  4. [gelöst]Selbst erstellter DP aktualisiert sich in Vis nicht.
    1.0k
    3.2k
25 Beiträge 3 Kommentatoren 677 Aufrufe 3 Beobachtet
  • CodierknechtC Codierknecht
    @geraldgatt
    Also wenn Du den DP mit 'nem Script beschreibst, muss der auf jeden Fall auch beschreibbar sein.
    Und dann zeig doch mal die Einstellungen des entsprechenden Widget in Vis.
    GeraldGatt
    @codierknecht
    [{"tpl":"tplValueFloat","data":{"oid":"0_userdata.0.Iobroker_Datenpunkt_.PV_Gesamt-Einspeinung+Bezug","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Verbrauch : ","html_append_plural":"W"},"style":{"left":"743px","top":"627px","width":"250px","height":"23px","color":"gray","font-size":"x-large","text-align":"left"},"widgetSet":"basic"}]
      @geraldgatt
      HomoranH Offline
      HomoranH Offline
      @codierknecht sagte in Selbst erstellter Datenpunkt aktualisiert sich in Vis nicht.:
      nope, bezieht sich nur auf den admin!
      aber es geht ja nicht um Beschreibung des States sondern um aktulisierung eines geänderten Wertes in der vis
        @geraldgatt
        GeraldGatt
        @codierknecht
        Sind das die richtigen Einstellungen,die du benötigst?
        Danke für´s Bemühen!
          @geraldgatt
          GeraldGatt
            CodierknechtC Online
            Codierknecht
            @homoran sagte in Selbst erstellter Datenpunkt aktualisiert sich in Vis nicht.:
            Ich sag's mal so: Sowas macht man nicht 😁
            Der Funktion tut das natürlich keinen Abbruch.
            Bei mir funzt das importierte Widget dummerweise einwandfrei.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
              Codierknecht
              Außer Browsercache löschen oder mal einen anderen Browser zu probieren gehen mir da erstmal die Ideen aus.
              G CodierknechtC 2 Antworten Letzte Antwort
                GeraldGatt
                @codierknecht
                Das Widget funktioniert bei mir nur mit Daten aus Modbus. Ich werde es mal einen anderen Browser versuchen.
                  Codierknecht
                  @GeraldGatt
                  Mir dünkt, 0_userdata.0.Iobroker_Datenpunkt_.PV_Gesamt-Einspeinung+Bezug ist kein guter Name für einen DP.
                  Erzeuge mal einen neuen DP ohne das +, also z.B. 0_userdata.0.Iobroker_Datenpunkt_.PV_Gesamt-EinspeisungUndBezug
                  Edit: Grundregel beim Programmieren (und damit auch in ioBroker):
                  Keine Umlaute und/oder Sonderzeichen. Kann funktionieren, muss aber nicht und bereitet früher oder später mal Ärger.
                  Wenn überhaupt, dann auf - oder _ beschränken.
                  G 1 Antwort Letzte Antwort
                    @GeraldGatt
                    GeraldGatt
                    @codierknecht
                    Du bist der Beste!!!! Ohne Sonderzeichen funktioniert es.
                    Auf den Namen währe ich nie gekommen. Danke, des es so ein Forum mit kompetenten Leuten gibt.
                    Danke codierknecht!!!!!!
                    • G GeraldGatt
                      @codierknecht
                      Codierknecht
                      @geraldgatt
                      Das ist halt auch oft "trial-and-error" 😁
                      Bei vielen Ideen ist dann hoffentlich auch mal eine richtige dabei.
                      Dann bearbeite bitte Deinen Eingangspost und setze ein "[gelöst] - " vor den Titel.
                      HomoranH G 2 Antworten Letzte Antwort
                        @geraldgatt
                        HomoranH Offline
                        HomoranH Offline
                        nicht wirklich.
                        ich habe in der Zwischenzeit den Artikel mit den illegal characters gesucht.
                        ich hab meinen uralten Link sogar gefunden, aber in dem Ziel standen sie nicht mehr.
                        Es gibt (gab) nämlich eine Liste mit verbotenen Zeichen für die ID.
                        Gerade bei der vis können diese Zeichen als Steuerzeichen missinterpretiert werden
                          @geraldgatt
                          GeraldGatt
                          @codierknecht
                          erledigt.
                            nicht wirklich.
                            Codierknecht
                            Gemäß dem Motto: "Man muss nicht alles wissen - man muss nur wissen, wo es steht" 😁
                            Das Problem an der Ecke: Es müsste eine immer aktuelle und vollständige Doku geben.
                            Aber das ist und bleibt ein Wunschtraum - auch bei meinen Projekten. Dafür haben große Companies entsprechend große Abteilungen. Sowas kann und muss ioBroker gar nicht leisten.
                              HomoranH Offline
                              HomoranH Offline
                              @codierknecht sagte in [gelöst]Selbst erstellter DP aktualisiert sich in Vis nicht.:
                              ich habe es 5 Jahre versucht in 5 Versionen
