  4. Backup geht nicht
    5.4k
Backup geht nicht
18 Beiträge 9 Kommentatoren 1.7k Aufrufe 7 Beobachtet
  • kmxakK kmxak
    @djmarc75
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : vmware
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     16:45:48 up  1:59,  1 user,  load average: 0.16, 0.18, 0.19
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sat 2023-04-29 16:45:48 CEST
               Universal time: Sat 2023-04-29 14:45:48 UTC
                     RTC time: Sat 2023-04-29 14:45:48
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             11G         10G        706M        2.0M        655M        1.2G
    Swap:           6.0G        876M        5.1G
    Total:           17G         11G        5.8G
            11976 M total memory
            10614 M used memory
             2107 M active memory
             3058 M inactive memory
              706 M free memory
               39 M buffer memory
              615 M swap cache
             5996 M total swap
              876 M used swap
             5120 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  5.9G     0  5.9G   0% /dev
    tmpfs          tmpfs     1.2G  1.1M  1.2G   1% /run
    /dev/sda1      ext4       24G   18G  5.3G  77% /
    tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G   60K  1.2G   1% /run/user/113
    tmpfs          tmpfs     1.2G   60K  1.2G   1% /run/user/1000
    [Sat Apr 29 14:46:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Apr 29 14:46:34 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.7G    /var/
    1.6G    /var/log/journal/bf3dc909e52842af994cc284b7d9afe6
    1.6G    /var/log
    774M    /var/cache
    Archived and active journals take up 1.5G in the file system.
    /opt/iobroker/backups:
    503M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    401M    /opt/iobroker/iobroker-data/files
    278M    /opt/iobroker/iobroker-data/backup-objects
    84M     /opt/iobroker/iobroker-data/files/vis.0
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    427M    /opt/iobroker/iobroker-data/states.jsonl
    118M    /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.15.0
    /usr/bin/node           v18.15.0
    /usr/bin/npm            9.5.0
    /usr/bin/npx            9.5.0
    nodejs:
      Installed: 18.15.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
         18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
     *** 18.15.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: ioBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
      system.adapter.denon.0                  : denon                 : ioBroker                                 - disabled
      system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      system.adapter.discord.0                : discord               : ioBroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
    + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
      system.adapter.fullcalendar.0           : fullcalendar          : ioBroker                                 - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 - disabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 - disabled
    + system.adapter.hp-ilo.0                 : hp-ilo                : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
    + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
      system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.paw.0                    : paw                   : ioBroker                                 - disabled, port: 8898
      system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 - disabled
    + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled, port: 0
    + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1337, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
    + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled, port: 3306
    + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 88, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
    + system.adapter.text2command.1           : text2command          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
      system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    latest alternative: http://iobroker.live/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.1  [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "denon"        : 1.15.0   , installed 1.15.0
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "discord"      : 1.1.6    , installed 1.1.6
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fhem"         : 1.6.3    , installed 1.6.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hp-ilo"       : 1.0.6    , installed 1.0.6
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "influxdb"     : 3.2.0    , installed 2.6.3  [Updatable]
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
    Adapter    "mqtt"         : 4.0.7    , installed 3.0.6  [Updatable]
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.5.10   , installed 0.6.1
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        193638
    States:         149083
    W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  Temporary failure resolving 'apt.grafana.com'
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  Temporary failure resolving 'repos.influxdata.com'
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  Temporary failure resolving 'repos.influxdata.com'
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Err:3 https://apt.grafana.com stable InRelease
    Err:4 https://repos.influxdata.com/debian stable InRelease
    Err:5 https://repos.influxdata.com/debian stretch InRelease
    Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 94
    *** Listening Ports ***
    tcp        0      0 192.168.2.24:42001      0.0.0.0:*               LISTEN      1001       19213      2199/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15585      619/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11979      647/influxd
    tcp        0      0 0.0.0.0:1337            0.0.0.0:*               LISTEN      1001       19251      2294/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22789      2257/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       22790      2257/io.mqtt.0
    tcp        0      0 192.168.2.24:8701       0.0.0.0:*               LISTEN      1001       22784      2233/io.hm-rpc.3
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       19017      2025/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22565      2025/iobroker.js-co
    tcp        0      0 192.168.2.24:12010      0.0.0.0:*               LISTEN      1001       21009      2210/io.hm-rpc.1
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      115        17416      590/redis-server 0.
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1110       1/init
    tcp6       0      0 :::4400                 :::*                    LISTEN      1001       26726      2462/io.milight-sma
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22598      2043/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22978      2609/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25841      2514/io.socketio.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        12039      647/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15587      619/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22017      2503/io.simple-api.
    tcp6       0      0 :::3000                 :::*                    LISTEN      116        16914      645/grafana
    tcp6       0      0 :::8443                 :::*                    LISTEN      1001       22794      2144/io.telegram.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13357      1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12359      1/init
    udp        0      0 0.0.0.0:50165           0.0.0.0:*                           114        1247       511/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21913      2620/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           114        1245       511/avahi-daemon: r
    udp        0      0 0.0.0.0:48034           0.0.0.0:*                           1001       21065      2462/io.milight-sma
    udp6       0      0 :::111                  :::*                                0          11598      1/init
    udp6       0      0 :::5353                 :::*                                114        1246       511/avahi-daemon: r
    udp6       0      0 :::55707                :::*                                114        1248       511/avahi-daemon: r
    2023-04-29 16:42:09.135  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
    2023-04-29 16:42:22.730  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:42:55.786  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:43:28.842  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:44:00.394  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:44:09.085  - warn: hp-ilo.0 (2418) Read-only state "hp-ilo.0.fans.Fan_1" has been written without ack-flag with value "15"
    2023-04-29 16:44:09.085  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
    2023-04-29 16:44:09.127  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
    2023-04-29 16:44:33.450  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:45:00.043  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 9051
    2023-04-29 16:45:03.885  - info: dwd.0 (9051) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.15.0, js-controller: 4.0.24
    2023-04-29 16:45:04.841  - info: dwd.0 (9051) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-04-29 16:45:05.354  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-29 16:45:06.506  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:45:20.427  - info: javascript.0 (2107) script.js.User.Telegram.Balkon_Telegram_Check: Tür Balkon wurde geöffnet
    2023-04-29 16:45:25.353  - info: javascript.0 (2107) script.js.User.Telegram.Balkon_Telegram_Check: Tür Balkon wurde geschlossen
    2023-04-29 16:45:39.562  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:46:09.690  - warn: hp-ilo.0 (2418) Read-only state "hp-ilo.0.fans.Fan_1" has been written without ack-flag with value "15"
    2023-04-29 16:46:09.691  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
    2023-04-29 16:46:09.691  - warn: hp-ilo.0 (2418) Read-only state "hp-ilo.0.fans.Fan_1" has been written without ack-flag with value "15"
    2023-04-29 16:46:09.730  - info: hp-ilo.0 (2418) State value to set for "hp-ilo.0.info.ILO_Status" has to be type "string" but received type "boolean"
    2023-04-29 16:46:12.618  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:46:42.634  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    2023-04-29 16:47:15.692  - error: sql.0 (2121) Error: connect EHOSTUNREACH 192.168.2.20:3306
    iob diag has finished.
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-21-amd64
    Installation:           vmware
    User-ID:                0
    X-Server:               true
    Pending OS-Updates:     94
    Pending iob updates:    3
    Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                            /usr/bin/npm            9.5.0
                            /usr/bin/npx            9.5.0
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:             11G         10G        609M        2.0M        488M        846M
    Swap:           6.0G        963M        5.0G
    Total:           17G         11G        5.6G
    Active iob-Instances:   38
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                193638
    States:                 149083
    Size of iob-Database:
    126M    /opt/iobroker/iobroker-data/objects.jsonl
    444M    /opt/iobroker/iobroker-data/states.jsonl
    @kmxak sagte in Backup geht nicht:
    Mem: 11G 10G 609M
    WOW!
    Was treibst du denn da?
    • kmxakK kmxak
      @djmarc75
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       true
      Desktop:
      Terminal:
      *** MEMORY ***
      Total:           17G         11G        5.8G
              10614 M used memory
                706 M free memory
                 39 M buffer memory
                615 M swap cache
               5996 M total swap
                876 M used swap
               5120 M free swap
      *** FILESYSTEM ***
      /var:
      2.7G    /var/
      1.6G    /var/log
      774M    /var/cache
      /usr/bin/npm            9.5.0
      /usr/bin/npx            9.5.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        193638
      States:         149083
      Pending Updates: 94
                           v.2023-04-16
      User-ID:                0
      X-Server:               true
                              /usr/bin/npm            9.5.0
                              /usr/bin/npx            9.5.0
      MEMORY:
      Total:           17G         11G        5.6G
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                193638
      States:                 149083
      errors=remount-ro
      Filesystem hat außerdem einen Schuss
      kmxakK 1 Antwort Letzte Antwort
        errors=remount-ro
        kmxakK Offline
        kmxakK Offline
        kmxak
        @homoran ich weiß es nicht... an sich lief das ganze bis jetzt. Wollte nur ein Backup ziehen und das ding umziehen/neu aufsetzen.
        Das Ram gedöns ka hab dem im esxi mal mehr zugewiesen oder was meinst du?
        Gruß Alex
        HomoranH simatecS 2 Antworten Letzte Antwort
        • kmxakK kmxak
          was meinst du?
          du brauchst 10GB RAM und hast nur noch 600mb frei
          Das reicht nicht für ein Backup
            Mem: 11G 10G 609M
            WOW!
            crunchipC Abwesend
            crunchipC Abwesend
            @homoran sagte in Backup geht nicht:
            Objects: 193638 States: 149083
            das scheint einiges am start zu sein
            • kmxakK kmxak
              simatecS Offline
              simatecS Offline
              simatec
              @kmxak alle Adapter stoppen oder noch besser iob stoppen und dann das Backup versuchen.
              Ansonsten vorher schauen, was da soviel RAM frisst und die Prozesse killen
              • Besuche meine Github Seite
              • HowTo Restore ioBroker
              • simatecS simatec
                kmxakK Offline
                kmxakK Offline
                kmxak
                @simatec
                das hatte ich probiert.
                Egal ich habe jetzt eine clean neuinstall gemacht und nur die scripte und das vis export übernommen.
                bisschen mehr arbeit aber wohl besser
                Gruß Alex
                • kmxakK kmxak
                  @simatec
                  CodierknechtC Online
                  Codierknecht
                  Dann aber hoffentlich ohne Desktop. Sowas hat auf 'nem Server nämlich nix zu suchen.
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  • CodierknechtC Codierknecht
                    kmxakK Offline
                    kmxakK Offline
                    kmxak
                    @codierknecht sagte in Backup geht nicht:
                    jawohl dieses mal richtig 😬
                    Gruß Alex
                    • kmxakK kmxak
                      Maddm
                      Hallo, ich bin neu hier im Forum - ich weiß nicht ob es korrekt ist, sich an ein passendes Thema dran zu hängen oder lieber ein eigenes Thema aufzumachen, ich hab mich fürs Dranhängen entschieden.
                      Ich nutze iobroker seit rund einem Monat, bin also ein ziemlicher Anfänger.
                      Ich hab mich über Foreneinträge und Youtube eingearbeitet und monitore mit iob ein wenig meine Heizung, Zählerstände und PV Anlage, auch mit vis hab ich ein wenig gemacht und bin aktuell recht zufrieden.
                      Der einzige Punkt, der mich aktuell stört:
                      mein Backup macht mir Probleme. Ich hab die default Einstellungen nicht verändert (Speicherort etc) und in dem Moment wo ich das Backup direkt starte per "iobroker Backup starten" geht das Popup auf mit dem Progress, unten ist "schließen wenn fertig" angehakt, aber das Ding wird nicht fertig, es hängt sich quasi auf.
                      Ich hab auch schon versucht, per ftp auf mein fritz.nas zu sichern, habe aber das Gefühl, dass die Verbindung dahin gar nicht erst aufgebaut wird (und weiß leider nicht wie ich das per Log be- oder widerlegen kann)
                      Und auch beim geschedulten Backup nachts um 03:30 kann ich an meinen Charts für Temperaturen etc sehen, dass ab dann nichts mehr passiert, solange bis ich morgens den Stecker ziehe um das Gerät durchzustarten... das ist nicht so sinnvoll. Allerding sehe ich, dass das System einige Backups anlegen konnte (die untersch. Zeiten kommen von ein paar Tests, den Zeitpunkt des Backups zu ändern).
                      Ich poste auch mal den Output von iob diag, vielleicht sieht jemand da etwas, was schief ist und kann mir auf die Art helfen.
                      Kernel: 		5.15.84-v8+
                      Installation: 		Native
                      User-ID: 		1000
                      X-Server: 		false
                      Boot Target: 		multi-user.target
                      Pending OS-Updates: 	54
                      Pending iob updates: 	0
                      Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
                      			/usr/bin/node 		v18.16.0
                      			/usr/bin/npm 		9.5.1
                      			/usr/bin/npx 		9.5.1
                      MEMORY:
                      Mem:            909M        581M         76M        0.0K        251M        269M
                      Swap:            99M         99M        0.0K
                      Total:          1.0G        681M         77M
                      Active iob-Instances: 	14
                      			admin 			6.3.5
                      ioBroker Status: 	iobroker is running on this host.
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		2205
                      States: 		1902
                      17M	/opt/iobroker/iobroker-data/objects.jsonl
                      2.9M	/opt/iobroker/iobroker-data/states.jsonl
                      Ich weiß leider nicht, wie ich den ganzen diag Output, der vor der Summary kommt, hier posten kann bzw. wo der mitgeloggt wird... ich kann ja nicht 20 Screenshots etc machen und posten
                      Hilfe highly welcome + vielen Dank!
                      DJMarc75D ? 2 Antworten Letzte Antwort
                      • M Maddm
                        Kernel: 		5.15.84-v8+
                        User-ID: 		1000
                        X-Server: 		false
                        			/usr/bin/npm 		9.5.1
                        			/usr/bin/npx 		9.5.1
                        MEMORY:
                        Swap:            99M         99M        0.0K
                        			admin 			6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 		2205
                        States: 		1902
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @maddm sagte in Backup geht nicht:
                        Dir geht der Speicher aus, was nicht wunderlich ist bei 1GB Ram.
                        Lehrling seit 1975 !!!
                        • M Maddm
                          Kernel: 		5.15.84-v8+
                          User-ID: 		1000
                          X-Server: 		false
                          			/usr/bin/npm 		9.5.1
                          			/usr/bin/npx 		9.5.1
                          MEMORY:
                          Swap:            99M         99M        0.0K
                          			admin 			6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 		2205
                          States: 		1902
                          Moin,
                          zu Punkt 1, Deiner Probleme.
                          Wie @DJMarc75 schon angemerkt hat, ist 1 GB nicht wirklich viel, und reicht meist nur so für ~10 Adapter, denn jeder Adapter braucht so ~ 60 - 100 MB, wenn dann noch das Betriebssystem Speicher braucht, ist Schluss und es wird in den Swap ausgelagert, der mit 99 MB auch nicht üppig ist, das ist aber nur ein Notnagel und so als Standard definiert.
                          Wenn jetzt bei allen laufenden Adaptern auch noch das Backup kommt, zum Komprimieren der Datei braucht er auch Speicher, dann macht Dein kleiner Rechner die Grätsche.
                          Teste mal so, fahre alle Adapter außer den BackitUp runter, dann kurz warten und das Backup starten.
                          Zu Punkt 2.:
                          Du loggst die mit putty/ssh auf dem ioBroker ein und führst die Befehle aus, in der Shell laufen die Zeilen durch, die kannst Du mit der Maus auswählen und kopieren, dann hier in Code Tags </> posten.
                          Bernd
                            Moin,
                            Zu Punkt 2.:
                            Bernd
                            Maddm
                            @dp20eic said in Backup geht nicht:
                            Bernd
                            Danke, das war schonmal ein guter Tipp, damit habe ich jetzt wenigstens mal ein Backup sauber hinbekommen.
                            • M Maddm
                              Bernd
                              Dann weißt du jetzt auch ziemlich sicher das du zu wenig RAM hast.
