  4. Backup geht nicht
Backup geht nicht
18 Beiträge 9 Kommentatoren 1.5k Aufrufe 7 Beobachtet
  • kmxakK Offline
    kmxakK Offline
    kmxak
    Moin das iobroker backup geht nicht mehr.
    fixer habe ich durchlaufen lassen.
    den heap zu erhöhen mit folgendem code bringt auch nix.
    wollte das System eigendlich gerade auf ein neues umziehen aber das zickt etwas rum
    export NODE_OPTIONS=--max-old-space-size=4096
    root@ioBroker:/opt/iobroker# iobroker backup
    host.ioBroker 149041 states saved
    host.ioBroker 193297 objects saved
    <--- Last few GCs --->
    [2009:0x5ef1950]    54421 ms: Mark-sweep (reduce) 2137.3 (2283.7) -> 1444.0 (1520.4) MB, 259.1 / 0.0 ms  (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 7436 ms) (average mu = 0.963, current mu = 0.970) ex[2009:0x5ef1950]    56110 ms: Mark-sweep 2134.1 (2209.4) -> 2133.9 (2157.2) MB, 348.3 / 0.0 ms  (+ 0.9 ms in 16 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 1634 ms) (average mu = 0.922, current mu = 0.794) allocation
    <--- JS stacktrace --->
    FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
     1: 0xb7b3e0 node::Abort() [node]
     2: 0xa8c8aa  [node]
     3: 0xd69100 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node]
     4: 0xd694a7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node]
     5: 0xf46ba5  [node]
     6: 0xf5908d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
     7: 0xf3378e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
     8: 0xf34b57 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
     9: 0xf15552 v8::internal::Factory::AllocateRawWithAllocationSite(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [node]
    10: 0xf1fdac v8::internal::Factory::NewJSObjectFromMap(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [node]
    11: 0x104f585 v8::internal::JsonParser<unsigned short>::BuildJsonObject(v8::internal::JsonParser<unsigned short>::JsonContinuation const&, v8::base::SmallVector<v8::internal::JsonProperty, 16ul, std::allocator<v8::internal::JsonProperty> > const&, v8::internal::Handle<v8::internal::Map>) [node]
    12: 0x1051208 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [node]
    13: 0x105191f v8::internal::JsonParser<unsigned short>::ParseJson() [node]
    14: 0xdeece3 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [node]
    15: 0x1707c79  [node]
    /usr/bin/iobroker: Zeile 10:  2008 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    Gruß Alex
    • kmxakK kmxak
       2: 0xa8c8aa  [node]
       5: 0xf46ba5  [node]
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @kmxak
      @kmxak sagte in Backup geht nicht:
      root@ioBroker
      So fängts an...
      und gib mal die Ausgab von
      iob diag
      durch.
      Lehrling seit 1975 !!!
      kmxakK HomoranH 2 Antworten Letzte Antwort
      • DJMarc75D DJMarc75
        @kmxak
        root@ioBroker
        So fängts an...
        iob diag
        durch.
        kmxakK Offline
        kmxakK Offline
        kmxak
        schrieb am zuletzt editiert von kmxak
        @djmarc75
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Architecture    : x86_64
        Docker          : false
        Virtualization  : vmware
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         16:45:48 up  1:59,  1 user,  load average: 0.16, 0.18, 0.19
        CPU threads: 8
        *** Time and Time Zones ***
                       Local time: Sat 2023-04-29 16:45:48 CEST
                   Universal time: Sat 2023-04-29 14:45:48 UTC
                         RTC time: Sat 2023-04-29 14:45:48
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             11G         10G        706M        2.0M        655M        1.2G
        Swap:           6.0G        876M        5.1G
        Total:           17G         11G        5.8G
                11976 M total memory
                10614 M used memory
                 2107 M active memory
                 3058 M inactive memory
                  706 M free memory
                   39 M buffer memory
                  615 M swap cache
                 5996 M total swap
                  876 M used swap
                 5120 M free swap
        *** FILESYSTEM ***
        udev           devtmpfs  5.9G     0  5.9G   0% /dev
        tmpfs          tmpfs     1.2G  1.1M  1.2G   1% /run
        /dev/sda1      ext4       24G   18G  5.3G  77% /
        tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.2G   60K  1.2G   1% /run/user/113
        tmpfs          tmpfs     1.2G   60K  1.2G   1% /run/user/1000
        [Sat Apr 29 14:46:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Sat Apr 29 14:46:34 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        2.7G    /var/
        1.6G    /var/log/journal/bf3dc909e52842af994cc284b7d9afe6
        1.6G    /var/log
        774M    /var/cache
        Archived and active journals take up 1.5G in the file system.
        /opt/iobroker/backups:
        503M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.2G    /opt/iobroker/iobroker-data/
        401M    /opt/iobroker/iobroker-data/files
        278M    /opt/iobroker/iobroker-data/backup-objects
        84M     /opt/iobroker/iobroker-data/files/vis.0
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        427M    /opt/iobroker/iobroker-data/states.jsonl
        118M    /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.15.0
        /usr/bin/node           v18.15.0
        /usr/bin/npm            9.5.0
        /usr/bin/npx            9.5.0
        nodejs:
          Installed: 18.15.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
             18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         *** 18.15.0-deb-1nodesource1 100
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
          system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: ioBroker                                 - disabled
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
          system.adapter.denon.0                  : denon                 : ioBroker                                 - disabled
          system.adapter.devices.0                : devices               : ioBroker                                 - disabled
          system.adapter.discord.0                : discord               : ioBroker                                 - disabled
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
        + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
          system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
          system.adapter.fullcalendar.0           : fullcalendar          : ioBroker                                 - disabled
        + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
          system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 - disabled
        + system.adapter.history.0                : history               : ioBroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 12010
        + system.adapter.hm-rpc.3                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 - disabled
        + system.adapter.hp-ilo.0                 : hp-ilo                : ioBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
        + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
          system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
          system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
          system.adapter.paw.0                    : paw                   : ioBroker                                 - disabled, port: 8898
          system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
        + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
          system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 - disabled
        + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled, port: 0
        + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1337, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
          system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
        + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled, port: 3306
        + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 88, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
        + system.adapter.text2command.1           : text2command          : ioBroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
          system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        sources       : conf/sources-dist.json
        online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
        latest alternative: http://iobroker.live/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.2.4    , installed 1.2.1  [Updatable]
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "alias-manager": 1.2.4    , installed 1.2.4
        Adapter    "backitup"     : 2.6.19   , installed 2.6.19
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
        Adapter    "denon"        : 1.15.0   , installed 1.15.0
        Adapter    "devices"      : 1.1.2    , installed 1.1.2
        Adapter    "discord"      : 1.1.6    , installed 1.1.6
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "fhem"         : 1.6.3    , installed 1.6.3
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
        Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "hp-ilo"       : 1.0.6    , installed 1.0.6
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 2.6.3  [Updatable]
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
        Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
        Adapter    "mqtt"         : 4.0.7    , installed 3.0.6  [Updatable]
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "node-red"     : 4.0.0    , installed 4.0.0
        Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
        Adapter    "openweathermap": 0.3.3   , installed 0.3.3
        Adapter    "paw"          : 0.3.2    , installed 0.3.2
        Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
        Adapter    "text2command" : 2.3.0    , installed 2.3.0
        Adapter    "unifi"        : 0.5.10   , installed 0.6.1
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        193638
        States:         149083
        W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  Temporary failure resolving 'apt.grafana.com'
        W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  Temporary failure resolving 'repos.influxdata.com'
        W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  Temporary failure resolving 'repos.influxdata.com'
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Err:3 https://apt.grafana.com stable InRelease
        Err:4 https://repos.influxdata.com/debian stable InRelease
        Err:5 https://repos.influxdata.com/debian stretch InRelease
        Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 94
        *** Listening Ports ***
        tcp        0      0 192.168.2.24:42001      0.0.0.0:*               LISTEN      1001       19213      2199/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15585      619/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11979      647/influxd
        tcp        0      0 0.0.0.0:1337            0.0.0.0:*               LISTEN      1001       19251      2294/io.sonoff.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22789      2257/io.mqtt.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       22790      2257/io.mqtt.0
        tcp        0      0 192.168.2.24:8701       0.0.0.0:*               LISTEN      1001       22784      2233/io.hm-rpc.3
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       19017      2025/iobroker.js-co
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22565      2025/iobroker.js-co
        tcp        0      0 192.168.2.24:12010      0.0.0.0:*               LISTEN      1001       21009      2210/io.hm-rpc.1
        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      115        17416      590/redis-server 0.
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1110       1/init
        tcp6       0      0 :::4400                 :::*                    LISTEN      1001       26726      2462/io.milight-sma
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22598      2043/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22978      2609/io.web.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25841      2514/io.socketio.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        12039      647/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15587      619/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22017      2503/io.simple-api.
        tcp6       0      0 :::3000                 :::*                    LISTEN      116        16914      645/grafana
        tcp6       0      0 :::8443                 :::*                    LISTEN      1001       22794      2144/io.telegram.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          13357      1/init
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12359      1/init
        udp        0      0 0.0.0.0:50165           0.0.0.0:*                           114        1247       511/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21913      2620/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           114        1245       511/avahi-daemon: r
        udp        0      0 0.0.0.0:48034           0.0.0.0:*                           1001       21065      2462/io.milight-sma
        udp6       0      0 :::111                  :::*                                0          11598      1/init
        udp6       0      0 :::5353                 :::*                                114        1246       511/avahi-daemon: r
        udp6       0      0 :::55707                :::*                                114        1248       511/avahi-daemon: r
        2023-04-29 16:42:09.135  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
        2023-04-29 16:42:22.730  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:42:55.786  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:43:28.842  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:44:00.394  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:44:09.085  - warn: hp-ilo.0 (2418) Read-only state "hp-ilo.0.fans.Fan_1" has been written without ack-flag with value "15"
        2023-04-29 16:44:09.085  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
        2023-04-29 16:44:09.127  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
        2023-04-29 16:44:33.450  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:45:00.043  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 9051
        2023-04-29 16:45:03.885  - info: dwd.0 (9051) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.15.0, js-controller: 4.0.24
        2023-04-29 16:45:04.841  - info: dwd.0 (9051) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-04-29 16:45:05.354  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-04-29 16:45:06.506  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:45:20.427  - info: javascript.0 (2107) script.js.User.Telegram.Balkon_Telegram_Check: Tür Balkon wurde geöffnet
        2023-04-29 16:45:25.353  - info: javascript.0 (2107) script.js.User.Telegram.Balkon_Telegram_Check: Tür Balkon wurde geschlossen
        2023-04-29 16:45:39.562  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:46:09.690  - warn: hp-ilo.0 (2418) Read-only state "hp-ilo.0.fans.Fan_1" has been written without ack-flag with value "15"
        2023-04-29 16:46:09.691  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
        2023-04-29 16:46:09.691  - warn: hp-ilo.0 (2418) Read-only state "hp-ilo.0.fans.Fan_1" has been written without ack-flag with value "15"
        2023-04-29 16:46:09.730  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
        2023-04-29 16:46:12.618  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:46:42.634  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        2023-04-29 16:47:15.692  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
        iob diag has finished.
                             v.2023-04-16
        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
        Kernel:                 5.10.0-21-amd64
        Installation:           vmware
        User-ID:                0
        X-Server:               true
        Pending OS-Updates:     94
        Pending iob updates:    3
        Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                                /usr/bin/npm            9.5.0
                                /usr/bin/npx            9.5.0
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:             11G         10G        609M        2.0M        488M        846M
        Swap:           6.0G        963M        5.0G
        Total:           17G         11G        5.6G
        Active iob-Instances:   38
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                193638
        States:                 149083
        Size of iob-Database:
        126M    /opt/iobroker/iobroker-data/objects.jsonl
        444M    /opt/iobroker/iobroker-data/states.jsonl
        Gruß Alex
          @kmxak
          root@ioBroker
          So fängts an...
          iob diag
          durch.
          @djmarc75 wahrscheinlich das übliche
          Backup zu groß, RAM zu klein
          • kmxakK kmxak
            @djmarc75
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=debian
            CPU threads: 8
                          NTP service: active
                      RTC in local TZ: no
            root
            /root
            root
            X-Server:       true
            Desktop:
            Terminal:
            *** MEMORY ***
            Total:           17G         11G        5.8G
                    10614 M used memory
                      706 M free memory
                       39 M buffer memory
                      615 M swap cache
                     5996 M total swap
                      876 M used swap
                     5120 M free swap
            *** FILESYSTEM ***
            /var:
            2.7G    /var/
            1.6G    /var/log
            774M    /var/cache
            /usr/bin/npm            9.5.0
            /usr/bin/npx            9.5.0
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        193638
            States:         149083
            Pending Updates: 94
                                 v.2023-04-16
            User-ID:                0
            X-Server:               true
                                    /usr/bin/npm            9.5.0
                                    /usr/bin/npx            9.5.0
            MEMORY:
            Total:           17G         11G        5.6G
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                193638
            States:                 149083
            Mem: 11G 10G 609M
            WOW!
            Was treibst du denn da?
            • kmxakK kmxak
              @djmarc75
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 8
                            NTP service: active
                        RTC in local TZ: no
              root
              /root
              root
              X-Server:       true
              Desktop:
              Terminal:
              *** MEMORY ***
              Total:           17G         11G        5.8G
                      10614 M used memory
                        706 M free memory
                         39 M buffer memory
                        615 M swap cache
                       5996 M total swap
                        876 M used swap
                       5120 M free swap
              *** FILESYSTEM ***
              /var:
              2.7G    /var/
              1.6G    /var/log
              774M    /var/cache
              /usr/bin/npm            9.5.0
              /usr/bin/npx            9.5.0
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        193638
              States:         149083
              Pending Updates: 94
                                   v.2023-04-16
              User-ID:                0
              X-Server:               true
                                      /usr/bin/npm            9.5.0
                                      /usr/bin/npx            9.5.0
              MEMORY:
              Total:           17G         11G        5.6G
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                193638
              States:                 149083
              errors=remount-ro
              Filesystem hat außerdem einen Schuss
              kmxakK 1 Antwort Letzte Antwort
                errors=remount-ro
                kmxakK Offline
                kmxakK Offline
                kmxak
                @homoran ich weiß es nicht... an sich lief das ganze bis jetzt. Wollte nur ein Backup ziehen und das ding umziehen/neu aufsetzen.
                Das Ram gedöns ka hab dem im esxi mal mehr zugewiesen oder was meinst du?
                Gruß Alex
                HomoranH simatecS 2 Antworten Letzte Antwort
                • kmxakK kmxak
                  was meinst du?
                  du brauchst 10GB RAM und hast nur noch 600mb frei
                  Das reicht nicht für ein Backup
                    Mem: 11G 10G 609M
                    WOW!
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @homoran sagte in Backup geht nicht:
                    Objects: 193638 States: 149083
                    das scheint einiges am start zu sein
                    • kmxakK kmxak
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @kmxak alle Adapter stoppen oder noch besser iob stoppen und dann das Backup versuchen.
                      Ansonsten vorher schauen, was da soviel RAM frisst und die Prozesse killen
                      • Besuche meine Github Seite
                      • HowTo Restore ioBroker
                      • simatecS simatec
                        kmxakK Offline
                        kmxakK Offline
                        kmxak
                        @simatec
                        das hatte ich probiert.
                        Egal ich habe jetzt eine clean neuinstall gemacht und nur die scripte und das vis export übernommen.
                        bisschen mehr arbeit aber wohl besser
                        Gruß Alex
                        • kmxakK kmxak
                          @simatec
                          CodierknechtC Offline
                          Codierknecht
                          Dann aber hoffentlich ohne Desktop. Sowas hat auf 'nem Server nämlich nix zu suchen.
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          • CodierknechtC Codierknecht
                            kmxakK Offline
                            kmxakK Offline
                            kmxak
                            @codierknecht sagte in Backup geht nicht:
                            jawohl dieses mal richtig 😬
                            Gruß Alex
                            • kmxakK kmxak
                              Maddm
                              Hallo, ich bin neu hier im Forum - ich weiß nicht ob es korrekt ist, sich an ein passendes Thema dran zu hängen oder lieber ein eigenes Thema aufzumachen, ich hab mich fürs Dranhängen entschieden.
                              Ich nutze iobroker seit rund einem Monat, bin also ein ziemlicher Anfänger.
                              Ich hab mich über Foreneinträge und Youtube eingearbeitet und monitore mit iob ein wenig meine Heizung, Zählerstände und PV Anlage, auch mit vis hab ich ein wenig gemacht und bin aktuell recht zufrieden.
                              Der einzige Punkt, der mich aktuell stört:
                              mein Backup macht mir Probleme. Ich hab die default Einstellungen nicht verändert (Speicherort etc) und in dem Moment wo ich das Backup direkt starte per "iobroker Backup starten" geht das Popup auf mit dem Progress, unten ist "schließen wenn fertig" angehakt, aber das Ding wird nicht fertig, es hängt sich quasi auf.
                              Ich hab auch schon versucht, per ftp auf mein fritz.nas zu sichern, habe aber das Gefühl, dass die Verbindung dahin gar nicht erst aufgebaut wird (und weiß leider nicht wie ich das per Log be- oder widerlegen kann)
                              Und auch beim geschedulten Backup nachts um 03:30 kann ich an meinen Charts für Temperaturen etc sehen, dass ab dann nichts mehr passiert, solange bis ich morgens den Stecker ziehe um das Gerät durchzustarten... das ist nicht so sinnvoll. Allerding sehe ich, dass das System einige Backups anlegen konnte (die untersch. Zeiten kommen von ein paar Tests, den Zeitpunkt des Backups zu ändern).
                              Ich poste auch mal den Output von iob diag, vielleicht sieht jemand da etwas, was schief ist und kann mir auf die Art helfen.
                              Kernel: 		5.15.84-v8+
                              Installation: 		Native
                              User-ID: 		1000
                              X-Server: 		false
                              Boot Target: 		multi-user.target
                              Pending OS-Updates: 	54
                              Pending iob updates: 	0
                              Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
                              			/usr/bin/node 		v18.16.0
                              			/usr/bin/npm 		9.5.1
                              			/usr/bin/npx 		9.5.1
                              MEMORY:
                              Mem:            909M        581M         76M        0.0K        251M        269M
                              Swap:            99M         99M        0.0K
                              Total:          1.0G        681M         77M
                              Active iob-Instances: 	14
                              			admin 			6.3.5
                              ioBroker Status: 	iobroker is running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		2205
                              States: 		1902
                              17M	/opt/iobroker/iobroker-data/objects.jsonl
                              2.9M	/opt/iobroker/iobroker-data/states.jsonl
                              Ich weiß leider nicht, wie ich den ganzen diag Output, der vor der Summary kommt, hier posten kann bzw. wo der mitgeloggt wird... ich kann ja nicht 20 Screenshots etc machen und posten
                              Hilfe highly welcome + vielen Dank!
                              DJMarc75D ? 2 Antworten Letzte Antwort
                              • M Maddm
                                Kernel: 		5.15.84-v8+
                                User-ID: 		1000
                                X-Server: 		false
                                			/usr/bin/npm 		9.5.1
                                			/usr/bin/npx 		9.5.1
                                MEMORY:
                                Swap:            99M         99M        0.0K
                                			admin 			6.3.5
                                Objects type: jsonl
                                States  type: jsonl
                                Objects: 		2205
                                States: 		1902
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                @maddm sagte in Backup geht nicht:
                                Dir geht der Speicher aus, was nicht wunderlich ist bei 1GB Ram.
                                • M Maddm
                                  Kernel: 		5.15.84-v8+
                                  User-ID: 		1000
                                  X-Server: 		false
                                  			/usr/bin/npm 		9.5.1
                                  			/usr/bin/npx 		9.5.1
                                  MEMORY:
                                  Swap:            99M         99M        0.0K
                                  			admin 			6.3.5
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects: 		2205
                                  States: 		1902
                                  Moin,
                                  zu Punkt 1, Deiner Probleme.
                                  Wie @DJMarc75 schon angemerkt hat, ist 1 GB nicht wirklich viel, und reicht meist nur so für ~10 Adapter, denn jeder Adapter braucht so ~ 60 - 100 MB, wenn dann noch das Betriebssystem Speicher braucht, ist Schluss und es wird in den Swap ausgelagert, der mit 99 MB auch nicht üppig ist, das ist aber nur ein Notnagel und so als Standard definiert.
                                  Wenn jetzt bei allen laufenden Adaptern auch noch das Backup kommt, zum Komprimieren der Datei braucht er auch Speicher, dann macht Dein kleiner Rechner die Grätsche.
                                  Teste mal so, fahre alle Adapter außer den BackitUp runter, dann kurz warten und das Backup starten.
                                  Zu Punkt 2.:
                                  Du loggst die mit putty/ssh auf dem ioBroker ein und führst die Befehle aus, in der Shell laufen die Zeilen durch, die kannst Du mit der Maus auswählen und kopieren, dann hier in Code Tags </> posten.
                                  Bernd
                                    Moin,
                                    Zu Punkt 2.:
                                    Bernd
                                    Maddm
                                    @dp20eic said in Backup geht nicht:
                                    Bernd
                                    Danke, das war schonmal ein guter Tipp, damit habe ich jetzt wenigstens mal ein Backup sauber hinbekommen.
                                    • M Maddm
                                      Bernd
                                      Dann weißt du jetzt auch ziemlich sicher das du zu wenig RAM hast.
                                      82.9k
