  4. ...nicht in offiziellem Repo
  5. Test Adapter eufy Home Robovac
    6.4k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
151 Beiträge 29 Kommentatoren 40.9k Aufrufe 31 Beobachtet
  • S SaAnMaFi
    @amiethaner Hey du benutzt aber auch die eufy clean App oder ? App-Version 2.14.0
    amiethaner
    @saanmafi Die Version hab ich grad ned da, aber ich hab im IOB aus Git installiert, den Link den TomBox im 1. Post drin hat.
    • S SaAnMaFi
      @saanmafi said in Test Adapter eufy Home Robovac:
      2023-01-19 18:36:58.486 - debug: euhome.0 (26751) {"result":{"exponent":"3","pbKey":"MIGdMA0GCSqGSIb3DQEBAQUAA4GLADCBhwKBgQC3G++LCMizncnUMoa0dphWKdPG19cyN6/xnkp/W65EcxQ+6/spb2BgHBGI/KBPAEskjUbRSW+SSqdzRL+VbOxxCJqdyyQJfjpPuOGR2vd9NAL4qv65a6jfjFE0S2iDxqalQJQfxMmO5erTkCaGpYXSC2SI3t2S0tNNXjMXWHd6UwIBAw==","publicKey":"128583599587316320066427519373958487917362130388243381016424776686077738627998030280118620719016122693480577031888461568274075772213337708119107902973063764125021277321517661080840521944335779460451432254892851827709539746674755618246803726810267650219299959196939973740742880810714516464041141864384484047443","token":"f0cac272ed18038b66cdc059f3118291"},"t":1674149818467,"success":true,"status":"ok"}
      2023-01-19 18:37:05.128 - debug: euhome.0 (26751) strToSign: a=tuya.m.user.uid.password.login||appVersion=3.8.5||clientId=yx5v9uc3ef9wg3v9atje||deviceId=gjfylv4vf8v5rtdsjgmuko4y9hb5at9kvmey0jcdra14||et=0.0.1||lang=en||os=Android||postData=68d9381bf4d71516729bdb2f3d21af76||requestId=220b64da-b8d6-4d89-aa41-f9b3e2818937||time=1674149825||ttid=android||v=1.0
      2023-01-19 18:37:05.128 - debug: euhome.0 (26751) Sending parameters:
      2023-01-19 18:37:05.129 - debug: euhome.0 (26751) {"a":"tuya.m.user.uid.password.login","deviceId":"gjfylv4vf8v5rtdsjgmuko4y9hb5at9kvmey0jcdra14","sdkVersion":"3.0.0cAnker","os":"Android","lang":"en","appVersion":"3.8.5","v":"1.0","clientId":"yx5v9uc3ef9wg3v9atje","time":1674149825,"postData":"{\"countryCode\":\"49\",\"uid\":\"eh-a3b3f44b2886727f6de6192c717bfe830af2a75a\",\"createGroup\":true,\"passwd\":\"000000000000000000000000000000000000000000000000000000000000000001ba70dc61708b9735ece4db0c7501814db721af0f4258cfe44c80980c9855ab52e160aa5a607b32b18dbce2c9f009fbb0ca1f9561838cce3b848e6f5a07d79041deeee3d00acb055215b3ae24e766377901ed7c76520ce1fcab10088ac9118d\",\"ifencrypt\":1,\"options\":{\"group\":1},\"token\":\"f0cac272ed18038b66cdc059f3118291\"}","et":"0.0.1","ttid":"android","appRnVersion":"5.11","platform":"Android","requestId":"220b64da-b8d6-4d89-aa41-f9b3e2818937","sign":"fbb6b41b4ea851e0ba5e1c13a1bd371ba8e6518522475d338e8c0968ace75f3f"}
      2023-01-19 18:37:05.222 - debug: euhome.0 (26751) Received response:
      2023-01-19 18:37:05.222 - debug: euhome.0 (26751) {"t":1674149825210,"success":false,"errorCode":"USER_PASSWD_WRONG","status":"error","errorMsg":"Incorrect account ID or password"}
      2023-01-19 18:37:05.224 - error: euhome.0 (26751) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-01-19 18:37:05.224 - error: euhome.0 (26751) unhandled promise rejection: Incorrect account ID or password
      2023-01-19 18:37:05.230 - error: euhome.0 (26751) Error: Incorrect account ID or password
      at TuyaCloud.request (/opt/iobroker/node_modules/iobroker.euhome/lib/tuyaCloud.js:267:11)
      at processTicksAndRejections (node:internal/process/task_queues:96:5)
      at TuyaCloud.loginEx (/opt/iobroker/node_modules/iobroker.euhome/lib/tuyaCloud.js:385:21)
      at Euhome.login (/opt/iobroker/node_modules/iobroker.euhome/main.js:140:17)
      at Euhome.onReady (/opt/iobroker/node_modules/iobroker.euhome/main.js:76:17)
      2023-01-19 18:37:05.231 - error: euhome.0 (26751) Exception-Code: USER_PASSWD_WRONG: Incorrect account ID or password
      2023-01-19 18:37:05.254 - info: euhome.0 (26751) terminating
      2023-01-19 18:37:05.255 - debug: euhome.0 (26751) Plugin sentry destroyed
      2023-01-19 18:37:05.256 - warn: euhome.0 (26751) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amiethaner
      @saanmafi sagte in Test Adapter eufy Home Robovac:
      Also ich bin sicher kein Pro, aber da würd i mal sagen Benutzer oder Passwort falsch.
      • M Michi_Pi
        @tombox okay, ich hab da wohl ein Problem unter Proxmox, am Raspi läuft der Adapter jetzt, die DP werden aktualisiert aber steuern funktioniert nicht. Im Log wird nichts reingeschrieben.
        I Offline
        I Offline
        isexglei
        Zunächst mal @tombox : Super Arbeit! Dankeschön! Darauf warte ich schon lange.
        @michi_pi ich hab das gleiche Problem; auslesen geht super - wenn ich versuche zu steuern, dann hängt sich bei mir der Adapter auf.
        @amiethaner hab wie du gesagt hast auto reingeschrieben (egal ob case-sensitive).
        Hier das Log euhome.log (Start der Instanz um 09:45:50.461 und um 09:51 hab ich dann "Auto" eingetragen). Er versucht dann ständig eine Verbindung auf localhost 6668 aufzubauen. Ist das ein Port von iobroker (offenen Port kann ich keinen finden)? Anschließend startet er dann neu und findet den Robovac wieder.
        • I isexglei
          tombox
          @isexglei
          Ich habe die logs nochmal verbessert aber es ist die situation dass der Adapter die Geräte nicht im Netzwerk sehen kann. Sie müssen in der gleichen IP Subnetz sein. Ich könne auch noch Steuerung und Abrufen via Cloud einbauen
          A I 2 Antworten Letzte Antwort
          • T tombox
            @isexglei
            amiethaner
            @tombox Also ich bin ziemlich zufrieden so wies grad is :) was aber noch super wär, wenn man die Reinigung für einzelne Räume iwie hinbekommen würde. Also ned nur Auto.
            • T tombox
              @isexglei
              I Offline
              I Offline
              isexglei
              schrieb am zuletzt editiert von isexglei
              @tombox hm... also der Pi und der Robovac sind im selben Netz. Der Pi hat allerdings noch weitere Netzwerkadapter. In die Cloud muss ich nicht zwingend - das passt schon so.
              Edit: Fehler gefunden. Problem lag an der Firewall. Der Roboter verschickt im Netz einen Broadcast. Auf dem Pi mit ufw hab ich folgende Rule aktiviert: ufw allow from ip.vom.rob.oter to 255.255.255.255 port 6667 proto udp
              • I isexglei
                tombox
                @isexglei Ok ja das macht Sinn. Wußte nicht das man sowas blocken kann ich nehme es mal in den log auf.
                • T tombox
                  Michi_Pi
                  @tombox @isexglei hab gerade nochmal getestet. Also steuern über den dps 2 "play_pause" geht doch bei mir, ich hatte die Änderung zuvor immer bestätigt, das ging nicht. Folgende dps hab ich auch getestet und funktionieren bei mir. 3, 5, 101, 102, 103
                  • M Michi_Pi
                    amiethaner
                    schrieb am zuletzt editiert von amiethaner
                    @michi_pi
                    Ah das muss ich auch mal probieren ohne Bestätigung
                    • A amiethaner
                      @michi_pi
                      tombox
                      @amiethaner
                      Alle Nutzersachen sind immer unbestätigt.
                      Ich habe noch states eingefügt da sieht man welche Werte die dps annehmen können.
                      Raumreinigung schaue ich mir noch an
                      T M 2 Antworten Letzte Antwort
                      • T tombox
                        @amiethaner
                        tombox
                        Ich sehe gerade es gibt keine Raumreinigung dann sollte es soweit ja passen
                        • T tombox
                          @amiethaner
                          Michi_Pi
                          @tombox die Werte sind da, nur kann ich ihn jetzt nicht mehr bedienen.
                          Ich muss denn Wertetyp auf String umstellen dann reagiert er wieder.
                          • M Michi_Pi
                            tombox
                            @michi_pi Lösch mal den Ordner dps und installier nochmal neu
                            • T tombox
                              amiethaner
                              @tombox hab ich das richtig verstanden das nur Auto geht? Also raumreinigung nicht bzw nur über die handy app?
                              • T tombox
                                Michi_Pi
                                @tombox hatte ich eigentlich gemacht. Hab jetzt die aktuelle Version 0.0.3 installiert und vorher nochmal alles deinstalliert. Jetzt geht es wieder.
                                • A amiethaner
                                  tombox
                                  @amiethaner wo geht es in der App bräuchte Zugang zu einem wo man räume wählen kann
                                  • T tombox
                                    amiethaner
                                    @tombox hast ne PN
                                    • A amiethaner
                                      @tombox hast ne PN
                                      tombox
                                      @amiethaner Habe etwas eingefügt
                                      euhome.0.id.remote.sendCommand
                                      damit kann man dann
                                        "method": "selectRoomsClean",
                                        "data": {
                                          "roomIds": [
                                          "cleanTimes": 1
                                      das sollte die Raum Cleaning aktivieren bitte mal testen
                                      • T tombox
                                        damit kann man dann
                                          "data": {
                                            "roomIds": [
                                            "cleanTimes": 1
                                        amiethaner
                                        @tombox muss ich den Adapter Neu installieren oder?
                                        • A amiethaner
                                          tombox
                                          @amiethaner Ja nur neu installieren nicht löschen
