  4. Speicher in Proxmox Container wächst langsam an
    5.5k
proxmoxramabsturzubuntu
17 Beiträge 8 Kommentatoren 1.8k Aufrufe 8 Beobachtet
  • Q Offline
    Q Offline
    quinti
    Skript v.2023-02-20
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.1 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.1 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.1 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     10:50:53 up 1 day, 14:10,  1 user,  load average: 7.07, 6.54, 6.21
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Fri 2023-03-03 10:50:53 CET
               Universal time: Fri 2023-03-03 09:50:53 UTC
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.1G        2.3G        1.3G        0.0K        546M        1.8G
    Swap:           2.0G        0.0K        2.0G
    Total:          6.1G        2.3G        3.3G
             4096 M total memory
             2285 M used memory
              219 M active memory
             2470 M inactive memory
             1263 M free memory
                0 M buffer memory
              546 M swap cache
             2048 M total swap
                0 M used swap
             2047 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--102--disk--0 ext4   7.8G  4.0G  3.5G  54% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs   16G     0   16G   0% /dev/shm
    tmpfs                            tmpfs  6.3G  124K  6.3G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
    /var:
    990M    /var/
    471M    /var/lib
    300M    /var/log
    294M    /var/log/journal/32d44d8684294c40a3c38c17aef6802e
    /opt/iobroker/backups:
    96M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    292M    /opt/iobroker/iobroker-data/
    178M    /opt/iobroker/iobroker-data/files
    84M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.fe83292c.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/states.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.5M    /opt/iobroker/iobroker-data/files/vis.0/download/vis-views.json
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v14.20.1
    /usr/bin/node           v14.20.1
    /usr/bin/npm            6.14.17
    /usr/bin/npx            6.14.17
    nodejs:
      Installed: 14.20.1-deb-1nodesource1
      Candidate: 14.20.1-deb-1nodesource1
      Version table:
     *** 14.20.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    javascript:     6.1.4
    npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@4.0.2
    Adapters from github:   2
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
    + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.101.102
      system.adapter.landroid.0               : landroid              : iobroker                                 - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.101.102
    + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
      system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.101.102
      system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8087, bind: 127.0.0.1, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 192.168.101.102
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sureflap.0               : sureflap              : iobroker                                 -  enabled
    + system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    Active repo(s): online, beta
    Installed ioBroker-Instances
    Used repositories: online, beta
    Cannot download repository hash file from "https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist-hash.json": Request failed with status code 404
    Adapter    "admin"        : 6.3.6    , installed 6.3.5  [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.4    , installed 2.5.12 [Updatable]
    Adapter    "denon"        : 1.15.0   , installed 1.15.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "info"         : 1.9.26   , installed 1.9.25 [Updatable]
    Adapter    "iot"          : 1.14.4   , installed 1.14.3 [Updatable]
    Adapter    "javascript"   : 7.0.1    , installed 6.1.4  [Updatable]
    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
    Adapter    "knx"          : 2.0.17   , installed 1.0.45 [Updatable]
    Adapter    "landroid"     : 1.0.3    , installed 1.0.3
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "mqtt"         : 4.0.7    , installed 2.4.0  [Updatable]
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "octoprint"    : 4.1.0    , installed 4.0.1  [Updatable]
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "shelly"       : 6.4.0    , installed 6.2.4  [Updatable]
    Adapter    "socketio"     : 6.3.3    , installed 6.2.0  [Updatable]
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "sureflap"     : 1.1.6    , installed 1.1.5  [Updatable]
    Adapter    "tankerkoenig" : 3.3.7    , installed 2.0.12 [Updatable]
    Adapter    "traccar"      : 0.0.12   , installed 0.0.12
    Adapter    "tuya"         : 3.14.1   , installed 3.9.4  [Updatable]
    Adapter    "unifi"        : 0.6.3    , installed 0.6.3
    Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 5.5.1    , installed 5.2.12 [Updatable]
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.3.5    , installed 2.1.5  [Updatable]
    Objects and States
    Objects:        16596
    States:         16282
    Hit:1 https://deb.nodesource.com/node_14.x jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists... Done
    Pending Updates: 124
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        325996771  127/systemd-resolve
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      112        325996167  208/mariadbd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          325995531  1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          326007558  976/master
    tcp        0      0 192.168.101.102:1882    0.0.0.0:*               LISTEN      1000       326002094  557/io.shelly.0
    tcp        0      0 192.168.101.102:1887    0.0.0.0:*               LISTEN      1000       325999349  507/io.mqtt.0
    tcp        0      0 192.168.101.102:1886    0.0.0.0:*               LISTEN      1000       325999348  507/io.mqtt.0
    tcp        0      0 192.168.101.102:1885    0.0.0.0:*               LISTEN      1000       325998929  432/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       325996983  134/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       325996976  134/iobroker.js-con
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          326007559  976/master
    tcp6       0      0 :::51989                :::*                    LISTEN      1000       326001955  522/io.nuki-extende
    tcp6       0      0 :::111                  :::*                    LISTEN      0          325995533  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          325996677  1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       325997106  311/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       326007780  996/io.web.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       332939301  161970/io.mihome-va
    udp        0      0 192.168.101.102:37876   0.0.0.0:*                           1000       326004606  736/io.knx.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       326002255  592/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       326002256  592/io.tuya.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        325996770  127/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          325995532  1/init
    udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          325996080  149/ntpd
    udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          325996078  149/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          325996076  149/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          325996072  149/ntpd
    udp6       0      0 :::111                  :::*                                0          325995534  1/init
    udp6       0      0 fe80::6c30:19ff:fee:123 :::*                                113        325997698  149/ntpd
    udp6       0      0 fe80::3cdc:45ff:fe9:123 :::*                                113        325997696  149/ntpd
    udp6       0      0 ::1:123                 :::*                                0          325996082  149/ntpd
    udp6       0      0 :::123                  :::*                                0          325996867  149/ntpd
    2023-03-03 10:51:35.780  - debug: tuya.0 (592) stateChange tuya.0.bf47044dd352dbdc43opys.113 {"val":5,"ack":true,"ts":1677837095724,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1667119581213}
    2023-03-03 10:51:35.782  - debug: tuya.0 (592) stateChange tuya.0.bf47044dd352dbdc43opys.114 {"val":35,"ack":true,"ts":1677837095724,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1667119581451}
    2023-03-03 10:51:35.788  - debug: tuya.0 (592) stateChange tuya.0.bf47044dd352dbdc43opys.115 {"val":5,"ack":true,"ts":1677837095724,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1667119581480}
    2023-03-03 10:51:35.790  - debug: tuya.0 (592) stateChange tuya.0.bf47044dd352dbdc43opys.116 {"val":0,"ack":true,"ts":1677837095724,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1667119581481}
    2023-03-03 10:51:35.793  - debug: tuya.0 (592) stateChange tuya.0.bf47044dd352dbdc43opys.117 {"val":0,"ack":true,"ts":1677837095724,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1667119581497}
    2023-03-03 10:51:35.855  - debug: tuya.0 (592) stateChange tuya.0.bf47044dd352dbdc43opys.118 {"val":0,"ack":true,"ts":1677837095854,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1669191047470}
    2023-03-03 10:51:39.470  - info: knx.0 (736) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 4c 2b 00 29 00 bc e0 11 14 20 00 03 00 80 3f 68   ChID: 76
    2023-03-03 10:51:39.470  - info: knx.0 (736) WRITE : mappedName : Zisternenfüllstand    dest : 4/0/0  val: 2426.88   (DPT9.001) Zisternenfüllstand
    2023-03-03 10:51:39.471  - info: knx.0 (736) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
    2023-03-03 10:51:39.471  - info: knx.0 (736) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
    2023-03-03 10:51:39.471  - info: knx.0 (736) =====> STATE_TUNNELING_ACK
    2023-03-03 10:51:39.471  - info: knx.0 (736) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 4c 2b 00   ChID : 76 SeqCntIN : 43 SeqCntOUT : 48 queue length : 0
    2023-03-03 10:51:39.471  - info: knx.0 (736) ( 4.b ) return to STATE_READY, processing : false
    2023-03-03 10:51:39.471  - info: knx.0 (736) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
    2023-03-03 10:51:39.475  - silly: knx.0 (736) States user redis pmessage knx.0.*/knx.0.Sensorik.Analogeingang.Zisternenfüllstand:{"val":2426.88,"ack":true,"ts":1677837099474,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1677836979475}
    2023-03-03 10:51:39.504  - info: knx.0 (736) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 4c 2c 00 29 00 bc e0 11 14 20 04 03 00 80 01 7b   ChID: 76
    2023-03-03 10:51:39.505  - info: knx.0 (736) WRITE : mappedName : Aussentemperatur    dest : 4/0/4  val: 3.79   (DPT9.001) Aussentemperatur
    2023-03-03 10:51:39.505  - info: knx.0 (736) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
    2023-03-03 10:51:39.505  - info: knx.0 (736) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
    2023-03-03 10:51:39.505  - info: knx.0 (736) =====> STATE_TUNNELING_ACK
    2023-03-03 10:51:39.505  - info: knx.0 (736) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 4c 2c 00   ChID : 76 SeqCntIN : 44 SeqCntOUT : 48 queue length : 0
    2023-03-03 10:51:39.505  - info: knx.0 (736) ( 4.b ) return to STATE_READY, processing : false
    2023-03-03 10:51:39.505  - info: knx.0 (736) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
    2023-03-03 10:51:39.511  - silly: knx.0 (736) States user redis pmessage knx.0.*/knx.0.Sensorik.Analogeingang.Aussentemperatur:{"val":3.79,"ack":true,"ts":1677837099509,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1677837099509}
    2023-03-03 10:51:44.098  - warn: sonoff.0 (432) Cannot parse data "SENSOR": _{"Time":"2023-03-03T10:51:44","ENERGY":{"TotalStartTime":"2018-11-13T17:02:27","Total":1080.74158,"Yesterday":,"Today":0.01836,"Period":0.0,"Power":0.0,"ApparentPower":0.0,"ReactivePower":0.0,"Factor":0.00,"Voltage":233,"Current":0.000}}_ - SyntaxError: Unexpected token , in JSON at position 110
    arteckA CodierknechtC GlasfaserG ? 4 Antworten Letzte Antwort
    • Q quinti
      Skript v.2023-02-20
      *** BASE SYSTEM ***
      Docker          : false
      Release:        22.04
      Codename:       jammy
      NAME="Ubuntu"
      VERSION_ID="22.04"
      ID=ubuntu
      ID_LIKE=debian
      CPU threads: 2
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
               4096 M total memory
               2285 M used memory
                219 M active memory
               1263 M free memory
                  0 M buffer memory
                546 M swap cache
               2048 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      990M    /var/
      471M    /var/lib
      300M    /var/log
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        16596
      States:         16282
      arteckA Offline
      arteckA Offline
      arteck
      @quinti sagte in Speicher in Proxmox Container wächst langsam an:
      kannst schon mal da anfangen
      und der Tuya adapter läuft auf debug.. hat es einen grund ?
      • Q quinti
        Skript v.2023-02-20
        *** BASE SYSTEM ***
        Docker          : false
        Release:        22.04
        Codename:       jammy
        NAME="Ubuntu"
        VERSION_ID="22.04"
        ID=ubuntu
        ID_LIKE=debian
        CPU threads: 2
                         RTC time: n/a
                      NTP service: n/a
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
                 4096 M total memory
                 2285 M used memory
                  219 M active memory
                 1263 M free memory
                    0 M buffer memory
                  546 M swap cache
                 2048 M total swap
                    0 M used swap
                 2047 M free swap
        *** FILESYSTEM ***
        /var:
        990M    /var/
        471M    /var/lib
        300M    /var/log
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        16596
        States:         16282
        CodierknechtC Online
        Codierknecht
        @quinti
        124 fehlende Systemupdates und 17 veraltete Adaper.
        Noch Fragen?
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • CodierknechtC Codierknecht
          @quinti
          Noch Fragen?
          Und als root unterwegs.
          • Q quinti
            Skript v.2023-02-20
            *** BASE SYSTEM ***
            Docker          : false
            Release:        22.04
            Codename:       jammy
            NAME="Ubuntu"
            VERSION_ID="22.04"
            ID=ubuntu
            ID_LIKE=debian
            CPU threads: 2
                             RTC time: n/a
                          NTP service: n/a
                      RTC in local TZ: no
            root
            /root
            root
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
                     4096 M total memory
                     2285 M used memory
                      219 M active memory
                     1263 M free memory
                        0 M buffer memory
                      546 M swap cache
                     2048 M total swap
                        0 M used swap
                     2047 M free swap
            *** FILESYSTEM ***
            /var:
            990M    /var/
            471M    /var/lib
            300M    /var/log
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        16596
            States:         16282
            GlasfaserG Offline
            GlasfaserG Offline
            stable : http://download.iobroker.net/sources-dist.json
            beta : http://download.iobroker.net/sources-dist-latest.json
            Was hast du den da.... eine Testumgebung vom Jahre ....
            Da stimmt ja nichts ... und als BETA -Tester unterwegs !?
            uweklattU 1 Antwort Letzte Antwort
            • GlasfaserG Glasfaser
              uweklattU Offline
              uweklattU Offline
              uweklatt
              Ich nutze den Buanet Docker Container ebenfalls unter Proxmox.
              Ich stelle keinen wachsenden Speicherverbrauch fest.
              Das wird wohl an einem unsauberen Adapter liegen.
              Tschau
              Uwe
              Intel i5/Proxmox/LXC/Docker/ioBroker
              • Q quinti
                Skript v.2023-02-20
                *** BASE SYSTEM ***
                Docker          : false
                Release:        22.04
                Codename:       jammy
                NAME="Ubuntu"
                VERSION_ID="22.04"
                ID=ubuntu
                ID_LIKE=debian
                CPU threads: 2
                                 RTC time: n/a
                              NTP service: n/a
                          RTC in local TZ: no
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                         4096 M total memory
                         2285 M used memory
                          219 M active memory
                         1263 M free memory
                            0 M buffer memory
                          546 M swap cache
                         2048 M total swap
                            0 M used swap
                         2047 M free swap
                *** FILESYSTEM ***
                /var:
                990M    /var/
                471M    /var/lib
                300M    /var/log
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16596
                States:         16282
                Boot Target: graphical.target
                Moin,
                auch in einem LXC Container ein OS zu installieren, das den Grafik-Kram mitbringt und auch im Grafikmodus zu starten, birgt Gefahren und führt zu Problemen.
                Ich würde Dir dazu raten, dass Du ein Backup der iobroker Installation machst und den LXC Container sauber aufsetzt, mit
                Bernd
                • uweklattU uweklatt
                  Tschau
                  Uwe
                  @uweklatt sagte in Speicher in Proxmox Container wächst langsam an:
                  Moin,
                  nicht unbedingt!
                  Das Grundsystem des TE ist schon nicht sauber, fehlende Updates, veraltete nodejs Version usw.
                  Und Deine Installation, verstehe ich auch nicht, Du hast Proxmox, dann irgendwie Docker installiert um dann ein iobroker Docker Container zu installieren?
                  Wieso nutzt Du nicht gleich LXC Container, das erspart Dir eine Virtualisierungsschicht. Somit kann man Deine Installation mit der des TE nicht vergleichen.
                  Bernd
                    Moin,
                    nicht unbedingt!
                    Bernd
                    uweklattU Offline
                    uweklattU Offline
                    uweklatt
                    schrieb am zuletzt editiert von uweklatt
                    @dp20eic
                    Ich nutze unter Proxmox u.a. einen LXC Container mit Docker. Darin dann ioBroker als Docker-Image.
                    Durch Docker kann man einzelne Dienste sauber und unabhängig voneinander pflegen. (SQL-Server, MQTT-Server, WEB-Server, ...)
                    Dabei werden viele Basisdienste (Layer) gemeinsam genutzt, was Speicherplatz spart.
                    Es wäre natürlich auch möglich, ioBroker direkt als LXC zu installieren... Der Overhead durch Docker ist aber sehr gering.
                    Tschau
                    Uwe
                    crunchipC CodierknechtC 2 Antworten Letzte Antwort
                      @dp20eic
                      Tschau
                      Uwe
                      crunchipC Offline
                      crunchipC Offline
                      Das kann/macht Proxmox ja auch
                        @dp20eic
                        Tschau
                        Uwe
                        Codierknecht
                        Das klingt aber auch ein bisschen nach dem Hosenträger zum Gürtel. Wäre mir persönlich eine Schicht zu viel.
                        Entweder ioBroker in einem LCX unter Proxmox oder als Container in Docker.
                        Beides kombiniert ist wie "von hinten durch die Brust ins Auge".
