  4. Growatt exception: Error: {"result":3}
    5.4k
81 Beiträge 3 Kommentatoren 10.2k Aufrufe 3 Beobachtet
  • N nobbiman
    @wendy2702
    https://server.growatt.com
    @nobbiman
    Sonderzeichen im Passwort? Stell das mal auf was einfacheres nur aus Buchstaben und Ziffern um.
    N 2 Antworten Letzte Antwort
      @nobbiman
      N Offline
      N Offline
      nobbiman
      Nein, keine Sonderzeichen, nur Klein- und Großbuchstaben und Zahlen
      pi@iobroker-pi:~ $ nslookup server.growatt.com
      -bash: nslookup: command not found
        @nobbiman
        N Offline
        N Offline
        nobbiman
        schrieb am zuletzt editiert von nobbiman
        Nach Installation von nslookup:
        Server:         192.168.2.1
        Address:        192.168.2.1#53
        Non-authoritative answer:
        Address: 47.91.67.66
        pi@iobroker-pi:~ $ ping 47.91.67.66
        PING 47.91.67.66 (47.91.67.66) 56(84) bytes of data.
        64 bytes from 47.91.67.66: icmp_seq=1 ttl=95 time=12.9 ms
        64 bytes from 47.91.67.66: icmp_seq=2 ttl=95 time=11.4 ms
        64 bytes from 47.91.67.66: icmp_seq=3 ttl=95 time=12.4 ms
        64 bytes from 47.91.67.66: icmp_seq=4 ttl=95 time=11.3 ms
        Fehler aber auch noch Host-Neustart immer noch da! Auch nach Deinstallation des Adapters und Instanz , Neustart und Neuinstallation nicht!
        $ iobroker add growatt auto --host iobroker-pi --debug
        NPM version: 8.19.3Installing iobroker.growatt@2.0.0... (System call)
        npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        added 9 packages in 14s88 packages are looking for funding run `npm fund` for details
        host.iobroker-pi install adapter growatt
        upload [4] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/glogo.png glogo.png image/png
        upload [3] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/growatt.png growatt.png image/png
        upload [2] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/index_m.html index_m.html text/html
        upload [1] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/style.css style.css text/css
        upload [0] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/words.js words.js application/javascript
        host.iobroker-pi object system.adapter.growatt.0.compactMode created
        host.iobroker-pi object system.adapter.growatt.0.cpu created
        host.iobroker-pi object system.adapter.growatt.0.cputime created
        host.iobroker-pi object system.adapter.growatt.0.memHeapUsed created
        host.iobroker-pi object system.adapter.growatt.0.memHeapTotal created
        host.iobroker-pi object system.adapter.growatt.0.memRss created
        host.iobroker-pi object system.adapter.growatt.0.uptime created
        host.iobroker-pi object system.adapter.growatt.0.inputCount created
        host.iobroker-pi object system.adapter.growatt.0.outputCount created
        host.iobroker-pi object system.adapter.growatt.0.eventLoopLag created
        host.iobroker-pi object system.adapter.growatt.0.sigKill created
        host.iobroker-pi object system.adapter.growatt.0.logLevel created
        host.iobroker-pi object growatt.0.info created
        host.iobroker-pi object growatt.0.info.connection created
        host.iobroker-pi Set default value of growatt.0.info.connection: false
        host.iobroker-pi object system.adapter.growatt.0 created
        Process exited with code 0
        • N nobbiman
          Server:         192.168.2.1
          wendy2702W Online
          wendy2702W Online
          @nobbiman Dann muss ich ehrlich sagen gehen mir die Ideen aus warum der Adapter sich nicht verbindet.
          Mach dazu am besten ein Issue auf Github auf, dann bekommt der Entwickler das mit und kann vielleicht helfen.
          N 1 Antwort Letzte Antwort
          • wendy2702W wendy2702
            N Offline
            N Offline
            nobbiman
            @wendy2702
            Ja, das ist vielleicht der richtige Weg. Danke bis hier hin, ich werde danach hoffentlich hier in diesem Thread Positives berichten können.
            • N nobbiman
              @wendy2702
              wendy2702W Online
              wendy2702W Online
              @nobbiman Gibt noch eines was man machen kann. Ein TCP dump auf dem Netzwerk IF und dann mal mit Wireshark schauen.
              Zuerst rausfinden wie das IF heisst:
              ip a
              Dann kommt z.B. so was:
              2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                  link/ether b8:27:eb:b9:82:51 brd ff:ff:ff:ff:ff:ff
                  inet 192.168.178.17/24 brd 192.168.178.255 scope global dynamic noprefixroute eth0
              Das Interface heisst dann "eth0"
              Tcpdump dann so:
              sudo tcpdump -i eth0 -s 65535 -w growatt.pcapng
              File wird in dem Ordner gespeichert in dem man den Befehl ausführt.
              Vom Pi runterladen und mit Wireshark anschauen.
              Wenn du für den Zeitraum des Tests alle anderen Adapter stoppst ist das Ergebnis übersichtlicher.
                ip a
                Tcpdump dann so:
                N Offline
                N Offline
                nobbiman
                @wendy2702 said in Growatt exception: Error: {"result":3}:
                Wireshark
                Ach du droßer Gott, da muss ich erst einmal schauen, was Wireshark ist und wie das funktioniert - bin bislang eher der Windows-User. Aber ich mache mich mal dran, wird sicher aber ein wenig dauern.
                  ip a
                  Tcpdump dann so:
                  N Offline
                  N Offline
                  nobbiman
                  @wendy2702
                  Das fängt erst einmal nicht erfolgsversprechend an!
                  pi@iobroker-pi:~ $ ip a
                  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                      inet 127.0.0.1/8 scope host lo
                         valid_lft forever preferred_lft forever
                      inet6 ::1/128 scope host
                  2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
                      link/ether e4:5f:01:a4:ad:f2 brd ff:ff:ff:ff:ff:ff
                  3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                      link/ether e4:5f:01:a4:ad:f3 brd ff:ff:ff:ff:ff:ff
                      inet 192.168.2.157/24 brd 192.168.2.255 scope global dynamic noprefixroute wlan0
                         valid_lft 858018sec preferred_lft 750018sec
                      inet6 fd00::e7b7:5373:8d3d:9248/64 scope global dynamic mngtmpaddr noprefixroute
                         valid_lft 7198sec preferred_lft 3598sec
                      inet6 fe80::c7b6:c7b1:7ac7:17a4/64 scope link
                  pi@iobroker-pi:~ $ sudo tcpdump -i eth0 -s 65535 -w growatt.pcapng
                  sudo: tcpdump: command not found
                  wendy2702W 2 Antworten Letzte Antwort
                  • N nobbiman
                    @wendy2702
                    wendy2702W Online
                    wendy2702W Online
                    @nobbiman sagte in Growatt exception: Error: {"result":3}:
                    wlan0
                    OK.
                    Dein PI ist über WLAN angebunden. Hoffentlich ist das nicht schon die Ursache allen übels.
                    Kannst du den zum testen mal per Netzwerkkabel anschließen? Ist sowieso die bessere Lösung für einen Server.
                    Der Befehl wäre dann dieser:
                    sudo tcpdump -i wlan0 -s 65535 -w growatt.pcapng
                    Wireshark ist unter anderem auch für Windows verfügbar
                      wlan0
                      OK.
                      N Offline
                      N Offline
                      nobbiman
                      Diesen Befehl verstehe ich nicht! Ich habe ein Netzwerkkabel angeschlossen und überwache 'wlan0'?
                      Nach EIngabe des o.g. Befehls hängt der RasPi!
                      pi@iobroker-pi:~ $ sudo tcpdump -i wlan0 -s 65535 -w growatt.pcapng
                      tcpdump: listening on wlan0, link-type EN10MB (Ethernet), snapshot length 65535 bytes
                      Was muss ich tun, damit ein Ergebnis in die Datei geschrieben wird oder verstehe ich nur Bahnhof?
                      Übrigens klappte das zuvor auch über WLAN! Entfernung zum Router ca. 2m!
                      • N nobbiman
                        @wendy2702
                        wendy2702W Online
                        wendy2702W Online
                        Der Befehl monitored den Netzwerk Verkehr auf dem Interface "WLAN0" und schreibt die vollständige ausgabe in ein File namens: "growatt.pcapng"
                        Der PI hängt nicht, du musst das loggen mit "strg+C" beenden.
                        • N nobbiman
                          Das kann aber eigentlich nicht sein, das Netzwerkkabel-Interface eth0 ist nämlich DOWN:
                          Dafür funkt da ein Interface namens wlan0 durch die Gegend.
                            N Offline
                            N Offline
                            nobbiman
                            @thomas-braun said in Growatt exception: Error: {"result":3}:
                            Muss ich im RasPi WLAN abschalten?
                            wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                            • N nobbiman
                              wendy2702W Online
                              wendy2702W Online
                              @nobbiman Nur wenn das Netzwerkkabel funktioniert.
                              Tut es derzeit aber nicht
                              • N nobbiman
                                @nobbiman
                                Was hast du denn da grundsätzlich für ein Netzwerk? Kabelbasiert?
                                  @nobbiman
                                  N Offline
                                  N Offline
                                  nobbiman
                                  FritzBox -> Kabel -> Switch -> Kabel (jetzt) -> RasPi
                                  • N nobbiman
                                    wendy2702W Online
                                    wendy2702W Online
                                    @nobbiman Zeig
                                    ip a
                                      @nobbiman Zeig
                                      ip a
                                      N Offline
                                      N Offline
                                      nobbiman
                                      #66
                                      @wendy2702
                                      2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                                          inet 192.168.2.146/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
                                             valid_lft 862384sec preferred_lft 754384sec
                                          inet6 fd00::3e0a:160b:48e1:5cbf/64 scope global dynamic mngtmpaddr noprefixroute
                                             valid_lft 7159sec preferred_lft 3559sec
                                          inet6 fe80::4bce:c165:ef80:5d3d/64 scope link
                                             valid_lft 863954sec preferred_lft 755954sec
                                      • N nobbiman
                                        @wendy2702
                                        wendy2702W Online
                                        wendy2702W Online
                                        #67
                                        192.168.2.146/2
                                        Jetzt geht das Kabel.
                                        Dann kannst/solltest du WLAN jetzt aus knipsen.
                                        • N nobbiman
                                          #68
                                          @nobbiman
                                          Jetzt läuft das beides.
                                          192.168.2.146 per Kabel,
                                          192.168.2.157 per WLan
