  4. Test für mihome-vacuum 3.10.x
    6.7k
74 Beiträge 20 Kommentatoren 12.1k Aufrufe 22 Beobachtet
  • D dirkhe
    @bambam89 Also dann schick mal dein Log (debug), da drin solltest du sehen, ob er deine Karte updatet oder nicht. Wie oft er das macht, kannst du auch einstellen.
    BamBam89
    @dirkhe
    hier mal ein Auszug aus den Logs.
    mihome-vacuum.0
    2023-02-23 08:49:08.120	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":70}
    mihome-vacuum.0
    2023-02-23 08:49:08.109	debug	Message= {"id":70,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2023-02-23 08:49:08.108	debug	MIIO RECIVE: {"result":[100],"id":69}
    mihome-vacuum.0
    2023-02-23 08:49:08.099	debug	Message= {"id":69,"method":"get_sound_volume"}
    mihome-vacuum.0
    2023-02-23 08:49:08.069	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-67},"id":68}
    mihome-vacuum.0
    2023-02-23 08:49:08.044	debug	Message= {"id":68,"method":"get_network_info"}
    mihome-vacuum.0
    2023-02-23 08:49:08.042	debug	setGetStatus {"msg_ver":3,"msg_seq":1888,"state":18,"battery":99,"clean_time":108,"clean_area":3117500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2023-02-23 08:49:08.041	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":1888,"state":18,"battery":99,"clean_time":108,"clean_area":3117500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":67}
    mihome-vacuum.0
    2023-02-23 08:49:08.032	debug	Message= {"id":67,"method":"get_status"}
    mihome-vacuum.0
    2023-02-23 08:49:08.032	debug	get params for stock Vacuum
    mihome-vacuum.0
    2023-02-23 08:49:01.800	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.0
    2023-02-23 08:49:01.799	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f71a6effffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2023-02-23 08:48:57.991	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":66}
    mihome-vacuum.0
    2023-02-23 08:48:57.981	debug	Message= {"id":66,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2023-02-23 08:48:57.979	debug	MIIO RECIVE: {"result":[100],"id":65}
    mihome-vacuum.0
    2023-02-23 08:48:57.968	debug	Message= {"id":65,"method":"get_sound_volume"}
    mihome-vacuum.0
    2023-02-23 08:48:57.889	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-67},"id":64}
    mihome-vacuum.0
    2023-02-23 08:48:57.858	debug	Message= {"id":64,"method":"get_network_info"}
    mihome-vacuum.0
    2023-02-23 08:48:57.855	debug	setGetStatus {"msg_ver":3,"msg_seq":1887,"state":18,"battery":99,"clean_time":96,"clean_area":2742500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2023-02-23 08:48:57.853	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":1887,"state":18,"battery":99,"clean_time":96,"clean_area":2742500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":63}
    mihome-vacuum.0
    2023-02-23 08:48:57.842	debug	Message= {"id":63,"method":"get_status"}
    mihome-vacuum.0
    2023-02-23 08:48:57.841	debug	get params for stock Vacuum
    mihome-vacuum.0
    2023-02-23 08:48:51.795	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.0
    2023-02-23 08:48:51.794	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f71a64ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2023-02-23 08:48:47.788	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":62}
    mihome-vacuum.0
    2023-02-23 08:48:47.779	debug	Message= {"id":62,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2023-02-23 08:48:47.777	debug	MIIO RECIVE: {"result":[100],"id":61}
    mihome-vacuum.0
    2023-02-23 08:48:47.769	debug	Message= {"id":61,"method":"get_sound_volume"}
    mihome-vacuum.0
    2023-02-23 08:48:47.707	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-62},"id":60}
    mihome-vacuum.0
    2023-02-23 08:48:47.656	debug	Message= {"id":60,"method":"get_network_info"}
    mihome-vacuum.0
    2023-02-23 08:48:47.654	debug	setGetStatus {"msg_ver":3,"msg_seq":1886,"state":18,"battery":99,"clean_time":90,"clean_area":2392500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
    mihome-vacuum.0
    2023-02-23 08:48:47.654	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":1886,"state":18,"battery":99,"clean_time":90,"clean_area":2392500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":59}
    mihome-vacuum.0
    2023-02-23 08:48:47.629	debug	Message= {"id":59,"method":"get_status"}
    mihome-vacuum.0
    2023-02-23 08:48:47.629	debug	get params for stock Vacuum
    mihome-vacuum.0
    2023-02-23 08:48:40.655	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.0
    2023-02-23 08:48:40.655	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f71a59ffffffffffffffffffffffffffffffff
    mihome-vacuum.0
    2023-02-23 08:48:37.502	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":58}
    mihome-vacuum.0
    2023-02-23 08:48:37.492	debug	Message= {"id":58,"method":"get_carpet_mode"}
    mihome-vacuum.0
    2023-02-23 08:48:37.491	debug	MIIO RECIVE: {"result":[100],"id":57}
    mihome-vacuum.0
    2023-02-23 08:48:37.483	debug	Message= {"id":57,"method":"get_sound_volume"}
    mihome-vacuum.0
    2023-02-23 08:48:37.219	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-62},"id":56}
    mihome-vacuum.0
    2023-02-23 08:48:37.189	debug	Message= {"id":56,"method":"get_network_info"}
    mihome-vacuum.0
    2023-02-23 08:48:37.188	debug	setGetStatus {"msg_ver":3,"msg_seq":1885,"state":18,"battery":99,"clean_time":79,"clean_area":1992500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
    Der Intervall steht auf 2 Sekunden:
    • D Nicht stören
      D Nicht stören
      dirkhe
      @bambam89 Ähhh, da saugt er doch gar nicht. Du solltest schon zu der Zeit das log schicken, wo er saugt. Da müsste dann drin stehen, dass er eine neue Karte bekommt. Wenn du den Adapter startetest steht aber nicht von canvas Problemen?
      • D dirkhe
        BamBam89
        @dirkhe
        Der Log ist entstanden, als der S5 gesaugt hat.
        aktueller Log: (saugt gerade)
        mihome-vacuum.0
        2023-02-23 18:54:16.376	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f7a847ffffffffffffffffffffffffffffffff
        mihome-vacuum.0
        2023-02-23 18:54:10.918	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":120}
        mihome-vacuum.0
        2023-02-23 18:54:10.912	debug	Message= {"id":120,"method":"get_carpet_mode"}
        mihome-vacuum.0
        2023-02-23 18:54:10.911	debug	MIIO RECIVE: {"result":[100],"id":119}
        mihome-vacuum.0
        2023-02-23 18:54:10.902	debug	Message= {"id":119,"method":"get_sound_volume"}
        mihome-vacuum.0
        2023-02-23 18:54:10.837	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"b0:f2:08:c7:6e:83","rssi":-53},"id":118}
        mihome-vacuum.0
        2023-02-23 18:54:10.820	debug	Message= {"id":118,"method":"get_network_info"}
        mihome-vacuum.0
        2023-02-23 18:54:10.819	debug	setGetStatus {"msg_ver":3,"msg_seq":3966,"state":5,"battery":95,"clean_time":49,"clean_area":1210000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
        mihome-vacuum.0
        2023-02-23 18:54:10.818	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":3966,"state":5,"battery":95,"clean_time":49,"clean_area":1210000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":117}
        mihome-vacuum.0
        2023-02-23 18:54:10.363	debug	Message= {"id":117,"method":"get_status"}
        mihome-vacuum.0
        2023-02-23 18:54:10.362	debug	get params for stock Vacuum
        mihome-vacuum.0
        2023-02-23 18:54:06.370	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f7a83dffffffffffffffffffffffffffffffff
        mihome-vacuum.0
        2023-02-23 18:54:00.282	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":116}
        mihome-vacuum.0
        2023-02-23 18:54:00.275	debug	Message= {"id":116,"method":"get_carpet_mode"}
        mihome-vacuum.0
        2023-02-23 18:54:00.274	debug	MIIO RECIVE: {"result":[100],"id":115}
        mihome-vacuum.0
        2023-02-23 18:54:00.267	debug	Message= {"id":115,"method":"get_sound_volume"}
        mihome-vacuum.0
        2023-02-23 18:54:00.102	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"b0:f2:08:c7:6e:83","rssi":-58},"id":114}
        mihome-vacuum.0
        2023-02-23 18:54:00.081	debug	Message= {"id":114,"method":"get_network_info"}
        mihome-vacuum.0
        2023-02-23 18:54:00.080	debug	setGetStatus {"msg_ver":3,"msg_seq":3965,"state":5,"battery":95,"clean_time":38,"clean_area":847500,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
        mihome-vacuum.0
        2023-02-23 18:54:00.079	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":3965,"state":5,"battery":95,"clean_time":38,"clean_area":847500,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":113}
        mihome-vacuum.0
        2023-02-23 18:54:00.072	debug	Message= {"id":113,"method":"get_status"}
        mihome-vacuum.0
        2023-02-23 18:54:00.071	debug	get params for stock Vacuum
        Hier sieht man das der Sauger gestartet wurde:
        mihome-vacuum.0
        2023-02-23 18:53:19.834	info	trigger cleaning all
        • B BamBam89
          @dirkhe
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          mihome-vacuum.0
          D Nicht stören
          D Nicht stören
          dirkhe
          @bambam89 er ruft aber keine karte ab, entweder in den einstellungen den haken nivgt gesetzt oder canvas ist nicht verfügbar
            michael 1975
            Zeit gestern verbindet sich mein Sauger S7max unltra nicht mehr adapter bleibt gelb
            kann mir jemand helfen
            • D dirkhe
              @jb_sullivan du kannst cleanmap.mapURL' nehmen, der lefert dir eine Url auf die Map, die kannst du dann einfach in ein image src packen
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              @dirkheDa ich keine Vis mehr nutze sondern das Node Red Dashboard, habe ich Probleme mit der Einbindung der Karte
              Sobald ich die cleanmap.mapUrl mit der Iobroker in Node verbinde hängt sich das ganze System auf.
              Oder mache ich hier einen Fehler und ich muss nur die Url, welche mir im Browser komplett angezeigt wird, nur in die template node packen?
              So geht es jedenfalls nicht
              Mit besten Grüßen
              Andy
              • D Nicht stören
                D Nicht stören
                dirkhe
                @damrak2022 das kann dir leider nicht beantworten, in den einem datenpunkt steht halt eine url, relativ zum internen webserver, in dem anderen steht das img halt als data string. Was du brauchst, mußt du halt selber wissen.
                • D dirkhe
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  @dirkhe Wenn ich aber meine Url:
                  http://192.168.178.24:8082/mihome-vacuum.0.cleanmap.mapURL
                  im Browser aufrufe, sollte er mir doch eigentlich die Karte anzeigen, oder?
                  Bei mir steht dann aber lediglich: File not found:{}
                  Mit besten Grüßen
                  Andy
                  • Damrak2022D Damrak2022
                    D Nicht stören
                    D Nicht stören
                    dirkhe
                    schrieb am zuletzt editiert von dirkhe
                    @damrak2022 nein, dh musst den inhalt des datenpunktes hinter die ip + port hängen
                    • D dirkhe
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      @dirkhe Wenn ich das so mache
                      http://192.168.178.24:8082/mihome-vacuum.0.cleanmap.mapURL/mihome-vacuum.0.userfiles/actualMap.png
                      bekomme ich das als Ergebnis:
                      Kann das sein das für die Karte zwingend Canvas installiert sein muss Ich hatte da nämlich mal ein Problem und da wurde mir geraten es wegzulassen.
                      Mit besten Grüßen
                      Andy
                      Thomas BraunT D 2 Antworten Letzte Antwort
                        @damrak2022 sagte in Test für mihome-vacuum 3.9.x:
                        Ja.
                          Ja.
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          @thomas-braun Okay, dann werde ich nochmal versuchen eine korrekte Canvas Installation nach der Beschreibung des mihome Adapters hinzubekommen.
                          Mit besten Grüßen
                          Andy
                            @damrak2022
                            Die erforderlichen Pakete bringt ein
                            iob fix
                            auf den Rechner.
                              D Nicht stören
                              D Nicht stören
                              dirkhe
                              @damrak2022
                              http://192.168.178.24:8082/mihome-vacuum.0.userfiles/actualMap.png
                                @damrak2022
                                iob fix
                                auf den Rechner.
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                @thomas-braun Das habe ich durchgeführt. Wie prüfe ich das nun alles korrekt ist?
                                pi@homebridge:~ $ iob fix
                                library: loaded
                                Library version=2022-12-09
                                ioBroker or some processes are still running:
                                 io.admin.0
                                 io.history.0
                                 io.javascript.0
                                 io.scenes.0
                                 io.influxdb.0
                                 io.pushover.0
                                 io.ham.0
                                 io.ping.0
                                 io.rpi2.0
                                 io.shelly.0
                                 io.geofency.0
                                 io.hue.0
                                 io.zigbee.0
                                 io.discovery.0
                                 io.alexa2.0
                                 io.backitup.0
                                 io.web.0
                                 io.info.0
                                 io.snmp.0
                                 io.upnp.0
                                 io.iot.0
                                 io.withings.0
                                 io.twinkly.0
                                Please stop them first and try again!
                                pi@homebridge:~ $ iobroker stop
                                library: loaded
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2022-12-22
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/4)
                                OK:1 http://deb.debian.org/debian bullseye InRelease
                                Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                                Holen:3 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                                OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                OK:6 https://download.docker.com/linux/debian bullseye InRelease
                                Holen:7 https://apt.grafana.com stable InRelease [5.984 B]
                                OK:8 https://repos.influxdata.com/debian stable InRelease
                                OK:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                Es wurden 98,4 kB in 7 s geholt (14,0 kB/s).
                                Installed gcc-c++
                                    Checking ioBroker user and directory permissions (2/4)
                                    Database maintenance (3/4)
                                Checking for uncompressed JSONL databases... This might take a while!
                                Compressing /opt/iobroker/iobroker-data/states.jsonl
                                Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                Compressed 2 JSONL files. Done
                                    Checking autostart (4/4)
                                Enabling autostart...
                                Autostart enabled!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                pi@homebridge:~ $ iobroker start
                                pi@homebridge:~ $
                                Mit besten Grüßen
                                Andy
                                • Thomas BraunT Online
                                  @damrak2022
                                  apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                  muss zu jedem Paket sagen das es installiert ist und
                                  cd /opt/iobroker
                                  npm ls canvas
                                  spuckt sowas aus:
                                  echad@chet:/opt/iobroker $ npm ls canvas
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├─┬ iobroker.echarts@1.4.13
                                  │ ├── canvas@2.11.0
                                  │ └─┬ jsdom@21.1.1
                                  │   └── canvas@2.11.0 deduped
                                  ├─┬ iobroker.iot@1.14.5 (git+ssh://git@github.com/ioBroker/ioBroker.iot.git#c4f7c5139d48613a655453aed737e9694843ccd4)
                                  ├─┬ iobroker.mihome-vacuum@3.9.5
                                  └─┬ iobroker.parcel@0.0.25
                                    └─┬ jsdom@20.0.3
                                    @damrak2022
                                    cd /opt/iobroker
                                    npm ls canvas
                                    spuckt sowas aus:
                                    │ ├── canvas@2.11.0
                                    │ └─┬ jsdom@21.1.1
                                      └─┬ jsdom@20.0.3
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    @thomas-braun sagte in Test für mihome-vacuum 3.9.x:
                                    npm ls canvas
                                    Ich denke, das sieht so aus wie es sein soll
                                    pi@homebridge:~ $ apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                    build-essential:
                                      Installiert:           12.9
                                      Installationskandidat: 12.9
                                      Versionstabelle:
                                     *** 12.9 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    libcairo2-dev:
                                      Installiert:           1.16.0-5+rpt1
                                      Installationskandidat: 1.16.0-5+rpt1
                                      Versionstabelle:
                                     *** 1.16.0-5+rpt1 500
                                            500 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages
                                         1.16.0-5 500
                                    libpango1.0-dev:
                                      Installiert:           1.46.2-3
                                      Installationskandidat: 1.46.2-3
                                      Versionstabelle:
                                     *** 1.46.2-3 500
                                    libjpeg-dev:
                                      Installiert:           1:2.0.6-4
                                      Installationskandidat: 1:2.0.6-4
                                      Versionstabelle:
                                     *** 1:2.0.6-4 500
                                    libgif-dev:
                                      Installiert:           5.1.9-2
                                      Installationskandidat: 5.1.9-2
                                      Versionstabelle:
                                     *** 5.1.9-2 500
                                    librsvg2-dev:
                                      Installiert:           2.50.3+dfsg-1
                                      Installationskandidat: 2.50.3+dfsg-1
                                      Versionstabelle:
                                     *** 2.50.3+dfsg-1 500
                                    pi@homebridge:~ $ cd /opt/iobroker
                                    pi@homebridge:/opt/iobroker $ npm ls canvas
                                    ├─┬ iobroker.iot@1.14.2
                                    │ ├── canvas@2.11.0
                                    │ └─┬ jsdom@20.0.3
                                    └─┬ iobroker.mihome-vacuum@3.9.5
                                    Mit besten Grüßen
                                    Andy
                                      npm ls canvas
                                      build-essential:
                                        Installiert:           12.9
                                        Versionstabelle:
                                       *** 12.9 500
                                      libcairo2-dev:
                                        Versionstabelle:
                                           1.16.0-5 500
                                      libpango1.0-dev:
                                        Versionstabelle:
                                       *** 1.46.2-3 500
                                      libjpeg-dev:
                                        Versionstabelle:
                                       *** 1:2.0.6-4 500
                                      libgif-dev:
                                        Versionstabelle:
                                       *** 5.1.9-2 500
                                      librsvg2-dev:
                                        Versionstabelle:
                                      │ ├── canvas@2.11.0
                                      │ └─┬ jsdom@20.0.3
                                      @damrak2022
                                      Jau, schaut richtig aus.
                                      • D dirkhe
                                        @damrak2022
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        @dirkhe Bis jetzt liefert mir die Url
                                        Doch Karte ist da - Danke
                                        Mit besten Grüßen
                                        Andy
                                          @damrak2022
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          @thomas-braun Ich habe die Karte zwar eingebunden, allerdings wird mir der die Position des Saugers noch nicht in Echtzeit dargestellt.
                                          Mit besten Grüßen
                                          Andy
