  4. Adapter "smartmeter"
    6.7k
3.6k Beiträge 281 Kommentatoren 3.0m Aufrufe 162 Beobachtet
  • apollon77A apollon77
    @glh-510 Dbeug log und posten bzw als File attachen
    GLH 510G Offline
    GLH 510G Offline
    GLH 510
    #3157
    @apollon77
    smartmeter.0
    1785	2023-01-29 20:54:42.448	debug	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    1785	2023-01-29 20:54:42.446	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    1785	2023-01-29 20:50:31.994	debug	connected set to false
    smartmeter.0
    1785	2023-01-29 20:50:31.976	silly	States system redis pmessage system.adapter.smartmeter.0.logLevel/system.adapter.smartmeter.0.logLevel:{"val":"silly","ack":true,"ts":1675021831953,"q":0,"from":"system.adapter.smartmeter.0","lc":1675004875703}
    smartmeter.0
    1785	2023-01-29 20:50:31.947	debug	SmartmeterObis options: {"debug":0,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":300,"transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_0061CBBF-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":250000,"protocolD0WakeupCharacters":0,"protocolD0SignOnMessage":"?!","obisFallbackMedium":1}
    smartmeter.0
    1785	2023-01-29 20:50:31.918	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v14.19.0, js-controller: 4.0.24
    smartmeter.0
    1785	2023-01-29 20:50:31.484	debug	Plugin sentry Initialize Plugin (enabled=true)
    smartmeter.0
    11728	2023-01-29 20:49:01.516	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    smartmeter.0
    11728	2023-01-29 20:49:01.515	debug	Plugin sentry destroyed
    smartmeter.0
    11728	2023-01-29 20:49:01.428	info	Got terminate signal TERMINATE_YOURSELF
    smartmeter.0
    11728	2023-01-29 20:49:01.427	silly	States system redis pmessage system.adapter.smartmeter.0.sigKill/system.adapter.smartmeter.0.sigKill:{"val":-1,"ack":false,"ts":1675021741354,"q":0,"from":"system.host.raspberrypi","lc":1675021741354}
    smartmeter.0
    11728	2023-01-29 20:40:44.731	debug	Error: No or too long answer from Serial Device after last request.
    • GLH 510G GLH 510
      Da bei mir /?! das Ansprechzeichen ist, ist es wohl leider nicht D0 Standardkonform :-(
      @apollon77 said in Adapter "smartmeter":
      Generell gilt: Instanz auf Debug log stellen, Settings machen mit SO WENIG WIE MÖGLICH Änderungen (siehe oben), dann ins Log schauen. Dann sehr Ihr (bzw könnt es posten) was rein kommt an Daten und seht auch was der adapter tut. Wenn nur ein "Timeout weil keine Antwott kommt) dann ist generell was falsch und das gerät antwortet nicht oder der Kopf sitzt nicht korrekt.
      Die Frage ist was halt noch falsch sein kann. Der Timeout "Wartezeit auf serielle Antwort" steht auf 250 sec (Die Antwort dauert kürzer). Der Kopf sitzt richtig, sonst könnte ich nicht per Befehle von der Console aus senden die Antwort sehen.
      #3158
      @glh-510 sagte in Adapter "smartmeter":
      nochmals: Wo hast du diese Info her?
      @homoran Hab ich von da: https://digitaldad.de/2022/03/13/iobroker-stromzaehler-auslesen/
      dort habe ich nichts über deinen Zählertyp gefunden.
      @homoran sagte in Adapter "smartmeter":
      und wo stehen da die Daten für deinen Zähler?
      Fast jeder Zählertyp brauch andere Einstellungen.
      Aber erst einmal machen was jetzt auch noch @apollon77 sagt un @wendy2702 und ich bereits vorher:
      erst einmal Standardeinstellungen!
      hast du das inzwischen gemacht?
      Ist das log mit default Einstellungen vom Adapter?
      • GLH 510G GLH 510
        @apollon77
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        #3159
        @glh-510 baudrate bitte eintragen mit 300. und die selbst angegebene signon Nachricht rauslöschen.
        GLH 510G 2 Antworten Letzte Antwort
          GLH 510G Offline
          GLH 510G Offline
          GLH 510
          #3160
          @apollon77 Die Signon Nachricht hatte ich schon vorher rausgelöscht. Aber mit der 300 funktioniert es nun. Vielen Dank für die Hilfe.
          • GLH 510G GLH 510
            #3161
            @glh-510 warum kommen diese Informationen immer erst, wenn man mit der Fehlersuche schon/noch woanders ist?
              GLH 510G Offline
              GLH 510G Offline
              GLH 510
              #3162
              Es funktioniert jetzt auch die Baudratenerhöhung auf 19200baud. Leider aber nicht auf die "nicht standardkonforme" Baudrate von 115200. Würde das der Adapter eigentlich auch können oder sind die erlaubten Baudraten gemäß Standard programmiert?
              • GLH 510G GLH 510
                #3163
                Ja natürlich sind Sie das :-) Hätte auch bisher noch keinen Zähler gesehen der sowas kann ,...
                • GLH 510G Offline
                  GLH 510G Offline
                  GLH 510
                  #3164
                  @apollon77 Danke. Dann spiel ich mal ein wenig mit D0Protocol.js rum 😀
                    SuperDa
                    #3165
                    Hat niemand einen Vorschlag wie ich die folgenden Werte im Adapter einstellen muss, damit mein SensoStar U Daten ausspuckt?
                    WakeUp: 0x55 für 2,2Sek bzw. 53x 55555555555555555555 > 8N1,2400Baud
                    Antwortpause: 350ms
                    gefolgt von: 105BFE5916 >8E1,2400Baud
                    Der WMZ ist dann 4 Sekunden lang erreichbar, wenn keine weiteren Anfragen folgen, ansonsten muss dieser wie oben beschrieben wieder aufgeweckt werden.
                    Ansonsten liefert der SensoStar optisch 4x am Tag Daten.
                    Egal wie ich den Adapter einstelle, erscheint im LOG die Warnung "No or too long answer from Serial Device after last request."
                    Mit dem PC Programm "LorusFree" habe ich direkt auf Kopfdruck sämtliche Daten fehlerfrei erhalten, dann muss es doch auch mit dem Adapter funktionieren!?
                    Könnt Ihr mir bitte Helfen, ich komme an der Stelle einfach nicht weiter.
                    Vielen Dank!
                    Daniel
                    Meine aktuellen Einstellungen:
                    wendy2702W apollon77A 2 Antworten Letzte Antwort
                    • S SuperDa
                      Antwortpause: 350ms
                      Vielen Dank!
                      Daniel
                      wendy2702W Online
                      wendy2702W Online
                      #3166
                      @superda Keine Ahnung ob ich das Richtige Datenblatt gefunden habe, aber in dem welches ich gefunden habe steht bei den Schnittstellen nichts von dem was der Smartmeter Adapter kann:
                      optische Schnittstelle (M-Bus-Protokoll);
                      optional: wireless M-Bus; wireless M-Bus + 3 Impulseingänge; M-Bus;
                      M-Bus + 3 Impulseingänge; Modbus RTU; LoRaWAN + 3 Impulseingänge;
                      1 Impulsausgang; 2 Impulsausgänge
                      Ist das denn das Teil hier:
                      https://www.engelmann.de/wp-content/uploads/2022/09/Datenblatt_SensoStar_U_2022_09_14_de.pdf
                      • wendy2702W wendy2702
                        SuperDa
                        #3167
                        @wendy2702 Vielen Dank für Deine schnelle Rückmeldung! Ja, es ist der richtige WMZ. D.h. obwohl der Smartmeter Adapter das D0 Protokoll anbietet, ist es für den WMZ ungeeignet?
                        Der WMZ muss "aufgeweckt" werden, deshalb dachte ich, dass der Adapter bzw. Protokoll passen.
                        Ansonsten gibt es allgemein keine Erfahrungswerte mit Engelmann Zählern? Es gibt auch baugleiche wie von Elster.
                        • F Offline
                          fliegema
                          schrieb am zuletzt editiert von fliegema
                          #3168
                          Moin in die Runde,
                          bin leider mit der gelben Lampe des Adpaters gesegnet und komme nach Tagen des Googlns nichts weiter. Vlt. erkennt von Euch einer meinen Fehler.
                          Hardware: RPI 4 + USB IR Lesekopf EHZ Lese-Schreib-Kopf Volkszähler Hichi Smartmeter
                          Zähler: eBZ DD3 BZ06 DTA - SMZ1
                          Smartmeter auf einem ioBorker slave installiert.
                          bekomme auch auf der Konsole eine Ausgabe, also scheint die schlichte Verbindung zu klappen (die 1b 1b 1b kommt auch mit):
                          ~ $ cat /dev/ttyUSB0 | od -tx1
                          0000000 07 42 5a 44 44 33 0b 09 01 45 42 5a 01 00 10 4c
                          0000020 70 01 01 63 62 60 00 76 05 00 84 4a 0b 62 00 62
                          0000040 00 72 65 00 00 07 01 77 01 0b 09 01 45 42 5a 01
                          0000060 00 10 4c 70 01 72 62 01 65 03 39 47 91 7c 77 07
                          0000100 81 81 c7 82 03 ff 01 01 01 01 04 45 42 5a 01 77
                          0000120 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 42
                          0000140 5a 01 00 10 4c 70 01 77 07 01 00 01 08 00 ff 64
                          0000160 01 01 80 01 62 1e 52 fb 69 00 00 00 83 5f 19 f3
                          0000200 78 01 77 07 01 00 01 08 01 ff 01 01 62 1e 52 fb
                          0000220 69 00 00 00 83 59 0b a8 78 01 77 07 01 00 01 08
                          0000240 02 ff 01 01 62 1e 52 fb 69 00 00 00 00 06 0e 4b
                          0000260 00 01 77 07 01 00 10 07 00 ff 01 01 62 1b 52 fe
                          0000300 55 00 01 47 aa 01 77 07 01 00 24 07 00 ff 01 01
                          0000320 62 1b 52 fe 55 00 00 13 4a 01 77 07 01 00 38 07
                          0000340 00 ff 01 01 62 1b 52 fe 55 00 01 30 f8 01 77 07
                          0000360 01 00 4c 07 00 ff 01 01 62 1b 52 fe 55 00 00 03
                          0000400 68 01 77 07 01 00 20 07 00 ff 01 01 62 23 52 ff
                          0000420 63 09 62 01 77 07 01 00 34 07 00 ff 01 01 62 23
                          0000440 52 ff 63 09 4f 01 77 07 01 00 48 07 00 ff 01 01
                          0000460 62 23 52 ff 63 09 5c 01 01 01 63 3d d3 00 76 05
                          0000500 00 84 4a 0c 62 00 62 00 72 65 00 00 02 01 71 01
                          0000520 63 bd 43 00 1b 1b 1b 1b 1a 00 77 5d 1b 1b 1b 1
                          Mit minicom kommt auch viel raus.
                          sudo minicom -D /dev/ttyUSB0 -b 9600 7E1 --displayhex --wrap
                          Hier in der Suche Forum Suche haben auch einige einen DD3 Zähler und alle Einstellungen klappen bei mir im Smartmeter leider nicht.
                          Letzte Smartmeter Einstellung:
                          Es sol laut Anleitung folgendes gehen:
                          Habe mich ebenfalls versucht an "DigitalDad"s Guide zu halten, hat auch nicht geklappt Link zur Website
                          im Debug mode bekomme ich seeeeeeeeehr viele Meldungen bis hin das mein Master ioBroker in die Knie gehen will.
                          smartmeter.0
                          2023-02-04 13:19:12.550	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          smartmeter.0
                          2023-02-04 13:19:12.550	debug	ADD NEW DATA (9131 + NEW 4)
                          smartmeter.0
                          2023-02-04 13:19:12.547	debug	MATCH-RESULT SIGNON: "+\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u0015\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\ta\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t[\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\t`\u0001\u0001\u0001c/\u0012\u0000v\u0005\u0000\u0004^jb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cL-\u0000\u001b\u001b\u001b\u001b\u001a\u0000\nW\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^nb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001cmu\u0000v\u0005\u0000\u0004^ob\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039Jw|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`B\b\u0000\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z3=\u0000\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001o8\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\u0016\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001@\u0013\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u000f\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t\\\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t_\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\t\\\u0001\u0001\u0001cTK\u0000v\u0005\u0000\u0004^pb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c.Q\u0000\u001b\u001b\u001b\u001b\u001a\u0000Ob\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^tb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u0018}\u0000v\u0005\u0000\u0004^ub\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039Jx|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`Bm\u0001\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z4\"\u0001\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001iO\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\f\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001:\u001c\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c'\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tW\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t\\\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tf\u0001\u0001\u0001ct,\u0000v\u0005\u0000\u0004^vb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c@L\u0000\u001b\u001b\u001b\u001b\u001a\u00000 \u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^zb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\r\u000f\u0000v\u0005\u0000\u0004^{b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039Jy|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`BQ|\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z4\u0006|\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001k\n\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\u0018\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001<:\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c8\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t^\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t]\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\ta\u0001\u0001\u0001cZd\u0000v\u0005\u0000\u0004^|b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001crj\u0000\u001b\u001b\u001b\u001b\u001a\u0000G_\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^\u0000b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c_\u001e\u0000v\u0005\u0000\u0004^\u0001b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039Jz|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`C6b\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z4kb\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001k<\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012g\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001<3\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\"\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tU\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t_\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tb\u0001\u0001\u0001c\u0006X\u0000v\u0005\u0000\u0004^\u0002b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cw\u0010\u0000\u001b\u001b\u001b\u001b\u001a\u00008b\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^\u0006b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u0000r\u0000v\u0005\u0000\u0004^\u0007b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039J{|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`C\u001aQ\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z5OQ\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001gC\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012n\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u00018/\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c&\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tY\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t[\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\th\u0001\u0001\u0001c\u001cV\u0000v\u0005\u0000\u0004^\bb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cE6\u0000\u001b\u001b\u001b\u001b\u001a\u0000r#\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^\fb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001cpO\u0000v\u0005\u0000\u0004^\rb\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039J||w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`C\"\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z54\"\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001jo\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012f\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001;g\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\"\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t[\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t]\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\te\u0001\u0001\u0001c\u001du\u0000v\u0005\u0000\u0004^\u000eb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c++\u0000\u001b\u001b\u001b\u001b\u001a\u0000W\u0004\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^\u0012b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c`\b\u0000v\u0005\u0000\u0004^\u0013b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039J}|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`Dcz\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z6\u0018z\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001gq\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012I\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u00018\u0016\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u0012\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tV\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\ta\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\ta\u0001\u0001\u0001c(8\u0000v\u0005\u0000\u0004^\u0014b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cIW\u0000\u001b\u001b\u001b\u001b\u001a\u0000sl\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^\u0018b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u00105\u0000v\u0005\u0000\u0004^\u0019b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039J~|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`DI=\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z6~=\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001nX\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\u0016\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001?6\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\f\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t]\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t\\\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tf\u0001\u0001\u0001cE-\u0000v\u0005\u0000\u0004^\u001ab\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cOg\u0000\u001b\u001b\u001b\u001b\u001a\u0000Jo\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^\u001eb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001cOY\u0000v\u0005\u0000\u0004^\u001fb\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039J|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`E-\u0004\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z6b\u0004\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001i\u0000\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u00124\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001:\u000b\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001cA\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tV\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\ta\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\te\u0001\u0001\u0001cqi\u0000v\u0005\u0000\u0004^ b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c\r.\u0000\u001b\u001b\u001b\u001b\u001a\u0000\u001a\u0016\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^$b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c0:\u0000v\u0005\u0000\u0004^%b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0000|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`E\u0013\u001b\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z7H\u001b\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001o\u0005\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012w\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001@1\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c]\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tX\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tb\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\ta\u0001\u0001\u0001cdt\u0000v\u0005\u0000\u0004^&b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cc3\u0000\u001b\u001b\u001b\u001b\u001a\u00003m\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^*b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c%H\u0000v\u0005\u0000\u0004^+b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0001|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`Ey)\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z7.)\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001of\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\u000b\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001@X\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u0003\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t[\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t_\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\te\u0001\u0001\u0001c)\u000b\u0000v\u0005\u0000\u0004^,b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cQ\u0015\u0000\u001b\u001b\u001b\u001b\u001a\u0000;\u000e\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^0b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001cP@\u0000v\u0005\u0000\u0004^1b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0002|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`F_e\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z8\u0014e\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001p\u000b\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012p\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001@v\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c%\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tT\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\ta\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tg\u0001\u0001\u0001cx~\u0000v\u0005\u0000\u0004^2b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c\u0007\u0000\u001b\u001b\u001b\u001b\u001a\u0000;\u000b\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^6b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u000f,\u0000v\u0005\u0000\u0004^7b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0003|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`FEZ\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z8zZ\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001o\n\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\u0016\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001?>\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c6\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t[\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t]\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tb\u0001\u0001\u0001cF\u0001\u0000v\u0005\u0000\u0004^8b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c5Y\u0000\u001b\u001b\u001b\u001b\u001a\u0000 J\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^<b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u0011\u0000v\u0005\u0000\u0004^=b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0004|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`G,/\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z8a/\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001pg\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013*\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001A\u0015\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c(\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tX\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t]\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\te\u0001\u0001\u0001cwb\u0000v\u0005\u0000\u0004^>b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c[D\u0000\u001b\u001b\u001b\u001b\u001a\u0000{/\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^Bb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001cqk\u0000v\u0005\u0000\u0004^Cb\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0005|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`G\u00129\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z9G9\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001oX\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\u001a\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001?8\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u0006\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tY\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tX\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\th\u0001\u0001\u0001c\u0017\u0016\u0000v\u0005\u0000\u0004^Db\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cHn\u0000\u001b\u001b\u001b\u001b\u001a\u0000\u000f'\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^Hb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u0001V\u0000v\u0005\u0000\u0004^Ib\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0006|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`Gy.\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z9..\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001r\"\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u00132\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001C/\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001cA\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t`\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tY\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tb\u0001\u0001\u0001c?\u0018\u0000v\u0005\u0000\u0004^Jb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cN^\u0000\u001b\u001b\u001b\u001b\u001a\u0000d6\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^Nb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c^:\u0000v\u0005\u0000\u0004^Ob\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u0007|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`H_\u0015\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z:\u0014\u0015\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001nZ\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012w\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001?C\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c \u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tX\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\t[\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tc\u0001\u0001\u0001cV\"\u0000v\u0005\u0000\u0004^Pb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c,\"\u0000\u001b\u001b\u001b\u001b\u001a\u00000)\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^Tb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c+2\u0000v\u0005\u0000\u0004^Ub\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\b|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`HD9\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z:y9\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001mg\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013&\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001>?\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u0002\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t[\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tU\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\ti\u0001\u0001\u0001c\u001bj\u0000v\u0005\u0000\u0004^Vb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cB?\u0000\u001b\u001b\u001b\u001b\u001a\u0000(4\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^Zb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c>@\u0000v\u0005\u0000\u0004^[b\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\t|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`I+A\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z:`A\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001q \u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012>\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001Bi\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001by\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t_\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tX\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tb\u0001\u0001\u0001cw^\u0000v\u0005\u0000\u0004^\\b\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cp\u0019\u0000\u001b\u001b\u001b\u001b\u001a\u0000Dj\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^`b\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001cA#\u0000v\u0005\u0000\u0004^ab\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\n|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`I\u000b,\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z;@,\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001YN\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u00125\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001*\u001a\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001b\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tZ\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tV\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tc\u0001\u0001\u0001c6g\u0000v\u0005\u0000\u0004^bb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c\u0006F\u0000\u001b\u001b\u001b\u001b\u001a\u0000TW\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^fb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u001eO\u0000v\u0005\u0000\u0004^gb\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u000b|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`IgO\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z;\u001cO\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001M}\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0012m\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001\u001e\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u0011\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t^\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tT\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\th\u0001\u0001\u0001cVM\u0000v\u0005\u0000\u0004^hb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c4`\u0000\u001b\u001b\u001b\u001b\u001a\u0000Ou\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^lb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001cnr\u0000v\u0005\u0000\u0004^mb\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\f|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`JDx\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z;yx\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001M\u0014\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013j\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001\u001e\b\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\"\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t\\\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tX\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tc\u0001\u0001\u0001c][\u0000v\u0005\u0000\u0004^nb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001cZ}\u0000\u001b\u001b\u001b\u001b\u001a\u0000\u0019w\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^rb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c~5\u0000v\u0005\u0000\u0004^sb\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\r|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`J#0\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z<X0\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001VI\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013\b\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001'?\u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001c\u0002\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\tZ\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tT\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tb\u0001\u0001\u0001c\u0013%\u0000v\u0005\u0000\u0004^tb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c8\u0001\u0000\u001b\u001b\u001b\u001b\u001a\u0000SK\u001b\u001b\u001b\u001b\u0001\u0001\u0001\u0001v\u0005\u0000\u0004^xb\u0000b\u0000re\u0000\u0000\u0001\u0001v\u0001\u0001\u0007eBZDD3\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001\u0001c\u000e\b\u0000v\u0005\u0000\u0004^yb\u0000b\u0000re\u0000\u0000\u0007\u0001w\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001rb\u0001e\u00039K\u000e|w\u0007\u0001\u0001G\u0002\u0003\u0001\u0001\u0001\u0001\u0004EBZ\u0001w\u0007\u0001\u0000\u0000\u0000\t\u0001\u0001\u0001\u0001\u000b\t\u0001EBZ\u0001\u0000\u0010Lp\u0001w\u0007\u0001\u0000\u0001\b\u0000d\u0001\u0001\u0000\u0001b\u001eR{i\u0000\u0000\u0000\u0003`K\fI\u0001w\u0007\u0001\u0000\u0001\b\u0001\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0003Z<AI\u0001w\u0007\u0001\u0000\u0001\b\u0002\u0001\u0001b\u001eR{i\u0000\u0000\u0000\u0000\u0006\u000eK\u0000\u0001w\u0007\u0001\u0000\u0010\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001zX\u0001w\u0007\u0001\u0000$\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u0013E\u0001w\u0007\u0001\u00008\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0001K \u0001w\u0007\u0001\u0000L\u0007\u0000\u0001\u0001b\u001bR~U\u0000\u0000\u001bs\u0001w\u0007\u0001\u0000 \u0007\u0000\u0001\u0001b#Rc\t`\u0001w\u0007\u0001\u00004\u0007\u0000\u0001\u0001b#Rc\tT\u0001w\u0007\u0001\u0000H\u0007\u0000\u0001\u0001b#Rc\tg\u0001\u0001\u0001c&\u0000\u0000v\u0005\u0000\u0004^zb\u0000b\u0000re\u0000\u0000\u0002\u0001q\u0001c>1\u0000\u001b\u001b\u001b" -> null
                          smartmeter.0
                          2023-02-04 13:19:12.546	debug	CURRENT PROCESS STEP 0 IN CHECKMESSAGE
                          smartmeter.0
                          2023-02-04 13:19:12.546	debug	ADD NEW DATA (9128 + NEW 3)
                          Habe selbstverständlich den IR Lesekopf bereits gedreht, leider ohne Erfolg.
                          Der Zähler hat zwei Ausgaben:
                          Habe sowohl MSB als auch Info ausprobiert.
                          Wohl gemerkt, hatte vorher einen Hichi Wifi Lesekopf auf dem hat das auslesen auf der Info Schnittstelle wunderbar geklappt. Leider ist das WLAN bis in den Keller unzureichend für den Wifi Lesekopf gewesen, daher die Lösung mit ioBroker Slave und USB Lesekopf.
                          Wie in dieser Topic auch beschrieben, habe ich den Adapter auch mal auf Standard gelassen, leider auch ohne Erfolg.
                          Würde mich sehr über Hilfe von Euch freuen.
                          Cheers
                          K apollon77A 2 Antworten Letzte Antwort
                          • S SuperDa
                            Antwortpause: 350ms
                            Vielen Dank!
                            Daniel
                            #3169
                            @superda Ääähhmm ... DU hattest aber schon meine letzte Antwort gesehen??
                            Da hatte ich schon geschrieben das das eher nach MBus aussieht und das ist ein anderer Adapter und ein ganz anderes Protokoll
                            • F fliegema
                              Moin in die Runde,
                              smartmeter.0
                              smartmeter.0
                              smartmeter.0
                              smartmeter.0
                              smartmeter.0
                              klassisch
                              #3170
                              @fliegema Der Vollständigkeit halber: es darf immer nur EIN EINZIGES Programm die serielle Schnittstelle /USB beanspruchen.
                              Also alle anderen Tools aus, Raspi neustarten. Erst dann kann es losgehen.
                              • S SuperDa
                                #3171
                                @superda Nochmal: Aufwecken ist nicht das Problem, aber das was laut Spec dann gesendet werden muss ist eine MBUS message und nicht D0 !! Also wenn das echt D0 sein sollte (!!) dann ist das alles ne reine Katastrophe. AM besten frage doch mal beim Hersteller an wie genau D0 gehen soll
                                • F fliegema
                                  Moin in die Runde,
                                  smartmeter.0
                                  smartmeter.0
                                  smartmeter.0
                                  smartmeter.0
                                  smartmeter.0
                                  #3172
                                  @fliegema Also senn da "1b 1b 1b 1b" (wichtig 4 mal!) kommt dann ist das SML und nicht D0 ... Das wäre damit schonmal falsches protokoll in der gezeigten Konfig. Auch generell sehen die Daten nicht nach D0 aus, also mal SML versuchen. Damit tippe ich Du hast ein "SM" Modell? Dann ggf auch die anderen Seriellen einstellungen nutzen 9600,8, none, 1
                                    #3173
                                    @apollon77 sagte in Adapter "smartmeter":
                                    Natürlich hat er das
                                    @fliegema sagte in Adapter "smartmeter":
                                    F 1 Antwort Letzte Antwort
                                      wendy2702W Online
                                      wendy2702W Online
                                      #3174
                                      Ich hatte das oben schon geschrieben.
                                      Laut Beschreibung nix D0 und wie du richtig erkannt hast MBUS.
                                      Modbus soll er auch können.
                                        Hi All,
                                        mein Januarprojekt ist hiermit soweit das es das Licht der Welt erblicken kann und Euch zum testen zur Verfügung steht.
                                        URL zum installieren: https://github.com/Apollon77/ioBroker.smartmeter
                                        Wie bereits in einigen Threads, vor allem http://forum.iobroker.net/viewtopic.php?f=35&t=4726 diskutiert, geht es bei dem Adapter darum Smartmeter wie Stromzähler, Heizmengenzähler u.ä. Geräte auszulesen.
                                        Der Adapter unterstützt dazu verschiedene Wege des Datentransfers und verschiedene Protokolle.
                                        Datentransfers:
                                        • HTTP-URL
                                        • Lokale Datei
                                        • Serielles Device im Lesemodus
                                        • Serielles Device mit Bi-Direktionaler Kommunikation
                                        Protokolle:
                                        • D0 (ist ein Protokoll mit Bi-Direktionaler Kommuniation), also man muss nach Werten Fragen dann gibt der Zähler die erst preis
                                        • SML (SmartMeterLanguage) Wird bei vielen eHz oder EMH o.ä. Zählern ausgegeben und ist ein Standard
                                        • EFR SmartGridHub JSON-Protokoll (war ein Forum-Request)
                                        Aktuell haben alle Protokolle gemein das die Datenpunkte auf dem OBIS-Standard basieren, sodass der Adapter auch versucht den Namen zu ermitteln.
                                        So jetzt brauche ich Euch mit möglichst vielen verschiedenen Geräten :-) Bitte im Forum posten was es ist - ich will ne kleine Liste mit "bekannt Kompatibel" erstellen.
                                        Aktuell ist das Loggign per Default auf "info" und es wird noch viel geloggt. Das ändere ich dann vor offiziellem Release noch. Daher Instanz auf "warn" Loglevel setzen falls Euch das nervt :-) … Also wenn es mal klappt halt ...
                                        Hier ein paar Screens und Beispiele was Ihr erwarten könnt:
                                        Screenshot mit der Basiskonfig zum Auslesen der Daten von eine eHz oder EMH die vom Gerät geschickt werden.
                                        Wenn erfolgreich Daten ankommen dann werden die mit den OBIS-IDs, Namen und Weten im Log gelistet:
                                        2017-01-30 21:53:03.346  - info: smartmeter.0 129-129:199.130.3*255: Manufacturer ID = EMH
                                        2017-01-30 21:53:03.372  - info: smartmeter.0 1-0:0.0.9*255: Device ID = 0901454d48000041f045
                                        2017-01-30 21:53:03.383  - info: smartmeter.0 1-0:1.8.0*255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 15708.201 kWh
                                        2017-01-30 21:53:03.392  - info: smartmeter.0 1-0:1.8.1*255: Zählerstand 1 Summe Wirkarbeit Bezug + (T1) = 15708.201 kWh
                                        2017-01-30 21:53:03.398  - info: smartmeter.0 1-0:1.8.2*255: Zählerstand 1 Summe Wirkarbeit Bezug + (T2) = 0 kWh
                                        2017-01-30 21:53:03.405  - info: smartmeter.0 1-0:16.7.0*255: Momentanwert Gesamtwirkleistung (Total) = 686.6 W
                                        2017-01-30 21:53:03.411  - info: smartmeter.0 129-129:199.130.5*255: Forename/Public Key = e77ef33ea97bb6bba9bfa4fbd8b9f2ede51207b15acf6b98a237c21ca4982ee3ce18efe8438f1deba9d5c40eb68ae8f2
                                        Und das ganze wird dann als States auch angelegt und ist unter "Objekte" zu finden.
                                        Für Devices mit D0-protokoll hier auch ein Konfig-Beispiel. Bei mir ist das an der Fernwärmestation ein Siemens 2WR5 Zähler. Beim D0 Protokoll muss man etwas tiefer in die Specs des Gerätes schauen …
                                        Aktueller Stand ist das eigentlich alles läuft.
                                        Todo stand heute ist noch:
                                        • README im Github :-)
                                        • Einbau einer Option erst ab nem bestimmten Delta der Werte diese zu updaten. SML im Lesemodus von eHz kommen Daten alle 3-5 Sekunden und die ändern sich irgendwo im Nachkommastellenbereich … am Ende verursacht das Last und ich weiss nicht ob die Daten soooo aussagekräftig sind alle 5 Sekunden :-) Da nehm ich gern noch Feedback.
                                        Ingo F
                                        Thomas P 0
                                        schrieb am zuletzt editiert von Thomas P 0
                                        #3175
                                        @apollon77
                                        Hallo Apollon,
                                        ich kämpfe seit gestern mit einem Bylan BTK.30 Strömzähler. Eigentlich sollte er machen was erwartet wird. Ich habe den Smartmeter Adapter wie folgt eingestellt:
                                        Wenn ich den Zähler manuell auslese, bekommeich auch die passenden Daten. Ich habe die Einstellungen in HTerm unter Windows getestet.
                                        • 300BD 7E1 als Serielle Einstellungen
                                        • /?!<CR><LF> zum Starten der Kommunikation
                                        • Der Zähler sendet seine Identifikation
                                        • <ACK>0Z0<CR><LF>
                                        und schon kommen die Daten vom zähler. Hier als Ausschnitt:
                                        <2>0.0.0(66002067)<\r><\n>
                                        0.9.1(16:38:26)<\r><\n>
                                        0.9.2(23-02-04)<\r><\n>
                                        0.9.5(6)<\r><\n>
                                        1.8.0(001019.804*kWh)<\r><\n>
                                        1.8.0*1(000964.283*kWh)<\r><\n>
                                        1.8.0*2(000702.654*kWh)<\r><\n>
                                        1.8.1(000559.354*kWh)<\r><\n>
                                        So sollte es doch für den SMartmeter-Adapter sein, oder habe ich da noch einen Denkfelher drinnen? Ich habe mich durch die Spezifikationen mal durchgearbeitet, und eigentlich sollte er genau das erwarten. Allerdings sind meine Erfahrungen mit Serieller Kommunikation auch gut in viertel Jahrhundert her.
                                        Vielen Dank schon mal im Vorraus, und ein großes Dankeschön für die Arbeit.
                                        MfG
                                        Thomas Pfaffinger
                                        wendy2702W apollon77A 3 Antworten Letzte Antwort
                                        • T Thomas P 0
                                          @apollon77
                                          Hallo Apollon,
                                          • <ACK>0Z0<CR><LF>
                                          0.9.5(6)<\r><\n>
                                          MfG
                                          Thomas Pfaffinger
                                          wendy2702W Online
                                          wendy2702W Online
                                          #3176
                                          @thomas-p-0 sagte in Adapter "smartmeter":
                                          @apollon77
                                          Was soll uns dieser Post sagen?
