  4. Fehler beim Installieren der metro widgets
24 Beiträge 5 Kommentatoren 4.0k Aufrufe
  • N Offline
    N Offline
    navino
    bekomme folgende Fehlermeldung, vis und andere widgets gehen…
    exit 25
    iobroker 2015-08-29 14:33:29 info npm
    iobroker 2015-08-29 14:33:29 info ELIFECYCLE
    iobroker 2015-08-29 14:33:29 info code
    iobroker 2015-08-29 14:33:29 info npm ERR!
    iobroker 2015-08-29 14:33:29 info npm ERR! npm -v 1.4.28
    iobroker 2015-08-29 14:33:29 info npm ERR! node -v v0.10.35
    iobroker 2015-08-29 14:33:29 info command "C:\Program Files\nodejs\\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.v
    iobroker 2015-08-29 14:33:29 info ERR!
    iobroker 2015-08-29 14:33:29 info Windows_NT 6.1.7601npm
    iobroker 2015-08-29 14:33:29 info System
    iobroker 2015-08-29 14:33:29 info npm ERR! There is likely additional logging output above.
    iobroker 2015-08-29 14:33:29 info ERR! You can get their info via:npm ERR! npm owner ls iobroker.vis-metro
    iobroker 2015-08-29 14:33:29 info npm ERR! Tell the author that this fails on your system:npm ERR! node node_modules/grunt/lib/grunt prepublish
    iobroker 2015-08-29 14:33:29 info npm ERR! not with npm itself.
    iobroker 2015-08-29 14:33:29 info npm ERR! This is most likely a problem with the iobroker.vis-metro package,
    iobroker 2015-08-29 14:33:29 info npm ERR! Failed at the iobroker.vis-metro@0.1.7 prepublish script.
    iobroker 2015-08-29 14:33:29 info ERR! Exit status 8npm
    iobroker 2015-08-29 14:33:29 info iobroker.vis-metro@0.1.7 prepublish: node node_modules/grunt/lib/grunt prepublish
    iobroker 2015-08-29 14:33:29 info at node.js:929:3
    iobroker 2015-08-29 14:33:29 info at startup (node.js:119:16)
    iobroker 2015-08-29 14:33:29 info at Function.Module.runMain (module.js:497:10)
    iobroker 2015-08-29 14:33:29 info at Function.Module._load (module.js:280:25)
    iobroker 2015-08-29 14:33:29 info at Function.Module._resolveFilename (module.js:338:15)
    iobroker 2015-08-29 14:33:29 info Error: Cannot find module 'C:\Program Files\ioBroker\node_modules\iobroker.vis-metro\node_modules\grunt\lib\grunt'
    iobroker 2015-08-29 14:33:29 info ^
    iobroker 2015-08-29 14:33:29 info throw err;
    iobroker 2015-08-29 14:33:29 info module.js:340
    iobroker 2015-08-29 14:33:29 info npm install --production --prefix "C:/Program Files/ioBroker/node_modules/iobroker.vis-metro" (System call)
    iobroker 2015-08-29 14:33:29 info host.fujitsuH720 install adapter vis-metro
    iobroker 2015-08-29 14:33:26 info npm install iobroker.vis-metro --production --prefix "C:/Program Files/ioBroker" (System call)
    iobroker 2015-08-29 14:33:26 info add vis-metro
    navino
    http://www.navino.de
    • F Offline
      Fitti
      Schreibe bitte mal die Version des js-contoller unter dem Reiter Host in iobroker.
      Hast du einen roten LOG-Reiter? Kannst du darin auch noch Fehler sehen?
      Welche node.js Version nutzt Du? Laut Doku benötigt IoBroker eine Version >0.8 und <0.12.
      Keine Ahnung, ob es absoluter Unsinn ist, was ich hier schreibe, aber vielleicht hilft es Bluefox zur Analyse?
      Grüße,
      Fitti
      "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
      Plural von Status ist auch Status!
        Die nodejs version kleiner 0.12 galt wegen node red. Inzwischen ist diese Beschränkung aufgehoben. Trotzdem habe ich den Eindruck, dass iobroker mit neueren Versionen nicht vernünftig läuft.
        Mit den nodejs versionen gibt es auch unterschiedliche npm Versionen. Auch hier scheint es zu Problemen zu kommen, wobei ich glaube, dass npm (Server) selbst besonders am Wochenende Probleme hat.
        Gesendet von meinem LIFETAB_S785X mit Tapatalk
        • N Offline
          N Offline
          navino
          @Fitti:
          Grüße,
          Fitti `
          Habe die Version 0.7.11 , Log-reiter ist nicht rot, außer dem Fehler mit dem metro sehe ich sonst keine fehler
          nodjs habe ich in der version 0.10.35
          Kommisch ist, das ich das Problem erst nach der Deinsatllation habe. habe alles komplett deinstalliert, reste in den Verzeichnissen gelöscht…
          navino
            Mach mal
            cd /opt/iobroker
            npm cache clean
            iobroker upload vis-metro
            Rainer
            • N Offline
              N Offline
              navino
              @Homoran:
              Mach mal
              cd /opt/iobroker `
              Ich habe kein opt Dir …
              gruß
              navino
                Dann mach die restlichen Befehle in deinem Installationsverzeichnis von windows.
                Da kenne ich mich nicht aus.
                • N Offline
                  N Offline
                  navino
                  habe ich, leider ohne Erfolg.
                  Dann habe ich alles nocheinmal mit einem anderen Account probiert….wegen Cache oder so... auch nicht.
                  Dann habe ich einen anderen Rechner probiert, der noch nie was mit mit ioBroker und nodejs zu tun hatte, selbes Problem.
                  Also mach erstma weiter ohne metro... :-(
                  navino
                  • F Offline
                    Fitti
                    Was für ein Windows nutzt Du? Vielleicht schaffe ich es noch mal kurz das bei mir auszuprobieren…
                    • N Offline
                      N Offline
                      navino
                      Ich habe Windows 7 64 Bit, habe es auch auf Window 7 32 Bit probiert.
                      • F Offline
                        Fitti
                        Jupp, dass Gleiche bei mir, jedoch andere Fehleranzeigen.
                        Der Colorpicker, hqwidgets und bar widgets ließen sich installieren.
                        Ich habe sowohl den 0.5.0 Installer verwendet, als auch
                        node 0.10.22 manuell installiert und dann per Hand npm install iobroker.
                        Das Fehlerbild ist identisch, wenn man die Metros installieren möchte:
                        $ ./iobroker add vis-metro
                        host.computer1 install adapter vis-metro
                        module.js:340
                            throw err;
                            at node.js:929:3
                        npm
                         ERR!
                         iobroker.vis-metro@0.1.7 prepublish: `node node_modules/grunt/lib/grunt prepublish`npm ERR!
                         Exit status 8npm
                         ERR!
                        npm
                         ERR!
                         Failed at the iobroker.vis-metro@0.1.7 prepublish script.npm
                         ERR!
                         This is most likely a problem with the iobroker.vis-metro package,npm
                         ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
                        npm
                         ERR!     node node_modules/grunt/lib/grunt prepublishnpm
                         ERR!
                        npm
                        ERR!
                        npm
                        ERR!
                        System Windows_NT 6.1.7601
                        npm
                        ERR!
                        command
                         "C:\\Program Files\\nodejs\\\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.vis-metro"
                        npm
                        ERR!
                        cwd C:\Windows\system32npm
                        ERR! node -v v0.10.35npm ERR! npm -v 1.4.28
                        npm ERR! code ELIFECYCLE
                        Cannot install iobroker.vis-metro: 1
                          Habe keine ahnung und deswegen gegoogelt.
                          Mit nodejs kommt auch npm
                          Wie sieht es denn aus, wenn du anschließend ein älteres nodejs installierst:
                          @Fitti:
                          als auch node 0.10.22 manuell installiert `
                          Wird dann auch npm downgegraded?
                          auf meinem RasPi 2:
                           node -v v0.10.22
                          npm -v 1.3.14
                          Rainer
                          • F Offline
                            Fitti
                            Genau. Auf meiner Banane ist auch 0.10.22
                            Mit Bluefoxs 0.5.0 Installer kommt 0.10.35 rauf.
                            Deshalb hatte ich alles (iobroker und node.js) gelöscht und manuell 0.10.22 installiert. Und dann über den node packet installer npm iobroker installiert.
                            Fehler bleibt (leider) exakt identisch.
                            Fitti
                              AndyUM61
                              Hat denn das Problem inzwischen jemand gelöst?
                              Ich habe das gleiche Problem mit dem metro-widgets:(.
                              Die plump-widgets sind bei mir auch nicht sichtbar.
                              Andy
                              Internette Grüße
                              Andy
                              RaspberryMatic (Raspberry Pi3), CUxD, ioBroker (Synology/ Docker)
                              • F Offline
                                Fitti
                                Ich schätze, das kann nur Bluefox. Und der ist gerade noch im Urlaub.
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  @AndyUM61:
                                  Andy `
                                  Obwohl ich noch nicht ganz da bin 8-) . Sollte es jetzt gehen.
                                    Hast du dich wenigstens gut erholt?
                                    Gesendet von meinem Cynus T7 mit Tapatalk
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @Homoran:
                                      Gesendet von meinem Cynus T7 mit Tapatalk `
                                      Ja 8-) :lol: :geek:
                                        AndyUM61
                                        jetzt kommen zwar nicht mehr die Fehlermeldungen, und er scheint korrekt zu installieren,
                                        jedoch habe ich noch immer weder metro- noch plump-Widgets zur Auswahl im vis:(.
                                        Oder sind die irgendwo versteckt?
                                        Gruß Andy
                                        (ioBroker unter Windows 8.1)
                                        Internette Grüße
                                        Andy
                                          hast du das vis selbst nach der Installation der widgets neu gestartet?
