  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • mickymM mickym
    @damrak2022
    Na wir schauen nochmal ob der Service läuft.
    machmal
    systemctl status influxdb
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #145
    @mickym sagte in Influxdb2 Backitup:
    Uff
    Andy@homebridge:~ $ systemctl status influxdb
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
         Active: active (running) since Mon 2023-04-17 13:41:27 CEST; 2 days ago
           Docs: https://docs.influxdata.com/influxdb/
       Main PID: 717 (influxd)
          Tasks: 19 (limit: 3932)
            CPU: 8min 17.766s
         CGroup: /system.slice/influxdb.service
                 └─717 /usr/bin/influxd
    Apr 20 00:42:36 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T22:42:36.631449Z lvl=info msg="Retention policy deletion check (end)" log_id=0hFl9puG000 service=retention op_name=retention_de>
    Apr 20 01:12:36 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:12:36.631913Z lvl=info msg="Retention policy deletion check (start)" log_id=0hFl9puG000 service=retention op_name=retention_>
    Apr 20 01:12:36 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:12:36.632045Z lvl=info msg="Retention policy deletion check (end)" log_id=0hFl9puG000 service=retention op_name=retention_de>
    Apr 20 01:22:24 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:22:24.632000Z lvl=info msg="Cache snapshot (start)" log_id=0hFl9puG000 service=storage-engine engine=tsm1 op_name=tsm1_cache>
    Apr 20 01:22:24 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:22:24.643437Z lvl=info msg="Snapshot for path written" log_id=0hFl9puG000 service=storage-engine engine=tsm1 op_name=tsm1_ca>
    Apr 20 01:22:24 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:22:24.643518Z lvl=info msg="Cache snapshot (end)" log_id=0hFl9puG000 service=storage-engine engine=tsm1 op_name=tsm1_cache_s>
    Apr 20 01:31:32 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:31:32.352244Z lvl=info msg=Unauthorized log_id=0hFl9puG000 error="token required"
    Apr 20 01:39:07 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:39:07.541303Z lvl=info msg=Unauthorized log_id=0hFl9puG000 error="session not found"
    Apr 20 01:42:36 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:42:36.631495Z lvl=info msg="Retention policy deletion check (start)" log_id=0hFl9puG000 service=retention op_name=retention_>
    Apr 20 01:42:36 homebridge influxd-systemd-start.sh[717]: ts=2023-04-19T23:42:36.631747Z lvl=info msg="Retention policy deletion check (end)" log_id=0hFl9puG000 service=retention op_name=retention_de>
    lines 1-20/20 (END)
    Mit besten Grüßen
    Andy
    • mickymM mickym
      @damrak2022
      machmal
      mickymM Offline
      mickymM Offline
      mickym
      #146
      @mickym Das habe ich befürchtet.
      starte einfach mal deine maschine neu. ;)
      • mickymM mickym
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #147
        @mickym Den Rechner oder den Raspi
        Mit besten Grüßen
        Andy
        • Damrak2022D Damrak2022
          mickymM Offline
          mickymM Offline
          mickym
          #148
          @damrak2022 Den Raspi - da läuft doch Deine influx db drauf. Achte darauf dass der Influx Adapter gestoppt ist.
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #149
            @mickym Okay - Der Adapter ist schon die ganze Zeit gestoppt
            Mit besten Grüßen
            Andy
            • mickymM mickym
              @damrak2022
              machmal
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #150
              @mickym Startet gerade wieder
              Mit besten Grüßen
              Andy
                mickymM Offline
                mickymM Offline
                mickym
                #151
                @damrak2022 Gut dann checkst Du - aber der Service sollte nun nicht mehr laufen oder einen Fehler bringen.
                Also
                • mickymM mickym
                  Also
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #152
                  @mickym
                  ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
                       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor pres>
                       Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 3mi>
                      Process: 736 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
                          CPU: 4ms
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job,>
                  Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated>
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'ex>
                  Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-sour>
                  lines 1-12/12 (END)
                       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: >
                       Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 3min 45>
                      Process: 736 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code>
                          CPU: 4ms
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job, res>
                  Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, distribu>
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated too>
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'exit-c>
                  Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-source, >
                  lines 1-12/12 (END)
                       Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 3min 45s ago
                      Process: 736 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
                          CPU: 4ms
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                  Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated too quickly.
                  Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'exit-code'.
                  Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                  lines 1-12/12 (END)
                          CPU: 4ms
                  lines 1-12/12 (END)
                          CPU: 4ms
                  lines 1-12/12 (END)
                          CPU: 4ms
                  lines 1-12/12 (END)
                  Mit besten Grüßen
                  Andy
                    @mickym
                            CPU: 4ms
                    lines 1-12/12 (END)
                            CPU: 4ms
                    lines 1-12/12 (END)
                            CPU: 4ms
                    lines 1-12/12 (END)
                            CPU: 4ms
                    lines 1-12/12 (END)
                            CPU: 4ms
                    lines 1-12/12 (END)
                            CPU: 4ms
                    lines 1-12/12 (END)
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #153
                    @damrak2022 OK - also active ist es nicht mehr.
                    Gut wir schauen aber nun noch dieses Verzeichnis an - auch wenn der Service nicht mehr aktiv ist.
                    schau mal
                    sudo ls -la /usr/lib/influxdb
                    • mickymM mickym
                      schau mal
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #154
                      @mickym
                      Andy@homebridge:~ $ sudo ls -la /usr/lib/influxdb
                      ls: Zugriff auf '/usr/lib/influxdb' nicht möglich: Datei oder Verzeichnis nicht gefunden
                      Andy@homebridge:~ $
                      Mit besten Grüßen
                      Andy
                        @mickym
                        Andy@homebridge:~ $
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #155
                        @damrak2022 Gut ist nicht mehr da - also wieder neu installieren und dann GUI
                        sudo apt install influxdb2
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #156
                          Momentan nur drehendes Symbol. Ich sollte meiner Rechner mal kurz Neustarten, denn ich denke das ist der Grund
                          Mit besten Grüßen
                          Andy
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #157
                            @damrak2022 Wie nur drehendes Symbol - hat denn die Installation geklappt?
                            • mickymM mickym
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #158
                              @mickym Ja
                              Mit besten Grüßen
                              Andy
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #159
                                @mickym Ich starte mal neu
                                Mit besten Grüßen
                                Andy
                                  @mickym Ja
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #160
                                  @damrak2022
                                  Dann erst mal schauen, ob der Service läuft:
                                  • mickymM mickym
                                    @damrak2022
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #161
                                    Nein noch nicht
                                         Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 18m>
                                            CPU: 4ms
                                    lines 1-11/11 (END)
                                         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: e>
                                         Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 18min ago
                                            CPU: 4ms
                                    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job, rest>
                                    Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, distribut>
                                    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated too >
                                    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'exit-co>
                                    Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-source, d>
                                    lines 1-11/11 (END)
                                            CPU: 4ms
                                    lines 1-11/11 (END)
                                            CPU: 4ms
                                    lines 1-11/11 (END)
                                    Mit besten Grüßen
                                    Andy
                                      Nein noch nicht
                                              CPU: 4ms
                                      lines 1-11/11 (END)
                                              CPU: 4ms
                                      lines 1-11/11 (END)
                                              CPU: 4ms
                                      lines 1-11/11 (END)
                                              CPU: 4ms
                                      lines 1-11/11 (END)
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #162
                                      @damrak2022 Ok - dann lass es uns nochmal machen . aber den Service vorher stoppenn.
                                      Also nochmal das Ganze.
                                      sudo systemctl stop influxdb
                                      dann
                                      sudo systemctl disable influxdb
                                      dann
                                      Maschine neu starten
                                      sudo apt purge influxdb
                                      dann wieder die beiden Verzeichnisse löschen.
                                      Andy@homebridge:~ $ sudo rm -R /var/lib/influxdb
                                      Andy@homebridge:~ $ sudo rm -R /etc/influxdb
                                      Nochmal kontrollieren, dass der Service nicht mehr existiert:
                                      Dann Maschine nochmal neu starten.
                                      Dann wieder installieren und erst mal zeigen was bei
                                      rauskommt.
                                      • mickymM mickym
                                        dann
                                        dann
                                        rauskommt.
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #163
                                        @mickym okay
                                        Mit besten Grüßen
                                        Andy
                                          @mickym okay
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #164
                                          @damrak2022 Der Service ist aktiv
                                          Andy@homebridge:~ $ sudo apt purge influxdb
                                          Paket »influxdb« ist nicht installiert, wird also auch nicht entfernt.
                                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                                          Andy@homebridge:~ $ sudo apt purge influxdb2
                                          Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                                            influxdb2-cli
                                          Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                                          Die folgenden Pakete werden ENTFERNT:
                                            influxdb2*
                                          0 aktualisiert, 0 neu installiert, 1 zu entfernen und 1 nicht aktualisiert.
                                          Nach dieser Operation werden 99,1 MB Plattenplatz freigegeben.
                                          Möchten Sie fortfahren? [J/n] j
                                          (Lese Datenbank ... 55637 Dateien und Verzeichnisse sind derzeit installiert.)
                                          Entfernen von influxdb2 (2.7.0-1) ...
                                          (Lese Datenbank ... 55627 Dateien und Verzeichnisse sind derzeit installiert.)
                                          Löschen der Konfigurationsdateien von influxdb2 (2.7.0-1) ...
                                               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pre>
                                               Active: active (running) since Thu 2023-04-20 02:15:56 CEST; 4min 19s ago
                                              Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
                                             Main PID: 718 (influxd)
                                                Tasks: 9 (limit: 3932)
                                                  CPU: 1.861s
                                                       └─718 /usr/bin/influxd
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:5>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http:>
                                          Apr 20 02:15:56 homebridge influxd-systemd-start.sh[715]: InfluxDB started
                                          Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, dist>
                                          lines 1-21/21 (END)
                                          ● influxdb.service - InfluxDB is an open-source, distributed, time series databa>
                                               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pres>
                                              Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http:/>
                                          Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distr>
                                          lines 1-21/21 (END)
                                               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
                                              Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gP>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforc>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" lo>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http://localhost:8086/ready unavailable after 1 attempts...
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_i>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement e>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 servi>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 serv>
                                          Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storag>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 se>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 servi>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indi>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 service=telemetry interv>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener tr>
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-eng>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0h>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=st>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate >
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 service=telemetry interval=8h
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transpo>
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 s>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-prec>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited).>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http add>
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_n>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=rete>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation che>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrenc>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0h>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 por>
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retenti>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_q>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=8>
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention che>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interv>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=8086
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_op>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=102>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 m>
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_ope>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check_>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval=>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 ma>
                                          lines 1-21/21 (END)
                                                  CPU: 1.861s
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_open op>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check_inte>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval=10m >
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 ini>
                                          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_se>
                                          lines 1-21/21 (END)
                                          Mit besten Grüßen
                                          Andy
