<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst]Zigbee Adapter streikt]]></title><description><![CDATA[<p dir="auto">Hi!<br />
Kann mir wer helfen?<br />
Seit heute geht mein Zigbee Adapter nicht mehr auf Grün.<br />
Reboot des Pi erfolglos!<br />
Das einzige was ich gestern gemacht habe war ein<br />
Sudo apt update und ein Sudo apt upgrade</p>
<p dir="auto">Danke<br />
Liebe Grüße<br />
Jürgen</p>
<pre><code>
zigbee.0
2023-05-17 08:02:09.571	info	Installed Version: iobroker.zigbee@1.8.10
zigbee.0
2023-05-17 08:02:09.526	error	Error herdsman start
zigbee.0
2023-05-17 08:02:09.525	error	Failed to start Zigbee
zigbee.0
2023-05-17 08:02:09.523	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
zigbee.0
2023-05-17 08:02:09.500	info	Starting Zigbee npm ...
zigbee.0
2023-05-17 08:02:09.499	info	Try to reconnect. 1 attempts left
zigbee.0
2023-05-17 08:01:59.741	info	Installed Version: iobroker.zigbee@1.8.10
zigbee.0
2023-05-17 08:01:59.492	error	Error herdsman start
zigbee.0
2023-05-17 08:01:59.491	error	Failed to start Zigbee
zigbee.0
2023-05-17 08:01:59.490	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
zigbee.0
2023-05-17 08:01:59.005	info	Starting Zigbee npm ...
zigbee.0
2023-05-17 08:01:59.000	info	delete old Backup files. keep only last 10
zigbee.0
2023-05-17 08:01:58.823	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.0, js-controller: 4.0.24
host.raspberrypi
2023-05-17 08:01:53.159	info	instance system.adapter.zigbee.0 started with pid 11567
host.raspberrypi
2023-05-17 08:01:52.712	info	"system.adapter.zigbee.0" enabled
host.raspberrypi
2023-05-17 08:01:51.398	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
zigbee.0
2023-05-17 08:01:50.666	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
zigbee.0
2023-05-17 08:01:50.664	info	terminating
zigbee.0
2023-05-17 08:01:50.654	warn	Failed to stop zigbee during startup
zigbee.0
2023-05-17 08:01:50.496	info	Zigbee: disabling joining new devices.
zigbee.0
2023-05-17 08:01:50.266	info	cleaned everything up...
host.raspberrypi
2023-05-17 08:01:50.267	info	stopInstance system.adapter.zigbee.0 send kill signal
zigbee.0
2023-05-17 08:01:50.262	info	Got terminate signal TERMINATE_YOURSELF
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/65552/gelöst-zigbee-adapter-streikt</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 07:25:18 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/65552.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 May 2023 06:04:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 10:41:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
alles klar! Thanx</p>
]]></description><link>https://forum.iobroker.net/post/992940</link><guid isPermaLink="true">https://forum.iobroker.net/post/992940</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Wed, 17 May 2023 10:41:15 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 09:33:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a></p>
<p dir="auto">Dann haste doch gar kein Problem. Die Version aus den backports ist ja höher als die aus dem Standard/Update-Repo.</p>
<p dir="auto">Einfach weiter wie gewohnt das System auf Stand halten.</p>
]]></description><link>https://forum.iobroker.net/post/992901</link><guid isPermaLink="true">https://forum.iobroker.net/post/992901</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 17 May 2023 09:33:00 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 08:54:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Diesen da:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev">https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev</a></p>
<p dir="auto">cd  /etc/apt/sources.list.d<br />
sudo nano bullseye-backports.list</p>
<h1>bullseye-backports</h1>
<p dir="auto">deb <a href="http://deb.debian.org/debian" rel="nofollow ugc">http://deb.debian.org/debian</a> bullseye-backports main<br />
sudo apt update<br />
sudo apt -t bullseye-backports install udev</p>
]]></description><link>https://forum.iobroker.net/post/992866</link><guid isPermaLink="true">https://forum.iobroker.net/post/992866</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Wed, 17 May 2023 08:54:26 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 07:43:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a></p>
<p dir="auto">Das kommt darauf an welchen der 252551 Lösungswege du jetzt genommen hast.</p>
]]></description><link>https://forum.iobroker.net/post/992836</link><guid isPermaLink="true">https://forum.iobroker.net/post/992836</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 17 May 2023 07:43:04 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 07:21:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/martybr" aria-label="Profile: martybr">@<bdi>martybr</bdi></a><br />
heisst das für mich, dass ich nun kein update und uprade mehr machen darf bis dieser Bug repariert wurde?</p>
]]></description><link>https://forum.iobroker.net/post/992827</link><guid isPermaLink="true">https://forum.iobroker.net/post/992827</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Wed, 17 May 2023 07:21:17 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 07:19:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/martybr" aria-label="Profile: martybr">@<bdi>martybr</bdi></a><br />
ja, das wars!<br />
Vielen Dank!<br />
Liebe Grüße<br />
Jürgen</p>
]]></description><link>https://forum.iobroker.net/post/992826</link><guid isPermaLink="true">https://forum.iobroker.net/post/992826</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Wed, 17 May 2023 07:19:41 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 06:22:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a><br />
Das wird wahrscheinlich dieser Fehler sein:<br />
]]></description><link>https://forum.iobroker.net/post/992805</link><guid isPermaLink="true">https://forum.iobroker.net/post/992805</guid><dc:creator><![CDATA[MartyBr]]></dc:creator><pubDate>Wed, 17 May 2023 06:22:24 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Adapter streikt on Wed, 17 May 2023 06:17:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a> sagte in <a href="/post/992802">Zigbee Adapter streikt</a>:</p>
<blockquote>
<p dir="auto">Seit heute geht mein Zigbee Adapter nicht mehr auf Grün.</p>
</blockquote>
<p dir="auto">einfach so?</p>
]]></description><link>https://forum.iobroker.net/post/992804</link><guid isPermaLink="true">https://forum.iobroker.net/post/992804</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Wed, 17 May 2023 06:17:49 GMT</pubDate></item></channel></rss>
