  3. Einsteigerfragen
  4. Erstinstallation Ip Adresse nicht gefunden
    5.5k
111 Beiträge 5 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • P pmther
    Last login: Thu Mar 16 19:20:20 on ttys000
    Paul@Saskias-Air ~ % ssh paul@192.168.178.41
    The authenticity of host '192.168.178.41 (192.168.178.41)' can't be established.
    ED25519 key fingerprint is SHA256:vFjguricu5KqpRk0lsjyEx9OxnGTuzr0BL0LehEYF5E.
    This key is not known by any other names
    Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
    Warning: Permanently added '192.168.178.41' (ED25519) to the list of known hosts.
    paul@192.168.178.41's password:
    Linux paul 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64
    permitted by applicable law.
    paul@paul:~ $ sudo apt update && sudo apt full-upgrade
    Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [232 kB]
    Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [232 kB]
    Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [154 kB]
    Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [315 kB]
    Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [307 kB]
    Fetched 1,355 kB in 2s (632 kB/s)
    Reading package lists... Done
    12 packages can be upgraded. Run 'apt list --upgradable' to see them.
    Calculating upgrade... Done
    The following packages will be upgraded:
    curl libcamera-apps-lite libcamera0 libcurl3-gnutls libcurl4 libtiff5
    linux-libc-dev python3-libcamera python3-picamera2 python3-v4l2
    raspberrypi-bootloader raspberrypi-kernel
    12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 35.0 MB of archives.
    After this operation, 38.9 kB of additional disk space will be used.
    Do you want to continue? [Y/n] yes
    Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 curl arm64 7.74.0-1.3+deb11u7 [265 kB]
    Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-kernel arm64 1:1.20230306-1 [26.8 MB]
    Get:3 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u7 [325 kB]
    Get:4 http://security.debian.org/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u4 [278 kB]
    Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u7 [321 kB]
    Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230302+923f5d70-1 [804 kB]
    Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 0~git20230301+54a781d-1 [280 kB]
    Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 linux-libc-dev arm64 1:1.20230306-1 [1,073 kB]
    Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230302+923f5d70-1 [226 kB]
    Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-v4l2 all 0.3.2-1 [14.4 kB]
    Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.9-1 [48.9 kB]
    Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-bootloader arm64 1:1.20230306-1 [4,540 kB]
    Fetched 35.0 MB in 4s (9,177 kB/s)
    Reading changelogs... Done
    (Reading database ... 37663 files and directories currently installed.)
    Preparing to unpack .../00-curl_7.74.0-1.3+deb11u7_arm64.deb ...
    Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
    Preparing to unpack .../01-libcurl4_7.74.0-1.3+deb11u7_arm64.deb ...
    Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
    Preparing to unpack .../02-raspberrypi-kernel_1%3a1.20230306-1_arm64.deb ...
    Leaving 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
    Leaving 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
    Leaving 'diversion of /boot/kernel7l.img to /usr/share/rpikernelhack/kernel7l.img by rpikernelhack'
    Adding 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
    Leaving 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
    Leaving 'diversion of /boot/bcm2708-rpi-b-rev1.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-rev1.dtb by rpikernelhack'
    Leaving 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
    Leaving 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
    Leaving 'diversion of /boot/bcm2708-rpi-zero-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero-w.dtb by rpikernelhack'
    Leaving 'diversion of /boot/bcm2708-rpi-zero.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero.dtb by rpikernelhack'
    Leaving 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
    Leaving 'diversion of /boot/bcm2709-rpi-cm2.dtb to /usr/share/rpikernelhack/bcm2709-rpi-cm2.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
    Adding 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
    Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
    Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
    Adding 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
    Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
    Adding 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
    Unpacking raspberrypi-kernel (1:1.20230306-1) over (1:1.20230106-1) ...
    run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84+ /boot/kernel.img
    run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
    run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
    run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
    Preparing to unpack .../03-libcamera0_0~git20230302+923f5d70-1_arm64.deb ...
    Unpacking libcamera0:arm64 (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
    Preparing to unpack .../04-libtiff5_4.2.0-1+deb11u4_arm64.deb ...
    Unpacking libtiff5:arm64 (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
    Preparing to unpack .../05-libcamera-apps-lite_0~git20230301+54a781d-1_arm64.deb ...
    Unpacking libcamera-apps-lite (0~git20230301+54a781d-1) over (0~git20230125+9f08463-1) ...
    Preparing to unpack .../06-libcurl3-gnutls_7.74.0-1.3+deb11u7_arm64.deb ...
    Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
    Preparing to unpack .../07-linux-libc-dev_1%3a1.20230306-1_arm64.deb ...
    Unpacking linux-libc-dev:arm64 (1:1.20230306-1) over (1:1.20230106-1) ...
    Preparing to unpack .../08-python3-libcamera_0~git20230302+923f5d70-1_arm64.deb ...
    Unpacking python3-libcamera (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
    Preparing to unpack .../09-python3-v4l2_0.3.2-1_all.deb ...
    Unpacking python3-v4l2 (0.3.2-1) over (0.3.1-1) ...
    Preparing to unpack .../10-python3-picamera2_0.3.9-1_all.deb ...
    Unpacking python3-picamera2 (0.3.9-1) over (0.3.8-1) ...
    Preparing to unpack .../11-raspberrypi-bootloader_1%3a1.20230306-1_arm64.deb ...
    Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
    Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
    Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
    Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
    Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
    Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
    Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
    Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
    Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
    Adding 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
    Adding 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
    Adding 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
    Adding 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
    Adding 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
    Adding 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
    Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
    Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
    Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
    Unpacking raspberrypi-bootloader (1:1.20230306-1) over (1:1.20230106-1) ...
    Setting up linux-libc-dev:arm64 (1:1.20230306-1) ...
    Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) ...
    Setting up raspberrypi-kernel (1:1.20230306-1) ...
    Removing 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
    Removing 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
    Removing 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
    Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
    Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
    Removing 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
    Removing 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
    Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
    run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84+ /boot/kernel.img
    run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84+ /boot/kernel.img
    run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7+ /boot/kernel7.img
    run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
    run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7l+ /boot/kernel7l.img
    run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
    run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v8+ /boot/kernel8.img
    run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
    Setting up python3-v4l2 (0.3.2-1) ...
    Setting up raspberrypi-bootloader (1:1.20230306-1) ...
    Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
    Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
    Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
    Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
    Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
    Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
    Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
    Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
    Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
    Removing 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
    Removing 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
    Removing 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
    Removing 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
    Removing 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
    Removing 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
    Removing 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
    Removing 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
    Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
    Setting up libcurl4:arm64 (7.74.0-1.3+deb11u7) ...
    Setting up libtiff5:arm64 (4.2.0-1+deb11u4) ...
    Setting up curl (7.74.0-1.3+deb11u7) ...
    Setting up libcamera0:arm64 (0~git20230302+923f5d70-1) ...
    Setting up python3-libcamera (0~git20230302+923f5d70-1) ...
    Setting up libcamera-apps-lite (0~git20230301+54a781d-1) ...
    Setting up python3-picamera2 (0.3.9-1) ...
    Processing triggers for man-db (2.9.4-2) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
    paul@paul:~ $ sudo sed -i -e 's/defaults,noatime/defaults,noatime,commit=600/' /etc/fstab
    paul@paul:~ $ sudo reboot
    Connection to 192.168.178.41 closed by remote host.
    Connection to 192.168.178.41 closed.
    Paul@Saskias-Air ~ % curl sLf https://iobroker.net/install.sh | bash -
    % Total % Received % Xferd Average Speed Time Time Time Current
    Dload Upload Total Spent Left Speed
    0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: sLf
    100 65 100 65 0 0 218 0 --:--:-- --:--:-- --:--:-- 218
    bash: line 1: Moved: command not found
    Paul@Saskias-Air ~ % curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2022-12-09
    Welcome to the ioBroker installer!
    Installer version: 2022-12-22
    You might need to enter your password a couple of times.
    Installing prerequisites (1/4)
    Password:
    sudo: brew: command not found
    Node.js not found. Installing...
    Cannot install Node.js using brew.
    Please download Node.js from https://nodejs.org/dist/v14.18.1/node-v16.15.1.pkg
    Then try to install ioBroker again!
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
    was ist das für ein Käse ? Aus einer gängigen Anleitung hast Du das sicher nicht.
    Lehrling seit 1975 !!!
    P 1 Antwort Letzte Antwort
    • P pmther
      Last login: Thu Mar 16 19:20:20 on ttys000
      Paul@Saskias-Air ~ % ssh paul@192.168.178.41
      The authenticity of host '192.168.178.41 (192.168.178.41)' can't be established.
      ED25519 key fingerprint is SHA256:vFjguricu5KqpRk0lsjyEx9OxnGTuzr0BL0LehEYF5E.
      This key is not known by any other names
      Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
      Warning: Permanently added '192.168.178.41' (ED25519) to the list of known hosts.
      paul@192.168.178.41's password:
      Linux paul 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64
      permitted by applicable law.
      paul@paul:~ $ sudo apt update && sudo apt full-upgrade
      Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [232 kB]
      Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [232 kB]
      Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [154 kB]
      Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [315 kB]
      Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [307 kB]
      Fetched 1,355 kB in 2s (632 kB/s)
      Reading package lists... Done
      12 packages can be upgraded. Run 'apt list --upgradable' to see them.
      Calculating upgrade... Done
      The following packages will be upgraded:
      curl libcamera-apps-lite libcamera0 libcurl3-gnutls libcurl4 libtiff5
      linux-libc-dev python3-libcamera python3-picamera2 python3-v4l2
      raspberrypi-bootloader raspberrypi-kernel
      12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 35.0 MB of archives.
      After this operation, 38.9 kB of additional disk space will be used.
      Do you want to continue? [Y/n] yes
      Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 curl arm64 7.74.0-1.3+deb11u7 [265 kB]
      Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-kernel arm64 1:1.20230306-1 [26.8 MB]
      Get:3 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u7 [325 kB]
      Get:4 http://security.debian.org/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u4 [278 kB]
      Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u7 [321 kB]
      Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230302+923f5d70-1 [804 kB]
      Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 0~git20230301+54a781d-1 [280 kB]
      Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 linux-libc-dev arm64 1:1.20230306-1 [1,073 kB]
      Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230302+923f5d70-1 [226 kB]
      Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-v4l2 all 0.3.2-1 [14.4 kB]
      Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.9-1 [48.9 kB]
      Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-bootloader arm64 1:1.20230306-1 [4,540 kB]
      Fetched 35.0 MB in 4s (9,177 kB/s)
      Reading changelogs... Done
      (Reading database ... 37663 files and directories currently installed.)
      Preparing to unpack .../00-curl_7.74.0-1.3+deb11u7_arm64.deb ...
      Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      Preparing to unpack .../01-libcurl4_7.74.0-1.3+deb11u7_arm64.deb ...
      Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      Preparing to unpack .../02-raspberrypi-kernel_1%3a1.20230306-1_arm64.deb ...
      Leaving 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
      Leaving 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
      Leaving 'diversion of /boot/kernel7l.img to /usr/share/rpikernelhack/kernel7l.img by rpikernelhack'
      Adding 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
      Leaving 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
      Leaving 'diversion of /boot/bcm2708-rpi-b-rev1.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-rev1.dtb by rpikernelhack'
      Leaving 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
      Leaving 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
      Leaving 'diversion of /boot/bcm2708-rpi-zero-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero-w.dtb by rpikernelhack'
      Leaving 'diversion of /boot/bcm2708-rpi-zero.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero.dtb by rpikernelhack'
      Leaving 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
      Leaving 'diversion of /boot/bcm2709-rpi-cm2.dtb to /usr/share/rpikernelhack/bcm2709-rpi-cm2.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
      Adding 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
      Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
      Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
      Adding 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
      Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
      Adding 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
      Unpacking raspberrypi-kernel (1:1.20230306-1) over (1:1.20230106-1) ...
      run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84+ /boot/kernel.img
      run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
      run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
      run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
      Preparing to unpack .../03-libcamera0_0~git20230302+923f5d70-1_arm64.deb ...
      Unpacking libcamera0:arm64 (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
      Preparing to unpack .../04-libtiff5_4.2.0-1+deb11u4_arm64.deb ...
      Unpacking libtiff5:arm64 (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
      Preparing to unpack .../05-libcamera-apps-lite_0~git20230301+54a781d-1_arm64.deb ...
      Unpacking libcamera-apps-lite (0~git20230301+54a781d-1) over (0~git20230125+9f08463-1) ...
      Preparing to unpack .../06-libcurl3-gnutls_7.74.0-1.3+deb11u7_arm64.deb ...
      Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      Preparing to unpack .../07-linux-libc-dev_1%3a1.20230306-1_arm64.deb ...
      Unpacking linux-libc-dev:arm64 (1:1.20230306-1) over (1:1.20230106-1) ...
      Preparing to unpack .../08-python3-libcamera_0~git20230302+923f5d70-1_arm64.deb ...
      Unpacking python3-libcamera (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
      Preparing to unpack .../09-python3-v4l2_0.3.2-1_all.deb ...
      Unpacking python3-v4l2 (0.3.2-1) over (0.3.1-1) ...
      Preparing to unpack .../10-python3-picamera2_0.3.9-1_all.deb ...
      Unpacking python3-picamera2 (0.3.9-1) over (0.3.8-1) ...
      Preparing to unpack .../11-raspberrypi-bootloader_1%3a1.20230306-1_arm64.deb ...
      Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
      Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
      Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
      Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
      Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
      Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
      Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
      Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
      Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
      Adding 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
      Adding 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
      Adding 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
      Adding 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
      Adding 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
      Adding 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
      Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
      Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
      Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
      Unpacking raspberrypi-bootloader (1:1.20230306-1) over (1:1.20230106-1) ...
      Setting up linux-libc-dev:arm64 (1:1.20230306-1) ...
      Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) ...
      Setting up raspberrypi-kernel (1:1.20230306-1) ...
      Removing 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
      Removing 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
      Removing 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
      Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
      Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
      Removing 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
      Removing 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
      Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
      run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84+ /boot/kernel.img
      run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84+ /boot/kernel.img
      run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7+ /boot/kernel7.img
      run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
      run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7l+ /boot/kernel7l.img
      run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
      run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v8+ /boot/kernel8.img
      run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
      Setting up python3-v4l2 (0.3.2-1) ...
      Setting up raspberrypi-bootloader (1:1.20230306-1) ...
      Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
      Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
      Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
      Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
      Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
      Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
      Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
      Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
      Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
      Removing 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
      Removing 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
      Removing 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
      Removing 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
      Removing 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
      Removing 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
      Removing 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
      Removing 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
      Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
      Setting up libcurl4:arm64 (7.74.0-1.3+deb11u7) ...
      Setting up libtiff5:arm64 (4.2.0-1+deb11u4) ...
      Setting up curl (7.74.0-1.3+deb11u7) ...
      Setting up libcamera0:arm64 (0~git20230302+923f5d70-1) ...
      Setting up python3-libcamera (0~git20230302+923f5d70-1) ...
      Setting up libcamera-apps-lite (0~git20230301+54a781d-1) ...
      Setting up python3-picamera2 (0.3.9-1) ...
      Processing triggers for man-db (2.9.4-2) ...
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
      paul@paul:~ $ sudo sed -i -e 's/defaults,noatime/defaults,noatime,commit=600/' /etc/fstab
      paul@paul:~ $ sudo reboot
      Connection to 192.168.178.41 closed by remote host.
      Connection to 192.168.178.41 closed.
      Paul@Saskias-Air ~ % curl sLf https://iobroker.net/install.sh | bash -
      % Total % Received % Xferd Average Speed Time Time Time Current
      Dload Upload Total Spent Left Speed
      0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: sLf
      100 65 100 65 0 0 218 0 --:--:-- --:--:-- --:--:-- 218
      bash: line 1: Moved: command not found
      Paul@Saskias-Air ~ % curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2022-12-09
      Welcome to the ioBroker installer!
      Installer version: 2022-12-22
      You might need to enter your password a couple of times.
      Installing prerequisites (1/4)
      Password:
      sudo: brew: command not found
      Node.js not found. Installing...
      Cannot install Node.js using brew.
      Please download Node.js from https://nodejs.org/dist/v14.18.1/node-v16.15.1.pkg
      Then try to install ioBroker again!
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #66
      @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
      und @Thomas-Braun hatte recht ... das ist NCHT auf dem PI ;)
      Lehrling seit 1975 !!!
      P 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        was ist das für ein Käse ? Aus einer gängigen Anleitung hast Du das sicher nicht.
        pmther
        #67
        @djmarc75 sagte in Erstinstallation Ip Adresse nicht gefunden:
        doch, das ist aus der Anleitung kopiert
        • P pmther
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #68
          aus welcher genau ? gibts da einen Link zu der Anleitung ?
            pmther
            #69
            @djmarc75 okay, wie verbinde ich mich denn dann damit?
            habe gedacht der Befehl ssh... wäre dafür
            • P pmther
              Last login: Thu Mar 16 19:20:20 on ttys000
              Paul@Saskias-Air ~ % ssh paul@192.168.178.41
              The authenticity of host '192.168.178.41 (192.168.178.41)' can't be established.
              ED25519 key fingerprint is SHA256:vFjguricu5KqpRk0lsjyEx9OxnGTuzr0BL0LehEYF5E.
              This key is not known by any other names
              Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
              Warning: Permanently added '192.168.178.41' (ED25519) to the list of known hosts.
              paul@192.168.178.41's password:
              Linux paul 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64
              permitted by applicable law.
              paul@paul:~ $ sudo apt update && sudo apt full-upgrade
              Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
              Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
              Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [232 kB]
              Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [232 kB]
              Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [154 kB]
              Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [315 kB]
              Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [307 kB]
              Fetched 1,355 kB in 2s (632 kB/s)
              Reading package lists... Done
              12 packages can be upgraded. Run 'apt list --upgradable' to see them.
              Calculating upgrade... Done
              The following packages will be upgraded:
              curl libcamera-apps-lite libcamera0 libcurl3-gnutls libcurl4 libtiff5
              linux-libc-dev python3-libcamera python3-picamera2 python3-v4l2
              raspberrypi-bootloader raspberrypi-kernel
              12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Need to get 35.0 MB of archives.
              After this operation, 38.9 kB of additional disk space will be used.
              Do you want to continue? [Y/n] yes
              Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 curl arm64 7.74.0-1.3+deb11u7 [265 kB]
              Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-kernel arm64 1:1.20230306-1 [26.8 MB]
              Get:3 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u7 [325 kB]
              Get:4 http://security.debian.org/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u4 [278 kB]
              Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u7 [321 kB]
              Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230302+923f5d70-1 [804 kB]
              Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 0~git20230301+54a781d-1 [280 kB]
              Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 linux-libc-dev arm64 1:1.20230306-1 [1,073 kB]
              Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230302+923f5d70-1 [226 kB]
              Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-v4l2 all 0.3.2-1 [14.4 kB]
              Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.9-1 [48.9 kB]
              Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-bootloader arm64 1:1.20230306-1 [4,540 kB]
              Fetched 35.0 MB in 4s (9,177 kB/s)
              Reading changelogs... Done
              (Reading database ... 37663 files and directories currently installed.)
              Preparing to unpack .../00-curl_7.74.0-1.3+deb11u7_arm64.deb ...
              Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
              Preparing to unpack .../01-libcurl4_7.74.0-1.3+deb11u7_arm64.deb ...
              Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
              Preparing to unpack .../02-raspberrypi-kernel_1%3a1.20230306-1_arm64.deb ...
              Leaving 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
              Leaving 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
              Leaving 'diversion of /boot/kernel7l.img to /usr/share/rpikernelhack/kernel7l.img by rpikernelhack'
              Adding 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
              Leaving 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
              Leaving 'diversion of /boot/bcm2708-rpi-b-rev1.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-rev1.dtb by rpikernelhack'
              Leaving 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
              Leaving 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
              Leaving 'diversion of /boot/bcm2708-rpi-zero-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero-w.dtb by rpikernelhack'
              Leaving 'diversion of /boot/bcm2708-rpi-zero.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero.dtb by rpikernelhack'
              Leaving 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
              Leaving 'diversion of /boot/bcm2709-rpi-cm2.dtb to /usr/share/rpikernelhack/bcm2709-rpi-cm2.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
              Adding 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
              Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
              Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
              Adding 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
              Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
              Adding 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
              Unpacking raspberrypi-kernel (1:1.20230306-1) over (1:1.20230106-1) ...
              run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84+ /boot/kernel.img
              run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
              run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
              run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
              Preparing to unpack .../03-libcamera0_0~git20230302+923f5d70-1_arm64.deb ...
              Unpacking libcamera0:arm64 (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
              Preparing to unpack .../04-libtiff5_4.2.0-1+deb11u4_arm64.deb ...
              Unpacking libtiff5:arm64 (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
              Preparing to unpack .../05-libcamera-apps-lite_0~git20230301+54a781d-1_arm64.deb ...
              Unpacking libcamera-apps-lite (0~git20230301+54a781d-1) over (0~git20230125+9f08463-1) ...
              Preparing to unpack .../06-libcurl3-gnutls_7.74.0-1.3+deb11u7_arm64.deb ...
              Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
              Preparing to unpack .../07-linux-libc-dev_1%3a1.20230306-1_arm64.deb ...
              Unpacking linux-libc-dev:arm64 (1:1.20230306-1) over (1:1.20230106-1) ...
              Preparing to unpack .../08-python3-libcamera_0~git20230302+923f5d70-1_arm64.deb ...
              Unpacking python3-libcamera (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
              Preparing to unpack .../09-python3-v4l2_0.3.2-1_all.deb ...
              Unpacking python3-v4l2 (0.3.2-1) over (0.3.1-1) ...
              Preparing to unpack .../10-python3-picamera2_0.3.9-1_all.deb ...
              Unpacking python3-picamera2 (0.3.9-1) over (0.3.8-1) ...
              Preparing to unpack .../11-raspberrypi-bootloader_1%3a1.20230306-1_arm64.deb ...
              Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
              Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
              Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
              Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
              Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
              Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
              Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
              Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
              Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
              Adding 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
              Adding 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
              Adding 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
              Adding 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
              Adding 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
              Adding 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
              Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
              Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
              Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
              Unpacking raspberrypi-bootloader (1:1.20230306-1) over (1:1.20230106-1) ...
              Setting up linux-libc-dev:arm64 (1:1.20230306-1) ...
              Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) ...
              Setting up raspberrypi-kernel (1:1.20230306-1) ...
              Removing 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
              Removing 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
              Removing 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
              Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
              Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
              Removing 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
              Removing 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
              Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
              run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84+ /boot/kernel.img
              run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84+ /boot/kernel.img
              run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7+ /boot/kernel7.img
              run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
              run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7l+ /boot/kernel7l.img
              run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
              run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v8+ /boot/kernel8.img
              run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
              Setting up python3-v4l2 (0.3.2-1) ...
              Setting up raspberrypi-bootloader (1:1.20230306-1) ...
              Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
              Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
              Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
              Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
              Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
              Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
              Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
              Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
              Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
              Removing 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
              Removing 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
              Removing 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
              Removing 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
              Removing 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
              Removing 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
              Removing 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
              Removing 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
              Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
              Setting up libcurl4:arm64 (7.74.0-1.3+deb11u7) ...
              Setting up libtiff5:arm64 (4.2.0-1+deb11u4) ...
              Setting up curl (7.74.0-1.3+deb11u7) ...
              Setting up libcamera0:arm64 (0~git20230302+923f5d70-1) ...
              Setting up python3-libcamera (0~git20230302+923f5d70-1) ...
              Setting up libcamera-apps-lite (0~git20230301+54a781d-1) ...
              Setting up python3-picamera2 (0.3.9-1) ...
              Processing triggers for man-db (2.9.4-2) ...
              Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
              paul@paul:~ $ sudo sed -i -e 's/defaults,noatime/defaults,noatime,commit=600/' /etc/fstab
              paul@paul:~ $ sudo reboot
              Connection to 192.168.178.41 closed by remote host.
              Connection to 192.168.178.41 closed.
              Paul@Saskias-Air ~ % curl sLf https://iobroker.net/install.sh | bash -
              % Total % Received % Xferd Average Speed Time Time Time Current
              Dload Upload Total Spent Left Speed
              0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: sLf
              100 65 100 65 0 0 218 0 --:--:-- --:--:-- --:--:-- 218
              bash: line 1: Moved: command not found
              Paul@Saskias-Air ~ % curl -sLf https://iobroker.net/install.sh | bash -
              library: loaded
              Library version=2022-12-09
              Welcome to the ioBroker installer!
              Installer version: 2022-12-22
              You might need to enter your password a couple of times.
              Installing prerequisites (1/4)
              Password:
              sudo: brew: command not found
              Node.js not found. Installing...
              Cannot install Node.js using brew.
              Please download Node.js from https://nodejs.org/dist/v14.18.1/node-v16.15.1.pkg
              Then try to install ioBroker again!
              #70
              @pmther
              Und der LoginPrompt verrät dir, dass du da eben NICHT auf dem Pi herumspringst sondern versuchst der Saskia auf ihr Air den ioBroker in der Linux-Version zu installieren.
              P 1 Antwort Letzte Antwort
              • DJMarc75D DJMarc75
                @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
                das ist aus der Anleitung kopiert
                aus welcher genau ? gibts da einen Link zu der Anleitung ?
                pmther
                #71
                @djmarc75 sagte in Erstinstallation Ip Adresse nicht gefunden:
                ja, hier https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht/2
                  @pmther
                  pmther
                  #72
                  @thomas-braun okay und wie kann ich das ändern?
                  • P pmther
                    #73
                    @pmther
                    Du musst dich natürlich nach dem erfolgten Reboot wieder auf dem Pi einloggen.
                    Ich dachte das sei selbstverständlich...
                    P 2 Antworten Letzte Antwort
                    • P pmther
                      @djmarc75 okay, wie verbinde ich mich denn dann damit?
                      habe gedacht der Befehl ssh... wäre dafür
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #74
                      @pmther wenn Du den Raspi rebootest dann musst Du Dich ja auch danach neu drauf einloggen.
                      ok, sorry, kann man, muss man aber nicht.
                      Lehrling seit 1975 !!!
                        @pmther
                        pmther
                        #75
                        @thomas-braun okay, nein das war es für mich nicht. Mache sowas zum ersten mal und habe dadurch keinerlei Erfahrung damit gemacht
                          @pmther
                          pmther
                          #76
                          @thomas-braun jetzt scheint es zu funktionieren. er hängt gerade beim dritten von vierten schritt aber das liegt dann an den geringem Arbeitsspeicher.
                          • P pmther
                            #77
                            @pmther
                            Ja, da wirst du einiges an Geduld und sonstige Einschränkungen aufbringen müssen. Für mehr als einen ersten Einblick was möglich sein könnte wird das System nicht ausreichen.
                              @pmther
                              pmther
                              #78
                              @thomas-braun jetzt ist alles fertig. unter der ip Adresse kann ich leider wieder nichts öffnen.. der gleiche Fehler wie vorhin
                              • DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #79
                                @pmther dann jetzt nochmal die Ausgabe von
                                iob diag
                                diesmal aber in CODETAGS posten und nicht einfach nur wild hier einfügen...
                                mehr dazu gibt es hier:
                                Thomas BraunT P 3 Antworten Letzte Antwort
                                  iob diag
                                  #80
                                  Wenn man wie vorgesehen den Output kopiert sind sie codetags beim diag schon dabei. :-)
                                    iob diag
                                    pmther
                                    #81
                                    @djmarc75 @Thomas-Braun
                                    Skript v.2023-01-02
                                    *** BASE SYSTEM ***
                                    Model		: Raspberry Pi 3 Model A Plus Rev 1.0
                                    Architecture: 	aarch64
                                    Docker: 	false
                                    Virtualization: none
                                    Distributor ID:	Debian
                                    Description:	Debian GNU/Linux 11 (bullseye)
                                    Release:	11
                                    Codename:	bullseye
                                    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                    NAME="Debian GNU/Linux"
                                    VERSION_ID="11"
                                    VERSION="11 (bullseye)"
                                    VERSION_CODENAME=bullseye
                                    ID=debian
                                    HOME_URL="https://www.debian.org/"
                                    SUPPORT_URL="https://www.debian.org/support"
                                    BUG_REPORT_URL="https://bugs.debian.org/"
                                    Systemuptime and Load:
                                     20:39:35 up 42 min,  1 user,  load average: 1.04, 1.46, 4.30
                                    CPU threads: 4
                                    *** Time and Time Zones ***
                                    Thu Mar 16 19:39:35 UTC 2023
                                    Thu Mar 16 20:39:35 CET 2023
                                    CET +0100
                                    Europe/Berlin
                                    *** User and Groups ***
                                    paul
                                    /home/paul
                                    paul adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                    *** X-Server-Setup ***
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    Boot Target: 	multi-user.target
                                    *** MEMORY ***
                                    Mem:            419M        107M        125M        0.0K        185M        256M
                                    Swap:            99M         31M         68M
                                    Total:          519M        139M        193M
                                              419 M total memory
                                              108 M used memory
                                               94 M active memory
                                              118 M inactive memory
                                              125 M free memory
                                               10 M buffer memory
                                              174 M swap cache
                                               99 M total swap
                                               31 M used swap
                                               68 M free swap
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G  2.2G   26G   8% /
                                    devtmpfs       devtmpfs   80M     0   80M   0% /dev
                                    tmpfs          tmpfs     210M     0  210M   0% /dev/shm
                                    tmpfs          tmpfs      84M 1020K   83M   2% /run
                                    /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                                    tmpfs          tmpfs      42M     0   42M   0% /run/user/1000
                                    Messages in dmesg:
                                    [Thu Mar 16 19:57:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4a98718-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Thu Mar 16 19:57:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                    [Thu Mar 16 19:57:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Thu Mar 16 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    481M	/var/
                                    178M	/var/cache
                                    172M	/var/cache/apt
                                    147M	/var/lib
                                    122M	/var/lib/apt/lists
                                    /opt/iobroker/backups:
                                    du: cannot access '/opt/iobroker/backups/': No such file or directory
                                    /opt/iobroker/iobroker-data:
                                    3.2M	/opt/iobroker/iobroker-data/
                                    4.0K	/opt/iobroker/iobroker-data/states.jsonl.lock
                                    4.0K	/opt/iobroker/iobroker-data/objects.jsonl.lock
                                    4.0K	/opt/iobroker/iobroker-data/backup-objects
                                    3.1M	/opt/iobroker/iobroker-data/objects.jsonl
                                    36K	/opt/iobroker/iobroker-data/states.jsonl
                                    8.0K	/opt/iobroker/iobroker-data/iobroker.json
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs 	v16.19.1
                                    /usr/bin/node 		v16.19.1
                                    /usr/bin/npm 		8.19.3
                                    /usr/bin/npx 		8.19.3
                                    nodejs:
                                      Installed: 16.19.1-deb-1nodesource1
                                      Candidate: 16.19.1-deb-1nodesource1
                                      Version table:
                                     *** 16.19.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u3 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.5~dfsg-2~11u1 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller: 	4.0.24
                                    admin: 		6.3.5
                                    javascript: 	"javascript" not found
                                    npm ERR! code ELSPROBLEMS
                                    npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                                    npm ERR! invalid: iobroker.backitup@2.5.12 /opt/iobroker/node_modules/iobroker.backitup
                                    npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                                    npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
                                    npm ERR!     /home/paul/.npm/_logs/2023-03-16T19_39_57_392Z-debug-0.log
                                    Adapters from github: 	0
                                    Adapter State
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): stable
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                                    Objects and States
                                    Objects: 	43
                                    States: 	25
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30946      6898/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30939      6898/iobroker.js-co
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12810      483/sshd: /usr/sbin
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12821      483/sshd: /usr/sbin
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12111      654/dhcpcd
                                    udp        0      0 0.0.0.0:58815           0.0.0.0:*                           108        9723       361/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9721       361/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          9776       654/dhcpcd
                                    udp6       0      0 :::55504                :::*                                108        9724       361/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        9722       361/avahi-daemon: r
                                    2023-03-16 20:26:10.242  - info: host.paul iobroker.js-controller version 4.0.24 js-controller starting
                                    2023-03-16 20:26:10.256  - info: host.paul Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2023-03-16 20:26:10.295  - info: host.paul hostname: paul, node: v16.19.1
                                    2023-03-16 20:26:10.298  - info: host.paul ip addresses: 192.168.178.41 2a02:8108:83c0:6be6:6e48:546e:9c43:f897 fe80::f368:a842:35d3:70a
                                    2023-03-16 20:26:11.530  - info: host.paul connected to Objects and States
                                    2023-03-16 20:26:11.639  - info: host.paul Node.js version has changed from unknown to 16.19.1
                                    2023-03-16 20:26:11.774  - info: host.paul Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                    2023-03-16 20:26:12.015  - info: host.paul added notifications configuration of host
                                    2023-03-16 20:26:13.212  - info: host.paul  no instances found
                                    2023-03-16 20:26:13.214  - info: host.paul no instances found
                                      iob diag
                                      pmther
                                      #82
                                      @djmarc75 Danke, so sieht es doch gleich viel besser aus :)
                                      • P pmther
                                        #83
                                        @pmther
                                        iobroker start admin
                                          @pmther
                                          pmther
                                          #84
                                          Cannot find any instances of "admin"!
