  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F Offline
    federal
    gehe davon aus, dass auf dem Stick gleiche abgespeichert sind
    F HomoranH 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      @federal sagte in ioBroker Backup wieder einspielen:
      mit sudo iobroker restore
      Kein sudo vor ioBroker Befehle !
      Error: Cannot find module './lib/setup'
      cd /opt/iobroker
      iobroker fix
      sudo -H -u iobroker npm install iobroker.js-controller
      federal
      @glasfaser
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
      ^C(##################) ⠏ reify:aws-sdk: timing reifyNode:node_modules/iobroker.zigbee/node_module
      • F federal
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @federal
        alles gut ... nur Werbung
        • F federal
          federal
          pi@raspberrypi:/opt/iobroker $ iobroker status
          Objects type: jsonl
          States  type: jsonl
          pi@raspberrypi:/opt/iobroker $ iobroker start all
          The adapter "admin.0" was started.
          The adapter "tuya.0" was started.
          The adapter "backitup.0" was started.
          The adapter "vis-timeandweather.0" was started.
          The adapter "worx.0" was started.
          • F federal
            Objects type: jsonl
            States  type: jsonl
            GlasfaserG Offline
            GlasfaserG Offline
            The adapter .... was started.
            Ja ... und was ist jetzt !?
            F 1 Antwort Letzte Antwort
              federal
              @glasfaser
              so wie ich es verstehe, wurden nur 5 Adapter gestartet.
              iob läuft weiterhin nicht!
              Wie soll ich weiter vorgehen?
              • F federal
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Du hast doch ein Backup/Restore eingespielt ... und das dauert
                Aber :
                durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
                Neues Backup/Restore einspielen .
                F 2 Antworten Letzte Antwort
                  Aber :
                  federal
                  @glasfaser said in ioBroker Backup wieder einspielen:
                  Aber :
                  wie kann ich sicherstellen, dass PuTTY nicht aussteigt? Wenn man nichts eingibt, bricht die Verbindung weg.
                  Soll ich mit der letzten Sicherung probieren? Habe aber Chromecast Adapter v3.0.3 nicht zum laufen gebracht.
                  GlasfaserG HomoranH 2 Antworten Letzte Antwort
                  • F federal
                    hoffentlich!
                    dann könntest du eine Neuinstallation durchführen und ein funktionierendes Backup wieder einspielen.
                    • F federal
                      Aber :
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Zwei Session mit Putty machen .
                      Dann liegt ein Netzwerkproblem bei dir vor !
                      • F federal
                        Aber :
                        was haben wir denn überhaupt als Basis?
                        was kommt bei iob diag?
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @federal
                          @glasfaser sagte in ioBroker Backup wieder einspielen:
                          Dann passt meine Vermutung ... in einem anderen Thread von dir :
                          https://forum.iobroker.net/post/770163
                            federal
                            @homoran said in ioBroker Backup wieder einspielen:
                            Skript v.2023-04-02
                            *** BASE SYSTEM ***
                            Model           : Raspberry Pi 4 Model B Rev 1.2
                            Architecture    : armv7l
                            Docker          : false
                            Virtualization  : none
                            Distributor ID: Raspbian
                            Description:    Raspbian GNU/Linux 10 (buster)
                            Release:        10
                            Codename:       buster
                            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                            NAME="Raspbian GNU/Linux"
                            VERSION_ID="10"
                            VERSION="10 (buster)"
                            VERSION_CODENAME=buster
                            ID=raspbian
                            ID_LIKE=debian
                            HOME_URL="http://www.raspbian.org/"
                            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                            Systemuptime and Load:
                             18:54:45 up 41 days,  9:15,  2 users,  load average: 2.40, 2.64, 2.80
                            CPU threads: 4
                            *** Time and Time Zones ***
                                           Local time: Mon 2023-04-03 18:54:45 CEST
                                       Universal time: Mon 2023-04-03 16:54:45 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            pi
                            /home/pi
                            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:           3.8G        1.6G        167M        190M        2.1G        2.3G
                            Swap:           99M         37M         62M
                            Total:         3.9G        1.6G        230M
                                     3838 M total memory
                                     1571 M used memory
                                      853 M active memory
                                     2584 M inactive memory
                                      167 M free memory
                                      264 M buffer memory
                                     1836 M swap cache
                                       99 M total swap
                                       37 M used swap
                                       62 M free swap
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G  7.8G   21G  28% /
                            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                            tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                            tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
                            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                            tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                            [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                            [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                            [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
                            [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                            [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                            TARGET        SOURCE         FSTYPE OPTIONS
                            /             /dev/mmcblk0p2 ext4   rw,noatime
                            |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                            `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            576M    /var/
                            213M    /var/cache
                            200M    /var/cache/apt
                            142M    /var/log
                            141M    /var/cache/apt/archives
                            /opt/iobroker/backups:
                            103M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            449M    /opt/iobroker/iobroker-data/
                            311M    /opt/iobroker/iobroker-data/files
                            85M     /opt/iobroker/iobroker-data/backup-objects
                            72M     /opt/iobroker/iobroker-data/files/telegram.admin
                            51M     /opt/iobroker/iobroker-data/files/javascript.admin
                            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                            18M     /opt/iobroker/iobroker-data/states.jsonl
                            15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                            12M     /opt/iobroker/iobroker-data/objects.jsonl
                            9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v16.19.1
                            /usr/bin/node           v16.19.1
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
                            nodejs:
                              Installed: 16.19.1-deb-1nodesource1
                              Candidate: 16.19.1-deb-1nodesource1
                              Version table:
                             *** 16.19.1-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                 10.24.0~dfsg-1~deb10u3 500
                            find: '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv': No such file or directory
                            find: '/opt/iobroker/node_modules/.fsevents-yNYMVUiI': No such file or directory
                            find: '/opt/iobroker/node_modules/.iobroker.history-EyYkjPpJ': No such file or directory
                            Temp directories causing npm8 problem: 891
                            Some problems detected, please run iob fix
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  4.0.24
                            admin:          "admin" not found
                            javascript:     6.1.4
                            Adapters from github:   0
                            Adapter State
                              system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                              system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                              system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                              system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
                              system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                              system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                              system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                              system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                              system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                              system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
                            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                            + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                            + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
                            + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
                            + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                            + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                            + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
                            + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
                            + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
                            + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                            + system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                            + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                            + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
                            + instance is alive
                            ioBroker-Repositories
                            Stable (default): http://download.iobroker.net/sources-dist.json
                            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                            Installed ioBroker-Instances
                            Adapter    "history"      : 2.2.4    , installed 2.2.4
                            Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                            Adapter    "info"         : 1.9.19   , installed 1.9.19
                            Adapter    "iot"          : 1.14.2   , installed 1.14.2
                            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                            Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                            Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                            Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                            Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                            Adapter    "tado"         : 0.4.5    , installed 0.4.5
                            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                            Adapter    "text2command" : 2.3.0    , installed 2.3.0
                            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                            Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                            Adapter    "worx"         : 2.0.3    , installed 2.0.3
                            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                            Objects and States
                            Objects:        8545
                            States:         8737
                            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366535826  32518/io.sonoff.0
                            tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366534662  32324/iobroker.js-c
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366531583  32324/iobroker.js-c
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       366544012  1601/io.web.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
                            udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366550232  3641/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366550233  3641/io.tuya.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366534930  32501/io.shelly.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
                            udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
                            2023-04-03 18:56:10.723  - warn: shelly.0 (32501) [authEnabled] 192.168.178.61 (shellyswitch25 / shellyswitch25-40F520008D21 / SHSW-25#40F520008D21#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:10.731  - warn: shelly.0 (32501) [authEnabled] 192.168.178.66 (shellyswitch25 / shellyswitch25-40F520001056 / SHSW-25#40F520001056#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.031  - warn: shelly.0 (32501) [authEnabled] 192.168.178.88 (shelly1 / shelly1-483FDA8DAE88 / SHSW-1#483FDA8DAE88#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.158  - warn: shelly.0 (32501) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.165  - warn: shelly.0 (32501) [authEnabled] 192.168.178.91 (shellyplug-s / shellyplug-s-A4138B / SHPLG-S#A4138B#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.207  - warn: shelly.0 (32501) [authEnabled] 192.168.178.76 (shelly1 / shelly1-483FDA822EBC / SHSW-1#483FDA822EBC#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.340  - warn: shelly.0 (32501) [authEnabled] 192.168.178.72 (shellyswitch25 / shellyswitch25-40F52000DA81 / SHSW-25#40F52000DA81#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.430  - warn: shelly.0 (32501) [authEnabled] 192.168.178.63 (shelly1 / shelly1-40F52000CBB8 / SHSW-1#40F52000CBB8#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.592  - warn: shelly.0 (32501) [authEnabled] 192.168.178.94 (shelly1 / shelly1-F4CFA2ED662C / SHSW-1#F4CFA2ED662C#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.598  - warn: shelly.0 (32501) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:11.849  - warn: shelly.0 (32501) [authEnabled] 192.168.178.73 (shelly1 / shelly1-483FDA82B865 / SHSW-1#483FDA82B865#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:12.362  - warn: shelly.0 (32501) [authEnabled] 192.168.178.101 (shelly1 / shelly1-E8DB84D41EDF / SHSW-1#E8DB84D41EDF#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:12.490  - warn: shelly.0 (32501) [authEnabled] 192.168.178.33 (shelly1 / shelly1-C45BBE6B9506 / SHSW-1#C45BBE6B9506#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:12.701  - warn: shelly.0 (32501) [authEnabled] 192.168.178.65 (shelly1 / shelly1-E09806963C5D / SHSW-1#E09806963C5D#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-04-03 18:56:12.440  - info: netatmo.0 (32465) Websocket error: websocket error,  Error: websocket error
                                at WS.Transport.onError (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:64:13)
                                at WebSocket.ws.onerror (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:149:10)
                                at WebSocket.onError (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:452:14)
                                at WebSocket.emit (node:events:513:28)
                                at WebSocket.emit (node:domain:489:12)
                                at ClientRequest.response (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:721:12)
                                at Object.onceWrapper (node:events:628:26)
                                at ClientRequest.emit (node:events:525:35)
                                at ClientRequest.emit (node:domain:489:12)
                                at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:693:27)
                            iob diag has finished.
                            Press any key for a summary
                              @federal
                              federal
                              @federal
                              es lag daran, dass iob und Motioneye gemeinsam auf einem pi genutzt wurden. Seit dem ich Motioneye deaktiviert habe, lief alles gut!
                              • F federal
                                @federal
                                @federal
                                Solltest du tun. Und du solltest auch den Buster erlösen und durch das aktuelle Release Debian 11 'Bullseye' ersetzen, der Buster ist letztes Jahr im September abgekündigt worden.
                                Im Zuge dessen dann auch auf nodejs@18 springen.
                                • F federal
                                  Skript v.2023-04-02
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        10
                                  Codename:       buster
                                  VERSION_ID="10"
                                  ID=raspbian
                                  ID_LIKE=debian
                                  CPU threads: 4
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           99M         37M         62M
                                           3838 M total memory
                                           1571 M used memory
                                            853 M active memory
                                            167 M free memory
                                            264 M buffer memory
                                           1836 M swap cache
                                             99 M total swap
                                             37 M used swap
                                             62 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  576M    /var/
                                  213M    /var/cache
                                  200M    /var/cache/apt
                                  142M    /var/log
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  javascript:     6.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        8545
                                  States:         8737
                                  Pending Updates: 0
                                  @federal was ist denn das?
                                  ich denke der ist gerade neu gestartet?
                                  hat auch gut zu rödeln!
                                  Was läuft da sonst noch?
                                  und nur 5 Adapter sähen anders aus.
                                  admin als https konfiguriert?
                                  und deaktiviert
                                    und deaktiviert
                                    Nee, die Kiste ist am
                                    unsanft 'neugestartet' worden.
                                      Aber :
                                      federal
                                      Aber :
                                      habe ein Backup eigespielt
                                      System successfully restored!
                                      pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
                                      The adapter "history.0" was started.
                                      The adapter "javascript.0" was started.
                                      The adapter "scenes.0" was started.
                                      The adapter "telegram.0" was started.
                                      The adapter "chromecast.0" was started.
                                      The adapter "hmip.0" was started.
                                      The adapter "ical.0" was started.
                                      The adapter "netatmo.0" was started.
                                      The adapter "ping.0" was started.
                                      The adapter "shelly.0" was started.
                                      The adapter "sonoff.0" was started.
                                      The adapter "weatherunderground.0" was started.
                                      The adapter "zigbee.0" was started.
                                      The adapter "broadlink2.0" was started.
                                      The adapter "cloud.0" was started.
                                      The adapter "discovery.0" was started.
                                      The adapter "echarts.0" was started.
                                      The adapter "fb-checkpresence.0" was started.
                                      The adapter "feiertage.0" was started.
                                      The adapter "fullybrowser.0" was started.
                                      The adapter "harmony.0" was started.
                                      The adapter "info.0" was started.
                                      The adapter "iot.0" was started.
                                      The adapter "panasonic-comfort-cloud.0" was started.
                                      The adapter "sayit.0" was started.
                                      The adapter "sayit.1" was started.
                                      The adapter "sayit.2" was started.
                                      The adapter "sayit.3" was started.
                                      The adapter "tado.0" was started.
                                      The adapter "tankerkoenig.0" was started.
                                      The adapter "text2command.1" was started.
                                      The adapter "trashschedule.0" was started.
                                      The adapter "vis-inventwo.0" was started.
                                      The adapter "vis.0" was started.
                                      The adapter "web.0" was started.
                                      kann aber nach wie vor nicht auf iob zugreifen
                                      • F federal
                                        Aber :
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        iob list instances
                                        sagt
                                          iob list instances
                                          sagt
                                          federal
                                          iob list instances
                                          pi@raspberrypi:/opt/iobroker/backups $ iob list instances
                                          + instance is alive
                                          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
