  4. Test Adapter MEATER v1.0.x Latest
33 Beiträge 7 Kommentatoren 4.4k Aufrufe 10 Beobachtet
  • HiltexH Hiltex
    @xbit
    Mir ist auch schon aufgefallen, dass sich das manchmal unterschiedlich verhält. Der Adapter ändert an dieser Stelle nichts, die Werte werden so übertragen.
    Du kannst ja gerne mal auf Debug umschalten und die Server-Antwort hier posten (bitte den Token x-en). Dann wissen wir das ganz genau.
    XBiTX Offline
    XBiTX Offline
    XBiT
    @hiltex
    meater.0
    2022-12-05 18:37:17.444	debug	result from cloud: {"status":"OK","statusCode":200,"data":{"devices":[{"id":"0a09f6d1f1f46d1736026XXX","temperature":{"internal":34.1,"ambient":34.1},"cook":{"id":"7d0febd907a2175509ceb622f5a6XXX","name":"Ribeye-Steak","state":"Configured","temperature":{"target":60,"peak":36.1},"time":{"elapsed":1406,"remaining":-1}},"updated_at":1670261834},{"id":"a07872209a012a1dca62cb5e21a30eb8XXX","temperature":{"internal":22.9,"ambient":22.9},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261836},{"id":"ea07d39e351c1fec796a335b898XXX","temperature":{"internal":23.3,"ambient":23.3},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261826},{"id":"ada78a25095b799e186fa951bXXX","temperature":{"internal":22.9,"ambient":23.6},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261837}]},"meta":{}}
    meater.0
    2022-12-05 18:37:16.863	debug	fetch data from cloud
    meater.0
    2022-12-05 18:37:14.755	debug	Statuscode 200 --> OK
    meater.0
    2022-12-05 18:37:14.755	debug	result from cloud: {"status":"OK","statusCode":200,"data":{"devices":[{"id":"0a09f6d1f1f46d1736026XXX","temperature":{"internal":34.1,"ambient":34.1},"cook":{"id":"7d0febd907a2175509ceb622f5a6XXX","name":"Ribeye-Steak","state":"Configured","temperature":{"target":60,"peak":36.1},"time":{"elapsed":1406,"remaining":-1}},"updated_at":1670261834},{"id":"a07872209a012a1dca62cb5e21a30eb8XXX","temperature":{"internal":22.9,"ambient":22.9},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261822},{"id":"ea07d39e351c1fec796a335b898XXX","temperature":{"internal":23.3,"ambient":23.3},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261826},{"id":"ada78a25095b799e186fa951bXXX","temperature":{"internal":22.9,"ambient":23.3},"cook":{"id":"764a386b1f","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261824}]},"meta":{}}
    meater.0
    2022-12-05 18:37:14.161	debug	fetch data from cloud
    meater.0
    2022-12-05 18:37:12.059	debug	Statuscode 200 --> OK
    meater.0
    2022-12-05 18:37:12.058	debug	result from cloud: {"status":"OK","statusCode":200,"data":{"devices":[{"id":"0a09f6d1f1f46d1736026XXX","temperature":{"internal":33.9,"ambient":33.9},"cook":{"id":"7d0febd907a2175509ceb622f5a6XXX","name":"Ribeye-Steak","state":"Configured","temperature":{"target":60,"peak":36.1},"time":{"elapsed":1392,"remaining":-1}},"updated_at":1670261820},{"id":"a07872209a012a1dca62cb5e21a30eb8XXX","temperature":{"internal":22.9,"ambient":22.9},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261822},{"id":"ea07d39e351c1fec796a335b89833XXX","temperature":{"internal":23.3,"ambient":23.3},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261826},{"id":"ada78a25095b799e186fa951XXX","temperature":{"internal":22.9,"ambient":23.3},"cook":{"id":"764a386b1fXXX","name":null,"state":"Not Started","temperature":{"target":57,"peak":null},"time":{"elapsed":0,"remaining":-1}},"updated_at":1670261824}]},"meta":{}}
    meater.0
    2022-12-05 18:37:11.454	debug	fetch data from cloud
    meater.0
    2022-12-05 18:37:09.342	debug	Statuscode 200 --> OK
    Also kommt es schon so von der Cloud die Meater App wird es nur nicht Anzeigen wenn die Werte gleich sind..
    • HiltexH Hiltex
      @xbit
      XBiTX Offline
      XBiTX Offline
      XBiT
      schrieb am zuletzt editiert von XBiT
      @Hiltex
      Sorry muss nochmal was Fragen... Jetzt sind alle Meater ausgeschaltet.... nun kommt vom Adapter diese Meldung:
      host.IoBroker
      2022-12-05 19:27:47.220	error	instance system.adapter.meater.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      meater.0
      2022-12-05 19:27:46.673	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      meater.0
      2022-12-05 19:27:46.672	info	terminating
      meater.0
      2022-12-05 19:27:46.670	error	Unexpected token < in JSON at position 0
      meater.0
      2022-12-05 19:27:46.670	error	SyntaxError: Unexpected token < in JSON at position 0 at JSON.parse (<anonymous>) at /opt/iobroker/node_modules/iobroker.meater/main.js:82:40
      meater.0
      2022-12-05 19:27:46.670	error	unhandled promise rejection: Unexpected token < in JSON at position 0
      meater.0
      2022-12-05 19:27:46.670	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Muss das so?
      G HiltexH 2 Antworten Letzte Antwort
      • XBiTX XBiT
        @Hiltex
        host.IoBroker
        meater.0
        meater.0
        meater.0
        meater.0
        meater.0
        meater.0
        Muss das so?
        guergen
        @xbit Uiii, habe ich auch um 19:25 bekommen..... gleich mehrmals
        Und nen loop gab es ebenso
        • XBiTX XBiT
          @Hiltex
          host.IoBroker
          meater.0
          meater.0
          meater.0
          meater.0
          meater.0
          meater.0
          Muss das so?
          HiltexH Offline
          HiltexH Offline
          Hiltex
          @xbit nein, das soll nicht so. Ich habe vor ein paar Minuten ein neues Release hochgeladen, das genau diesen Fehler adressiert.
          Blog: indibit.de
          XBiTX 1 Antwort Letzte Antwort
          • HiltexH Hiltex
            XBiTX Offline
            XBiTX Offline
            XBiT
            @hiltex @guergen
            Danke läuft mit der neuen Version.
            • HiltexH Offline
              HiltexH Offline
              Hiltex
              schrieb am zuletzt editiert von Hiltex
              Ich habe gerade die Version 0.2.0 veröffentlicht.
              Dabei gab es folgende Änderungen:
              • hinzugefügt: Es gibt einen neuen Datenpunkt, mit dem man das Update manuell antriggern kann
              • verbessert: Beschreibung von Fehlern (ob es ein Fehler vom MEATER Cloud Server oder ein im Adapter unbehandelter Fehler ist)
              • behoben: Wenn der MEATER Cloud Server einen Fehler zurückgesandt hat, der nicht von der API kam, dann hat der Adapter bis zum Neustart keine keine Daten mehr abgerufen
              Viel Spaß beim Testen.
              Blog: indibit.de
              • HiltexH Offline
                HiltexH Offline
                Hiltex
                Ich habe gerade die Version 0.2.1 veröffentlicht.
                Der MEATER Cloud Server scheint ab und an echte Probleme zu haben und sendet einen Fehler, der im Error-Handling bisher nicht berücksichtigt war. Das führte dann zum Absturz des Adapters. Dieses Problem wird nun berücksichtigt und sodass der Adapter nun weiter laufen sollte, wenn dieses Problem wieder auftritt.
                Blog: indibit.de
                • HiltexH Offline
                  HiltexH Offline
                  Hiltex
                  Gestern wurde das Review vom MEATER-Adapter abgeschlossen. Er ist jetzt im Latest-Repository verfügbar und kann ganz normal über den Adapter-Tab innerhalb der ioBroker-Oberfläche installiert werden, sofern man in den Einstellungen "Latest" ausgewählt hat.
                  Blog: indibit.de
                  • HiltexH Offline
                    HiltexH Offline
                    Hiltex
                    Ich habe gerade die Version 0.2.2 veröffentlicht.
                    Die Fehlerbehandlung wurde nochmal nachjustiert, wenn der Cloud-Server nicht die korrekte Antwort sendet. Bei mir kam heute ein Restart-Loop, da ein Fehler nicht abgefangen war.
                    Blog: indibit.de
                    • HiltexH Hiltex
                      XBiTX Offline
                      XBiTX Offline
                      XBiT
                      @hiltex
                      bei mir auch bin nur noch nicht dazu gekommen etwas zu schreiben.
                      Danke für das Update.
                      • HiltexH Offline
                        HiltexH Offline
                        Hiltex
                        Ich habe gerade die Version 0.2.3 veröffentlicht.
                        Es gab keine funktionellen Änderungen, ich hab nur das Error-Logging ein bisschen aufgeräumt. D.h., dass im Fall eines Fehlers jetzt nicht mehr 5 Einträge im Log auftauchen, sondern nur noch einer. Die Rückmeldungen vom Cloud-Server sind jetzt nur noch im Debug-Mode zu sehen, da man ohnehin nichts machen kann, wenn er ein Problem hat.
                        Ich würde den Adapter gern bald ins Stable-Repository schieben. Wenn also noch jemand Probleme oder Wüsche hat, dann wäre es ein guter Zeitpunkt sich hier zu melden :)
                        Blog: indibit.de
                          schmidti
                          wie komme ich an das Widget?
                          Schmidti
                          HiltexH 1 Antwort Letzte Antwort
                          • S schmidti
                            Schmidti
                            HiltexH Offline
                            HiltexH Offline
                            Hiltex
                            @schmidti
                            Sorry für die späte Antwort. Es handelt sich dabei nicht um ein richtiges Widget, sondern einen Export aus VIS. Zu finden ist das in dem alten Repository, wo das ganze noch kein Adapter war, sondern ein einfaches Script:
                            https://github.com/Standarduser/iobroker-meater-script/tree/beta/vis
                            Damit alles korrekt angezeigt wird musst du die Material-Design-Widgets installiert haben und den Inhalt der user.css in den CSS-Tab in VIS übernehmen
                            Blog: indibit.de
                            • HiltexH Offline
                              HiltexH Offline
                              Hiltex
                              ich hatte vor knapp zwei Wochen die Version 1.0.2 veröffentlicht, die einige auch schon installiert haben.
                              Von den Funktionen her hatte sich nichts geändert, lediglich der Node 14-Support wurde aufgegeben und ein paar Abhängigkeiten angepasst.
                              Hat jemand Probleme mit der Version, sonst würde ich diese Version ins Stable schieben.
                              Blog: indibit.de
                              XBiTX G 2 Antworten Letzte Antwort
                              • HiltexH Hiltex
                                XBiTX Offline
                                XBiTX Offline
                                XBiT
                                @hiltex
                                Habe leider die letzten Wochen nicht mit dem Meater gegrillt, kann leider deshalb keine Auskunft geben. Sorry....
                                • HiltexH Hiltex
                                  guergen
                                  @hiltex Bisher keine Probleme!
                                    dotcomers
                                    Hallo, sehr coller Adapter, sobald ich den Kochvorgang beende, Stürzt der Adapter ab und endet in einem Loop, gibt es vll einen Tipp für mich? vielen DankBildschirmfoto 2023-12-26 um 09.32.16.png
                                    • D dotcomers
                                      HiltexH Offline
                                      HiltexH Offline
                                      Hiltex
                                      @dotcomers
                                      Würdest du dazu bitte ein Issue auf Github eröffnen und das Log mit einfügen?
                                      https://github.com/Standarduser/ioBroker.meater/issues
                                      Vielen Dank.
                                      Blog: indibit.de
                                      • F Offline
                                        flisse
                                        Moin,
                                        ich bin erst seit kurzem Besitzer des Meater+ und habe mal eine grundlegende, wenn auch vielleicht blöde Frage dazu.
                                        Funktioniert der Adapter nur, wenn das Smartphone in der Nähe ist und die Verbindung zu der Basisstation vom Meater hergestellt hat oder gibt es die Möglichkeit etwas zu installieren, damit das Smartphone nicht zwingend nötig ist?
                                        • F flisse
                                          Moin,
                                          HiltexH Offline
                                          HiltexH Offline
                                          Hiltex
                                          @flisse
                                          Die Meater-Thermometer funktionieren alle über Bluetooth, sodass die Reichweite begrenzt ist.
                                          Aber es gibt den Meater Block, der es ermöglicht, die Thermometer über WLAN zu betreiben. Er bildet dann die Schnittstelle zur Cloud, sodass man mit dem Smartphone nicht mehr in der Nähe bleiben muss, weil die Thermometer mit dem Block gekoppelt sind.
                                          Blog: indibit.de
