  4. Instanz - Javascript bleibt rot
    5.4k
22 Beiträge 6 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • I Intruminator
    wow, na das ist ja ne echt coole Funktion!
    In Detail:
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     16:41:55 up  1:06,  1 user,  load average: 0.47, 0.68, 0.43
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Mar 19 15:41:55 UTC 2023
    Sun Mar 19 16:41:55 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            922M        466M        123M        0.0K        332M        409M
    Swap:            99M         71M         28M
    Total:          1.0G        537M        151M
              922 M total memory
              466 M used memory
              284 M active memory
              414 M inactive memory
              123 M free memory
               57 M buffer memory
              275 M swap cache
               99 M total swap
               71 M used swap
               28 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       15G  3.7G   10G  28% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
    tmpfs          tmpfs     185M 1008K  184M   1% /run
    /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    Messages in dmesg:
    [Sun Mar 19 15:35:34 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=be80aafe-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Mar 19 15:35:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Mar 19 15:35:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Mar 19 15:35:47 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    1.1G    /var/
    616M    /var/lib
    511M    /var/lib/piVCCU3
    459M    /var/lib/piVCCU3/rootfs
    241M    /var/log/journal
    /opt/iobroker/backups:
    22M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    139M    /opt/iobroker/iobroker-data/
    102M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
         16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
     *** 16.19.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : DieterSmarthomePi                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : DieterSmarthomePi                        -  enabled
    + system.adapter.discovery.0              : discovery             : DieterSmarthomePi                        -  enabled
      system.adapter.flot.0                   : flot                  : DieterSmarthomePi                        -  enabled
    + system.adapter.history.0                : history               : DieterSmarthomePi                        -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : DieterSmarthomePi                        -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : DieterSmarthomePi                        -  enabled, port: 0
      system.adapter.javascript.0             : javascript            : DieterSmarthomePi                        - disabled
    + system.adapter.shelly.0                 : shelly                : DieterSmarthomePi                        -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : DieterSmarthomePi                        -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : DieterSmarthomePi                        -  enabled
      system.adapter.vis-history.0            : vis-history           : DieterSmarthomePi                        -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : DieterSmarthomePi                        -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : DieterSmarthomePi                        -  enabled
      system.adapter.vis-weather.0            : vis-weather           : DieterSmarthomePi                        -  enabled
      system.adapter.vis.0                    : vis                   : DieterSmarthomePi                        -  enabled
    + system.adapter.web.0                    : web                   : DieterSmarthomePi                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.12   , installed 2.5.10 [Updatable]
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.44   , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
    Adapter    "shelly"       : 6.3.1    , installed 6.0.0  [Updatable]
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.1.0  [Updatable]
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Objects and States
    Objects:        1250
    States:         953
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:4 https://www.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 33
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12800      737/dnsmasq
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15835      1493/io.shelly.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14708      660/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15457      660/iobroker.js-con
    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       16446      1609/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12762      720/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13257      1459/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14161      1744/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12764      720/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13342      417/avahi-daemon: r
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12799      737/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12796      737/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13365      520/dhclient
    udp        0      0 0.0.0.0:48781           0.0.0.0:*                           108        13344      417/avahi-daemon: r
    udp6       0      0 :::36040                :::*                                108        13345      417/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13343      417/avahi-daemon: r
    2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
    2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
    2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
    2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:43:23)
    2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
    2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32)
    2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:878:12)
    2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:     at node:internal/main/run_main_module:22:47
    2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:  {
    2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/package.json',
    2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:   requestPath: 'suncalc2'
    2023-03-19 15:50:17.318  - error: host.DieterSmarthomePi Caught by controller[0]: }
    2023-03-19 15:50:17.318  - error: host.DieterSmarthomePi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-03-19 15:50:17.318  - info: host.DieterSmarthomePi Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2023-03-19 16:04:40.611  - info: host.DieterSmarthomePi "system.adapter.javascript.0" disabled
    2023-03-19 16:18:51.367  - info: admin.0 (1459) ==> Connected system.user.admin from ::ffff:192.168.178.54
    2023-03-19 16:36:43.168  - info: host.DieterSmarthomePi Delete log file iobroker.2023-01-20.log.gz
    2023-03-19 16:36:43.178  - info: host.DieterSmarthomePi Delete log file iobroker.2023-01-21.log.gz
    2023-03-19 16:38:58.990  - info: admin.0 (1459) <== Disconnect system.user.admin from ::ffff:192.168.178.54
    2023-03-19 16:38:59.013  - info: admin.0 (1459) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
    2023-03-19 16:39:00.523  - info: admin.0 (1459) failed connection to socket.io from ::ffff:192.168.178.54: Passport was not initialized
    Summary:
                         v.2023-01-02
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Installation:           Native
    Timezone:               Europe/Berlin
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     33
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Status admin:
    Pending iob updates:    5
    Objects:                1250
    States:                 953
    Size of iob-Database:
    712K    /opt/iobroker/iobroker-data/states.jsonl
    @intruminator
    Zunächst mal alles auf Stand bringen.
    Also Betriebssystem inkl. nodejs und die ganzen Adapter und den js-controller.
    I 1 Antwort Letzte Antwort
    • I Intruminator
      In Detail:
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         71M         28M
                922 M total memory
                466 M used memory
                284 M active memory
                123 M free memory
                 57 M buffer memory
                275 M swap cache
                 99 M total swap
                 71 M used swap
                 28 M free swap
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      1.1G    /var/
      616M    /var/lib
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        1250
      States:         953
      Pending Updates: 33
      Summary:
                           v.2023-01-02
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Objects:                1250
      States:                 953
      @intruminator
      Könnte auch zusammen mit dem piVCCU gleichzeitig auf dem kleinen System eng werden.
        @intruminator
        I Offline
        I Offline
        Intruminator
        Hi Thomas,
        ich habe jetzt alles auf den neusten Stand gebracht - hat ein bisschen gedauert.
        3 Adapter kann ich gerade nicht updaten, weil er der Meinung ist, dass meine node-version höher sein müsste, dabei ist jetzt 16.19.1 in Betrieb und läuft.
        Javascript Adapter ist noch rot. Konfigurieren muss ich den ja nicht oder?
        • I Intruminator
          Hi Thomas,
          @intruminator sagte in Instanz - Javascript bleibt rot:
          Das ist dann aber höchstwahrscheinlich schon krumm.
          iob diag
          sagt dazu?
            iob diag
            sagt dazu?
            I Offline
            I Offline
            Intruminator
            hab gerade mal neugestartet - javascript ist jetzt grün.
            Ich vermute, dass du Recht hast und der Pi mit nur 1GB RAM ganz schön am schuften ist.
            Ich schaue mal, ob ich mit dem Adapter jetzt was anfangen kann.
            Vielen Dank euch allen erstmal.
            In Detail:
            Skript v.2023-01-02
            *** BASE SYSTEM ***
            Docker:         false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
             20:07:10 up 6 min,  2 users,  load average: 0.33, 1.11, 0.64
            CPU threads: 4
            Sun Mar 19 19:07:10 UTC 2023
            Sun Mar 19 20:07:10 CET 2023
            CET +0100
            Europe/Berlin
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            921M        555M        156M        1.0M        209M        335M
            Swap:            99M          0B         99M
            Total:          1.0G        555M        256M
                      921 M total memory
                      555 M used memory
                      617 M active memory
                       70 M inactive memory
                      156 M free memory
                       19 M buffer memory
                      190 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /dev/root      ext4       15G  4.2G  9.5G  31% /
            tmpfs          tmpfs     461M     0  461M   0% /dev/shm
            tmpfs          tmpfs     185M  1.1M  184M   1% /run
            /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
            Messages in dmesg:
            [Sun Mar 19 20:01:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=be80aafe-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Mar 19 20:01:11 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [Sun Mar 19 20:01:11 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [Sun Mar 19 20:01:36 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
            [Sun Mar 19 20:01:36 2023] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
            [Sun Mar 19 20:01:36 2023] EXT4-fs (mmcblk0p2): recovery complete
            [Sun Mar 19 20:01:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Mar 19 20:01:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Mar 19 20:01:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            /var:
            1.5G    /var/
            616M    /var/lib
            429M    /var/cache
            145M    /opt/iobroker/iobroker-data/
            13M     /opt/iobroker/iobroker-data/objects.jsonl
            6.5M    /opt/iobroker/iobroker-data/states.jsonl
            /usr/bin/nodejs         v16.19.1
            /usr/bin/node           v16.19.1
            /usr/bin/npm            8.19.3
            /usr/bin/npx            8.19.3
            nodejs:
              Installed: 16.19.1-deb-1nodesource1
              Version table:
             *** 16.19.1-deb-1nodesource1 500
            Temp directories causing npm8 problem: 2
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + system.adapter.javascript.0             : javascript            : DieterSmarthomePi                        -  enabled
            + instance is alive
            Adapter    "hm-rega"      : 3.0.44   , installed 3.0.44
            Objects and States
            Objects:        1290
            States:         1005
            Pending Updates: 0
            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14148      695/dnsmasq
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12845      685/sshd: /usr/sbin
            tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       16044      1903/io.hm-rpc.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15762      1467/io.shelly.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13068      629/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13061      629/iobroker.js-con
            tcp6       0      0 :::22                   :::*                    LISTEN      0          12847      685/sshd: /usr/sbin
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16838      1790/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17822      2027/io.web.0
            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14147      695/dnsmasq
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14144      695/dnsmasq
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4989       520/dhclient
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        521        371/avahi-daemon: r
            udp        0      0 0.0.0.0:34616           0.0.0.0:*                           108        523        371/avahi-daemon: r
            udp6       0      0 :::47152                :::*                                108        524        371/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        522        371/avahi-daemon: r
            2023-03-19 20:03:34.992  - info: tankerkoenig.0 (2198) Sync time set to 5 minutes or 300000 ms
            2023-03-19 20:03:49.706  - info: hm-rega.0 (1947) ReGaHSS 192.168.178.83 up
            2023-03-19 20:03:50.913  - info: hm-rega.0 (1947) time difference local-ccu 1s
            2023-03-19 20:03:51.520  - info: hm-rega.0 (1947) request state values
            2023-03-19 20:03:51.552  - info: hm-rega.0 (1947) Updated all datapoints
            2023-03-19 20:03:51.571  - info: hm-rega.0 (1947) got 4 variables
            2023-03-19 20:03:51.723  - info: hm-rega.0 (1947) added/updated 4 variables
            2023-03-19 20:03:51.725  - info: hm-rega.0 (1947) deleted 0 variables
            2023-03-19 20:03:51.737  - info: hm-rega.0 (1947) got 0 programs
            2023-03-19 20:03:51.755  - info: hm-rega.0 (1947) added/updated 0 programs
            2023-03-19 20:03:51.756  - info: hm-rega.0 (1947) deleted 0 programs
            2023-03-19 20:03:51.779  - info: hm-rega.0 (1947) update rooms to enum.rooms
            2023-03-19 20:03:51.831  - info: hm-rega.0 (1947) update functions to enum.functions
            2023-03-19 20:03:51.905  - info: hm-rega.0 (1947) update favorites to enum.favorites
            2023-03-19 20:04:14.054  - info: web.0 (2027) ==> Connected system.user.admin from ::ffff:192.168.178.54
            2023-03-19 20:04:18.751  - info: web.0 (2027) <== Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
            2023-03-19 20:04:19.760  - info: web.0 (2027) ==> Connected system.user.admin from ::ffff:192.168.178.54
            2023-03-19 20:04:22.265  - info: web.0 (2027) ==> Connected system.user.admin from ::ffff:192.168.178.54
            2023-03-19 20:04:30.199  - info: web.0 (2027) <== Disconnect system.user.admin from ::ffff:192.168.178.54 flot
            2023-03-19 20:04:30.205  - info: web.0 (2027) <== Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
            2023-03-19 20:04:31.633  - info: admin.0 (1790) failed connection to socket.io from ::ffff:192.168.178.54: Passport was not initialized
            2023-03-19 20:04:38.519  - info: admin.0 (1790) ==> Connected system.user.admin from ::ffff:192.168.178.54
            2023-03-19 20:05:31.834  - info: admin.0 (1790) ==> Connected system.user.admin from ::ffff:192.168.178.54
            2023-03-19 20:05:36.615  - info: admin.0 (1790) <== Disconnect system.user.admin from ::ffff:192.168.178.54
            2023-03-19 20:07:20.901  - info: admin.0 (1790) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
            Summary:
                                 v.2023-01-02
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     0
            Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Status admin:
            Pending iob updates:    3
            Objects:                1290
            States:                 1005
            6.7M    /opt/iobroker/iobroker-data/states.jsonl
            • I Intruminator
              In Detail:
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Docker:         false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              CET +0100
              Europe/Berlin
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                        921 M total memory
                        555 M used memory
                        617 M active memory
                        156 M free memory
                         19 M buffer memory
                        190 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              *** FILESYSTEM ***
              Messages in dmesg:
              /var:
              1.5G    /var/
              616M    /var/lib
              429M    /var/cache
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        1290
              States:         1005
              Pending Updates: 0
              Summary:
                                   v.2023-01-02
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            8.19.3
                                      /usr/bin/npx            8.19.3
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Status admin:
              Objects:                1290
              States:                 1005
              @intruminator
              Fahr die Kiste IMMER ordentlich herunter! Dann zwebröselst du dir auch nicht (so schnell) dein Dateisystem wie hier zusehen.
              • I Intruminator
                In Detail:
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Docker:         false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                CPU threads: 4
                CET +0100
                Europe/Berlin
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                          921 M total memory
                          555 M used memory
                          617 M active memory
                          156 M free memory
                           19 M buffer memory
                          190 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                Messages in dmesg:
                /var:
                1.5G    /var/
                616M    /var/lib
                429M    /var/cache
                /usr/bin/npm            8.19.3
                /usr/bin/npx            8.19.3
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        1290
                States:         1005
                Pending Updates: 0
                Summary:
                                     v.2023-01-02
                User-ID:                1000
                X-Server:               false
                                        /usr/bin/npm            8.19.3
                                        /usr/bin/npx            8.19.3
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Status admin:
                Objects:                1290
                States:                 1005
                @intruminator
                Und dann wirst du das ausführen müssen:
                https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
                Anschließend
                iob update
                iob upgrade all
                Und schau was da an Instanzen noch entbehrlich ist. Der discovery-Adapter braucht z.B. eher nicht laufen.
                • GarganoG Offline
                  GarganoG Offline
                  Gargano
                  Jetzt habe ich auch das Problem. .Javasript bleibt rot und bringt Fehlermeldung mit suncalc2:
                  Was hab ich gemacht :
                  apt-update
                  apt-upgrade
                  Nach dem Reboot bleiben dann die Javascript Instanzen rot. (Ging vor dem update)
                  Dann in Putty:
                  cd /opt/iobroker/node_modules/iobroker.javascript
                  bzw.
                  npm install --omit=dev
                  Hat aber nichts gebracht.
                  host.raspberrypi
                  2023-04-01 13:47:41.536	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.raspberrypi
                  2023-04-01 13:47:41.535	error	Caught by controller[0]: Node.js v18.15.0
                  host.raspberrypi
                  2023-04-01 13:47:41.535	error	Caught by controller[0]: }
                  host.raspberrypi
                  2023-04-01 13:47:41.534	error	Caught by controller[0]: requestPath: 'suncalc2'
                  host.raspberrypi
                  2023-04-01 13:47:41.521	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/package.json',
                  host.raspberrypi
                  2023-04-01 13:47:41.520	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  host.raspberrypi
                  2023-04-01 13:47:41.519	error	Caught by controller[0]: {
                  host.raspberrypi
                  2023-04-01 13:47:41.519	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
                  host.raspberrypi
                  2023-04-01 13:47:41.518	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  host.raspberrypi
                  2023-04-01 13:47:41.517	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:958:12)
                  host.raspberrypi
                  2023-04-01 13:47:41.517	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
                  host.raspberrypi
                  2023-04-01 13:47:41.516	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                  host.raspberrypi
                  2023-04-01 13:47:41.515	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
                  host.raspberrypi
                  2023-04-01 13:47:41.514	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
                  host.raspberrypi
                  2023-04-01 13:47:41.510	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
                  host.raspberrypi
                  2023-04-01 13:47:41.509	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
                  host.raspberrypi
                  2023-04-01 13:47:41.508	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:920:27)
                  host.raspberrypi
                  2023-04-01 13:47:41.507	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1061:27)
                  host.raspberrypi
                  2023-04-01 13:47:41.506	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:678:18)
                  host.raspberrypi
                  2023-04-01 13:47:41.506	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:436:19)
                  host.raspberrypi
                  2023-04-01 13:47:41.505	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/suncalc2.js'. Please verify that the package.json has a valid "main" entry
                  host.raspberrypi
                  2023-04-01 13:47:41.504	error	Caught by controller[0]: ^
                  host.raspberrypi
                  2023-04-01 13:47:41.501	error	Caught by controller[0]: throw err;
                  host.raspberrypi
                  2023-04-01 13:47:41.501	error	Caught by controller[0]: node:internal/modules/cjs/loader:444
                  iob diag :
                  2023-04-01 13:49:40.349  - error: host.raspberrypi Caught by controller[0]:       ^
                  2023-04-01 13:49:40.350  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/o                                                 pt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/suncalc2.js'. Please verify that the p                                                 ackage.json has a valid "main" entry
                  2023-04-01 13:49:40.351  - error: host.raspberrypi Caught by controller[0]:     at tryPackage (node:inter                                                 nal/modules/cjs/loader:436:19)
                  2023-04-01 13:49:40.352  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._findP                                                 ath (node:internal/modules/cjs/loader:678:18)
                  2023-04-01 13:49:40.352  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resol                                                 veFilename (node:internal/modules/cjs/loader:1061:27)
                  2023-04-01 13:49:40.353  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load                                                  (node:internal/modules/cjs/loader:920:27)
                  2023-04-01 13:49:40.353  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:i                                                 nternal/modules/cjs/loader:1141:19)
                  2023-04-01 13:49:40.355  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal                                                 /modules/cjs/helpers:110:18)
                  2023-04-01 13:49:40.355  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/o                                                 pt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
                  2023-04-01 13:49:40.356  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:                                                 internal/modules/cjs/loader:1254:14)
                  2023-04-01 13:49:40.356  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensi                                                 ons..js (node:internal/modules/cjs/loader:1308:10)
                  2023-04-01 13:49:40.357  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:inte                                                 rnal/modules/cjs/loader:1117:32)
                  2023-04-01 13:49:40.358  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load                                                  (node:internal/modules/cjs/loader:958:12)
                  2023-04-01 13:49:40.358  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEn                                                 tryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  2023-04-01 13:49:40.359  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run                                                 _main_module:23:47
                  2023-04-01 13:49:40.359  - error: host.raspberrypi Caught by controller[0]:  {
                  2023-04-01 13:49:40.360  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                  2023-04-01 13:49:40.360  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_m                                                 odules/iobroker.javascript/node_modules/suncalc2/package.json',
                  2023-04-01 13:49:40.361  - error: host.raspberrypi Caught by controller[0]:   requestPath: 'suncalc2'
                  2023-04-01 13:49:40.361  - error: host.raspberrypi Caught by controller[0]: }
                  2023-04-01 13:49:40.362  - error: host.raspberrypi Caught by controller[0]: Node.js v18.15.0
                  2023-04-01 13:49:40.363  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with c                                                 ode 1 (JS_CONTROLLER_STOPPED)
                  2023-04-01 13:49:40.363  - info: host.raspberrypi Rebuild for adapter system.adapter.javascript.0 not suc                                                 cessful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in ada                                                 pter directory manually.
                  2023-04-01 13:50:00.075  - info: host.raspberrypi instance system.adapter.meteoalarm.0 started with pid 5                                                 922
                  2023-04-01 13:50:05.733  - info: host.raspberrypi instance system.adapter.meteoalarm.0 terminated with co                                                 de 11 (ADAPTER_REQUESTED_TERMINATION)
                  iob diag summary :
                                       v.2023-01-02
                  Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     1
                  Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                                          /usr/bin/node           v18.15.0
                                          /usr/bin/npm            9.5.0
                                          /usr/bin/npx            9.5.0
                                          admin                   6.4.3
                  At least one iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  Status admin:
                  Pending iob updates:    1
                  Active repo(s): Beta (latest)
                  Objects:                20397
                  States:                 18713
                  5.2M    /opt/iobroker/iobroker-data/objects.json.bak
                  40K     /opt/iobroker/iobroker-data/states.json.bak
                  • GarganoG Gargano
                    apt-update
                    apt-upgrade
                    Dann in Putty:
                    bzw.
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    iob diag :
                    iob diag summary :
                                         v.2023-01-02
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.5.0
                                            /usr/bin/npx            9.5.0
                                            admin                   6.4.3
                    Objects type: redis
                    States  type: redis
                    Status admin:
                    Objects:                20397
                    States:                 18713
                    @gargano sagte in Instanz - Javascript bleibt rot:
                    Mit
                    sudo apt update
                    sudo apt full-upgrade
                    wird ein Schuh draus.
                    iob upgrade javascript@7.0.3
                    sagt?
                    Denn eigentlich ist das eine Dependency von javascript:
                    echad@chet:/opt/iobroker $ npm ls suncalc2
                    iobroker.inst@3.0.0 /opt/iobroker
                    └─┬ iobroker.javascript@7.0.3
                      └── suncalc2@1.8.1
                    Tip am Rande: Bitte zieh das Fenster des Terminals so breit wie möglich. Oder nutze ein Terminalprogramm das besser mit Zeilenumbrüchen umgehen kann als puTTY.
                    GarganoG 1 Antwort Letzte Antwort
                      Mit
                      sudo apt update
                      sagt?
                        └── suncalc2@1.8.1
                      GarganoG Offline
                      GarganoG Offline
                      Gargano
                      @thomas-braun Tatsächlich ist alles wieder da, danke.
                      Aber eigentlich habe ich gelernt, daß sudo böse ist :-))
                      • GarganoG Gargano
                        Stimmt. Wenn es für Dinge verwendet wird, die auch ohne sudo funktionieren.
                        Ein apt update und apt full-upgrade funktionieren aber nur mit root-Rechten. Darf ja nicht jeder Heini am System herumschrauben.
                        • GarganoG Gargano
                          ... in Verbindung mit Befehlen die mit iobroker... oder npm... beginnen.
                            GarganoG Offline
                            GarganoG Offline
                            Gargano
                            @thomas-braun again what learned....
                            • GarganoG Gargano
                              @gargano
                              Ich sollte einen VHS-Kurs zu 'Linux' anbieten...
