  4. Kaco Wechselrichter und ModBus
104 Beiträge 18 Kommentatoren 32.1k Aufrufe 16 Beobachtet
  • R roesthod
    @roesthod Leider stecke ich jetzt erneut fest. Das gleiche Fehlerbild wie bereits @jojo8897 beschrieben.
    Das Register 40084 kommt als Wert: 0 zurück.
    2023-02-04 13:59:59.876 - debug: modbus.0 (3876) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-02-04 13:59:59.931 - debug: modbus.0 (3876) Objects client ready ... initialize now
    2023-02-04 13:59:59.932 - debug: modbus.0 (3876) Objects create System PubSub Client
    2023-02-04 13:59:59.932 - debug: modbus.0 (3876) Objects create User PubSub Client
    2023-02-04 14:00:00.080 - debug: modbus.0 (3876) Objects client initialize lua scripts
    2023-02-04 14:00:00.083 - debug: modbus.0 (3876) Objects connected to redis: 127.0.0.1:9001
    2023-02-04 14:00:00.084 - silly: modbus.0 (3876) redis psubscribe cfg.o.system.user.*
    2023-02-04 14:00:00.139 - silly: modbus.0 (3876) redis psubscribe cfg.o.enum.*
    2023-02-04 14:00:00.159 - silly: modbus.0 (3876) objectDB connected
    2023-02-04 14:00:00.160 - debug: modbus.0 (3876) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-02-04 14:00:00.213 - debug: modbus.0 (3876) States create System PubSub Client
    2023-02-04 14:00:00.213 - debug: modbus.0 (3876) States create User PubSub Client
    2023-02-04 14:00:00.294 - debug: modbus.0 (3876) States connected to redis: 127.0.0.1:9000
    2023-02-04 14:00:00.294 - silly: modbus.0 (3876) statesDB connected
    2023-02-04 14:00:00.604 - debug: modbus.0 (3876) Plugin sentry Initialize Plugin (enabled=true)
    2023-02-04 14:00:00.757 - info: modbus.0 (3876) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
    2023-02-04 14:00:00.817 - silly: modbus.0 (3876) States system redis pmessage system.adapter.modbus.0.logLevel/system.adapter.modbus.0.logLevel:{"val":"silly","ack":true,"ts":1675515600813,"q":0,"from":"system.adapter.modbus.0","lc":1675446048053}
    2023-02-04 14:00:00.953 - debug: modbus.0 (3876) Initialize Objects for disInputs: []
    2023-02-04 14:00:00.953 - debug: modbus.0 (3876) Initialize Objects for coils: []
    2023-02-04 14:00:00.953 - debug: modbus.0 (3876) Initialize Objects for inputRegs: []
    2023-02-04 14:00:00.954 - debug: modbus.0 (3876) Initialize Objects for holdingRegs: [{"_address":"40084","name":"","description":"Aktuell","unit":"","type":"floatbe","len":2,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"address":40084,"deviceId":1,"id":"holdingRegisters.40084"}]
    2023-02-04 14:00:00.954 - debug: modbus.0 (3876) Add holdingRegisters.40084: {"_id":"holdingRegisters.40084","type":"state","common":{"name":"Aktuell","role":"level","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40084,"deviceId":1,"type":"floatbe","len":2,"offset":0,"factor":1,"poll":true}}
    2023-02-04 14:00:01.186 - silly: modbus.0 (3876) States user redis pmessage modbus.0.*/modbus.0.info.connection:{"val":false,"ack":true,"ts":1675515601182,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1675515596252}
    2023-02-04 14:00:01.199 - info: modbus.0 (3876) Connected to slave 192.168.1.221
    2023-02-04 14:00:01.199 - debug: modbus.0 (3876) [DevID_1] Poll start ---------------------
    2023-02-04 14:00:01.200 - debug: modbus.0 (3876) Initialization of scale factors done!
    2023-02-04 14:00:01.200 - debug: modbus.0 (3876) [DevID_1/holdingRegs] Poll address 40084 - 2 registers
    2023-02-04 14:00:01.208 - silly: modbus.0 (3876) States user redis pmessage modbus.0.*/modbus.0.info.connection:{"val":true,"ack":true,"ts":1675515601206,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1675515601206}
    2023-02-04 14:00:01.350 - debug: modbus.0 (3876) [DevID_1/holdingRegs] Poll address 40084 DONE
    2023-02-04 14:00:01.402 - silly: modbus.0 (3876) States user redis pmessage modbus.0.*/modbus.0.holdingRegisters.40084:{"val":0,"ack":true,"ts":1675515601388,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1675515234967}
    2023-02-04 14:00:01.403 - silly: modbus.0 (3876) States user redis pmessage modbus.0.*/modbus.0.info.pollTime:{"val":152,"ack":true,"ts":1675515601393,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1675515601393}
    2023-02-04 14:00:02.405 - debug: modbus.0 (3876) [DevID_1] Poll start ---------------------
    2023-02-04 14:00:02.405 - debug: modbus.0 (3876) [DevID_1/holdingRegs] Poll address 40084 - 2 registers
    2023-02-04 14:00:02.566 - debug: modbus.0 (3876) [DevID_1/holdingRegs] Poll address 40084 DONE
    2023-02-04 14:00:03.617 - debug: modbus.0 (3876) [DevID_1] Poll start ---------------------
    2023-02-04 14:00:03.618 - debug: modbus.0 (3876) [DevID_1/holdingRegs] Poll address 40084 - 2 registers
    2023-02-04 14:00:04.127 - debug: modbus.0 (3876) [DevID_1/holdingRegs] Poll address 40084 DONE
    2023-02-04 14:00:04.132 - silly: modbus.0 (3876) States user redis pmessage modbus.0.*/modbus.0.info.pollTime:{"val":509,"ack":true,"ts":1675515604129,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1675515604129}
    Habt Ihr eine Idee ???
    wendy2702W Online
    wendy2702W Online
    #77
    @roesthod Hat sich die Adresse wirklich geändert?
    Mal die "alte" getestet?
    Gibt es ein Doc das die Adressen passend zur Installierten Firmware beschreibt?
    • S Online
      S Online
      Schimi
      #78
      Versuch vielleicht erstmal nur eine Adresse zu erreichen... So hab ich "damals" auch angefangen...
      R 1 Antwort Letzte Antwort
      • S Schimi
        roesthod
        #79
        @schimi Vielen Dank für die Hilfe, ich habe es herrausgefunden.
        1.) KACO Account erzeugen um an die Dokumentation zukommen.
        2.) Das Dokument SunSpec-Information beinhaltet die ModBus Register Zuordnungen
        3.) Parameter als Integer anlegen, nicht als float oder double. Mit dem SF (Skalefaktor) Wert wird der eigentliche Wert ausgerechet. Der SF Wert ist nicht der Wert im Adapter, er wird übertragen.
        • R roesthod
          S Online
          S Online
          Schimi
          #80
          @roesthod
          Dann werden die was bei dem NX3 was geändert haben....
          Wenn du alles am laufen hast, wäre super wenn du das zum import für andere hier einstellst :-)
            stronoff
            #81
            ich habe ebenfalls einen KACO blueplanet NX3 M2, allerdings in der 20.0 Variante. Ich bekomme diesen zur Zeit nur über die USB WIFI Kommunikationseinheit in das Netzwerk eingebunden. Wenn ich versuche ihn über die Ethernetports ins lokale Netz zu bekommen funktioniert das leider nicht. Schließen sich die Anbindung an das blueplanet Monitoring (https://www.solar-monitoring.net/) und die Verwendung als ModBus tatsächlich aus oder gibt es die Möglichkeit irgendwie beides zu nutzen???
            • S Schimi
              @roesthod
              roesthod
              #82
              @schimi Gerne doch:
              _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
              40072	Amps			uint16be	1	1	0		level		true	false	false	false
              40073	AmpsPhaseA			uint16be	1	1	0		level		true	false	false	false
              40074	AmpsPhaseB			uint16be	1	1	0		level		true	false	false	false
              40075	AmpsPhaseC			int16be	1	1	0		level		true	false	false	false
              40076	A_SF			int16be	1	1	0		level		true	false	false	false
              40084	Watts			int16be	1	1	0		level		true	false	false	false
              40085	W_SF			int16be	1	1	0		level		true	false	false	false
              40094	WattHour			uint32be	2	1	0		level		true	false	false	false
              40096	WH_SF			int16be	1	1	0		level		true	false	false	false
              40103	TmpCab			int16be	1	1	0		level		true	false	false	false
              40107	Tmp_SF			int16be	1	1	0		level		true	false	false	false
              • S stronoff
                roesthod
                #83
                @stronoff Also, das ist interessant. Ich dachte der Wechselrichter kann nur WLan. Also meiner wurde nur Wlan seitig eingebunden. In der KACO NX Setup App kann man unter Betriebsmodus eigentlich nur zwischen Datenupload-Modus und ModBus-TCP Server-Modus wählen. Somit vermute ich schliesst es sich gegenseitig aus....
                • R roesthod
                  stronoff
                  #84
                  @roesthod
                  Danke für deine Rückmeldung.
                  Meine Hoffnung war, ich könnte einen der beiden LAN Anschlüsse für Modbus und die WLAN Kommunikationseinheit für Blueplanet nutzen.
                  Wofür sind dann die zwei Ethernet Ports?
                  • R roesthod
                    @schimi Gerne doch:
                    #85
                    @roesthod Wärst Du so nett und stellst Es auch hier https://github.com/ioBroker/modbus-templates zur Verfügung ... Die anderen die andere haben ggf auch ... Wir versuchen hier mal alles zu sammeln
                    X 1 Antwort Letzte Antwort
                    • apollon77A apollon77
                      X Offline
                      X Offline
                      xx-94
                      #86
                      Hallo, ich habe das Problem mit meinen Kaco NX3 nicht die richtigen Wetter Anzeigt
                      z.B. zeigt er 70Watt an und in Wirklichkeit sind es 708Watt
                      was mache ich da Falsch?
                      Bildschirmfoto 2023-04-08 um 09.47.56.png Bildschirmfoto 2023-04-08 um 09.47.37.png
                      HomoranH S wierer-sigiW 3 Antworten Letzte Antwort
                      • X xx-94
                        #87
                        @xx-94 sagte in Kaco Wechselrichter und ModBus:
                        und was sagt die Anleitung zu den Registern?
                        Faktor?
                        • X xx-94
                          S Online
                          S Online
                          Schimi
                          #88
                          @xx-94 ich würde den Faktor auf 0.1 mal ändern
                          • X xx-94
                            wierer-sigiW Offline
                            wierer-sigi
                            schrieb am zuletzt editiert von wierer-sigi
                            #89
                            Kurz nachgefragt. Welches Setup habt Ihr beim Kaco … NX3 ?
                            Hätte folgendes Probiert:
                            • NX Setup
                              • Überwachung & Steuerung auf Modbus TCP IP Server eingestellt
                              • Modbus Adresse eingestellt ( z.B. 3 )
                            • iobroker
                              • Modbus Adapter installiert
                                TCP
                                IP-Adresse des KACO
                                Port 502
                                Geräte ID 3
                                Master
                                • Holding Register 80084 ( sonst wie in den BIldern oben )
                            Leider wird der Adapter im letzen Punkt „Verbunden mit Adapter oder Dienst“ nicht grün.
                            Im Protokoll sehe ich folgende Fehlermeldung:
                            Habt Ihr noch eine Idee?
                            2023-05-14 20:43:00.022	info	Connected to slave 192.168.178.247
                            modbus.0
                            2023-05-14 20:41:00.998 debug Closing client on purpose.
                            modbus.0
                            2023-05-14 20:40:59.997 debug Cleaning up request fifo.
                            modbus.0
                            2023-05-14 20:40:59.997 debug Socket closed with error
                            modbus.0
                            2023-05-14 20:40:59.988 info Disconnected from slave 192.168.178.247
                            modbus.0
                            2023-05-14 20:40:59.986 debug Closing client on purpose.
                            modbus.0
                            2023-05-14 20:40:59.935 warn Poll error count: 6 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                            modbus.0
                            2023-05-14 20:40:59.934 debug Received pdu describes an error.
                            modbus.0
                            2023-05-14 20:40:59.762 debug [DevID_4/holdingRegs] Poll address 80084 - 1 registers
                            modbus.0
                            2023-05-14 20:40:59.762 debug [DevID_4] Poll start ---------------------
                            • wierer-sigiW wierer-sigi
                              • NX Setup
                              • iobroker
                                  TCP
                                  IP-Adresse des KACO
                                  Port 502
                                  Geräte ID 3
                                  Master
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              wendy2702W Online
                              wendy2702W Online
                              #90
                              @wierer-sigi habe kein Kaco aber die Register Adresse stimmt nicht.
                              Adapter wird erst grün wenn mindestens 1 Register erfolgreich ausgelesen werden kann
                              • wendy2702W wendy2702
                                #91
                                @wendy2702 sagte in Kaco Wechselrichter und ModBus:
                                @wierer-sigi sagte in Kaco Wechselrichter und ModBus:
                                was soll das für ein Wert sein?
                                Vielleicht
                                @roesthod sagte in Kaco Wechselrichter und ModBus:
                                wierer-sigiW 1 Antwort Letzte Antwort
                                  Vielleicht
                                  wierer-sigi
                                  #92
                                  Danke Euch,
                                  Hatte heute den Adapter de- / installiert und die richtige Adresse verwendet. Jetzt funktioniert es.
                                    Danke Euch,
                                    #93
                                    und die wäre?
                                      und die wäre?
                                      wierer-sigi
                                      #94
                                      Bei meinem Kaco … NX3
                                      40084 für die Wattanzeige mit Faktor 10 und Signed 16 Bit ( Big Indian )
                                      wierer-sigiW HomoranH H 3 Antworten Letzte Antwort
                                        wierer-sigi
                                        #95
                                        Habe mittlerweile die Adressen für U1-U3, U1/U2, U2/U3; U3/U1, A1-A3 und den „Gesamt“ Ertrag eingerichtet bekommen.
                                        Habt Ihr die Adresse für den „Heute“ Ertrag und nice to have wäre der String PV1 - U und A und String PV2 U und A
                                        T K 2 Antworten Letzte Antwort
                                          #96
                                          Danke!
                                          das passt ja auch zu der früher von @roesthod geposteten Liste von Adressen.
                                          wie bist du auf/an die 80xxx gekommen?
