  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F federal
    @glasfaser
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    ^C(##################) ⠏ reify:aws-sdk: timing reifyNode:node_modules/iobroker.zigbee/node_module
    GlasfaserG Offline
    GlasfaserG Offline
    @federal
    alles gut ... nur Werbung
    • F federal
      gehe davon aus, dass auf dem Stick gleiche abgespeichert sind
      federal
      pi@raspberrypi:/opt/iobroker $ iobroker status
      Objects type: jsonl
      States  type: jsonl
      pi@raspberrypi:/opt/iobroker $ iobroker start all
      The adapter "admin.0" was started.
      The adapter "tuya.0" was started.
      The adapter "backitup.0" was started.
      The adapter "vis-timeandweather.0" was started.
      The adapter "worx.0" was started.
      • F federal
        Objects type: jsonl
        States  type: jsonl
        GlasfaserG Offline
        GlasfaserG Offline
        @federal sagte in ioBroker Backup wieder einspielen:
        The adapter .... was started.
        Ja ... und was ist jetzt !?
        F 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          federal
          @glasfaser
          so wie ich es verstehe, wurden nur 5 Adapter gestartet.
          iob läuft weiterhin nicht!
          Wie soll ich weiter vorgehen?
          • F federal
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            Du hast doch ein Backup/Restore eingespielt ... und das dauert
            Aber :
            durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
            Neues Backup/Restore einspielen .
            F 2 Antworten Letzte Antwort
              Aber :
              federal
              @glasfaser said in ioBroker Backup wieder einspielen:
              Aber :
              wie kann ich sicherstellen, dass PuTTY nicht aussteigt? Wenn man nichts eingibt, bricht die Verbindung weg.
              Soll ich mit der letzten Sicherung probieren? Habe aber Chromecast Adapter v3.0.3 nicht zum laufen gebracht.
              GlasfaserG HomoranH 2 Antworten Letzte Antwort
              • F federal
                hoffentlich!
                dann könntest du eine Neuinstallation durchführen und ein funktionierendes Backup wieder einspielen.
                • F federal
                  Aber :
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Zwei Session mit Putty machen .
                  Dann liegt ein Netzwerkproblem bei dir vor !
                  • F federal
                    Aber :
                    was haben wir denn überhaupt als Basis?
                    was kommt bei iob diag?
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @federal
                      @glasfaser sagte in ioBroker Backup wieder einspielen:
                      Dann passt meine Vermutung ... in einem anderen Thread von dir :
                      https://forum.iobroker.net/post/770163
                        federal
                        @homoran said in ioBroker Backup wieder einspielen:
                        Skript v.2023-04-02
                        *** BASE SYSTEM ***
                        Model           : Raspberry Pi 4 Model B Rev 1.2
                        Architecture    : armv7l
                        Docker          : false
                        Virtualization  : none
                        Distributor ID: Raspbian
                        Description:    Raspbian GNU/Linux 10 (buster)
                        Release:        10
                        Codename:       buster
                        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                        NAME="Raspbian GNU/Linux"
                        VERSION_ID="10"
                        VERSION="10 (buster)"
                        VERSION_CODENAME=buster
                        ID=raspbian
                        ID_LIKE=debian
                        HOME_URL="http://www.raspbian.org/"
                        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                        Systemuptime and Load:
                         18:54:45 up 41 days,  9:15,  2 users,  load average: 2.40, 2.64, 2.80
                        CPU threads: 4
                        *** Time and Time Zones ***
                                       Local time: Mon 2023-04-03 18:54:45 CEST
                                   Universal time: Mon 2023-04-03 16:54:45 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           3.8G        1.6G        167M        190M        2.1G        2.3G
                        Swap:           99M         37M         62M
                        Total:         3.9G        1.6G        230M
                                 3838 M total memory
                                 1571 M used memory
                                  853 M active memory
                                 2584 M inactive memory
                                  167 M free memory
                                  264 M buffer memory
                                 1836 M swap cache
                                   99 M total swap
                                   37 M used swap
                                   62 M free swap
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G  7.8G   21G  28% /
                        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                        tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                        tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                        [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                        [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                        [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
                        [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        TARGET        SOURCE         FSTYPE OPTIONS
                        /             /dev/mmcblk0p2 ext4   rw,noatime
                        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        576M    /var/
                        213M    /var/cache
                        200M    /var/cache/apt
                        142M    /var/log
                        141M    /var/cache/apt/archives
                        /opt/iobroker/backups:
                        103M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        449M    /opt/iobroker/iobroker-data/
                        311M    /opt/iobroker/iobroker-data/files
                        85M     /opt/iobroker/iobroker-data/backup-objects
                        72M     /opt/iobroker/iobroker-data/files/telegram.admin
                        51M     /opt/iobroker/iobroker-data/files/javascript.admin
                        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                        18M     /opt/iobroker/iobroker-data/states.jsonl
                        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                        12M     /opt/iobroker/iobroker-data/objects.jsonl
                        9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v16.19.1
                        /usr/bin/node           v16.19.1
                        /usr/bin/npm            8.19.3
                        /usr/bin/npx            8.19.3
                        nodejs:
                          Installed: 16.19.1-deb-1nodesource1
                          Candidate: 16.19.1-deb-1nodesource1
                          Version table:
                         *** 16.19.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                             10.24.0~dfsg-1~deb10u3 500
                        find: '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv': No such file or directory
                        find: '/opt/iobroker/node_modules/.fsevents-yNYMVUiI': No such file or directory
                        find: '/opt/iobroker/node_modules/.iobroker.history-EyYkjPpJ': No such file or directory
                        Temp directories causing npm8 problem: 891
                        Some problems detected, please run iob fix
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  4.0.24
                        admin:          "admin" not found
                        javascript:     6.1.4
                        Adapters from github:   0
                        Adapter State
                          system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                          system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                          system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
                          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                          system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                          system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                          system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                          system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                        + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
                        + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
                        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                        + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
                        + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
                        + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
                        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                        + system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                        + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
                        + instance is alive
                        ioBroker-Repositories
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Installed ioBroker-Instances
                        Adapter    "history"      : 2.2.4    , installed 2.2.4
                        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                        Adapter    "info"         : 1.9.19   , installed 1.9.19
                        Adapter    "iot"          : 1.14.2   , installed 1.14.2
                        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                        Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                        Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                        Adapter    "tado"         : 0.4.5    , installed 0.4.5
                        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                        Adapter    "text2command" : 2.3.0    , installed 2.3.0
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                        Adapter    "worx"         : 2.0.3    , installed 2.0.3
                        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                        Objects and States
                        Objects:        8545
                        States:         8737
                        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366535826  32518/io.sonoff.0
                        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366534662  32324/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366531583  32324/iobroker.js-c
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       366544012  1601/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
                        udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366550232  3641/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366550233  3641/io.tuya.0
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366534930  32501/io.shelly.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
                        udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
                        2023-04-03 18:56:10.723  - warn: shelly.0 (32501) [authEnabled] 192.168.178.61 (shellyswitch25 / shellyswitch25-40F520008D21 / SHSW-25#40F520008D21#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:10.731  - warn: shelly.0 (32501) [authEnabled] 192.168.178.66 (shellyswitch25 / shellyswitch25-40F520001056 / SHSW-25#40F520001056#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.031  - warn: shelly.0 (32501) [authEnabled] 192.168.178.88 (shelly1 / shelly1-483FDA8DAE88 / SHSW-1#483FDA8DAE88#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.158  - warn: shelly.0 (32501) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.165  - warn: shelly.0 (32501) [authEnabled] 192.168.178.91 (shellyplug-s / shellyplug-s-A4138B / SHPLG-S#A4138B#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.207  - warn: shelly.0 (32501) [authEnabled] 192.168.178.76 (shelly1 / shelly1-483FDA822EBC / SHSW-1#483FDA822EBC#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.340  - warn: shelly.0 (32501) [authEnabled] 192.168.178.72 (shellyswitch25 / shellyswitch25-40F52000DA81 / SHSW-25#40F52000DA81#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.430  - warn: shelly.0 (32501) [authEnabled] 192.168.178.63 (shelly1 / shelly1-40F52000CBB8 / SHSW-1#40F52000CBB8#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.592  - warn: shelly.0 (32501) [authEnabled] 192.168.178.94 (shelly1 / shelly1-F4CFA2ED662C / SHSW-1#F4CFA2ED662C#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.598  - warn: shelly.0 (32501) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:11.849  - warn: shelly.0 (32501) [authEnabled] 192.168.178.73 (shelly1 / shelly1-483FDA82B865 / SHSW-1#483FDA82B865#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:12.362  - warn: shelly.0 (32501) [authEnabled] 192.168.178.101 (shelly1 / shelly1-E8DB84D41EDF / SHSW-1#E8DB84D41EDF#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:12.490  - warn: shelly.0 (32501) [authEnabled] 192.168.178.33 (shelly1 / shelly1-C45BBE6B9506 / SHSW-1#C45BBE6B9506#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:12.701  - warn: shelly.0 (32501) [authEnabled] 192.168.178.65 (shelly1 / shelly1-E09806963C5D / SHSW-1#E09806963C5D#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 18:56:12.440  - info: netatmo.0 (32465) Websocket error: websocket error,  Error: websocket error
                            at WS.Transport.onError (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:64:13)
                            at WebSocket.ws.onerror (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:149:10)
                            at WebSocket.onError (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:452:14)
                            at WebSocket.emit (node:events:513:28)
                            at WebSocket.emit (node:domain:489:12)
                            at ClientRequest.response (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:721:12)
                            at Object.onceWrapper (node:events:628:26)
                            at ClientRequest.emit (node:events:525:35)
                            at ClientRequest.emit (node:domain:489:12)
                            at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:693:27)
                        iob diag has finished.
                        Press any key for a summary
                          @federal
                          federal
                          @federal
                          es lag daran, dass iob und Motioneye gemeinsam auf einem pi genutzt wurden. Seit dem ich Motioneye deaktiviert habe, lief alles gut!
                          • F federal
                            @federal
                            @federal
                            Solltest du tun. Und du solltest auch den Buster erlösen und durch das aktuelle Release Debian 11 'Bullseye' ersetzen, der Buster ist letztes Jahr im September abgekündigt worden.
                            Im Zuge dessen dann auch auf nodejs@18 springen.
                            • F federal
                              Skript v.2023-04-02
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        10
                              Codename:       buster
                              VERSION_ID="10"
                              ID=raspbian
                              ID_LIKE=debian
                              CPU threads: 4
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           99M         37M         62M
                                       3838 M total memory
                                       1571 M used memory
                                        853 M active memory
                                        167 M free memory
                                        264 M buffer memory
                                       1836 M swap cache
                                         99 M total swap
                                         37 M used swap
                                         62 M free swap
                              *** FILESYSTEM ***
                              /var:
                              576M    /var/
                              213M    /var/cache
                              200M    /var/cache/apt
                              142M    /var/log
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              javascript:     6.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        8545
                              States:         8737
                              Pending Updates: 0
                              @federal was ist denn das?
                              ich denke der ist gerade neu gestartet?
                              hat auch gut zu rödeln!
                              Was läuft da sonst noch?
                              und nur 5 Adapter sähen anders aus.
                              admin als https konfiguriert?
                              und deaktiviert
                                und deaktiviert
                                Nee, die Kiste ist am
                                unsanft 'neugestartet' worden.
                                  Aber :
                                  federal
                                  Aber :
                                  habe ein Backup eigespielt
                                  System successfully restored!
                                  pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
                                  The adapter "history.0" was started.
                                  The adapter "javascript.0" was started.
                                  The adapter "scenes.0" was started.
                                  The adapter "telegram.0" was started.
                                  The adapter "chromecast.0" was started.
                                  The adapter "hmip.0" was started.
                                  The adapter "ical.0" was started.
                                  The adapter "netatmo.0" was started.
                                  The adapter "ping.0" was started.
                                  The adapter "shelly.0" was started.
                                  The adapter "sonoff.0" was started.
                                  The adapter "weatherunderground.0" was started.
                                  The adapter "zigbee.0" was started.
                                  The adapter "broadlink2.0" was started.
                                  The adapter "cloud.0" was started.
                                  The adapter "discovery.0" was started.
                                  The adapter "echarts.0" was started.
                                  The adapter "fb-checkpresence.0" was started.
                                  The adapter "feiertage.0" was started.
                                  The adapter "fullybrowser.0" was started.
                                  The adapter "harmony.0" was started.
                                  The adapter "info.0" was started.
                                  The adapter "iot.0" was started.
                                  The adapter "panasonic-comfort-cloud.0" was started.
                                  The adapter "sayit.0" was started.
                                  The adapter "sayit.1" was started.
                                  The adapter "sayit.2" was started.
                                  The adapter "sayit.3" was started.
                                  The adapter "tado.0" was started.
                                  The adapter "tankerkoenig.0" was started.
                                  The adapter "text2command.1" was started.
                                  The adapter "trashschedule.0" was started.
                                  The adapter "vis-inventwo.0" was started.
                                  The adapter "vis.0" was started.
                                  The adapter "web.0" was started.
                                  kann aber nach wie vor nicht auf iob zugreifen
                                  • F federal
                                    Aber :
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    iob list instances
                                    sagt
                                      iob list instances
                                      sagt
                                      federal
                                      iob list instances
                                      pi@raspberrypi:/opt/iobroker/backups $ iob list instances
                                      + instance is alive
                                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                      • F federal
                                        iob list instances
                                        + instance is alive
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @federal
                                        iob start admin
                                        • F federal
                                          iob list instances
                                          + instance is alive
                                          @federal
                                          Der admin läuft nicht.
                                          iob start admin
                                          Hast du zwischenzeitlich den
                                          iob fix
                                          ausgeführt?
