  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.2k Aufrufe 147 Beobachtet
  • FabioF Fabio
    @astuermer was sagt denn das log im ioBroker? Du bekommst kein Captcha an deine Emali?
    astuermerA Offline
    astuermerA Offline
    astuermer
    #718
    @fa-bio
    Keine Mail. Kein Captcha im Log.
    2023-03-22 14:23:30.258 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 (force=false, process=true)
    2023-03-22 14:23:30.269 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 send kill signal
    2023-03-22 14:23:30.950 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-22 14:23:31.121 - info: host.RasPi-Smarthome instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-03-22 14:23:31.122 - info: host.RasPi-Smarthome Restart adapter system.adapter.web.0 because enabled
    2023-03-22 14:23:32.247 - info: host.RasPi-Smarthome instance system.adapter.web.0 started with pid 5371
    2023-03-22 14:23:33.410 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 started with pid 5390
    2023-03-22 14:24:29.478 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 (force=false, process=true)
    2023-03-22 14:24:29.490 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 send kill signal
    2023-03-22 14:24:33.131 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-22 14:24:37.107 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 started with pid 6053
    2023-03-22 14:25:40.134 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 (force=false, process=true)
    2023-03-22 14:25:40.155 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 send kill signal
    2023-03-22 14:25:43.776 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-22 14:25:47.791 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 started with pid 6793
    2023-03-22 14:30:56.925 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 (force=false, process=true)
    2023-03-22 14:30:56.945 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 send kill signal
    2023-03-22 14:30:57.600 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-22 14:30:57.692 - info: host.RasPi-Smarthome instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-03-22 14:30:57.693 - info: host.RasPi-Smarthome Restart adapter system.adapter.web.0 because enabled
    2023-03-22 14:30:58.824 - info: host.RasPi-Smarthome instance system.adapter.web.0 started with pid 9916
    2023-03-22 14:31:00.079 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 started with pid 9932
    FabioF 1 Antwort Letzte Antwort
    • astuermerA astuermer
      @fa-bio
      FabioF Offline
      FabioF Offline
      Fabio
      #719
      @astuermer läuft der web adapter?
      Iobroker:
      • Matter over Thread Hilfe
      astuermerA 1 Antwort Letzte Antwort
      • FabioF Fabio
        astuermerA Offline
        astuermerA Offline
        astuermer
        schrieb am zuletzt editiert von astuermer
        #720
        @fa-bio Jap, der ist grün.
        Zuerst auf allen IPs, habs aber auf die WLAN IP meines Raspberrys jetzt gelegt.
        Port 8082 ist eingestellt.
        Mein ioBroker läuft auf Port 8084.
        Ist das ein Problem?
        FabioF 2 Antworten Letzte Antwort
          FabioF Offline
          FabioF Offline
          Fabio
          #721
          @astuermer ja dann weiß ich auch nicht. Evtl. solltest du dann mit zwei Faktor arbeiten bei Eufy. Ist dein Sytem aktuell?
          Iobroker:
          • FabioF Fabio
            astuermerA Offline
            astuermerA Offline
            astuermer
            #722
            @fa-bio Hab auch soeben 2FA aktiviert, da kommt aber auch nichts im Log.
            System ist aktuell, Update läuft 2x wöchentlich.
              FabioF Offline
              FabioF Offline
              Fabio
              #723
              @astuermer meiner auf 8082 könnte evtl daran liegen
              Iobroker:
                FabioF Offline
                FabioF Offline
                Fabio
                #724
                @astuermer du musst doch eine Email von Eufy bekommen.
                Iobroker:
                • FabioF Fabio
                  astuermerA Offline
                  astuermerA Offline
                  astuermer
                  #725
                  @fa-bio Ja, war für die 2FA Aktivierung am Smartphone.
                  Aber derselbe Code wird ja nicht in ioBroker funktionieren nehm ich an?
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    schrieb am zuletzt editiert von Fabio
                    #726
                    @astuermer doch trage ihn ein unter objekte eusec verify_code
                    Iobroker:
                    • FabioF Fabio
                      astuermerA Offline
                      astuermerA Offline
                      astuermer
                      #727
                      @fa-bio Ok hab ihn eingetragen, er wird dann aber rot - hat das was zu bedeuten?
                      Verbindung dennoch nicht möglich, vermutlich wegen dem noch fehlenden Captcha. Wie kommt man an das wenns im Log nicht aufscheint?
                        astuermerA Offline
                        astuermerA Offline
                        astuermer
                        #728
                        @astuermer Fehler gefunden... :D Das Log für den Adapter war nur auf error gestellt. Hab nun Captcha und 2FA bekommen. Adapter ist grün :)
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          #729
                          @astuermer prima 👍 😊
                          Iobroker:
                          • FabioF Fabio
                            astuermerA Offline
                            astuermerA Offline
                            astuermer
                            #730
                            @fa-bio Eine Frage aber noch... bei mir sind die 4 Datenfelder für "livestream" und "last_livestream*" leer bzw auf NULL. Wie bekomme ich da die Daten rein?
                            Ist eine Eufy Solocam E40.
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              #731
                              @astuermer es wird zur Zeit nicht mehr unterstüzt bitte lesen:
                              https://github.com/bropat/ioBroker.eusec/releases/tag/0.9.10
                              Iobroker:
                              • FabioF Fabio
                                astuermerA Offline
                                astuermerA Offline
                                astuermer
                                #732
                                @fa-bio Ach mist, danke. Hatte die Cam extra bestellt weil sie als kompatibel auf Github markiert war :)
                                Danke trotzdem!
                                  Danke trotzdem!
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  #733
                                  @astuermer ist sie ja auch ;-) , das Problem liegt da wohl bei Eufy, so wie ich das verstehe.:man-shrugging:
                                  Iobroker:
                                  • FabioF Fabio
                                    MINKI
                                    #734
                                    @fa-bio Ich klinke mich hier jetzt aus. Habe meine cams eingepackt und die gehen zurück nach China. Habe vorgestern eine andere Cam gekauft und läuft bereits heute problemlos in der Home-App. Danke für euren ganzen Support hier! Macht weiter so!
                                    • M MINKI
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #735
                                      @minki okay gern geschehen, hab viel Freude mit deiner neuen Cam. 👍😉
                                      Iobroker:
                                        bishop9191
                                        #736
                                        Gibts denn Alternativen zu Eufy?
                                        -Komplett Kabellos
                                        -kein Abo
                                        -einbindbar in ioBroker
                                        • B bishop9191
                                          -Komplett Kabellos
                                          -kein Abo
                                          astuermerA Offline
                                          astuermerA Offline
                                          astuermer
                                          #737
                                          @bishop9191 Ich hab mir statt der Eufy Solocam jetzt die Eufycam 2C geholt. Derzeit mit 40 Euro Rabatt und direkt Homekit kompatibel - so spar ich mir die Einbindung über ioBroker.
