  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • keksnK keksn
    keksn@Influxdb:~$ sudo apt update
    apt policy influxdb*
    Hit:1 https://repos.influxdata.com/debian stable InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu kinetic InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
    Ign:5 https://repos.influxdata.com/debian $(lsb_release InRelease
    Err:6 https://repos.influxdata.com/debian $(lsb_release Release
      404  Not Found [IP: 18.66.15.57 443]
    Reading package lists... Done
    E: The repository 'https://repos.influxdata.com/debian $(lsb_release Release' does not have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    N: Unable to locate package influxdb2-client-2.3.0-linux-amd64
    N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64'
    N: Unable to locate package influxdb2-client-2.3.0-linux-amd64.tar.gz
    N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64.tar.gz'
    keksn@Influxdb:~$
    @keksn sagte in Influxdb2 Backitup:
    Dein influxdb-Repository ist falsch aufgesetzt.
    Software wird nicht über tar.gz-Archive installiert.
    keksnK 1 Antwort Letzte Antwort
      keksnK Offline
      keksnK Offline
      keksn
      @thomas-braun danke, was wäre die Lösung "einfach erklärt"?
      • keksnK keksn
        @keksn
        rm influxdb2*
        rm /etc/apt/sources.list.d/influx*
        sudo apt update
          @keksn
          rm influxdb2*
          sudo apt update
          keksnK Offline
          keksnK Offline
          keksn
          keksn@Influxdb:~$ rm influxdb2*
          sudo apt update
          rm: cannot remove 'influxdb2-client-2.3.0-linux-amd64': Is a directory
          rm: remove write-protected regular file '/etc/apt/sources.list.d/influxdata.list'?
          rm: remove write-protected regular file '/etc/apt/sources.list.d/influxdb.list'?
          • keksnK keksn
            sudo apt update
            @keksn
            sudo rm -rf influxdb2*
            sudo rm /etc/apt/sources.list.d/influx*
            sudo apt update
            keksnK 2 Antworten Letzte Antwort
              @keksn
              sudo apt update
              keksnK Offline
              keksnK Offline
              keksn
              @thomas-braun sagte in Influxdb2 Backitup:
              sudo apt update
              denke die ganze Installation ist zum Kübeln....
              eksn@Influxdb:~$ sudo rm -rf influxdb2*
              sudo apt updatekeksn@Influxdb:~$
                404  Not Found [IP: 18.66.15.86 443]
              keksn@Influxdb:~$
              • keksnK keksn
                sudo apt update
                keksn@Influxdb:~$
                @keksn
                kinetic ist eh das falsche Pferd.
                ls -lAh /etc/apt/sources.list.d/
                sagt?
                  @keksn
                  sudo apt update
                  keksnK Offline
                  keksnK Offline
                  keksn
                  gibt es ausser der Anleitung von Influxdb eine einfache Anleitung Influxdb2 sauber unter Proxmox in einem Ct zu Installieren?
                    @keksn
                    sagt?
                    keksnK Offline
                    keksnK Offline
                    keksn
                    Ich nehme normalerweise Debian nur läuft das in letzter zeit so langsam im CT ....
                    • keksnK keksn
                      @keksn
                      Keine Ahnung. Was ist an der Anleitung wie man Quellen anlegt kompliziert?
                      • keksnK keksn
                        Und warum sollte ein Ubuntu-Debian da anders laufen?
                          @keksn
                          sagt?
                          keksnK Offline
                          keksnK Offline
                          keksn
                          keksn@Influxdb:~$ ls -lAh /etc/apt/sources.list.d/
                          total 8.0K
                          -rw-r--r-- 1 root root 117 Apr 16 12:20 influxdata.list
                          -rw-r--r-- 1 root root  66 Apr 16 13:22 influxdb.list
                          keksn@Influxdb:~$
                          • keksnK keksn
                            total 8.0K
                            keksn@Influxdb:~$
                            @keksn
                            Lösch die beiden Dateien. Da steht offenbar Mist drin.
                              keksnK Offline
                              keksnK Offline
                              keksn
                              keine Ahnung warum das so ist, die Bedienung über die Konsole läut schleppend..
                                @keksn
                                keksnK Offline
                                keksnK Offline
                                keksn
                                @keksn
                                wie mache ich das
                                • keksnK keksn
                                  @keksn
                                  sudo rm /etc/apt/sources.list.d/influ*
                                  wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                  echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                  echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                  sudo apt update
                                    @keksn
                                    keksnK Offline
                                    keksnK Offline
                                    keksn
                                    es kommt bei mir da immer zu Fehlern.
                                    • keksnK keksn
                                      Geheime Fehler sind immer die schlimmsten. Da kann man nämlich nix machen.
                                      -1
                                        @keksn
                                        sudo apt update
                                        keksnK Offline
                                        keksnK Offline
                                        keksn
                                        @keksn
                                        sudo apt update
                                        danke , sollte dann der Backupfehler weg sein? Der ist noch vorhanden..
                                          keksnK Offline
                                          keksnK Offline
                                          keksn
                                          sind nicht geheim...denke aber nicht Du hast sooo viel Zeit mit mir die Installationsfehler durchzugehen
