  4. javascript bleibt rot bei iob Neustart
javascriptiob neutstart
30 Beiträge 4 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • bahnuhrB bahnuhr
    wenn ich iob komplett neu starten, wird die Instanz von javascript nicht grün. Die Folge ist, dass meine ganzen Scripte nicht starten.
    Im log steht folgendes:
    host.iobroker
    2023-03-04 08:36:54.584	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.iobroker
    2023-03-04 08:36:54.584	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2023-03-04 08:36:54.584	error	Caught by controller[0]: }
    host.iobroker
    2023-03-04 08:36:54.584	error	Caught by controller[0]: ]
    host.iobroker
    2023-03-04 08:36:54.584	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: requireStack: [
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12) {
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:426:4)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:18:15)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: Require stack:
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: Error: Cannot find module './sourcemap'
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: ^
    host.iobroker
    2023-03-04 08:36:54.579	error	Caught by controller[0]: throw err;
    host.iobroker
    2023-03-04 08:36:54.579	error	Caught by controller[0]: node:internal/modules/cjs/loader:998
    host.iobroker
    2023-03-04 08:36:54.221	info	instance system.adapter.javascript.0 started with pid 13204
    Dort steht zum Schluss dann:
    Also in putty ausgeführt:
    cd /opt/iobroker/
    npm install javascript --production
    Danach die Intanz wieder neu gestartet und alles läuft wieder.
    Frage:
    Warum ist das so?
    und warum wird die Instanz nicht bei einem iob Neustart gleich grün ?
    Und: Wie kann ich dies beheben.
    Achja: überall auf stable; mit 1 oder 2 Ausnahmen (web, ws) wg. dort ws problem. Dort bin ich auf beta.
    mfg
    Dieter
    @bahnuhr sagte in javascript bleibt rot bei iob Neustart:
    ich bin jetzt nicht ganz sicher, ob du damit das
    wirklich umgesetzt hast.
    ich verstehe das so, dass du noch tiefer in die Struktur bis zum js-Adapter musst, und dort nicht
    eingeben sollst
    • bahnuhrB bahnuhr
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      cd /opt/iobroker/
      Frage:
      Warum ist das so?
      mfg
      Dieter
      hattest du ein node Update gemacht?
      wird eigentlich nach einer node Änderung angestoßen.
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @homoran sagte in javascript bleibt rot bei iob Neustart:
        Ne, das ist mir schon öfters passiert mit dem js adapter
        heute nacht um 03:00 iob neu getartet und dann ging nichts mehr
        nach
        ging es ja wieder (kann doch dann nicht ganz falsch gewesen sein)
        Danke.
        • bahnuhrB bahnuhr
          nach
          vielleicht sogar besser, und der Adapter hat es auf dem "richtigen" Weg nicht geschafft 😂
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            so, hab jetzt mal
            im Ordner: node-modules/iobroker.javascript
            ausgeführt und danach iob komplett neu gestartet.
            Jetzt ist auch JS sofort grün.
            Komisch; aber scheint nun korrekt zu laufen.
            Danke @Homoran für den Schubser in die offensichtlich richtige Richtung.
            Danke.
            GarganoG Thomas BraunT 2 Antworten Letzte Antwort
            • bahnuhrB bahnuhr
              so, hab jetzt mal
              GarganoG Offline
              GarganoG Offline
              Gargano
              Danke, hatte das gleiche Problem mit der 7.01
              • bahnuhrB bahnuhr
                so, hab jetzt mal
                Thomas BraunT Offline
                Ist obsolet mit aktuellen npm Versionen.
                Es soll nun
                npm install --omit=dev
                verwendet werden.
                bahnuhrB GarganoG 2 Antworten Letzte Antwort
                  Es soll nun
                  verwendet werden.
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Das kann man aber nicht wissen.
                  Zumal im log ja was anderes stand.
                  Aber Danke für die Info.
                  Muss ich mir mal aufschreiben.
                  Danke.
                  • bahnuhrB bahnuhr
                    Im Log steht eigentlich genau das drin, wenn man --production verwendet.
                    • bahnuhrB bahnuhr
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      cd /opt/iobroker/
                      Frage:
                      Warum ist das so?
                      mfg
                      Dieter
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @Thomas-Braun
                      das stand im log
                      Danke.
                        Es soll nun
                        verwendet werden.
                        GarganoG Offline
                        GarganoG Offline
                        Gargano
                        Was ist die empfohlene npm und nodejs Version aktuell ?
                        Ist das irgendwo immer aktuell beshrieben ? Hab leider nichts gefunden
                        bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                        • GarganoG Gargano
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          @gargano sagte in javascript bleibt rot bei iob Neustart:
                          steht doch bei Info drin:
                          Danke.
                          • GarganoG Gargano
                            @gargano
                            Nodejs@16, die bringt die passende npm@8 gleich richtig mit.
                            Wenn nodejs denn richtig installiert wurde.
                            GarganoG 1 Antwort Letzte Antwort
                              @gargano
                              GarganoG Offline
                              GarganoG Offline
                              Gargano
                              @bahnuhr
                              Danke , dann habe ich die aktuellste
                              Manchmal sieht man halt den Wald vor lauter Bäumen nicht. 🙄
                              • GarganoG Gargano
                                @bahnuhr
                                @gargano
                                iob diag
                                sagt? Die Summary reicht.
                                  @gargano
                                  iob diag
                                  GarganoG Offline
                                  GarganoG Offline
                                  Gargano
                                                       v.2023-01-02
                                  Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                  Installation:           Native
                                  Timezone:               Europe/Berlin
                                  User-ID:                1000
                                  X-Server:               false
                                  Pending OS-Updates:     0
                                  Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                          /usr/bin/node           v16.19.1
                                                          /usr/bin/npm            8.19.3
                                                          /usr/bin/npx            8.19.3
                                  ioBroker Core:          js-controller           4.0.24
                                                          admin                   6.3.6
                                  At least one iobroker host is running.
                                  Objects type: redis
                                  States  type: redis
                                  Status admin:
                                  Pending iob updates:    1
                                  Active repo(s): Beta (latest)
                                  Objects:                19917
                                  States:                 18221
                                  Size of iob-Database:
                                  5.2M    /opt/iobroker/iobroker-data/objects.json.bak
                                  40K     /opt/iobroker/iobroker-data/states.json.bak
                                  • GarganoG Gargano
                                                         v.2023-01-02
                                    User-ID:                1000
                                    X-Server:               false
                                                            /usr/bin/npm            8.19.3
                                                            /usr/bin/npx            8.19.3
                                                            admin                   6.3.6
                                    Objects type: redis
                                    States  type: redis
                                    Status admin:
                                    Objects:                19917
                                    States:                 18221
                                    @gargano
                                    Passt grundsätzlich.
                                    Schaufel das Update beim iobroker noch rein und stell das RunLevel / Boot Target auf Multi-User um.
                                    • GarganoG Offline
                                      GarganoG Offline
                                      Gargano
                                      Das pending Update ist der Gerätemanager, der ist noch auf 1.1.1 , weil der 1.1.2 buggy ist und nicht funktioniert.
                                      Warum boot Target auf multi User ?
                                      • GarganoG Gargano
                                        @gargano
                                        Weil Multi-User/ RunLevel 3 für den Betrieb als Server die richtige Einstellung ist.
                                          @gargano
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          Installation:           kvm
                                          User-ID:                1000
                                          X-Server:               false
                                          Ich hab das auch so.
                                          Wo kommt dies her ?
                                          Hab ich da bei der Installation von Debian 11 irgendwo was falsch angeklickt?
                                          Wie stellt man dies um?
                                          Und ist dies notwendig?
                                          Danke.
