  4. Node-Red
  5. Garagenzustand visualisieren
    6.5k
43 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
  • mickymM Offline
    mickymM Offline
    mickym
    @dr-pie Du kannst doch mit der iobroker IN Node den Datenpunkt auslesen? Da muss nichts bekannt sein. Entweder der Datenpunkt existiert oder nicht. wo hast du ein Problem?
    Importiere mal die 4 Nodes:
           "id": "f990f52fabd7315d",
           "type": "ioBroker in",
           "z": "b4c67f329886e71e",
           "name": "",
           "topic": "mqtt.0.shelly#2232342.status.input:100",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "MQTT",
           "x": 320,
           "y": 460,
           "wires": [
                   "0ed6a6e27b2da91f"
           "id": "0ed6a6e27b2da91f",
           "type": "json",
           "name": "",
           "property": "payload",
           "action": "",
           "pretty": false,
           "x": 510,
           "y": 460,
           "wires": [
                   "2feeeee6452e3620"
           "id": "2feeeee6452e3620",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.state",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 710,
           "y": 460,
           "wires": [
                   "4c6b3a64290772f8"
           "id": "4c6b3a64290772f8",
           "type": "debug",
           "name": "debug 45",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "false",
           "statusVal": "",
           "statusType": "auto",
           "x": 900,
           "y": 460,
           "wires": []
    und passe den Pfad zum Datenpunkt vorne an
    Dr.PieD 1 Antwort Letzte Antwort
    • mickymM mickym
             "name": "",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 320,
             "y": 460,
             "wires": [
                     "0ed6a6e27b2da91f"
             "type": "json",
             "name": "",
             "action": "",
             "pretty": false,
             "x": 510,
             "y": 460,
             "wires": [
                     "2feeeee6452e3620"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 710,
             "y": 460,
             "wires": [
                     "4c6b3a64290772f8"
             "type": "debug",
             "name": "debug 45",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 900,
             "y": 460,
             "wires": []
      Dr.PieD Offline
      Dr.PieD Offline
      Dr.Pie
      schrieb am zuletzt editiert von Dr.Pie
      @mickym Wie lese ich den Datenpunkt denn aus im Node ??
      • mickymM Offline
        mickymM Offline
        mickym
        @dr-pie Hast Du meinen Flow nicht importiert?
        • mickymM mickym
          Dr.PieD Offline
          Dr.PieD Offline
          Dr.Pie
          @mickym ich hatte das gar nicht gesehen das da unter "Spoiler" was stehen kann ... peinlich.
          Da kannste ja sehen wo ich stehe 😁
          • mickymM Offline
            mickymM Offline
            mickym
            @dr-pie Nach dem Deploy - klickst Du im mqtt Adapter einfach doppelt auf den Wert und setzt ihn nochmal und dann schaust ob im Debug Fenster was ankommt.
            • mickymM mickym
              Dr.PieD Offline
              Dr.PieD Offline
              Dr.Pie
              @mickym püüüüü ...
              wenn ich das Tor nun öffne erscheint der Zustand.
              Das funktioniert ja schon mal
              • Dr.PieD Dr.Pie
                @mickym püüüüü ...
                mickymM Offline
                mickymM Offline
                mickym
                @dr-pie Na dann hast du wenn du das debug Fenster aufmachst den Wert.
                • mickymM mickym
                  Dr.PieD Offline
                  Dr.PieD Offline
                  Dr.Pie
                  @mickym Ja suuuuper ... das scheint zu funktionieren.
                  Nach jeder änderung kommt die Meldung im Debug-Fenster.
                  Das hätten wir nun ...
                  Was muss ich denn nun machen damit ich diesen Zustand visualisieren kann ?
                  • Dr.PieD Dr.Pie
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @dr-pie Na dazu müsste ich ja erstmal wissen, was Du für eine Visualisierung nutzt. ;) Derer gibt es ja, wie erwähnt viele.
                    • mickymM mickym
                      Dr.PieD Offline
                      Dr.PieD Offline
                      Dr.Pie
                      @mickym Also ich habe die Vis vom iobroker.
                      Dort will ich ein Bild das eine geschlossene oder eine offene Garage anzeigt.
                      • Dr.PieD Dr.Pie
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @dr-pie Na gut - im VIS musst Du dich selbst drum kümmern welches Widget du da nutzt.
                        Erstelle unter 0_userdata.0 einen Datenpunkt indem wir das Ergebnis des Flows schreiben können.
                        • mickymM mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @mickym Nein ich hab eine bessere Idee.
                          Hast Du schon 2 Bilder?
                          • mickymM mickym
                            Dr.PieD Offline
                            Dr.PieD Offline
                            Dr.Pie
                            @mickym ichhabe das mit den verschiedenen Bildern bei verschiedenen Zuständen schon 100x gemacht.
                            Aber halt noch nie über mqtt.
                            • Dr.PieD Dr.Pie
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @dr-pie Na ok - dann erstelle einen Datenpunkt und hänge eine iobroker-Out Node anstelle der Debug Node hinten an den Flow. Im Topic gibst Du den Pfad zu Datenpunkt an - den musst Du aber manuell über die Zwischenablage kopieren.
                              • mickymM mickym
                                Dr.PieD Offline
                                Dr.PieD Offline
                                Dr.Pie
                                @mickym bei einem Bild nutze ich iFrame ... was kann man bei einem Textfeld nehmen ?
                                • Dr.PieD Dr.Pie
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @dr-pie Ich bin kein VIS Profi
                                  Also Text kannst Du hiermit
                                  anzeigen oder Du nimmst das HTML widget. Also VIS habe ich nur mal zum Spielen genutzt.
                                  Wenn Du einen String in den Datenpunkt schreiben willst - dann mache ich Dir das - aber kopiere mir doch bitte mal den Pfad des Datenpunktes, den Du erstellt hast hier rein.
                                  • mickymM mickym
                                    Dr.PieD Offline
                                    Dr.PieD Offline
                                    Dr.Pie
                                    @mickym Mit diesem Teil habe ich auch schon gespielt.Ist aber nicht das was ich suche.
                                    Bei meinen kleinen Bildchen kann bei true oder false verschiedene auswählen.
                                    Aber für Text habe ich noch nichts passendes gefunden.
                                    • Dr.PieD Dr.Pie
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @dr-pie Du brauchst nur einen Datenpunkt und wir schreiben in diesen Datenpunkt. Ich zeigs Dir.
                                      Du erstellst unter userdata_0.0 einen Datenpunkt mit dem Typ Zeichenkette:
                                      Einen Datenpunkt erstellst Du in dem Du den darüber liegenden Ordner markierst und dann mit + einen Datenpunkt erstellst:
                                      ggf. musst Du in den Expertenmodus schalten - weiss ich nicht:
                                      Das Manschgerl ;) - muss grün sein. ;)
                                      Dann importierst Du nochmal diese beiden Nodes;
                                      Den Rest kannst Du wegschmeissen.
                                             "type": "change",
                                             "z": "7e6af0015415146d",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                                     "t": "change",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "from": "true",
                                                     "fromt": "bool",
                                                     "to": "Garage ist offen",
                                                     "tot": "str"
                                                     "t": "change",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "from": "false",
                                                     "fromt": "bool",
                                                     "to": "Garage ist geschlossen",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 750,
                                             "y": 2780,
                                             "wires": [
                                                     "028856d0e789b57c"
                                             "id": "028856d0e789b57c",
                                             "type": "ioBroker out",
                                             "name": "garage",
                                             "topic": "0_userdata.0.Test.garage",
                                             "ack": "false",
                                             "autoCreate": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 960,
                                             "y": 2780,
                                             "wires": []
                                      Dann gehst Du auf die Schaltfläche aus der 1. Abbildung und klickst auf das Kopieren Symbol links.
                                      • mickymM mickym
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                                       "t": "change",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "from": "true",
                                                       "fromt": "bool",
                                                       "tot": "str"
                                                       "t": "change",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "from": "false",
                                                       "fromt": "bool",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 750,
                                               "y": 2780,
                                               "wires": [
                                                       "028856d0e789b57c"
                                               "name": "garage",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 960,
                                               "y": 2780,
                                               "wires": []
                                        Dr.PieD Offline
                                        Dr.PieD Offline
                                        Dr.Pie
                                        @mickym Moooment
                                        • Dr.PieD Dr.Pie
                                          @mickym Moooment
                                          Dr.PieD Offline
                                          Dr.PieD Offline
                                          Dr.Pie
                                          @dr-pie Ich bin bereits weiter.
                                          Einen Datenpunkt habe ich schon erstellt.
                                          Der funktioniert auch so wie er soll.
                                          Ändert sich der Zustand von Input100 sendet er per mqtt an den Broker.
                                          Der schreibt dann den entsprechenden Wert in den Datenpunkt.
                                          Ich habe mir noch schnell ein kleines Blockly gebastelt was mir per Whatsapp eine Nachricht sendet das das Tor geöffnet ist.
                                          Das alles funktioniert ... das erstaunt mich ein wenig.
