  4. Test für mihome-vacuum 3.10.x
    6.7k
74 Beiträge 20 Kommentatoren 12.1k Aufrufe 22 Beobachtet
  • B BamBam89
    @dirkhe
    Der Log ist entstanden, als der S5 gesaugt hat.
    aktueller Log: (saugt gerade)
    mihome-vacuum.0
    2023-02-23 18:54:16.376	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f7a847ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2023-02-23 18:54:10.918	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":120}
    mihome-vacuum.0
    2023-02-23 18:54:10.912	debug	Message= {"id":120,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2023-02-23 18:54:10.911	debug	MIIO RECIVE: {"result":[100],"id":119}
    mihome-vacuum.0
    2023-02-23 18:54:10.902	debug	Message= {"id":119,"method":"get_sound_volume"}
    mihome-vacuum.0
    2023-02-23 18:54:10.837	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"b0:f2:08:c7:6e:83","rssi":-53},"id":118}
    mihome-vacuum.0
    2023-02-23 18:54:10.820	debug	Message= {"id":118,"method":"get_network_info"}
    mihome-vacuum.0
    2023-02-23 18:54:10.819	debug	setGetStatus {"msg_ver":3,"msg_seq":3966,"state":5,"battery":95,"clean_time":49,"clean_area":1210000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2023-02-23 18:54:10.818	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":3966,"state":5,"battery":95,"clean_time":49,"clean_area":1210000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":117}
    mihome-vacuum.0
    2023-02-23 18:54:10.363	debug	Message= {"id":117,"method":"get_status"}
    mihome-vacuum.0
    2023-02-23 18:54:10.362	debug	get params for stock Vacuum
    mihome-vacuum.0
    2023-02-23 18:54:06.370	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f7a83dffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2023-02-23 18:54:00.282	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":116}
    mihome-vacuum.0
    2023-02-23 18:54:00.275	debug	Message= {"id":116,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2023-02-23 18:54:00.274	debug	MIIO RECIVE: {"result":[100],"id":115}
    mihome-vacuum.0
    2023-02-23 18:54:00.267	debug	Message= {"id":115,"method":"get_sound_volume"}
    mihome-vacuum.0
    2023-02-23 18:54:00.102	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"b0:f2:08:c7:6e:83","rssi":-58},"id":114}
    mihome-vacuum.0
    2023-02-23 18:54:00.081	debug	Message= {"id":114,"method":"get_network_info"}
    mihome-vacuum.0
    2023-02-23 18:54:00.080	debug	setGetStatus {"msg_ver":3,"msg_seq":3965,"state":5,"battery":95,"clean_time":38,"clean_area":847500,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2023-02-23 18:54:00.079	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":3965,"state":5,"battery":95,"clean_time":38,"clean_area":847500,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":113}
    mihome-vacuum.0
    2023-02-23 18:54:00.072	debug	Message= {"id":113,"method":"get_status"}
    mihome-vacuum.0
    2023-02-23 18:54:00.071	debug	get params for stock Vacuum
    Hier sieht man das der Sauger gestartet wurde:
    mihome-vacuum.0
    2023-02-23 18:53:19.834	info	trigger cleaning all
    D Nicht stören
    D Nicht stören
    dirkhe
    @bambam89 er ruft aber keine karte ab, entweder in den einstellungen den haken nivgt gesetzt oder canvas ist nicht verfügbar
      michael 1975
      Zeit gestern verbindet sich mein Sauger S7max unltra nicht mehr adapter bleibt gelb
      kann mir jemand helfen
      • D dirkhe
        @jb_sullivan du kannst cleanmap.mapURL' nehmen, der lefert dir eine Url auf die Map, die kannst du dann einfach in ein image src packen
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        @dirkheDa ich keine Vis mehr nutze sondern das Node Red Dashboard, habe ich Probleme mit der Einbindung der Karte
        Sobald ich die cleanmap.mapUrl mit der Iobroker in Node verbinde hängt sich das ganze System auf.
        Oder mache ich hier einen Fehler und ich muss nur die Url, welche mir im Browser komplett angezeigt wird, nur in die template node packen?
        So geht es jedenfalls nicht
        Mit besten Grüßen
        Andy
        • D Nicht stören
          D Nicht stören
          dirkhe
          @damrak2022 das kann dir leider nicht beantworten, in den einem datenpunkt steht halt eine url, relativ zum internen webserver, in dem anderen steht das img halt als data string. Was du brauchst, mußt du halt selber wissen.
          • D dirkhe
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            @dirkhe Wenn ich aber meine Url:
            http://192.168.178.24:8082/mihome-vacuum.0.cleanmap.mapURL
            im Browser aufrufe, sollte er mir doch eigentlich die Karte anzeigen, oder?
            Bei mir steht dann aber lediglich: File not found:{}
            Mit besten Grüßen
            Andy
            • Damrak2022D Damrak2022
              D Nicht stören
              D Nicht stören
              dirkhe
              schrieb am zuletzt editiert von dirkhe
              @damrak2022 nein, dh musst den inhalt des datenpunktes hinter die ip + port hängen
              • D dirkhe
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                @dirkhe Wenn ich das so mache
                http://192.168.178.24:8082/mihome-vacuum.0.cleanmap.mapURL/mihome-vacuum.0.userfiles/actualMap.png
                bekomme ich das als Ergebnis:
                Kann das sein das für die Karte zwingend Canvas installiert sein muss Ich hatte da nämlich mal ein Problem und da wurde mir geraten es wegzulassen.
                Mit besten Grüßen
                Andy
                Thomas BraunT D 2 Antworten Letzte Antwort
                  @damrak2022 sagte in Test für mihome-vacuum 3.9.x:
                  Ja.
                    Ja.
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    @thomas-braun Okay, dann werde ich nochmal versuchen eine korrekte Canvas Installation nach der Beschreibung des mihome Adapters hinzubekommen.
                    Mit besten Grüßen
                    Andy
                      @damrak2022
                      Die erforderlichen Pakete bringt ein
                      iob fix
                      auf den Rechner.
                        D Nicht stören
                        D Nicht stören
                        dirkhe
                        @damrak2022
                        http://192.168.178.24:8082/mihome-vacuum.0.userfiles/actualMap.png
                          @damrak2022
                          iob fix
                          auf den Rechner.
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          @thomas-braun Das habe ich durchgeführt. Wie prüfe ich das nun alles korrekt ist?
                          pi@homebridge:~ $ iob fix
                          library: loaded
                          Library version=2022-12-09
                          ioBroker or some processes are still running:
                           io.admin.0
                           io.history.0
                           io.javascript.0
                           io.scenes.0
                           io.influxdb.0
                           io.pushover.0
                           io.ham.0
                           io.ping.0
                           io.rpi2.0
                           io.shelly.0
                           io.geofency.0
                           io.hue.0
                           io.zigbee.0
                           io.discovery.0
                           io.alexa2.0
                           io.backitup.0
                           io.web.0
                           io.info.0
                           io.snmp.0
                           io.upnp.0
                           io.iot.0
                           io.withings.0
                           io.twinkly.0
                          Please stop them first and try again!
                          pi@homebridge:~ $ iobroker stop
                          library: loaded
                              Welcome to the ioBroker installation fixer!
                              Script version: 2022-12-22
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/4)
                          OK:1 http://deb.debian.org/debian bullseye InRelease
                          Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                          Holen:3 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                          OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                          OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                          OK:6 https://download.docker.com/linux/debian bullseye InRelease
                          Holen:7 https://apt.grafana.com stable InRelease [5.984 B]
                          OK:8 https://repos.influxdata.com/debian stable InRelease
                          OK:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                          Es wurden 98,4 kB in 7 s geholt (14,0 kB/s).
                          Installed gcc-c++
                              Checking ioBroker user and directory permissions (2/4)
                              Database maintenance (3/4)
                          Checking for uncompressed JSONL databases... This might take a while!
                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                          Compressed 2 JSONL files. Done
                              Checking autostart (4/4)
                          Enabling autostart...
                          Autostart enabled!
                              Your installation was fixed successfully
                              Run iobroker start to start ioBroker again!
                          pi@homebridge:~ $ iobroker start
                          pi@homebridge:~ $
                          Mit besten Grüßen
                          Andy
                          • Thomas BraunT Online
                            @damrak2022
                            apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                            muss zu jedem Paket sagen das es installiert ist und
                            cd /opt/iobroker
                            npm ls canvas
                            spuckt sowas aus:
                            echad@chet:/opt/iobroker $ npm ls canvas
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├─┬ iobroker.echarts@1.4.13
                            │ ├── canvas@2.11.0
                            │ └─┬ jsdom@21.1.1
                            │   └── canvas@2.11.0 deduped
                            ├─┬ iobroker.iot@1.14.5 (git+ssh://git@github.com/ioBroker/ioBroker.iot.git#c4f7c5139d48613a655453aed737e9694843ccd4)
                            ├─┬ iobroker.mihome-vacuum@3.9.5
                            └─┬ iobroker.parcel@0.0.25
                              └─┬ jsdom@20.0.3
                              @damrak2022
                              cd /opt/iobroker
                              npm ls canvas
                              spuckt sowas aus:
                              │ ├── canvas@2.11.0
                              │ └─┬ jsdom@21.1.1
                                └─┬ jsdom@20.0.3
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              @thomas-braun sagte in Test für mihome-vacuum 3.9.x:
                              npm ls canvas
                              Ich denke, das sieht so aus wie es sein soll
                              pi@homebridge:~ $ apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                              build-essential:
                                Installiert:           12.9
                                Installationskandidat: 12.9
                                Versionstabelle:
                               *** 12.9 500
                                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                              libcairo2-dev:
                                Installiert:           1.16.0-5+rpt1
                                Installationskandidat: 1.16.0-5+rpt1
                                Versionstabelle:
                               *** 1.16.0-5+rpt1 500
                                      500 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages
                                   1.16.0-5 500
                              libpango1.0-dev:
                                Installiert:           1.46.2-3
                                Installationskandidat: 1.46.2-3
                                Versionstabelle:
                               *** 1.46.2-3 500
                              libjpeg-dev:
                                Installiert:           1:2.0.6-4
                                Installationskandidat: 1:2.0.6-4
                                Versionstabelle:
                               *** 1:2.0.6-4 500
                              libgif-dev:
                                Installiert:           5.1.9-2
                                Installationskandidat: 5.1.9-2
                                Versionstabelle:
                               *** 5.1.9-2 500
                              librsvg2-dev:
                                Installiert:           2.50.3+dfsg-1
                                Installationskandidat: 2.50.3+dfsg-1
                                Versionstabelle:
                               *** 2.50.3+dfsg-1 500
                              pi@homebridge:~ $ cd /opt/iobroker
                              pi@homebridge:/opt/iobroker $ npm ls canvas
                              ├─┬ iobroker.iot@1.14.2
                              │ ├── canvas@2.11.0
                              │ └─┬ jsdom@20.0.3
                              └─┬ iobroker.mihome-vacuum@3.9.5
                              Mit besten Grüßen
                              Andy
                                npm ls canvas
                                build-essential:
                                  Installiert:           12.9
                                  Versionstabelle:
                                 *** 12.9 500
                                libcairo2-dev:
                                  Versionstabelle:
                                     1.16.0-5 500
                                libpango1.0-dev:
                                  Versionstabelle:
                                 *** 1.46.2-3 500
                                libjpeg-dev:
                                  Versionstabelle:
                                 *** 1:2.0.6-4 500
                                libgif-dev:
                                  Versionstabelle:
                                 *** 5.1.9-2 500
                                librsvg2-dev:
                                  Versionstabelle:
                                │ ├── canvas@2.11.0
                                │ └─┬ jsdom@20.0.3
                                @damrak2022
                                Jau, schaut richtig aus.
                                • D dirkhe
                                  @damrak2022
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  @dirkhe Bis jetzt liefert mir die Url
                                  Doch Karte ist da - Danke
                                  Mit besten Grüßen
                                  Andy
                                    @damrak2022
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    @thomas-braun Ich habe die Karte zwar eingebunden, allerdings wird mir der die Position des Saugers noch nicht in Echtzeit dargestellt.
                                    Mit besten Grüßen
                                    Andy
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @damrak2022 Wenn Du die base64 Daten direkt aus dem Datenpunkt triggern lässt dann sollte die Karte auch automatisch aktualisiert werden, sobald sich das Bild ändert:
                                      Ich habs mal in den anderen Thread gepostet: https://forum.iobroker.net/post/968990
                                      • mickymM mickym
                                        D Nicht stören
                                        D Nicht stören
                                        dirkhe
                                        es gibt mal wieder eine neue Test version: 3.10.0
                                        • check also stockcommands in onMessage
                                        • add feature waterbox level #755
                                          Sneaker75
                                          Ich habe mein System (ioBroker auf RaspberryPi4) mit dieser Anleitung auf NodeJS 18 aktualisiert. Soweit hat alles gut geklappt, bis auf das ich im Protokoll immer eine Warnung vom mihome-vacuum-Adapter bekomme
                                          CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                                          Die Steuerung des Roborock S5 funktioniert einwandfrei wie bisher, aber die Karte wird nicht mehr aktualisiert in der VIS. Es wird eine alte Karte angezeigt - die vor dem Update auf Node.JS 18.
                                          Zum Zeitpunkt des Updates hatte ich den Adapter auf der Version 3.4.2 installiert. Als ich nach dem Update den Fehler mit der Karte bemerkt habe, habe ich den Adapter auf 3.9.5 aktualisiert. Das hat aber leider keine Besserung bzgl. des Kartenproblems ergeben.
                                          Mein System:
                                          Debian 10 Buster
                                          js-controller: 4.0.23
                                          NodeJS: 18.15.0
                                          NPM: 9.5.0
                                          Meiner Meinung nach ist Canvas installiert.
                                          pi@raspberrypi4-iob:~ $ cd /opt/iobroker/
                                          pi@raspberrypi4-iob:/opt/iobroker $ npm list canvas
                                          iobroker.inst@2.0.3 /opt/iobroker
                                          ├── canvas@2.11.2
                                          │ ├── canvas@2.11.2 deduped
                                          │ └─┬ jsdom@20.0.3
                                          │   └── canvas@2.11.2 deduped
                                          └─┬ iobroker.parcel@0.0.25 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#401a3aef0407456c6f18419a25517e9d26fab685)
                                            └─┬ jsdom@21.1.1
                                          Was kann ich machen?
