  3. Off Topic
  4. Microcontroller
  5. Tasmota D1 Mini gerechnete Werte via Mqtt übertragen
    5.9k
Geplant Angeheftet Gesperrt Verschoben Microcontroller
18 Beiträge 5 Kommentatoren 3.4k Aufrufe 5 Beobachtet
  • W Wuffi26
    @ralla66 ```
    D
    p:m1=0
    p:g1=0
    p:g2=0
    p:month1=0
    p:month2=0
    p:month3=0
    p:gesamt=0
    c1=0
    s1=0
    h1=0
    hkw1=0
    gkw1=0
    gkw2=0
    mkw1=0
    mkw2=0
    mkw3=0
    mkwgs=0
    skw1=0
    hgp=0
    g1gp=0
    g2gp=0
    m1gp=0
    m2gp=0
    m3gp=0
    gsgp=0
    hr=0
    dy=0
    zu=0.9617
    br=11.233
    gp=17.956
    gasinit=0.0
    gastotal=0
    B
    =>sensor53 l255
    S
    h1=s1-m1
    hkw1=h1brzu
    hgp=(hkw1gp)/100
    gkw1=g1
    brzu
    gkw2=g2
    brzu
    mkw1=month1
    brzu
    mkw2=month2
    brzu
    mkw3=month3
    brzu
    mkwgs=gesamt
    brzu
    g1gp=(gkw1
    gp)/100
    g2gp=(gkw2gp)/100
    m1gp=(mkw1
    gp)/100
    m2gp=(mkw2gp)/100
    m3gp=(mkw3
    gp)/100
    gsgp=(mkwgsgp)/100
    skw1=s1
    br*zu
    hr=hours
    dy=day
    if chg[hr]>0
    and hr==0
    then
    m1=s1
    g2=g1
    g1=h1
    month1=month1+h1
    gesamt=gesamt+h1
    if chg[dy]<2
    and dy==1
    then
    month3=month2
    month2=month1
    month1=0
    endif
    svars
    endif
    if upsecs%tper==0{
    =>Publish tasmota/%topic%/main/td_m3 %2h1%
    =>Publish tele/%topic%/main/td_kwh %2hkw1%
    =>Publish tele/%topic%/main/yd_m3 %2g1%
    =>Publish tele/%topic%/main/yd_kwh %2gkw1%
    =>Publish tele/%topic%/main/dbyd_m3 %2g2%
    =>Publish tele/%topic%/main/dbyd_kwh %2gkw2%
    =>Publish tele/%topic%/main/value %2s1%
    =>Publish tele/%topic%/main/gastotal %2gastotal%
    =>Publish tele/%topic%/json {"gastotal": "%2gastotal%", "value": "%2s1%", "today_m3": "%2h1%", "today_kwh": "%2hkw1%", "yesterday_m3": "%2g1%", "yesterday_kwh": "%2gkw1%", "db_yesterday_m3": "%2g2%", "db_yesterday_kwh": "%2gkw2%"}
    T
    s1=Counter#C1/100
    c1=Counter#C1
    gastotal=(c1/100)+gasinit
    W
    GAS gezählt: {m} %3s1% m³
    Zählerstand: {m} %gastotal% m³
    Zustandszahl: {m} %zu%
    Brennwert: {m} %br% kWh/m³
    Gaspreis: {m} %gp% Cent/kWh
    Verbrauch:
    Heute: {m} %2h1% m³ | %2hkw1% kWh
    Kosten: {m} %2hgp% €
    Gestern: {m} %2g1% m³ | %2gkw1% kWh
    Kosten: {m} %2g1gp% €
    Vorgestern: {m} %2g2% m³ | %2gkw2% kWh
    Kosten: {m} %2g2gp% €
    Aktueller Monat: {m} %2month1% m³ | %2m1gp% €
    Letzter Monat: {m} %2month2% m³ | %2m2gp% €
    Vorletzter Monat: {m} %2month3% m³ | %2m3gp% €
    Gesamt: {m} %2gesamt% m³ | %2gsgp% €
    Ralla66R Offline
    Ralla66R Offline
    Ralla66
    @wuffi26
    deine Telemetrieperiode hat den Wert ?
    mal auf 10 stellen,
    teste mal unter D eine var anlegen mit eigen=365,
    unter T das einfügen,
    =>publish tele/%topic%/Test %eigen%
    dann sollte im Mqtt Adapter unter tele Datenpunkt Test der Wert 365 stehen.
    W 1 Antwort Letzte Antwort
    • Ralla66R Ralla66
      @wuffi26
      mal auf 10 stellen,
      W Offline
      W Offline
      Wuffi26
      @ralla66 ok danke sehr, werde es gleich mal testen.
      • W Wuffi26
        W Offline
        W Offline
        Wuffi26
        @Ralla66 habe es mal getestet, er legt kein solchen Datenpunkt an, nutze dem Sonoff Mqtt adapter. liegt es vielleicht an der Tasmota Version oder an den Mqtt server?
        WalW Ralla66R 3 Antworten Letzte Antwort
        • W Wuffi26
          WalW Offline
          WalW Offline
          Wal
          schrieb am zuletzt editiert von Wal
          @wuffi26 ,
          in meinen Skripten nehme ich 'stat' nicht tele und RESULT am Ende unter '>T'
          >T
          =>publish stat/%topic%/RESULT {"Sensor.Indoor.Temperatur":%1tin%}
          und im Adapter muss die automatische Erstellung der Datenpunkte aktiviert sein.
          Edit: Der Datenpunkt wird unter 'sonoff.0.%topic%.Sensor.Indoor.Temperatur' erstellt.
          Walter
          DoorIO-Adapter
          • W Wuffi26
            Ralla66R Offline
            Ralla66R Offline
            Ralla66
            @wuffi26
            für Sonoff Adapter verwende ich diese Syntax :
            eigen=365
            unter
            J
            ,"Test":{"Eigen":%eigen%}
            einfügen
            Nach Änderung des Scriptes immer Sonoff Adapter neu starten !
            Besser Datenpunkte komplett löschen und Neustart.
            • WalW Wal
              @wuffi26 ,
              >T
              W Offline
              W Offline
              Wuffi26
              @wal Ok danke für Deine Antwort, mit dem automatischen Erstellen hab ich eigentlich noch nie Probleme gehabt, die Datenpunkte waren alles bisher da. Ich werde es gleich mal probieren.
              • W Wuffi26
                Ralla66R Offline
                Ralla66R Offline
                Ralla66
                @wuffi26
                Test Script, damit festgestellt werden kann ob der Weg geht, ESP nach Sonoff Adapter.
                Tasmota ist Paul 12.4
                >D
                ;Variablen
                eigen=365
                ;Web Gui
                >W
                Eigen{m}%eigen%
                ;Tasmota Sonoff Adapter
                >J
                ,"Test"
                :{"Eigen":%eigen%}
                Tasmota von hier
                Telemetrie Tasmota auf 10 stellen
                H 1 Antwort Letzte Antwort
                • W Wuffi26
                  W Offline
                  W Offline
                  Wuffi26
                  @Wal Hallo und Grüße, endlich hab ich es so wie ich mir das gedacht habe, herzlichen Dank, alleine wäre ich NIeeeeee drauf gekommen.
                  Ralla66R 1 Antwort Letzte Antwort
                  • W Wuffi26
                    Ralla66R Offline
                    Ralla66R Offline
                    Ralla66
                    @wuffi26
                    Prima, passt ja dann.
                    woran lag es nun ?
                    W 2 Antworten Letzte Antwort
                    • Ralla66R Ralla66
                      @wuffi26
                      woran lag es nun ?
                      W Offline
                      W Offline
                      Wuffi26
                      @ralla66 Kann ich leider nicht sagen aber ich denke, das es was mit dem code und der telemetry Übertragung zu tun hat. Wie gesagt , bin nicht so fit mit tasmota, was eigentlich sehr schade ist weil man sehr viel machen kann damit.
                      • Ralla66R Ralla66
                        @wuffi26
                        woran lag es nun ?
                        W Offline
                        W Offline
                        Wuffi26
                        @ralla66 Übrigens habe ich das image genauso wie Du sagtest auf den D1 mini geschrieben.
                        • W Wuffi26
                          Ralla66R Offline
                          Ralla66R Offline
                          Ralla66
                          @wuffi26
                          Telemetrie ist die Erneuerung der Daten / Werte im Sonoff Adapter nach Zeit.
                          300 bedeutet das es 5 minuten dauert ( 5 x 60 sec) bis die Werte erneuert werden.
                          Schreibst du das Script um dauert es halt 5 min bis neue Daten kommen.
                          • Ralla66R Ralla66
                            @wuffi26
                            W Offline
                            W Offline
                            Wuffi26
                            @ralla66 ok Danke sehr, ich habe jetzt eine 60 draus Gemacht damit es nicht so lange dauert
                            • W Wuffi26
                              Hallo Gemeinde, ich hab ein kleines Problem, es fing alles mit einen Gaszähler an, wollte Ihn Smart machen und dacht ich nehme Tasmota, Zähler ist drin und Zählt. Nun habe ich das Problem das die ganzen Datenpunkte fehlen bis auf den Counter. der wird immer aktualisiert. Ich hab ein Scripting Tasmota auf einen D1MINI. Soweit funktioniert alles, bis auf die fehlenden Datenpunkte.Das markierte ist der counter der im IObroker via Mqtt broker angezeigt wird. Ich möchte das die berechneten Werte via MQTT übertragen werden. Oder funktioniert das so nicht was ich da vor habe???
                              Andreas OttenA Offline
                              Andreas Otten
                              schrieb am zuletzt editiert von Andreas Otten
                              @wuffi26 Darf ich höflich nach dem Script fragen.
                              Ich habe momentan "Heute und Gestern" in meinem Tasmota Script, aber würde gerne auch Monat, letzter Monat / Gesamt haben.
                              Wenn ich die snips aus dem Forum nehme fehlt mir immer irgendeine Variable.
                              Bei mir seiht es im Moment so aus:
                              >D
                              p:m1=0
                              s1=0
                              p:g1=0
                              h1=0
                              hkw1=0
                              gkw1=0
                              skw1=0
                              hgp=0
                              ggp=0
                              akw1=0
                              hr=0
                              mi=0
                              zu=0.9702
                              br=9.835
                              gp=7.26
                              farbe1="#008000"
                              farbe2="#f00000"
                              farbe3="#00fdfd"
                              >B
                              ->sensor53 r
                              tper=10
                              >S
                              h1=s1-m1
                              hkw1=h1*br*zu
                              hgp=(hkw1*gp)/100
                              gkw1=g1*br*zu
                              ggp=(gkw1*gp)/100
                              skw1=s1*br*zu
                              akw1=(skw1*gp)/100
                              hr=hours
                              if chg[hr]>0
                               and hr==0
                                then
                                 m1=s1
                                 g1=h1
                                 svars
                              endif
                              >T
                              s1=GAS1#Stand_Haus1
                              >W
                              Verbrauch:
                              Kosten: {m} %2ggp% €
                              <p style="color:#00d6e9;">Gas gesamt: {m} <p style="color:#00d6e9;">%2s1% m3 | %2skw1% kWh</p>
                              <p style="color:#00d6e9;">Kosten: {m} <p style="color:#00d6e9;">%2akw1% €</p>
                              >M 1
                              +1,4,c,1,-25,GAS1
                              1,1-0:1.8.0*255(@100,Zählerstand,m³,Stand_Haus1,18
                              • Ralla66R Ralla66
                                @wuffi26
                                >D
                                ;Variablen
                                eigen=365
                                ;Web Gui
                                >W
                                Eigen{m}%eigen%
                                >J
                                ,"Test"
                                :{"Eigen":%eigen%}
                                Tasmota von hier
                                heidepower
                                @ralla66 habe es genau wie du es erklärt hast gemacht, leider bekomme ich keinen Datenpunkt im iobroker erstellt!
                                Woran kann es liegen? Ich habe einen Durchflussmesser. In dem Script wird Liter/min, Liter/h berechnet und auf einem oled ausgegeben. Diesen Wert hätte ich gerne via mqtt übertragen an den iobroker.
                                Zum Test habe ich dein Beispiel eingefügt. In der Tasmota Oberfläche wird die 365 angezeigt, aber nicht an den iobroker übertragen. Es wird nur der Counter übertragen.
                                >D
                                p:pAktuell=0
                                p:pVorherige=0
                                p:pDiff=0
                                p:qLiter_sec=0
                                p:qLiter_min=0
                                p:qLiter_h=0
                                p:qLiter_Total=0
                                eigen=365
                                >S
                                pVorherige=pAktuell
                                pAktuell=pc[1]
                                pDiff=pAktuell-pVorherige
                                qLiter_sec=(pDiff/450)
                                qLiter_min=(qLiter_sec*60)
                                qLiter_h=(qLiter_min*60)
                                qLiter_Total=(pc[1]/450)
                                ->displaytext [zs4x-8y11] %0qLiter_h%[s1x80y38] l/min
                                ;Rahmen
                                ;->DisplayText [x0y0r128:64]
                                >W
                                ;Durchfluss{m}   %qLiter_sec% Liter/s
                                Durchfluss{m}    %qLiter_min% Liter/min
                                Durchfluss{m}    %qLiter_h% Liter/h
                                Total{m}         %qLiter_Total% Liter
                                Eigen{m}%eigen%
                                >J
                                ,"Test"
                                :{"Eigen":%eigen%}
