
    info
    instance system.adapter.web.1 started with pid 5124
    host.linaro-alip
    2018-03-12 18:15:06.980
    info
    Restart adapter system.adapter.parser.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.parser.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:15:06.954
    error
    by controller[0]: 2018-03-12 18:15:06.869 - parser.0 already running
    host.linaro-alip
    2018-03-12 18:15:05.569
    info
    instance system.adapter.simple-api.0 started with pid 5114
    host.linaro-alip
    2018-03-12 18:15:05.529
    info
    instance system.adapter.socketio.0 started with pid 5108
    host.linaro-alip
    2018-03-12 18:15:05.409
    info
    instance system.adapter.hue.0 started with pid 5102
    host.linaro-alip
    2018-03-12 18:15:04.898
    info
    instance system.adapter.history.0 started with pid 5096
    javascript.0
    2018-03-12 18:15:04.772
    info
    script.js.common.Strom.umrechnung: 128419.212
    host.linaro-alip
    2018-03-12 18:15:04.740
    info
    instance system.adapter.text2command.0 started with pid 5085
    host.linaro-alip
    2018-03-12 18:15:04.700
    info
    instance system.adapter.node-red.0 started with pid 5084
    host.linaro-alip
    2018-03-12 18:15:04.478
    info
    Restart adapter system.adapter.broadlink2.0 because enabled
    host.linaro-alip
    2018-03-12 18:15:04.477
    error
    instance system.adapter.broadlink2.0 terminated with code 7 (Adapter already running)
    Caught
    error
    by controller[0]: 2018-03-12 18:15:04.318 - broadlink2.0 already running
    host.linaro-alip
    2018-03-12 18:15:04.240
    info
    instance system.adapter.sayit.0 started with pid 5074
    host.linaro-alip
    2018-03-12 18:15:04.124
    info
    Restart adapter system.adapter.ping.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:15:04.123
    error
    by controller[0]: 2018-03-12 18:15:04.079 - ping.0 already running
    host.linaro-alip
    2018-03-12 18:15:03.758
    info
    instance system.adapter.parser.0 started with pid 5064
    host.linaro-alip
    2018-03-12 18:15:03.380
    info
    instance system.adapter.paw.0 started with pid 5056
    host.linaro-alip
    2018-03-12 18:15:02.568
    info
    instance system.adapter.broadlink2.0 started with pid 5018
    host.linaro-alip
    2018-03-12 18:15:02.407
    info
    instance system.adapter.ping.0 started with pid 5012
    daswetter.0
    2018-03-12 18:15:01.873
    info
    starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
    daswetter.0
    2018-03-12 18:15:01.794
    info
    States connected to redis: 0.0.0.0:6379
    javascript.0
    2018-03-12 18:15:00.577
    info
    script.js.common.Heizung.Waermebedarf: Ventil Küche 14 Ventil Bad 44 Ventil Wohnzimmer 13 Ventil Esszimmer 13 Ventilges 84
    host.linaro-alip
    2018-03-12 18:15:00.045
    info
    instance system.adapter.daswetter.0 started with pid 4979
    host.linaro-alip
    2018-03-12 18:14:58.647
    info
    Restart adapter system.adapter.javascript.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:14:58.646
    error
    by controller[0]: 2018-03-12 18:14:58.608 - javascript.0 already running
    host.linaro-alip
    2018-03-12 18:14:55.635
    info
    instance system.adapter.javascript.0 started with pid 4962
    host.linaro-alip
    2018-03-12 18:14:49.946
    info
    Restart adapter system.adapter.scenes.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    Caught
    error
    by controller[0]: 2018-03-12 18:14:49.925 - scenes.0 already running
    host.linaro-alip
    2018-03-12 18:14:48.947
    info
    Restart adapter system.adapter.pushbullet.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.pushbullet.0 terminated with code 7 (Adapter already running)
    Caught
    error
    by controller[0]: 2018-03-12 18:14:48.918 - pushbullet.0 already running
    host.linaro-alip
    2018-03-12 18:14:48.888
    info
    Restart adapter system.adapter.owntracks.0 because enabled
    host.linaro-alip
    error
    instance system.adapter.owntracks.0 terminated with code 7 (Adapter already running)
    Caught
    2018-03-12 18:14:48.887
    error
    by controller[0]: 2018-03-12 18:14:48.858 - owntracks.0 already running
    host.linaro-alip
    2018-03-12 18:14:48.716
    info
    instance system.adapter.scenes.0 started with pid 4942
    web.1
    2018-03-12 18:14:48.710
    info
    2018-03-12T17:14:48.710Z Connected system.user.admin
    host.linaro-alip
    2018-03-12 18:14:47.981
    info
    Restart adapter system.adapter.web.0 because enabled
    gruss Stephan
    geändert: Code in Code-Tags; Homoran (Mod)
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Anscheinend wurden beim Update die Adapter nicht richtig beendet. Am einfachsten ist es wohl, wenn du die Kiste mal komplett neu startest.
      Warum sudo böse ist: https://forum.iobroker.net/post/17109
        stephan61
        Hätte ich auch dran denken können
        Gruß Stephan
