  4. iQontrol Vis Support Thread
    6.6k
android app vishow-toios appiqontrolmobile uivis
1.6k Beiträge 143 Kommentatoren 900.1k Aufrufe 122 Beobachtet
  • s.bormannS s.bormann
    Gerade veröffentlicht:
    Version 2.1.0 (2023-01-24)
    • (sbormann) Fixed marquee for INFO_A/B after resizing tile.
    • (sbormann) Subheading with no visible tiles beneath are now hided.
    • (sbormann) Added option to hide STATE and LEVEL in dialog.
    • (sbormann) Fixed default icons for ERROR, UNREACH and BATTERY (if you have changed them in a previous version you might need to change them again).
    • (sbormann) Fixed size of custom toolbar icons.
    • (sbormann) Added DISCHARGE to Battery.
    • (sbormann) Fixed Favorites not working in map-widget with instance-number.
    • (sbormann) Enhanced JSON-Table to work with alexa-shoppinglist-adapter.
    • (sbormann) Added badges to toolbar.
    • (sbormann) Enhanced handling of images in BACKGROUND_HTML.
    • (sbormann) Added option to protect instance by passphrase.
    • (sbormann) Added option to set value of LOCK_OPEN for doors with lock.
    • (sbormann) Linking color to GLOW or BACKGROUND_COLOR now works when using ALTERNATIVE_COLORSPACE.
    • (sbormann) Added URL-Parameter &language=xx.
    • (sbormann) Added option to center headers and subheaders.
    • (sbormann) Enhanced FLOT-Chart-Widget to display more Datapoints.
    • (sbormann) Fixed timestamp in JSON-Table-Widget.
    • (dirkhe) Fixed and enhanced step attribute.
    • (sbormann) Moved options caption for STATE and caption for LEVEL into section STATE, LEVEL and TIMESTAMP.
    • (sbormann) Added option to set favorite values for LEVEL.
    • (sbormann) You can now click on linked devices.
    • (sbormann) Prevented back-swiping for safari.
    • (sbormann) Updated some dependencies.
    Wird spätestens morgen im latest / beta erscheinen. Ich hoffe, alles läuft. Viele Grüße!
    da_WoodyD Offline
    da_WoodyD Offline
    #741
    @s-bormann sagte in iQontrol Vis Support Thread:
    gerade eingenietet. ich musste bei den icons nix neu ändern und funktionieren tuts auch.
    der rest wird sich weisen... :)
    • G Online
      G Online
      Gonzokalle
      #742
      Hallo, ist es richtig, dass der Gerätetyp "Knopf" einen Taster darstellen soll?
      Wie kann ich bei dem "Knopf" einen eigenen DP für die untere Anzeige einstellen?
      da_WoodyD s.bormannS 2 Antworten Letzte Antwort
      • G Gonzokalle
        da_WoodyD Offline
        da_WoodyD Offline
        #743
        @gonzokalle naja, was willst du mit knopf?
        https://github.com/sbormann/ioBroker.iqontrol/blob/master/README.md
        G 1 Antwort Letzte Antwort
        • da_WoodyD da_Woody
          G Online
          G Online
          Gonzokalle
          #744
          @da_woody
          Mit dem net-tools Adapter soll ein PC im Netzwerk geweckt werden. Das funktioniert auch soweit.
          Unten soll aber nicht der DP net-tools Adapter angezeigt werden, sondern ein DP vom radar2.0 Adapter.
          Also ob der PC nun wirklich an oder aus ist.
          • G Gonzokalle
            @da_woody
            da_WoodyD Offline
            da_WoodyD Offline
            #745
            @gonzokalle ich verwende das ding nicht, aber so wie ich das belinse, bei state eben deinen radar2 DP verwenden...
              G Online
              G Online
              Gonzokalle
              #746
              @da_woody
              Der aktuell mit dem DP vom net-tools belegt.
              Ich probiere mal was.
              • G Gonzokalle
                @da_woody
                G Online
                G Online
                Gonzokalle
                #747
                @gonzokalle
                So geht es nicht.
                • G Gonzokalle
                  @gonzokalle
                  So geht es nicht.
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #748
                  @gonzokalle wie gesagt, tu mir da nicht leicht ohne das selbst zu verwenden.
                  aber du hast jetzt bei set und off_set andere sachen eingetragen.
                  vielleicht kannst du da was über cd06c3f9-49b4-412d-b18d-100313fadd29-grafik.png basteln. oder über den schraubenschlüssel, oder einen schalter versuchen zu verwenden...
                  • G Online
                    G Online
                    Gonzokalle
                    #749
                    Mit dem Schraubenschlüssel kenne ich mich nicht aus.
                    Wie kann ich denn bei dem Schalter für unten eine anderen DP zuweisen?
                    • G Gonzokalle
                      G Online
                      G Online
                      Gonzokalle
                      #750
                      @gonzokalle
                      Es geht jetzt. Den DP für unten bei Power eintragen. Dann zeige Power als State aktivieren.
                      Funktioniert bei Schalter, Licht, Ventilator. Bei "Knopf / Taster" nicht.
                        @chrisbgl sagte in iQontrol Vis Support Thread:
                        ich habe ein Problem:
                        Ich möchte mit einem Widget eine Webseite anzeigen, aber egal welche Webseite ich bei BACKGROUND_URL eintrage (z.B. https://www.google.de) zeigt das Widget nur einen grauen Hintergrund und "google.de hat die Verbindung abgelehnt" an.
                        Weiß jemand woran das liegen kann?
                        Manche Seiten lehnen die Einbindung in einen iFrame ab - da kann man dann leider nichts machen.
                        ChrisBGL
                        schrieb am zuletzt editiert von ChrisBGL
                        #751
                        @s-bormann said in iQontrol Vis Support Thread:
                        Da bleibt dann nur als externen Link öffnen?
                        • iobroker_RainerI Offline
                          iobroker_Rainer
                          #752
                          Ich möchte nach Click auf einen Button
                          1. den Status des damit verbunden Gerätes verändern UND DIREKT ANSCHLIESSEND
                          2. zur Ansicht XYZ wechseln
                            Ich weiss zwar, wie ich jeweils den Status ändere ODER zu einer anderen Ansicht wechsle, aber nicht, wie man das gleichzeitig machen kann.
                            Was mir helfen würde wäre z.B., wenn ich wüsste, wie man via Blockly in iqontrol eine bestimmte Ansicht aufrufen könnte.
                            Wahrscheinlich habe ich Tomaten auf den Augen, habe aber nix in der Doku gefunden dazu ...
                          Weiss da jemand Rat?
                          • da_WoodyD Offline
                            da_WoodyD Offline
                            #753
                            @iobroker_rainer hab auf die schnelle jetzt nur das gefunden.
                            https://forum.iobroker.net/topic/22039/test-adapter-iqontrol-2-0-x-vis-entwicklungs-thread/706
                            iobroker_RainerI 1 Antwort Letzte Antwort
                              iobroker_Rainer
                              #754
                              @da_woody Prima - das wars! Vielen Dank für den Link👍
                              • iobroker_RainerI iobroker_Rainer
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #755
                                @iobroker_rainer na fein! 👍
                                  iobroker_Rainer
                                  #756
                                  ... okay ich war wohl doch zu optimistisch - habe es nicht hingekriegt. Hier nochmals zur Verdeutlichung, was ich erreichen möchte....
                                  In dieser Ansicht lasse ich mir Systemmeldungen anzeigen, die ich über den Log-Parser-Adapter gesammelt habe. Wenn ich den Schalter "Reset Logging" betätige, dann wird auch brav das Logging geleert und auch die Ansicht aktualisiert. Ich möchte nun erreichen, dass mit dem Betätigen des Schalters auch AUTOMATISCH die Home-Ansicht gezeigt wird.
                                  So wie ich diverse Foren-Einträge verstanden habe, muss dies INNERHALB der Visu automatisiert werden und geht nicht über Blockly ...
                                  Hat jemand eine Idee?
                                  Mike77M da_WoodyD s.bormannS 3 Antworten Letzte Antwort
                                    Mike77M Offline
                                    Mike77M Offline
                                    Mike77
                                    #757
                                    Guten Morgen zusammen,
                                    ich hab mir zwar schon einiges zusammengebastelt, aber ich merke immer noch, daß ich die Linux-Denkweise nicht verstehe...
                                    Ich bekomme es nicht hin ein in iobroker erzeugtes, aber sich veränderndes Bild in Iqontrol darstellen zu lassen. (also ohne Upload in der Oberfläche) -> Echart als JPG wegen der Performance beim Anzeigen auf meinem uralten Tablet.
                                    In welchen Order muss ich denn das Bild speichern lassen und wie als Background HTML aufrufen, daß es auch angezeigt wird?
                                    Habe das Bild in /opt/iobroker/iobroker-data/files/iqontrol.meta/userimages/demo/bild.jpg erzeugt, aber ich kann es nicht anzeigen lassen.
                                    Mike
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #758
                                      @iobroker_rainer hab da gestern rumgetestet. warum du da einen schalter verwendest, versteh ich mal nicht. da musst du aus, dann wieder einschalten. ich hab mit knopf/button getestet. mit klick aufs icon gelöscht, dann mit klick auf die kachel home anzeige.
                                      wird sicher eine möglichkeit geben, z.b. über ein widget, aber da kenn ich mich auch zu wenig aus.
                                      • Mike77M Mike77
                                        Mike
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        #759
                                        @michael-mauer sagte in iQontrol Vis Support Thread:
                                        wieso in einen ordner speichern? du musst doch einen DP für das bild haben in den objekten. ein .jpeg kannst du auch nicht als Background HTML aufrufen.
                                        Mike77M 1 Antwort Letzte Antwort
                                          Mike77M Offline
                                          Mike77M Offline
                                          Mike77
                                          schrieb am zuletzt editiert von Mike77
                                          #760
                                          @da_woody Hallo Woody,
                                          hmmm, da bin ich jetzt überfragt... Ich habe keinen Datenpunkt.
                                          Ich speichere alle 5 Minuten das Echart als JPG ins Dateisystem... Geklaut aus dem Script, wie man das Echart per Telegram verschickt.
                                          Und genau diese Datei versuche ich anzuzeigen.
                                          Im Background_HTML als Konstante: <img src="./../iqontrol.meta/userimages/echart/bild.jpg">
                                          Da liegt es... Das funktioniert aber nur mit Bildern, die ich vorher per Upload im IQontrol hochgeladen habe... aber nicht, wenn ein anders Programm da das Bild abgelegt hat... Selbst wenn ich ein hochgeladenes Bild überschreibe, bleibt es beim alten Bild im Browser...
                                          Vermutlich weil IQontrol die beim Start irgendwoanders ablegt.
                                          Aus anderen Verzeichnissen habe ich aber das Anzeigen auch nicht geschafft.
                                          Mike
