  4. [gelöst]Zigbee Adapter streikt
    5.4k
9 Beiträge 4 Kommentatoren 357 Aufrufe 4 Beobachtet
  • J Online
    J Online
    jwedenig
    schrieb am zuletzt editiert von jwedenig
    Hi!
    Kann mir wer helfen?
    Seit heute geht mein Zigbee Adapter nicht mehr auf Grün.
    Reboot des Pi erfolglos!
    Das einzige was ich gestern gemacht habe war ein
    Sudo apt update und ein Sudo apt upgrade
    Liebe Grüße
    Jürgen
    zigbee.0
    2023-05-17 08:02:09.571	info	Installed Version: iobroker.zigbee@1.8.10
    zigbee.0
    2023-05-17 08:02:09.526	error	Error herdsman start
    zigbee.0
    2023-05-17 08:02:09.525	error	Failed to start Zigbee
    zigbee.0
    2023-05-17 08:02:09.523	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
    zigbee.0
    2023-05-17 08:02:09.500	info	Starting Zigbee npm ...
    zigbee.0
    2023-05-17 08:02:09.499	info	Try to reconnect. 1 attempts left
    zigbee.0
    2023-05-17 08:01:59.741	info	Installed Version: iobroker.zigbee@1.8.10
    zigbee.0
    2023-05-17 08:01:59.492	error	Error herdsman start
    zigbee.0
    2023-05-17 08:01:59.491	error	Failed to start Zigbee
    zigbee.0
    2023-05-17 08:01:59.490	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
    zigbee.0
    2023-05-17 08:01:59.005	info	Starting Zigbee npm ...
    zigbee.0
    2023-05-17 08:01:59.000	info	delete old Backup files. keep only last 10
    zigbee.0
    2023-05-17 08:01:58.823	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.0, js-controller: 4.0.24
    host.raspberrypi
    2023-05-17 08:01:53.159	info	instance system.adapter.zigbee.0 started with pid 11567
    host.raspberrypi
    2023-05-17 08:01:52.712	info	"system.adapter.zigbee.0" enabled
    host.raspberrypi
    2023-05-17 08:01:51.398	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0
    2023-05-17 08:01:50.666	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2023-05-17 08:01:50.664	info	terminating
    zigbee.0
    2023-05-17 08:01:50.654	warn	Failed to stop zigbee during startup
    zigbee.0
    2023-05-17 08:01:50.496	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-05-17 08:01:50.266	info	cleaned everything up...
    host.raspberrypi
    2023-05-17 08:01:50.267	info	stopInstance system.adapter.zigbee.0 send kill signal
    zigbee.0
    2023-05-17 08:01:50.262	info	Got terminate signal TERMINATE_YOURSELF
    crunchipC M 2 Antworten Letzte Antwort
    • J jwedenig
      Hi!
      Liebe Grüße
      Jürgen
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.raspberrypi
      zigbee.0
      crunchipC Abwesend
      crunchipC Abwesend
      @jwedenig sagte in Zigbee Adapter streikt:
      einfach so?
      • J jwedenig
        Hi!
        Liebe Grüße
        Jürgen
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.raspberrypi
        zigbee.0
        MartyBr
        @jwedenig
        Das wird wahrscheinlich dieser Fehler sein:
        https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
        Martin
        Homematic und Homematic IP
        J 2 Antworten Letzte Antwort
        • M MartyBr
          @jwedenig
          J Online
          J Online
          jwedenig
          @martybr
          ja, das wars!
          Vielen Dank!
          Liebe Grüße
          Jürgen
          • M MartyBr
            @jwedenig
            J Online
            J Online
            jwedenig
            @martybr
            heisst das für mich, dass ich nun kein update und uprade mehr machen darf bis dieser Bug repariert wurde?
            • J jwedenig
              @martybr
              @jwedenig
              Das kommt darauf an welchen der 252551 Lösungswege du jetzt genommen hast.
                @jwedenig
                J Online
                J Online
                jwedenig
                Diesen da:
                cd /etc/apt/sources.list.d
                sudo nano bullseye-backports.list
                bullseye-backports
                deb http://deb.debian.org/debian bullseye-backports main
                sudo apt update
                sudo apt -t bullseye-backports install udev
                • J jwedenig
                  Diesen da:
                  bullseye-backports
                  sudo apt update
                  @jwedenig
                  Dann haste doch gar kein Problem. Die Version aus den backports ist ja höher als die aus dem Standard/Update-Repo.
                  Einfach weiter wie gewohnt das System auf Stand halten.
                    @jwedenig
                    J Online
                    J Online
                    jwedenig
                    alles klar! Thanx
