  4. Instanz - Javascript bleibt rot
    5.4k
22 Beiträge 6 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • Thomas BraunT Online
    @intruminator
    Schau mal das System in Gänze an.
    iob diag
    I 1 Antwort Letzte Antwort
      @intruminator
      iob diag
      I Offline
      I Offline
      Intruminator
      wow, na das ist ja ne echt coole Funktion!
      In Detail:
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Architecture:   armv7l
      Docker:         false
      Virtualization: none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       16:41:55 up  1:06,  1 user,  load average: 0.47, 0.68, 0.43
      CPU threads: 4
      *** Time and Time Zones ***
      Sun Mar 19 15:41:55 UTC 2023
      Sun Mar 19 16:41:55 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            922M        466M        123M        0.0K        332M        409M
      Swap:            99M         71M         28M
      Total:          1.0G        537M        151M
                922 M total memory
                466 M used memory
                284 M active memory
                414 M inactive memory
                123 M free memory
                 57 M buffer memory
                275 M swap cache
                 99 M total swap
                 71 M used swap
                 28 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4       15G  3.7G   10G  28% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     462M     0  462M   0% /dev/shm
      tmpfs          tmpfs     185M 1008K  184M   1% /run
      /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      Messages in dmesg:
      [Sun Mar 19 15:35:34 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=be80aafe-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Mar 19 15:35:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun Mar 19 15:35:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Mar 19 15:35:47 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      1.1G    /var/
      616M    /var/lib
      511M    /var/lib/piVCCU3
      459M    /var/lib/piVCCU3/rootfs
      241M    /var/log/journal
      /opt/iobroker/backups:
      22M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      139M    /opt/iobroker/iobroker-data/
      102M    /opt/iobroker/iobroker-data/files
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      12M     /opt/iobroker/iobroker-data/objects.jsonl
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.0
      /usr/bin/node           v16.19.0
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Installed: 16.19.0-deb-1nodesource1
        Candidate: 16.19.1-deb-1nodesource1
        Version table:
           16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
       *** 16.19.0-deb-1nodesource1 100
           12.22.12~dfsg-1~deb11u3 500
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.23
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : DieterSmarthomePi                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : DieterSmarthomePi                        -  enabled
      + system.adapter.discovery.0              : discovery             : DieterSmarthomePi                        -  enabled
        system.adapter.flot.0                   : flot                  : DieterSmarthomePi                        -  enabled
      + system.adapter.history.0                : history               : DieterSmarthomePi                        -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : DieterSmarthomePi                        -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : DieterSmarthomePi                        -  enabled, port: 0
        system.adapter.javascript.0             : javascript            : DieterSmarthomePi                        - disabled
      + system.adapter.shelly.0                 : shelly                : DieterSmarthomePi                        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : DieterSmarthomePi                        -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : DieterSmarthomePi                        -  enabled
        system.adapter.vis-history.0            : vis-history           : DieterSmarthomePi                        -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : DieterSmarthomePi                        -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : DieterSmarthomePi                        -  enabled
        system.adapter.vis-weather.0            : vis-weather           : DieterSmarthomePi                        -  enabled
        system.adapter.vis.0                    : vis                   : DieterSmarthomePi                        -  enabled
      + system.adapter.web.0                    : web                   : DieterSmarthomePi                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.5.12   , installed 2.5.10 [Updatable]
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.44   , installed 3.0.40 [Updatable]
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
      Adapter    "shelly"       : 6.3.1    , installed 6.0.0  [Updatable]
      Adapter    "tankerkoenig" : 3.3.7    , installed 3.1.0  [Updatable]
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Objects and States
      Objects:        1250
      States:         953
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:4 https://www.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 33
      *** Listening Ports ***
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12800      737/dnsmasq
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15835      1493/io.shelly.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14708      660/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15457      660/iobroker.js-con
      tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       16446      1609/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12762      720/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13257      1459/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14161      1744/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12764      720/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13342      417/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12799      737/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12796      737/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13365      520/dhclient
      udp        0      0 0.0.0.0:48781           0.0.0.0:*                           108        13344      417/avahi-daemon: r
      udp6       0      0 :::36040                :::*                                108        13345      417/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13343      417/avahi-daemon: r
      2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
      2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
      2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
      2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
      2023-03-19 15:50:17.315  - error: host.DieterSmarthomePi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:43:23)
      2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
      2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
      2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32)
      2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:878:12)
      2023-03-19 15:50:17.316  - error: host.DieterSmarthomePi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:     at node:internal/main/run_main_module:22:47
      2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:  {
      2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/package.json',
      2023-03-19 15:50:17.317  - error: host.DieterSmarthomePi Caught by controller[0]:   requestPath: 'suncalc2'
      2023-03-19 15:50:17.318  - error: host.DieterSmarthomePi Caught by controller[0]: }
      2023-03-19 15:50:17.318  - error: host.DieterSmarthomePi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-03-19 15:50:17.318  - info: host.DieterSmarthomePi Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2023-03-19 16:04:40.611  - info: host.DieterSmarthomePi "system.adapter.javascript.0" disabled
      2023-03-19 16:18:51.367  - info: admin.0 (1459) ==> Connected system.user.admin from ::ffff:192.168.178.54
      2023-03-19 16:36:43.168  - info: host.DieterSmarthomePi Delete log file iobroker.2023-01-20.log.gz
      2023-03-19 16:36:43.178  - info: host.DieterSmarthomePi Delete log file iobroker.2023-01-21.log.gz
      2023-03-19 16:38:58.990  - info: admin.0 (1459) <== Disconnect system.user.admin from ::ffff:192.168.178.54
      2023-03-19 16:38:59.013  - info: admin.0 (1459) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
      2023-03-19 16:39:00.523  - info: admin.0 (1459) failed connection to socket.io from ::ffff:192.168.178.54: Passport was not initialized
      Summary:
                           v.2023-01-02
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Installation:           Native
      Timezone:               Europe/Berlin
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     33
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      ioBroker Core:          js-controller           4.0.23
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Pending iob updates:    5
      Objects:                1250
      States:                 953
      Size of iob-Database:
      712K    /opt/iobroker/iobroker-data/states.jsonl
      • I Intruminator
        In Detail:
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Docker:         false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        CET +0100
        Europe/Berlin
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         71M         28M
                  922 M total memory
                  466 M used memory
                  284 M active memory
                  123 M free memory
                   57 M buffer memory
                  275 M swap cache
                   99 M total swap
                   71 M used swap
                   28 M free swap
        *** FILESYSTEM ***
        Messages in dmesg:
        /var:
        1.1G    /var/
        616M    /var/lib
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        1250
        States:         953
        Pending Updates: 33
        Summary:
                             v.2023-01-02
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Objects:                1250
        States:                 953
        @intruminator
        Zunächst mal alles auf Stand bringen.
        Also Betriebssystem inkl. nodejs und die ganzen Adapter und den js-controller.
        • I Intruminator
          In Detail:
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Docker:         false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          CET +0100
          Europe/Berlin
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M         71M         28M
                    922 M total memory
                    466 M used memory
                    284 M active memory
                    123 M free memory
                     57 M buffer memory
                    275 M swap cache
                     99 M total swap
                     71 M used swap
                     28 M free swap
          *** FILESYSTEM ***
          Messages in dmesg:
          /var:
          1.1G    /var/
          616M    /var/lib
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        1250
          States:         953
          Pending Updates: 33
          Summary:
                               v.2023-01-02
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Status admin:
          Objects:                1250
          States:                 953
          @intruminator
          Könnte auch zusammen mit dem piVCCU gleichzeitig auf dem kleinen System eng werden.
            @intruminator
            I Offline
            I Offline
            Intruminator
            Hi Thomas,
            ich habe jetzt alles auf den neusten Stand gebracht - hat ein bisschen gedauert.
            3 Adapter kann ich gerade nicht updaten, weil er der Meinung ist, dass meine node-version höher sein müsste, dabei ist jetzt 16.19.1 in Betrieb und läuft.
            Javascript Adapter ist noch rot. Konfigurieren muss ich den ja nicht oder?
            • I Intruminator
              Hi Thomas,
              @intruminator sagte in Instanz - Javascript bleibt rot:
              Das ist dann aber höchstwahrscheinlich schon krumm.
              iob diag
              sagt dazu?
                iob diag
                sagt dazu?
                I Offline
                I Offline
                Intruminator
                hab gerade mal neugestartet - javascript ist jetzt grün.
                Ich vermute, dass du Recht hast und der Pi mit nur 1GB RAM ganz schön am schuften ist.
                Ich schaue mal, ob ich mit dem Adapter jetzt was anfangen kann.
                Vielen Dank euch allen erstmal.
                In Detail:
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Docker:         false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                 20:07:10 up 6 min,  2 users,  load average: 0.33, 1.11, 0.64
                CPU threads: 4
                Sun Mar 19 19:07:10 UTC 2023
                Sun Mar 19 20:07:10 CET 2023
                CET +0100
                Europe/Berlin
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            921M        555M        156M        1.0M        209M        335M
                Swap:            99M          0B         99M
                Total:          1.0G        555M        256M
                          921 M total memory
                          555 M used memory
                          617 M active memory
                           70 M inactive memory
                          156 M free memory
                           19 M buffer memory
                          190 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                /dev/root      ext4       15G  4.2G  9.5G  31% /
                tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                tmpfs          tmpfs     185M  1.1M  184M   1% /run
                /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                Messages in dmesg:
                [Sun Mar 19 20:01:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=be80aafe-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sun Mar 19 20:01:11 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                [Sun Mar 19 20:01:11 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                [Sun Mar 19 20:01:36 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                [Sun Mar 19 20:01:36 2023] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
                [Sun Mar 19 20:01:36 2023] EXT4-fs (mmcblk0p2): recovery complete
                [Sun Mar 19 20:01:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sun Mar 19 20:01:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Sun Mar 19 20:01:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                /var:
                1.5G    /var/
                616M    /var/lib
                429M    /var/cache
                145M    /opt/iobroker/iobroker-data/
                13M     /opt/iobroker/iobroker-data/objects.jsonl
                6.5M    /opt/iobroker/iobroker-data/states.jsonl
                /usr/bin/nodejs         v16.19.1
                /usr/bin/node           v16.19.1
                /usr/bin/npm            8.19.3
                /usr/bin/npx            8.19.3
                nodejs:
                  Installed: 16.19.1-deb-1nodesource1
                  Version table:
                 *** 16.19.1-deb-1nodesource1 500
                Temp directories causing npm8 problem: 2
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                js-controller:  4.0.24
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + system.adapter.javascript.0             : javascript            : DieterSmarthomePi                        -  enabled
                + instance is alive
                Adapter    "hm-rega"      : 3.0.44   , installed 3.0.44
                Objects and States
                Objects:        1290
                States:         1005
                Pending Updates: 0
                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14148      695/dnsmasq
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12845      685/sshd: /usr/sbin
                tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       16044      1903/io.hm-rpc.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15762      1467/io.shelly.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13068      629/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13061      629/iobroker.js-con
                tcp6       0      0 :::22                   :::*                    LISTEN      0          12847      685/sshd: /usr/sbin
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16838      1790/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17822      2027/io.web.0
                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14147      695/dnsmasq
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14144      695/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4989       520/dhclient
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        521        371/avahi-daemon: r
                udp        0      0 0.0.0.0:34616           0.0.0.0:*                           108        523        371/avahi-daemon: r
                udp6       0      0 :::47152                :::*                                108        524        371/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        522        371/avahi-daemon: r
                2023-03-19 20:03:34.992  - info: tankerkoenig.0 (2198) Sync time set to 5 minutes or 300000 ms
                2023-03-19 20:03:49.706  - info: hm-rega.0 (1947) ReGaHSS 192.168.178.83 up
                2023-03-19 20:03:50.913  - info: hm-rega.0 (1947) time difference local-ccu 1s
                2023-03-19 20:03:51.520  - info: hm-rega.0 (1947) request state values
                2023-03-19 20:03:51.552  - info: hm-rega.0 (1947) Updated all datapoints
                2023-03-19 20:03:51.571  - info: hm-rega.0 (1947) got 4 variables
                2023-03-19 20:03:51.723  - info: hm-rega.0 (1947) added/updated 4 variables
                2023-03-19 20:03:51.725  - info: hm-rega.0 (1947) deleted 0 variables
                2023-03-19 20:03:51.737  - info: hm-rega.0 (1947) got 0 programs
                2023-03-19 20:03:51.755  - info: hm-rega.0 (1947) added/updated 0 programs
                2023-03-19 20:03:51.756  - info: hm-rega.0 (1947) deleted 0 programs
                2023-03-19 20:03:51.779  - info: hm-rega.0 (1947) update rooms to enum.rooms
                2023-03-19 20:03:51.831  - info: hm-rega.0 (1947) update functions to enum.functions
                2023-03-19 20:03:51.905  - info: hm-rega.0 (1947) update favorites to enum.favorites
                2023-03-19 20:04:14.054  - info: web.0 (2027) ==> Connected system.user.admin from ::ffff:192.168.178.54
                2023-03-19 20:04:18.751  - info: web.0 (2027) <== Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2023-03-19 20:04:19.760  - info: web.0 (2027) ==> Connected system.user.admin from ::ffff:192.168.178.54
                2023-03-19 20:04:22.265  - info: web.0 (2027) ==> Connected system.user.admin from ::ffff:192.168.178.54
                2023-03-19 20:04:30.199  - info: web.0 (2027) <== Disconnect system.user.admin from ::ffff:192.168.178.54 flot
                2023-03-19 20:04:30.205  - info: web.0 (2027) <== Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2023-03-19 20:04:31.633  - info: admin.0 (1790) failed connection to socket.io from ::ffff:192.168.178.54: Passport was not initialized
                2023-03-19 20:04:38.519  - info: admin.0 (1790) ==> Connected system.user.admin from ::ffff:192.168.178.54
                2023-03-19 20:05:31.834  - info: admin.0 (1790) ==> Connected system.user.admin from ::ffff:192.168.178.54
                2023-03-19 20:05:36.615  - info: admin.0 (1790) <== Disconnect system.user.admin from ::ffff:192.168.178.54
                2023-03-19 20:07:20.901  - info: admin.0 (1790) <== Disconnect system.user.admin from ::ffff:192.168.178.54 admin
                Summary:
                                     v.2023-01-02
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     0
                Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                        /usr/bin/npm            8.19.3
                                        /usr/bin/npx            8.19.3
                ioBroker Core:          js-controller           4.0.24
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Status admin:
                Pending iob updates:    3
                Objects:                1290
                States:                 1005
                6.7M    /opt/iobroker/iobroker-data/states.jsonl
                • I Intruminator
                  In Detail:
                  Skript v.2023-01-02
                  *** BASE SYSTEM ***
                  Docker:         false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=raspbian
                  ID_LIKE=debian
                  CPU threads: 4
                  CET +0100
                  Europe/Berlin
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                            921 M total memory
                            555 M used memory
                            617 M active memory
                            156 M free memory
                             19 M buffer memory
                            190 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  Messages in dmesg:
                  /var:
                  1.5G    /var/
                  616M    /var/lib
                  429M    /var/cache
                  /usr/bin/npm            8.19.3
                  /usr/bin/npx            8.19.3
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        1290
                  States:         1005
                  Pending Updates: 0
                  Summary:
                                       v.2023-01-02
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            8.19.3
                                          /usr/bin/npx            8.19.3
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Status admin:
                  Objects:                1290
                  States:                 1005
                  @intruminator
                  Fahr die Kiste IMMER ordentlich herunter! Dann zwebröselst du dir auch nicht (so schnell) dein Dateisystem wie hier zusehen.
                  • I Intruminator
                    In Detail:
                    Skript v.2023-01-02
                    *** BASE SYSTEM ***
                    Docker:         false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                    CET +0100
                    Europe/Berlin
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                              921 M total memory
                              555 M used memory
                              617 M active memory
                              156 M free memory
                               19 M buffer memory
                              190 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    *** FILESYSTEM ***
                    Messages in dmesg:
                    /var:
                    1.5G    /var/
                    616M    /var/lib
                    429M    /var/cache
                    /usr/bin/npm            8.19.3
                    /usr/bin/npx            8.19.3
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        1290
                    States:         1005
                    Pending Updates: 0
                    Summary:
                                         v.2023-01-02
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            8.19.3
                                            /usr/bin/npx            8.19.3
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Status admin:
                    Objects:                1290
                    States:                 1005
                    @intruminator
                    Und dann wirst du das ausführen müssen:
                    https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
                    Anschließend
                    iob update
                    iob upgrade all
                    Und schau was da an Instanzen noch entbehrlich ist. Der discovery-Adapter braucht z.B. eher nicht laufen.
                    • GarganoG Offline
                      GarganoG Offline
                      Gargano
                      Jetzt habe ich auch das Problem. .Javasript bleibt rot und bringt Fehlermeldung mit suncalc2:
                      Was hab ich gemacht :
                      apt-update
                      apt-upgrade
                      Nach dem Reboot bleiben dann die Javascript Instanzen rot. (Ging vor dem update)
                      Dann in Putty:
                      cd /opt/iobroker/node_modules/iobroker.javascript
                      bzw.
                      npm install --omit=dev
                      Hat aber nichts gebracht.
                      host.raspberrypi
                      2023-04-01 13:47:41.536	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi
                      2023-04-01 13:47:41.535	error	Caught by controller[0]: Node.js v18.15.0
                      host.raspberrypi
                      2023-04-01 13:47:41.535	error	Caught by controller[0]: }
                      host.raspberrypi
                      2023-04-01 13:47:41.534	error	Caught by controller[0]: requestPath: 'suncalc2'
                      host.raspberrypi
                      2023-04-01 13:47:41.521	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/package.json',
                      host.raspberrypi
                      2023-04-01 13:47:41.520	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                      host.raspberrypi
                      2023-04-01 13:47:41.519	error	Caught by controller[0]: {
                      host.raspberrypi
                      2023-04-01 13:47:41.519	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
                      host.raspberrypi
                      2023-04-01 13:47:41.518	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      host.raspberrypi
                      2023-04-01 13:47:41.517	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:958:12)
                      host.raspberrypi
                      2023-04-01 13:47:41.517	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
                      host.raspberrypi
                      2023-04-01 13:47:41.516	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                      host.raspberrypi
                      2023-04-01 13:47:41.515	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
                      host.raspberrypi
                      2023-04-01 13:47:41.514	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
                      host.raspberrypi
                      2023-04-01 13:47:41.510	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
                      host.raspberrypi
                      2023-04-01 13:47:41.509	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
                      host.raspberrypi
                      2023-04-01 13:47:41.508	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:920:27)
                      host.raspberrypi
                      2023-04-01 13:47:41.507	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1061:27)
                      host.raspberrypi
                      2023-04-01 13:47:41.506	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:678:18)
                      host.raspberrypi
                      2023-04-01 13:47:41.506	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:436:19)
                      host.raspberrypi
                      2023-04-01 13:47:41.505	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/suncalc2.js'. Please verify that the package.json has a valid "main" entry
                      host.raspberrypi
                      2023-04-01 13:47:41.504	error	Caught by controller[0]: ^
                      host.raspberrypi
                      2023-04-01 13:47:41.501	error	Caught by controller[0]: throw err;
                      host.raspberrypi
                      2023-04-01 13:47:41.501	error	Caught by controller[0]: node:internal/modules/cjs/loader:444
                      iob diag :
                      2023-04-01 13:49:40.349  - error: host.raspberrypi Caught by controller[0]:       ^
                      2023-04-01 13:49:40.350  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/o                                                 pt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/suncalc2.js'. Please verify that the p                                                 ackage.json has a valid "main" entry
                      2023-04-01 13:49:40.351  - error: host.raspberrypi Caught by controller[0]:     at tryPackage (node:inter                                                 nal/modules/cjs/loader:436:19)
                      2023-04-01 13:49:40.352  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._findP                                                 ath (node:internal/modules/cjs/loader:678:18)
                      2023-04-01 13:49:40.352  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resol                                                 veFilename (node:internal/modules/cjs/loader:1061:27)
                      2023-04-01 13:49:40.353  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load                                                  (node:internal/modules/cjs/loader:920:27)
                      2023-04-01 13:49:40.353  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:i                                                 nternal/modules/cjs/loader:1141:19)
                      2023-04-01 13:49:40.355  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal                                                 /modules/cjs/helpers:110:18)
                      2023-04-01 13:49:40.355  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/o                                                 pt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
                      2023-04-01 13:49:40.356  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:                                                 internal/modules/cjs/loader:1254:14)
                      2023-04-01 13:49:40.356  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensi                                                 ons..js (node:internal/modules/cjs/loader:1308:10)
                      2023-04-01 13:49:40.357  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:inte                                                 rnal/modules/cjs/loader:1117:32)
                      2023-04-01 13:49:40.358  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load                                                  (node:internal/modules/cjs/loader:958:12)
                      2023-04-01 13:49:40.358  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEn                                                 tryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      2023-04-01 13:49:40.359  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run                                                 _main_module:23:47
                      2023-04-01 13:49:40.359  - error: host.raspberrypi Caught by controller[0]:  {
                      2023-04-01 13:49:40.360  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2023-04-01 13:49:40.360  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_m                                                 odules/iobroker.javascript/node_modules/suncalc2/package.json',
                      2023-04-01 13:49:40.361  - error: host.raspberrypi Caught by controller[0]:   requestPath: 'suncalc2'
                      2023-04-01 13:49:40.361  - error: host.raspberrypi Caught by controller[0]: }
                      2023-04-01 13:49:40.362  - error: host.raspberrypi Caught by controller[0]: Node.js v18.15.0
                      2023-04-01 13:49:40.363  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with c                                                 ode 1 (JS_CONTROLLER_STOPPED)
                      2023-04-01 13:49:40.363  - info: host.raspberrypi Rebuild for adapter system.adapter.javascript.0 not suc                                                 cessful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in ada                                                 pter directory manually.
                      2023-04-01 13:50:00.075  - info: host.raspberrypi instance system.adapter.meteoalarm.0 started with pid 5                                                 922
                      2023-04-01 13:50:05.733  - info: host.raspberrypi instance system.adapter.meteoalarm.0 terminated with co                                                 de 11 (ADAPTER_REQUESTED_TERMINATION)
                      iob diag summary :
                                           v.2023-01-02
                      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     1
                      Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                                              /usr/bin/node           v18.15.0
                                              /usr/bin/npm            9.5.0
                                              /usr/bin/npx            9.5.0
                                              admin                   6.4.3
                      At least one iobroker host is running.
                      Objects type: redis
                      States  type: redis
                      Status admin:
                      Pending iob updates:    1
                      Active repo(s): Beta (latest)
                      Objects:                20397
                      States:                 18713
                      5.2M    /opt/iobroker/iobroker-data/objects.json.bak
                      40K     /opt/iobroker/iobroker-data/states.json.bak
                      • GarganoG Gargano
                        apt-update
                        apt-upgrade
                        Dann in Putty:
                        bzw.
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        iob diag :
                        iob diag summary :
                                             v.2023-01-02
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.5.0
                                                /usr/bin/npx            9.5.0
                                                admin                   6.4.3
                        Objects type: redis
                        States  type: redis
                        Status admin:
                        Objects:                20397
                        States:                 18713
                        @gargano sagte in Instanz - Javascript bleibt rot:
                        Mit
                        sudo apt update
                        sudo apt full-upgrade
                        wird ein Schuh draus.
                        iob upgrade javascript@7.0.3
                        sagt?
                        Denn eigentlich ist das eine Dependency von javascript:
                        echad@chet:/opt/iobroker $ npm ls suncalc2
                        iobroker.inst@3.0.0 /opt/iobroker
                        └─┬ iobroker.javascript@7.0.3
                          └── suncalc2@1.8.1
                        Tip am Rande: Bitte zieh das Fenster des Terminals so breit wie möglich. Oder nutze ein Terminalprogramm das besser mit Zeilenumbrüchen umgehen kann als puTTY.
                        GarganoG 1 Antwort Letzte Antwort
                          Mit
                          sudo apt update
                          sagt?
                            └── suncalc2@1.8.1
                          GarganoG Offline
                          GarganoG Offline
                          Gargano
                          @thomas-braun Tatsächlich ist alles wieder da, danke.
                          Aber eigentlich habe ich gelernt, daß sudo böse ist :-))
                          • GarganoG Gargano
                            Stimmt. Wenn es für Dinge verwendet wird, die auch ohne sudo funktionieren.
                            Ein apt update und apt full-upgrade funktionieren aber nur mit root-Rechten. Darf ja nicht jeder Heini am System herumschrauben.
                            • GarganoG Gargano
                              ... in Verbindung mit Befehlen die mit iobroker... oder npm... beginnen.
                                GarganoG Offline
                                GarganoG Offline
                                Gargano
                                @thomas-braun again what learned....
                                • GarganoG Gargano
                                  @gargano
                                  Ich sollte einen VHS-Kurs zu 'Linux' anbieten...
