  4. Werte aus iobroker für EVCC
    5.9k
    1.5k
28 Beiträge 5 Kommentatoren 4.9k Aufrufe 4 Beobachtet
  • W Offline
    W Offline
    wwshaui
    Guten Morgen Gemeinde,
    nach vielen Stunden testen und probieren habe ich die Lösung mit dem Socket.IO Adapter um eine Wert aus dem iobroker für EVCC zu verwenden.
    Hier das Beispiel:
    meters:
      - name: grid1
        type: custom
        power:
          source: http
          uri: http://192.168.178.50:8087/getPlainValue/smartmeter.0.1-0:16_7_0__255.value
          #method: getPlainValue # default HTTP method
          #headers:
          #- content-type: application/json
          #auth: # basic authorization
          #  type: basic
          #  user: admin
          # password: admin
          #insecure: false # set to true to trust self-signed certificates
          #jq: .data.tuples[0][1] # parse response json
          scale: 1 # floating point factor applied to result, e.g. for kW to W conversion
          timeout: 10s # timeout in golang duration format, see https://golang.org/pkg/time/#ParseDuration
      - type: template
        template: solarlog
        usage: pv
        host: 192.168.178.61
        port: 502
    • W wwshaui
      Hier das Beispiel:
      meters:
        - name: grid1
          type: custom
          power:
            source: http
            #headers:
            #  type: basic
            #  user: admin
            # password: admin
        - type: template
          template: solarlog
          usage: pv
          port: 502
      Borkenkäfer
      @wwshaui
      hallo wwshaui
      nutze deine Konfi wie folgt
      meters:
      • type: custom
        power:
        source: http
        uri: http://192.168.178.58:8081/getPlainValue/smartmeter.0.1-0:16_7_0__255.value
      bekomme aber die Fehlermeldung
      [main ] INFO 2023/01/16 19:20:34 evcc 0.111.1
      [main ] INFO 2023/01/16 19:20:34 using config file: /etc/evcc.yaml
      [db ] INFO 2023/01/16 19:20:34 using sqlite database: /root/.evcc/evcc.db
      [eebus ] INFO 2023/01/16 19:20:34 Local SKI: 9a6f63f1d28f0a42a3a8c1da441b19b7f2fd0507
      [eebus ] DEBUG 2023/01/16 19:20:34 mdns: announce
      [eebus ] DEBUG 2023/01/16 19:20:34 mdns: using avahi
      [eebus ] DEBUG 2023/01/16 19:20:34 starting websocket server on :4712
      [main ] FATAL 2023/01/16 19:20:34 cannot create meter 'gridmeter': cannot create meter 'custom': 1 error(s) decoding:
      was ist noch falsch
      Danke Uli
      C arteckA 2 Antworten Letzte Antwort
      • B Borkenkäfer
        @wwshaui
        hallo wwshaui
        meters:
        • type: custom
          power:
          source: http
        was ist noch falsch
        Danke Uli
        Carsten1210
        @borkenkäfer
        Ich meine du brauchst dazu auch den Simple API Adapter.
        Dann kannst du im Browser die Adresse aufrufen: http://192.168.178.58:8081/getPlainValue/smartmeter.0.1-0:16_7_0__255.value und es sollte dir ein Wert zurück gegeben werden.
        Wenn der Simple API Adpater nicht läuft kommt bei der Adresse eine Fehlermeldung.
        Gruß, Carsten
        B 2 Antworten Letzte Antwort
        • B Borkenkäfer
          @wwshaui
          hallo wwshaui
          meters:
          • type: custom
            power:
            source: http
          was ist noch falsch
          Danke Uli
          arteckA Offline
          arteckA Offline
          arteck
          @borkenkäfer dir ist schon klar dass der beitrag aus März 2022 ist ???
          was has du/ihr vor ??
          • arteckA arteck
            Borkenkäfer
            @arteck
            Moin
            ich lese im IObroker mittels IR Lesekopf meinen Energiezähler aus und Steuere damit in abhängigkeit der aktuell
            eingespeisten Leistungs meine Wärmepumpe.
            dieser Wert ist also in IObroker vorhanden
            mit EVCC möchte ich nun weitere überschüssige Energie in mein E-auto laden
            den Zähler mit IR Lesekopf kann ich in EVCC aber nicht einbinden, daher der Versuch über diesen Weg.
            Dass der Beitrag aus März 2022 ist habe ich gesehen, hab aber keine andere Möglichkeit gefunden.
            es scheint zwar einen EVCC Adapter in IOBroker zu geben aber irgendwie finde ich den nicht
            bin für andere Lösungen offen
            Danke Uli
            • C Carsten1210
              @borkenkäfer
              Gruß, Carsten
              Borkenkäfer
              @carsten1210
              Moin Werte bekomme ich jetzt
              schon mal Danke
              • C Carsten1210
                @borkenkäfer
                Gruß, Carsten
                Borkenkäfer
                @carsten1210
                im Browser bekomme ich den richtigen Wert
                beim debuggen im EVCC bekomme ich aber diese Fehlermeldung
                sudo evcc -l debug meter
                [main ] INFO 2023/01/17 17:28:58 evcc 0.111.1
                [main ] INFO 2023/01/17 17:28:58 using config file: /etc/evcc.yaml
                [main ] FATAL 2023/01/17 17:28:58 While parsing config: yaml: line 22: mapping values are not allowed in this context
                • arteckA arteck
                  Borkenkäfer
                  @arteck
                  bekomme jetzt einen Wert nachdem ich im IOBroker noch Socketio installiert habe
                  [main ] INFO 2023/01/17 18:09:32 evcc 0.111.1
                  [main ] INFO 2023/01/17 18:09:32 using config file: /etc/evcc.yaml
                  [db ] INFO 2023/01/17 18:09:32 using sqlite database: /root/.evcc/evcc.db
                  [eebus ] INFO 2023/01/17 18:09:32 Local SKI: 9a6f63f1d28f0a42a3a8c1da441b19b7f2fd0507
                  [eebus ] DEBUG 2023/01/17 18:09:32 mdns: announce
                  [eebus ] DEBUG 2023/01/17 18:09:32 mdns: using avahi
                  [eebus ] DEBUG 2023/01/17 18:09:32 starting websocket server on :4712
                  [eebus ] ERROR 2023/01/17 18:09:32 error during websocket server starting: listen tcp :4712: bind: address already in use
                  Power: 363W
                  • B Borkenkäfer
                    @arteck
                    Power: 363W
                    Borkenkäfer
                    @borkenkäfer said in Werte aus iobroker für EVCC:
                    @arteck
                    Power: 363W
                    wenn ich die EVCC installation prüfe kommt aber noch
                    evcc[9245]: [site ] ERROR 2023/01/17 18:25:54 grid meter: invalid character '<' looking for beginning of value
                    C 1 Antwort Letzte Antwort
                    • B Borkenkäfer
                      @arteck
                      Power: 363W
                      Carsten1210
                      @borkenkäfer
                      Kannst du mal deine EVCC.yaml anhängen (Zumindest den Teil mit den "Meters")?!
                      Oben im Beitrag sieht man die Einrückungen nicht korrekt.
                      Bei http://192.168.178.58:8081/getPlainValue/smartmeter.0.1-0:16_7_0__255.value bekommst du einen Zahlwert im Browser angezeigt oder was steht dann da?!
                      Meters sieht bei mir so aus:
                      meters:
                        - name: grid1
                          type: custom
                          power:
                            source: http
                            uri: http://192.168.178.50:8087/getPlainValue/smartmeter.0.1-1:1_7_0.value
                            scale: 1000
                            timeout: 10s
                      Gruss, Carsten
                        Borkenkäfer
                        @carsten1210
                        hallo
                        im browser wird nur der Wert angezeigt, z.B. 657
                        ich muß aber über die 8087 gehen, bei 8081 kommt eine Fehlermeldung
                        yaml meter sieht wie folgt aus
                        meters:
                        • name: gridmeter
                          type: custom
                          power:
                          source: http
                          uri: http://192.168.178.58:8087/getPlainValue/smartmeter.0.1-0:16_7_0__255.value
                          timeout: 30s # timeout in golang duration format, see https://golang.org/pkg/time/#ParseDuration
                        sehe nicht wirklich einen Unterschied zu deiner , außer das anscheinend bei die "- name" noch etwas mehr eingerückt ist, und scale bei mir 1, bei dir 1000
                        probiere ich mal aus
                        • B Borkenkäfer
                          @carsten1210
                          hallo
                          meters:
                          • name: gridmeter
                            type: custom
                            power:
                            source: http
                          Borkenkäfer
                          @carsten1210
                          hallo
                          meters:
                          • name: gridmeter
                            type: custom
                            power:
                            source: http
                          jetz bekomme ich unexpected status
                          • B Borkenkäfer
                            @carsten1210
                            hallo
                            meters:
                            • name: gridmeter
                              type: custom
                              power:
                              source: http
                            Borkenkäfer
                            @carsten1210
                            hallo
                            meters:
                            • name: gridmeter
                              type: custom
                              power:
                              source: http
                            yaml jetzt so
                            meters:
                            • name: gridmeter
                              type: custom
                              power:
                              source: http
                              uri: http://192.168.178.58:8087/getPlainValue/smartmeter.0.1-1:1_7_0.value
                              scale: 1
                              timeout: 20s
                            • B Borkenkäfer
                              @carsten1210
                              hallo
                              meters:
                              • name: gridmeter
                                type: custom
                                power:
                                source: http
                              yaml jetzt so
                              meters:
                              • name: gridmeter
                                type: custom
                                power:
                                source: http
                                scale: 1
                                timeout: 20s
                              Borkenkäfer
                              immer noch Fehlermeldungen
                              habe alles wieder zurückgeändert auf
                              meters:
                              • name: gridmeter
                                type: custom
                                power:
                                source: http
                                scale: 1
                                timeout: 20s
                              jetz bekomme ich beim debuggen den richtigen Wert, aber mit Error
                              ERROR 2023/01/18 17:48:22 error during websocket server starting: listen tcp :4712: bind: address already in use
                              Power: 218W
                              [eebus ] DEBUG 2023/01/18 17:48:22 mdns: stop announcement
                              • B Borkenkäfer
                                meters:
                                • name: gridmeter
                                  type: custom
                                  power:
                                  source: http
                                  scale: 1
                                  timeout: 20s
                                Power: 218W
                                Borkenkäfer
                                meters:
                                • name: gridmeter
                                  type: custom
                                  power:
                                  source: http
                                  scale: 1
                                  timeout: 20s
                                Power: 218W
                                und bei evcc -c evcc.yaml, bekomme ich diese meldung
                                [main ] INFO 2023/01/18 17:49:59 evcc 0.111.1
                                [main ] INFO 2023/01/18 17:49:59 using config file: evcc.yaml
                                [main ] INFO 2023/01/18 17:49:59 starting ui and api at :7070
                                [main ] ERROR 2023/01/18 17:49:59 could not open config file: open evcc.yaml: no such file or directory
                                [main ] FATAL 2023/01/18 17:49:59 open evcc.yaml: no such file or directory
                                [main ] FATAL 2023/01/18 17:49:59 will attempt restart in: 5m0s
                                [server] FATAL 2023/01/18 17:49:59 unlinkat /tmp/evcc: operation not permitted
                                als ob die yaml Datei gar nicht da ist
                                • B Borkenkäfer
                                  meters:
                                  • name: gridmeter
                                    type: custom
                                    power:
                                    source: http
                                    scale: 1
                                    timeout: 20s
                                  Power: 218W
                                  Carsten1210
                                  schrieb am zuletzt editiert von Carsten1210
                                  @borkenkäfer
                                  Nutzt du evcc und iobroker auf dem Raspi?!
                                  Wenn ja schau mal in das Verzeichnis Root/etc , in dem Verzeichnis sollte evcc installiert sein und auch die yaml liegen.
                                  In der Doku wird auch darauf verwiese das die yaml dahin verschoben werden muss.
                                  Wenn du deinen Teil der yaml postest verwende bitte die Code-Tags (</> Symbol beim Beitrag schreiben) damit die Formatierung auch mit rüber kommt.
                                  Die 8087 ist der Port auf dem Simple-API bei mir läuft (Weiss jetzt nicht ob das der Default Port ist oder nicht).
                                  Pack deine yaml-Datei bitte noch mal in Code Tag hier rein damit man auch die Formatierng sehen kann.
                                  SKIs usw. kann du da gerne mit XXX angeben.
                                  Den EVCC Adapter kannst du im IOBroker verwenden wenn EVCC läuft.
                                  Gruss, Carsten
                                  • C Carsten1210
                                    @borkenkäfer
                                    Gruss, Carsten
                                    Borkenkäfer
                                    @carsten1210
                                    Hallo Carsten
                                    Ja nutze beides auf einem rasperry
                                    Habe den befehl sudo mv …. Auch gemacht,
                                    Aber auch da kam die Fehlermeldung das die datei
                                    Nicht vorhanden ist
                                    Werde morgen mal schauen
                                    • B Borkenkäfer
                                      @carsten1210
                                      Hallo Carsten
                                      Nicht vorhanden ist
                                      Borkenkäfer
                                      @borkenkäfer
                                      Moin Carsten
                                      Über den datei manager kann ich die evcc. Yaml in etc sehen
                                      Uli
                                      • B Borkenkäfer
                                        @borkenkäfer
                                        Moin Carsten
                                        Uli
                                        Carsten1210
                                        @borkenkäfer
                                        Ich glaube das hatte ich auch einmal.
                                        Liegt in home/pi auch noch einmal die evcc.yaml (Verzeichnis kann ich gerade nicht nachschauen, ist das von wo du die evcc.yaml nach etc verschoben / kopiert hast)?!
                                        Ich meine als die fehlte kam bei mir auch mal die Meldung das er die nicht findet.
                                        Gruss, Carsten
                                        • C Carsten1210
                                          @borkenkäfer
                                          Gruss, Carsten
                                          Borkenkäfer
                                          @carsten1210
                                          Hallo
                                          Jetzt funktioniert einiges mehr
                                          Energiefluss wird angezeigt
                                          In der ski für die wallbox hatte ich nach 4 zeichen ein Leerzeichen, kam so von der wallbox und ich hatte
                                          Hochkommas davor und dahinter
                                          War anscheinend auch falsch, stand aber nirgendwo
                                          Werde jetzt versuchen meinen pv einzubinden
                                          Danke für deine Hilfe
                                          Schönen abend
                                          Uli
                                          82.6k
