  4. Alexa2 wird nicht grün
37 Beiträge 9 Kommentatoren 4.7k Aufrufe 8 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    Docker, CT oder VM?
    • M Micha487
      @wendy2702
      Hier die Ausgabe von iob diag:
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Architecture:   x86_64
      Docker:         false
      Virtualization: none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       14:14:48 up 16 days,  3:49,  1 user,  load average: 0.30, 0.36, 0.28
      CPU threads: 4
      *** Time and Time Zones ***
      Thu Mar 23 13:14:48 UTC 2023
      Thu Mar 23 14:14:48 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      michael
      /home/michael
      michael root tty sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            7.6G        2.8G        456M        3.0M        4.3G        4.6G
      Swap:           959M        298M        661M
      Total:          8.6G        3.1G        1.1G
               7604 M total memory
               2824 M used memory
               2790 M active memory
               3805 M inactive memory
                455 M free memory
                203 M buffer memory
               4121 M swap cache
                959 M total swap
                298 M used swap
                661 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     761M  3.3M  758M   1% /run
      /dev/sdc2      ext4       28G   11G   17G  39% /
      tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sdc1      vfat      480M  152K  479M   1% /boot/efi
      tmpfs          tmpfs     3.8G     0  3.8G   0% /tmp
      /dev/md0       btrfs     1.9T  465G  1.4T  25% /srv/dev-disk-by-uuid-f73f47e3-2ce2-46aa-bac7-6fb48b0f8ad7
      Messages in dmesg:
      [Tue Mar  7 10:25:24 2023] EXT4-fs (sdc2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Mar  7 10:25:26 2023] EXT4-fs (sdc2): re-mounted. Quota mode: none.
      TARGET                                                       SOURCE    FSTYPE OPTIONS
      /                                                            /dev/sdc2 ext4   rw,relatime,errors=remount-ro,stripe=8191
      |-/boot/efi                                                  /dev/sdc1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      `-/srv/dev-disk-by-uuid-f73f47e3-2ce2-46aa-bac7-6fb48b0f8ad7 /dev/md0  btrfs  rw,relatime,space_cache,subvolid=5,subvol=/
      /var:
      5.1G    /var/
      3.5G    /var/log
      2.8G    /var/log/journal/ae294c6a10a444a3b6967374bd197196
      1.1G    /var/cache/apt
      /opt/iobroker/backups:
      24M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      127M    /opt/iobroker/iobroker-data/
      87M     /opt/iobroker/iobroker-data/files
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      7.3M    /opt/iobroker/iobroker-data/objects.jsonl
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.9M    /opt/iobroker/iobroker-data/states.jsonl
      4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.15.0
      /usr/bin/node           v18.15.0
      /usr/bin/npm            9.6.2
      /usr/bin/npx            9.6.2
      nodejs:
        Installed: 18.15.0-deb-1nodesource1
        Candidate: 18.15.0-deb-1nodesource1
        Version table:
       *** 18.15.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : nas                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : nas                                      -  enabled
      + system.adapter.backitup.0               : backitup              : nas                                      -  enabled
      + system.adapter.discovery.0              : discovery             : nas                                      -  enabled
      + system.adapter.influxdb.0               : influxdb              : nas                                      -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : nas                                      -  enabled
        system.adapter.sma-em.0                 : sma-em                : nas                                      - disabled
      + system.adapter.smartmeter.0             : smartmeter            : nas                                      -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : nas                                      -  enabled
      + system.adapter.viessmann.0              : viessmann             : nas                                      -  enabled, port: 3002
        system.adapter.vis.0                    : vis                   : nas                                      -  enabled
      + system.adapter.web.0                    : web                   : nas                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.5.12   , installed 2.5.12
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "viessmann"    : 1.4.2    , installed 1.4.3
      Objects and States
      Objects:        492
      States:         400
      Get:1 file:/var/cache/openmediavault/archives  InRelease
      Ign:1 file:/var/cache/openmediavault/archives  InRelease
      Get:2 file:/var/cache/openmediavault/archives  Release
      Ign:2 file:/var/cache/openmediavault/archives  Release
      Get:3 file:/var/cache/openmediavault/archives  Packages
      Ign:3 file:/var/cache/openmediavault/archives  Packages
      Get:4 file:/var/cache/openmediavault/archives  Translation-de
      Ign:4 file:/var/cache/openmediavault/archives  Translation-de
      Get:5 file:/var/cache/openmediavault/archives  Translation-en
      Ign:5 file:/var/cache/openmediavault/archives  Translation-en
      Get:6 file:/var/cache/openmediavault/archives  Translation-de_DE
      Ign:6 file:/var/cache/openmediavault/archives  Translation-de_DE
      Hit:7 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:8 http://ftp.de.debian.org/debian bullseye InRelease
      Hit:9 https://openmediavault-plugin-developers.github.io/packages/debian shaitan InRelease
      Hit:10 https://repos.influxdata.com/debian stable InRelease
      Hit:11 http://ftp.de.debian.org/debian bullseye-updates InRelease
      Hit:12 https://packages.grafana.com/enterprise/deb stable InRelease
      Get:13 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
      Hit:14 https://repos.influxdata.com/debian bullseye InRelease
      Hit:15 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:16 https://deb.debian.org/debian bullseye-backports InRelease
      Hit:17 https://packages.openmediavault.org/public shaitan InRelease
      Fetched 43.3 kB in 4s (11.9 kB/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          927060     84090/smbd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          927061     84090/smbd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17913      775/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      113        18169      819/influxd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18081      782/nginx: master p
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13224      1/init
      tcp        0      0 127.0.0.1:40089         0.0.0.0:*               LISTEN      1003       6081088    448139/io.alexa2.0
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        17889      698/systemd-resolve
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        17895      698/systemd-resolve
      tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      0          966222     90245/vcontrold
      tcp        0      0 172.17.0.1:5357         0.0.0.0:*               LISTEN      64757      925454     84101/python3
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1003       19885      1168/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1003       14277      1168/iobroker.js-co
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16825      979/master
      tcp        0      0 192.168.178.195:5357    0.0.0.0:*               LISTEN      64757      2878240    84101/python3
      tcp6       0      0 :::445                  :::*                    LISTEN      0          927058     84090/smbd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          927059     84090/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17915      775/sshd: /usr/sbin
      tcp6       0      0 :::80                   :::*                    LISTEN      0          18082      782/nginx: master p
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13227      1/init
      tcp6       0      0 :::5355                 :::*                    LISTEN      102        17892      698/systemd-resolve
      tcp6       0      0 :::3000                 :::*                    LISTEN      114        6037867    444253/grafana
      tcp6       0      0 :::8086                 :::*                    LISTEN      113        19513      819/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1003       18553      1247/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1003       6044772    445298/io.web.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        17894      698/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          394        1/init
      udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          13882      762/chronyd
      udp        0      0 0.0.0.0:37394           0.0.0.0:*                           111        13867      722/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        13865      722/avahi-daemon: r
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        17888      698/systemd-resolve
      udp        0      0 0.0.0.0:42450           0.0.0.0:*                           64757      925450     84101/python3
      udp        0      0 0.0.0.0:38938           0.0.0.0:*                           64757      2878753    84101/python3
      udp        0      0 192.168.178.195:3702    0.0.0.0:*                           64757      2878754    84101/python3
      udp        0      0 239.255.255.250:3702    0.0.0.0:*                           64757      2878752    84101/python3
      udp        0      0 172.17.0.1:3702         0.0.0.0:*                           64757      925451     84101/python3
      udp        0      0 239.255.255.250:3702    0.0.0.0:*                           64757      925449     84101/python3
      udp6       0      0 :::49067                :::*                                111        13868      722/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          14451      1/init
      udp6       0      0 ::1:323                 :::*                                0          13883      762/chronyd
      udp6       0      0 :::5353                 :::*                                111        13866      722/avahi-daemon: r
      udp6       0      0 :::5355                 :::*                                102        17891      698/systemd-resolve
      2023-03-23 14:14:43.190  - info: smartmeter.0 (307633) Received 7 values, 3 updated
      2023-03-23 14:14:46.389  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1901,"ack":false,"time":1679577286387},"_id":457854}
      2023-03-23 14:14:47.174  - info: smartmeter.0 (307633) Received 7 values, 0 updated
      2023-03-23 14:14:49.475  - info: smartmeter.0 (307633) Received 7 values, 3 updated
      2023-03-23 14:14:52.400  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1902,"ack":false,"time":1679577292398},"_id":457855}
      2023-03-23 14:14:53.468  - info: smartmeter.0 (307633) Received 7 values, 1 updated
      2023-03-23 14:14:55.769  - info: smartmeter.0 (307633) Received 7 values, 3 updated
      2023-03-23 14:14:58.400  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1903,"ack":false,"time":1679577298399},"_id":457856}
      2023-03-23 14:14:59.754  - info: smartmeter.0 (307633) Received 7 values, 1 updated
      2023-03-23 14:15:02.036  - info: smartmeter.0 (307633) Received 7 values, 2 updated
      2023-03-23 14:15:04.398  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1904,"ack":false,"time":1679577304396},"_id":457857}
      2023-03-23 14:15:06.032  - info: smartmeter.0 (307633) Received 7 values, 1 updated
      2023-03-23 14:15:06.684  - info: smartmeter.1 (209035) Received 4 values, 0 updated
      2023-03-23 14:15:08.298  - info: smartmeter.0 (307633) Received 7 values, 3 updated
      2023-03-23 14:15:10.398  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1905,"ack":false,"time":1679577310396},"_id":457858}
      2023-03-23 14:15:12.295  - info: smartmeter.0 (307633) Received 7 values, 1 updated
      2023-03-23 14:15:14.586  - info: smartmeter.0 (307633) Received 7 values, 3 updated
      2023-03-23 14:15:16.392  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1906,"ack":false,"time":1679577316389},"_id":457859}
      2023-03-23 14:15:18.572  - info: smartmeter.0 (307633) Received 7 values, 1 updated
      2023-03-23 14:15:20.839  - info: smartmeter.0 (307633) Received 7 values, 3 updated
      2023-03-23 14:15:22.386  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1907,"ack":false,"time":1679577322384},"_id":457860}
      2023-03-23 14:15:24.830  - info: smartmeter.0 (307633) Received 7 values, 1 updated
      2023-03-23 14:15:27.139  - info: smartmeter.0 (307633) Received 7 values, 3 updated
      2023-03-23 14:15:28.397  - debug: alexa2.0 (448139) Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1908,"ack":false,"time":1679577328396},"_id":457861}
      2023-03-23 14:15:31.127  - info: smartmeter.0 (307633) Received 7 values, 0 updated
      @micha487 sagte in Alexa2 wird nicht grün:
      Die Gruppe 'root' hat bei dem User 'michael' nix zu suchen. Darüberhinaus ist der doch eh schon in 'sudo' drin.
      Lösch den Alexa2-Adapter mal und leg den neu an.
      Und schalte die Synchornisierung mit SmartHome-Geräten zunächst mal aus.
      • wendy2702W wendy2702
        Docker, CT oder VM?
        Micha487
        @wendy2702 said in Alexa2 wird nicht grün:
        Docker, CT oder VM
        Debian läuft auf meiner NAS, habe dort Debian installiert und dann OMV drauf gepackt. Deutlich später habe ich dann iobroker mit Grafana drauf gezogen im meine Geräte zu Hause etwas besser steuern zu können. Es läuft also nicht als VM oder Docker, mit dem Begriff CT kann ich aktuell leider nichts anfangen.
          Micha487
          hab die Gruppe 'root' bei dem User 'michael' entfernt entfernt.
          Den Alexa2-Adapter habe ich gelöscht und neu angelegt, hier die Ausgabe im Log:
          alexa2.0
          2023-03-23 16:48:36.322	error	Error: You can try to get the cookie manually by opening http://192.168.178.195:46821/ with your browser.
          alexa2.0
          alexa2.0
          2023-03-23 16:48:36.322	debug	Error from Alexa init: You can try to get the cookie manually by opening http://192.168.178.195:46821/ with your browser.
          alexa2.0
          2023-03-23 16:48:36.321	debug	Alexa-Remote: Error from retrieving cookies
          alexa2.0
          2023-03-23 16:48:36.321	debug	Alexa-Cookie: Proxy-Server listening on port 46821
          alexa2.0
          2023-03-23 16:48:36.307	debug	Alexa-Cookie: Proxy-Mode enabled if needed: 192.168.178.195:0 to listen on 0.0.0.0
          alexa2.0
          2023-03-23 16:48:36.307	debug	Alexa-Cookie: Use as Accept-Language: de-DE
          alexa2.0
          2023-03-23 16:48:36.307	debug	Alexa-Cookie: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36
          alexa2.0
          2023-03-23 16:48:36.307	debug	Alexa-Cookie: Use as Device-App-Name: ioBroker Alexa2
          alexa2.0
          2023-03-23 16:48:36.306	debug	Alexa-Cookie: Use as Base-Amazon-URL: amazon.com
          alexa2.0
          2023-03-23 16:48:36.306	debug	Alexa-Cookie: Use as Login-Amazon-URL: amazon.de
          alexa2.0
          2023-03-23 16:48:36.163	debug	Alexa-Remote: No cookie given, generate one
          alexa2.0
          2023-03-23 16:48:36.162	debug	Alexa-Remote: Use as Base-URL: alexa.amazon.de
          alexa2.0
          2023-03-23 16:48:36.162	debug	Alexa-Remote: Use as Login-Amazon-URL: amazon.de
          alexa2.0
          2023-03-23 16:48:36.162	debug	Alexa-Remote: Use as API User-Agent Postfix: ioBroAlexa2/3.23.2
          alexa2.0
          2023-03-23 16:48:36.161	debug	Alexa-Remote: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36
          alexa2.0
          2023-03-23 16:48:36.161	debug	Update Devices Configuration Interval: 3604s
          alexa2.0
          2023-03-23 16:48:36.160	debug	Update Device State Interval: 309s
          alexa2.0
          2023-03-23 16:48:36.160	debug	Update History Interval: 300s
          alexa2.0
          2023-03-23 16:48:36.159	info	Proxy IP not set, use first network interface (192.168.178.195) instead
          alexa2.0
          2023-03-23 16:48:36.157	info	Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          alexa2.0
          2023-03-23 16:48:36.114	info	starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.15.0, js-controller: 4.0.24
          alexa2.0
          2023-03-23 16:48:35.909	debug	Plugin sentry Initialize Plugin (enabled=true)
          alexa2.0
          2023-03-23 16:48:35.885	debug	States connected to redis: 127.0.0.1:9000
          alexa2.0
          2023-03-23 16:48:35.839	debug	States create User PubSub Client
          alexa2.0
          2023-03-23 16:48:35.838	debug	States create System PubSub Client
          alexa2.0
          2023-03-23 16:48:35.833	debug	Redis States: Use Redis connection: 127.0.0.1:9000
          alexa2.0
          2023-03-23 16:48:35.821	debug	Objects connected to redis: 127.0.0.1:9001
          alexa2.0
          2023-03-23 16:48:35.817	debug	Objects client initialize lua scripts
          alexa2.0
          2023-03-23 16:48:35.806	debug	Objects create User PubSub Client
          alexa2.0
          2023-03-23 16:48:35.804	debug	Objects create System PubSub Client
          alexa2.0
          2023-03-23 16:48:35.797	debug	Objects client ready ... initialize now
          alexa2.0
          2023-03-23 16:48:35.765	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          alexa2.0
          2023-03-23 16:48:08.517	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          alexa2.0
          2023-03-23 16:48:07.514	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
          alexa2.0
          2023-03-23 16:48:07.510	info	Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          alexa2.0
          2023-03-23 16:48:07.461	info	starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.15.0, js-controller: 4.0.24
          alexa2.0
          2023-03-23 16:48:04.599	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          alexa2.0
          2023-03-23 16:48:04.596	error	Error: Unexpected end of JSON input
          alexa2.0
          2023-03-23 16:47:47.687	error	Error: You can try to get the cookie manually by opening http://192.168.178.195:42089/ with your browser.
          alexa2.0
          alexa2.0
          2023-03-23 16:47:47.526	info	Proxy IP not set, use first network interface (192.168.178.195) instead
          alexa2.0
          2023-03-23 16:47:47.524	info	Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          alexa2.0
          2023-03-23 16:47:47.478	info	starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.15.0, js-controller: 4.0.24
          • M Micha487
            Docker, CT oder VM
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            Grafana hat da mal jetzt nix im Beitrag zu suchen... aber das ganze Zeuch VOR dem Grafana ist nicht grad uninteressant... NAS... welches System ?
            Lehrling seit 1975 !!!
            • apollon77A Online
              apollon77A Online
              Jetzt lasst mal das arme Netzwerk-Interace in ruhe :-)) Das ist das egal.
              Was ist denn das für ein Amazon Account? Ein Deutscher? Oder was anderes? Irgendwie komischer Familienaccount oder sonstwas?
              Diesen Fehler das am Ende der Cookie Nummer ein 401 mit nem Fehler wie hier kommt hatten auch schon ne handvoll andrer User. So richtig rausfinden konnten wir die Ursache nie. Meistens waren es komische Acccounts oder Länderkram oder Ip/DNS Blocker oder es ging plötzlich ein paar Tage später wieder ...
              Thomas BraunT M 2 Antworten Letzte Antwort
              • apollon77A apollon77
                @apollon77
                Was ist denn
                für ein Fehler? Korruptes JSON?
                  @apollon77
                  Was ist denn
                  apollon77A Online
                  apollon77A Online
                  @thomas-braun In dem Falle von 401 als Fehler kommt scheinbar eine HTML seite zurück und der Adapter versucht das JSON zu parsen ... Die Frage warum diese 401 kommt ist die Magische
                    Micha487
                    @apollon77 ist eigentlich kein Familienaccount sondern mein eigener. Auch wenn ich damit quasi an jedem PC, Fernseher, mehreren Alexas, Fire-TV-Sticks etc. angemeldet bin. Sollte hier aber wohl keine Rolle spielen?
                    Es handelt sich dabei um einen deutschen Account.
                    @DJMarc75 Ist ein Eigenbau-NAS. Ist ein ASRock J4105-ITX SoC So.BGA Dual Channel DDR Mini-ITX Retail mit nem Inter-Tech Mini-ITX PSU 120W als Netzteil mit nem M.2 SSD fürs Betriebssystem in einem Thermaltake Core V1 Cube Case schwarz Mini ITX
                    DJMarc75D apollon77A 2 Antworten Letzte Antwort
                    • M Micha487
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      aha
                      • M Micha487
                        apollon77A Online
                        apollon77A Online
                        @micha487 Hm... wenn sonst nichts im "Wege" ist wie Pihole oder andere DNS dinge dann muss ich sagen bin ich im Moment ratlos. Ich könnte nur anbieten das Du mir Zugangsdaten gibts (also ändere dein passwort vorher bzw nachher) und ich es so mal selbst versuchen kann und schauen kann was bei mir passiert. Wenn das eine option ist schreb mir bitte eine E-Mail an iobroker@fischer-ka.de mit referenz hierher damit wir dann einen zeitpunkt abstimmen können (also ändere mal jetzt noch keine Passwörter, ich muss nen Zeit slot finden wo ich reinschauen kann).
                          Micha487
                          @apollon77 danke für das Angebot, ich probiere einfach mal bissle weiter rum, ob ich dahinter komme. Sollte ich auf dein Angebot zurück kommen wollen, melde ich mich per Mail bei dir, wie angeboten :)
                          • M Micha487
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            Wenn man einem Hilfsangebot des Adapterentwicklers quasi in die Fresse schlägt - selten erlebt, aber ok 😁
                            Ich entschuldige mich für diese Aussage nachdrücklich !
                            -1
                            • DJMarc75D DJMarc75
                              apollon77A Online
                              apollon77A Online
                              @djmarc75 Ne ehrlich, das ist schon ok ... Zugang zum Amazon Account weiterzugeben ist schon so eine Sache. Und es ist vollkommen ok wenn jemand das nicht annimmt
                              DJMarc75D R 2 Antworten Letzte Antwort
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                @apollon77 ja schon, aber dann wird halt nur suboptimal geholfen - weil nicht anders möglich... da fällt mir grad ein: schon von den geplanten neuen AmazonTV gelesen ? 😀 (am Rande gefragt und - schwupps - gern ausgelagert :) )
                                  Rico Sander
                                  @apollon77 sagte in Alexa2 wird nicht grün:
                                  Ausserdem lernt man durch selber machen mehr, als durch nachmachen. Aber das ist ja Konsens hier im Forum,
                                  Wenns nicht geht, wie man will
                                  - muss mans tun, wie man kann.
                                  • R Rico Sander
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @pi-ter sagte in Alexa2 wird nicht grün:
                                    Und durch Downvotes zeigt man auch wie man so tickt - danke dafür.... gemerkt !
                                    haselchenH R 2 Antworten Letzte Antwort
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @djmarc75 sagte in Alexa2 wird nicht grün:
                                      Wer im Glashaus sitzt…..
                                        Rico Sander
                                        @djmarc75
                                        Ich weiß nicht welches Problem Du gerade hattest, aber Dir auch ein schönes Wochenende.
                                        Ich fand nur Deine Bemerkung in die Fresse schlägt unpassend und unnötig.
                                        • R Rico Sander
                                          @djmarc75
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          @pi-ter jo, war vll überzogen...und ich hab den betroffenen Beitrag auch bearbeitet !
