  3. Einsteigerfragen
  4. Installation
  5. Root
Root
23 Beiträge 7 Kommentatoren 3.1k Aufrufe 6 Beobachtet
    @gmix Du könntest ja mal mit exec ein cat auf die /etc/passwd machen.
      <variables>
        <variable id="65W2$~OFA47_euU!QzaV">user</variable>
        <variable id="Q_d1D0s5GB;Hs?sW0vPZ">result</variable>
      </variables>
      <block type="exec" id="s{vuzYLMgjaV#rL@%fcf" x="88" y="88">
        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
        <field name="WITH_STATEMENT">TRUE</field>
        <field name="LOG"></field>
        <value name="COMMAND">
          <shadow type="text" id="u^D/}?dS_+StbvuUr9QI">
            <field name="TEXT">cat /etc/passwd</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_forEach" id="P]nbSv~GsGhh+5g;M?CV">
            <field name="VAR" id="65W2$~OFA47_euU!QzaV">user</field>
            <value name="LIST">
              <block type="lists_split" id=")RkUVA]9H%gVtG9|1y*1">
                <mutation mode="SPLIT"></mutation>
                <field name="MODE">SPLIT</field>
                <value name="INPUT">
                  <block type="variables_get" id="HaUTfP6@$$2S3NAXq3p!">
                    <field name="VAR" id="Q_d1D0s5GB;Hs?sW0vPZ">result</field>
                  </block>
                </value>
                <value name="DELIM">
                  <shadow type="text" id="+A_EHI[acBUyITH`6Qzn">
                    <field name="TEXT">\n</field>
                  </shadow>
                  <block type="text_newline" id="T}:TM?,FfE/N6Td^JpxG">
                    <field name="Type">\n</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO">
              <block type="debug" id="5(DW7uESb7z=0@cStt`O">
                <value name="TEXT">
                  <shadow type="text" id="seCg.u6GcpeSFX84wh~}">
                  </shadow>
                  <block type="text_getSubstring" id=".YDG9rsUa%f7em{qO)D(">
                    <mutation at1="false" at2="true"></mutation>
                    <field name="WHERE1">FIRST</field>
                    <field name="WHERE2">FROM_START</field>
                    <value name="STRING">
                      <block type="variables_get" id="}[AUK%OMi9et.rcVaobj">
                      </block>
                    </value>
                    <value name="AT2">
                      <block type="math_arithmetic" id="M6)V~n@Mh:i4BT.VPnC9">
                        <value name="A">
                          <shadow type="math_number" id="oXyFK5]TVV(8!6O,oCV0">
                            <field name="NUM">1</field>
                          </shadow>
                          <block type="text_indexOf" id="N],W2dw8Ah9d2wb0eWc1">
                            <field name="END">FIRST</field>
                            <value name="VALUE">
                              <block type="variables_get" id="S$Om6LR#c5IDh7B53#EM">
                              </block>
                            </value>
                            <value name="FIND">
                              <shadow type="text" id="#GIMV]OIx~in;.IMuza{">
                                <field name="TEXT">:</field>
                              </shadow>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <shadow type="math_number" id="]Ol,cES$z1j2*mHZAv?4">
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    Die Liste könnte man noch Filtern um direkt nur Nutzer zu bekommen, welche auch eine Login-Bash haben:
    cat /etc/passwd | grep /bin/bash
    Gmix
    Ich komme per Putty nicht rein, weil ich ja den Standarduser nicht mehr weiß. ;)
    haus-automatisierungH Marc BergM 2 Antworten Letzte Antwort
    • G Gmix
      haus-automatisierungH Offline
      @gmix sagte in Root:
      Daher ja mein Hinweis mit dem exec-Script, um eine Liste der existierenden Benutzer zu bekommen...
      📚 Meine Dokumentation
      G 1 Antwort Letzte Antwort
        Gmix
        Vielen Dank!
        Ich muss das jetzt mal in Ruhe verstehen, was du mir aufgeschrieben hast.
        Bin absoluter Neuling und wieß noch nicht, wie ich dieses Script anwenden muss.
        • G Gmix
          Vielen Dank!
          • JavaScript Adapter installieren
          • exec in den Instanzeinstellungen erlauben
          • Neues Blockly-Script anlegen
          • XML importieren
          • Script Starten
          • Im Log die Benutzernamen anschauen
            • XML importieren
            • Script Starten
            Gmix
            Bin jetzt an dem Punkt XML importieren. Habe dein Script in den Windows-Editor kopiert und als user.xml gespeichert, bekomme das unter Sccripts aber nicht importiert.
            crunchipC da_WoodyD 2 Antworten Letzte Antwort
            • G Gmix
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              und direkt am Raspi per HDMI/Tastatur + Root anzumelden, ist keine Option?
              • Marc BergM Marc Berg
                Gmix
                @marc-berg merke ich mir. Jetzt versuche ich mich gerade mit dem Script.
                • G Gmix
                  crunchipC Abwesend
                  crunchipC Abwesend
                    Gmix
                    @crunchip
                    Sorry, habe mich falsch ausgedrückt. Das Importieren habe ich gefunden, es klappt aber nicht.
                    -> Error: Can't find end of central directory : is this a zip file ? If it is, see https://stuk.github.io/jszip/documentation/howto/read_zip.html
                    Habe dann ein leere JS-Script erstellt und den Inhalt des Scripts hineinkopiert. Nach dem Starten kommt -> error javascript.0 (24624) script.js.Skript_1 compile failed: at script.js.Skript_1:1
                    • G Gmix
                      @crunchip
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @gmix du musst doch oben nur den kompletten code markieren und strg +C drücken, im script auf importieren und strg +V
                      nichts zwischenspeichern auf dem PC
                        Gmix
                        Soweit bin ich ja gekommen. Habe mit dem Plus-Zeichen ein leeres JS mit Namen User im Ordner root erzeugt und in dieses leere Script die Zeilen hineinkopiert und abgespeichert. Nach Start mit dem roten Dreieck kommen diese Meldungen:
                        11:54:44.439 info javascript.0 (24624) Start javascript script.js.User
                        11:54:44.441 error javascript.0 (24624) script.js.User compile failed: at script.js.User:1
                        • G Gmix
                          crunchipC Abwesend
                          crunchipC Abwesend
                          leeres JS
                          blockly
                          so sollte es aussehen
                            leeres JS
                            blockly
                            Gmix
                            @crunchip Danke!
                            Habe meinen Fehler entdeckt.
                                <variables>
                                </variables>
                                    </shadow>
                                  </value>
                                      <value name="LIST">
                                            </block>
                                          </value>
                                            </shadow>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                          <value name="TEXT">
                                            </shadow>
                                                </block>
                                              </value>
                                              <value name="AT2">
                                                  <value name="A">
                                                    </shadow>
                                                        </block>
                                                      </value>
                                                      <value name="FIND">
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                </block>
                              </xml>
                              Gmix
                              @haus-automatisierung
                              Vielen Dank für die exakte Hilfe !
                              • G Gmix
                                @gmix Gern, hast Du den Benutzernamen wenigstens rausgefunden? :)
                                • G Offline
                                  Gmix
                                  Ja und nein.
                                  Ich dachte, ich hätte einen eigenen erzeugt. Einen solchen habe ich aber nicht gefunden. Allerdings gibt es den "pi", den es ja eigentlich nicht mehr geben dürfte und von dem ich sicher war, ihn nicht angelegt zu haben. Und bei dem funktioniert mein Testpasswort nicht und auch nicht "raspberry". Ich werde mal die SD-Card bearbeiten, um den "pi" nutzen zu können.
                                  Möglicherweise mache ich die Installation auch noch einmal komplett neu und mache mir dann entsprechende Notizen. Bin ziemlich irritiert.
                                  • G Gmix
                                    Ja und nein.
                                    Ich meine, den 'pi' hat man als FallBack drin gelassen. Gibt u. U. noch skripte/Software die den User 'pi' benötigen.
                                      Gmix
                                      @thomas-braun ok. Dann sollte ich den wohl besser in Ruhe lassen. Wenn ich das Passwort ändere, wäre er für solche Funktionalitäten ja nicht mehr einsetzbar.
                                      Eine Neuinstallation ist nicht wirklich schlimm. Ich habe bisher nur ein paar Adapter installiert und Alexa, Shelly, Tapo etc. eingebunden. Mehr ist eh nicht vorhanden.
                                      • G Gmix
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        IMHO fäng da das problem an.
                                        so etwas macht man mit notepad++ oder ähnlichem.
                                        • da_WoodyD da_Woody
                                          Gmix
                                          @da_woody genau. "Ähnliches" habe ich benutzt. Hat ja auch dann geklappt. Der Fehler lag anderswo.
