  4. javascript bleibt rot bei iob Neustart
javascriptiob neutstart
30 Beiträge 4 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    wenn ich iob komplett neu starten, wird die Instanz von javascript nicht grün. Die Folge ist, dass meine ganzen Scripte nicht starten.
    Im log steht folgendes:
    host.iobroker
    2023-03-04 08:36:54.584	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.iobroker
    2023-03-04 08:36:54.584	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2023-03-04 08:36:54.584	error	Caught by controller[0]: }
    host.iobroker
    2023-03-04 08:36:54.584	error	Caught by controller[0]: ]
    host.iobroker
    2023-03-04 08:36:54.584	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: requireStack: [
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker
    2023-03-04 08:36:54.583	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12) {
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:426:4)
    host.iobroker
    2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:18:15)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
    host.iobroker
    2023-03-04 08:36:54.581	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: Require stack:
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: Error: Cannot find module './sourcemap'
    host.iobroker
    2023-03-04 08:36:54.580	error	Caught by controller[0]: ^
    host.iobroker
    2023-03-04 08:36:54.579	error	Caught by controller[0]: throw err;
    host.iobroker
    2023-03-04 08:36:54.579	error	Caught by controller[0]: node:internal/modules/cjs/loader:998
    host.iobroker
    2023-03-04 08:36:54.221	info	instance system.adapter.javascript.0 started with pid 13204
    Dort steht zum Schluss dann:
    Also in putty ausgeführt:
    cd /opt/iobroker/
    npm install javascript --production
    Danach die Intanz wieder neu gestartet und alles läuft wieder.
    Frage:
    Warum ist das so?
    und warum wird die Instanz nicht bei einem iob Neustart gleich grün ?
    Und: Wie kann ich dies beheben.
    Achja: überall auf stable; mit 1 oder 2 Ausnahmen (web, ws) wg. dort ws problem. Dort bin ich auf beta.
    mfg
    Dieter
    Danke.
    HomoranH bahnuhrB 3 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      cd /opt/iobroker/
      Frage:
      Warum ist das so?
      mfg
      Dieter
      @bahnuhr sagte in javascript bleibt rot bei iob Neustart:
      ich bin jetzt nicht ganz sicher, ob du damit das
      wirklich umgesetzt hast.
      ich verstehe das so, dass du noch tiefer in die Struktur bis zum js-Adapter musst, und dort nicht
      eingeben sollst
      • bahnuhrB bahnuhr
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        cd /opt/iobroker/
        Frage:
        Warum ist das so?
        mfg
        Dieter
        hattest du ein node Update gemacht?
        wird eigentlich nach einer node Änderung angestoßen.
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @homoran sagte in javascript bleibt rot bei iob Neustart:
          Ne, das ist mir schon öfters passiert mit dem js adapter
          heute nacht um 03:00 iob neu getartet und dann ging nichts mehr
          nach
          ging es ja wieder (kann doch dann nicht ganz falsch gewesen sein)
          Danke.
          • bahnuhrB bahnuhr
            nach
            vielleicht sogar besser, und der Adapter hat es auf dem "richtigen" Weg nicht geschafft 😂
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              so, hab jetzt mal
              im Ordner: node-modules/iobroker.javascript
              ausgeführt und danach iob komplett neu gestartet.
              Jetzt ist auch JS sofort grün.
              Komisch; aber scheint nun korrekt zu laufen.
              Danke @Homoran für den Schubser in die offensichtlich richtige Richtung.
              Danke.
              GarganoG Thomas BraunT 2 Antworten Letzte Antwort
              • bahnuhrB bahnuhr
                so, hab jetzt mal
                GarganoG Offline
                GarganoG Offline
                Gargano
                Danke, hatte das gleiche Problem mit der 7.01
                • bahnuhrB bahnuhr
                  so, hab jetzt mal
                  Thomas BraunT Offline
                  Ist obsolet mit aktuellen npm Versionen.
                  Es soll nun
                  npm install --omit=dev
                  verwendet werden.
                  bahnuhrB GarganoG 2 Antworten Letzte Antwort
                    Es soll nun
                    verwendet werden.
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    Das kann man aber nicht wissen.
                    Zumal im log ja was anderes stand.
                    Aber Danke für die Info.
                    Muss ich mir mal aufschreiben.
                    Danke.
                    • bahnuhrB bahnuhr
                      Im Log steht eigentlich genau das drin, wenn man --production verwendet.
                      • bahnuhrB bahnuhr
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        cd /opt/iobroker/
                        Frage:
                        Warum ist das so?
                        mfg
                        Dieter
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @Thomas-Braun
                        das stand im log
                        Danke.
                          Es soll nun
                          verwendet werden.
                          GarganoG Offline
                          GarganoG Offline
                          Gargano
                          Was ist die empfohlene npm und nodejs Version aktuell ?
                          Ist das irgendwo immer aktuell beshrieben ? Hab leider nichts gefunden
                          bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                          • GarganoG Gargano
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            @gargano sagte in javascript bleibt rot bei iob Neustart:
                            steht doch bei Info drin:
                            Danke.
                            • GarganoG Gargano
                              @gargano
                              Nodejs@16, die bringt die passende npm@8 gleich richtig mit.
                              Wenn nodejs denn richtig installiert wurde.
                              GarganoG 1 Antwort Letzte Antwort
                                @gargano
                                GarganoG Offline
                                GarganoG Offline
                                Gargano
                                @bahnuhr
                                Danke , dann habe ich die aktuellste
                                Manchmal sieht man halt den Wald vor lauter Bäumen nicht. 🙄
                                • GarganoG Gargano
                                  @bahnuhr
                                  @gargano
                                  iob diag
                                  sagt? Die Summary reicht.
                                    @gargano
                                    iob diag
                                    GarganoG Offline
                                    GarganoG Offline
                                    Gargano
                                                         v.2023-01-02
                                    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                    Installation:           Native
                                    Timezone:               Europe/Berlin
                                    User-ID:                1000
                                    X-Server:               false
                                    Pending OS-Updates:     0
                                    Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                            /usr/bin/node           v16.19.1
                                                            /usr/bin/npm            8.19.3
                                                            /usr/bin/npx            8.19.3
                                    ioBroker Core:          js-controller           4.0.24
                                                            admin                   6.3.6
                                    At least one iobroker host is running.
                                    Objects type: redis
                                    States  type: redis
                                    Status admin:
                                    Pending iob updates:    1
                                    Active repo(s): Beta (latest)
                                    Objects:                19917
                                    States:                 18221
                                    Size of iob-Database:
                                    5.2M    /opt/iobroker/iobroker-data/objects.json.bak
                                    40K     /opt/iobroker/iobroker-data/states.json.bak
                                    • GarganoG Gargano
                                                           v.2023-01-02
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            8.19.3
                                                              /usr/bin/npx            8.19.3
                                                              admin                   6.3.6
                                      Objects type: redis
                                      States  type: redis
                                      Status admin:
                                      Objects:                19917
                                      States:                 18221
                                      @gargano
                                      Passt grundsätzlich.
                                      Schaufel das Update beim iobroker noch rein und stell das RunLevel / Boot Target auf Multi-User um.
                                      • GarganoG Offline
                                        GarganoG Offline
                                        Gargano
                                        Das pending Update ist der Gerätemanager, der ist noch auf 1.1.1 , weil der 1.1.2 buggy ist und nicht funktioniert.
                                        Warum boot Target auf multi User ?
                                        • GarganoG Gargano
                                          @gargano
                                          Weil Multi-User/ RunLevel 3 für den Betrieb als Server die richtige Einstellung ist.
