  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 327.7k Aufrufe 63 Beobachtet
  • U UncleB
    @glasfaser said in [Diskussion zum HowTo nodejs-Installation und upgrade](/post/916062
    > sudo -H -u iobroker npm install iobroker.js-controller
    pi@raspberrypi:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 22
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c -- node iobroker.js setup first
    npm ERR! No connection to databases possible ...
    npm ERR!  Cannot load "custom": Connection is closed.
    npm ERR!  Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed.
    npm ERR!     /home/iobroker/.npm/_logs/2022-12-25T09_41_59_839Z-debug-0.log
    MOD-EDIT: Codeincode-tagsgesetzt!
    GlasfaserG Offline
    GlasfaserG Offline
    #499
    @uncleb sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
    Warum packst du die Ausgabe nicht in Code-Tags </> , das kann man so nicht lesen.
    und zeige mal :
    du -sh  /opt/iobroker/iobroker-data/objects.jsonl
    U 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      und zeige mal :
      U Offline
      U Offline
      UncleB
      #500
      @glasfaser said in Diskussion zum HowTo nodejs-Installation und upgrade:
      Sorry, nun in den Code Tags
      pi@raspberrypi:/opt/iobroker $ du -sh  /opt/iobroker/iobroker-data/objects.jsonl
      5,1M    /opt/iobroker/iobroker-data/objects.jsonl
      • U Offline
        U Offline
        UncleB
        #501
        Keiner mehr ne Idee??
        Ich hätte das Update einfach sein lassn sollen..
        • U UncleB
          #502
          @uncleb
          Mach einen eigenen Thread mit dem Problem auf, das hat ja mit dem HowTo zur nodeJS-Installation nichts zu tun.
          Da dann die Ausgabe von
          iobroker diag
          rein. Ggf. zuvor den
          iobroker fix
          ausführen.
          • Thomas SchulzeT Offline
            Thomas Schulze
            #503
            ich möchte auf Node 16 inklusive npm 8 updaten.
            npm -v && node -v && nodejs -v
            6.14.17
            v14.21.1
            v14.21.1
            Beim check des npm tree erhalte ich folgende Ausgabe.
            Sollte/muss ich den milight Adapter vorher deinstallieren?
            npm ls | grep -E 'github|ERR'
            │ │ │ ├── github-from-package@0.0.0
            │ ├─┬ node-milight-promise@0.3.2 (github:Steiger04/node-milight-promise#f1089feac9b7990727adf2016891029436729d33)
            npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@4.0.2
            iobroker@nuc-server:/opt/iobroker$
            sind die ganzen deduped (deduplicated) Einträge hier OK und können ignoriert werden oder muss hier noch etwas bereinigt werden?
            npm ls
            iobroker.inst@2.0.3 /opt/iobroker
            ├── colors@1.4.0
            ├─┬ fs-extra@7.0.1
            │ ├── graceful-fs@4.2.4
            │ ├─┬ jsonfile@4.0.0
            │ │ └── graceful-fs@4.2.4 deduped
            │ └── universalify@0.1.2
            ├─┬ iobroker@2.0.3
            │ ├── colors@1.4.0 deduped
            │ ├── fs-extra@7.0.1 deduped
            │ ├── semver@5.7.1 deduped
            │ └── yargs@7.1.1 deduped
            ├─┬ iobroker.admin@6.3.5
            │ ├─┬ @iobroker/adapter-core@2.6.7
            │ │ └─┬ @types/iobroker@4.0.5
            │ │   └── @types/node@14.0.14 deduped
            │ ├─┬ @iobroker/socket-classes@1.0.2
            │ │ ├── @iobroker/adapter-core@2.6.7 deduped
            │ │ ├── axios@0.27.2 deduped
            │ │ ├── cookie-parser@1.4.6 deduped
            │ │ └── passport@0.6.0 deduped
            │ ├─┬ @iobroker/ws-server@2.1.0
            │ │ └── ws@8.7.0
            │ ├─┬ axios@0.27.2
            │ │ ├── follow-redirects@1.15.2
            │ │ └─┬ form-data@4.0.0
            │ │   ├── asynckit@0.4.0
            │ │   ├── combined-stream@1.0.8 deduped
            │ │   └── mime-types@2.1.27 deduped
            │ ├─┬ body-parser@1.20.1
            │ │ ├── bytes@3.1.2
            │ │ ├── content-type@1.0.4
            │ │ ├── debug@2.6.9 deduped
            │ │ ├── depd@2.0.0
            │ │ ├── destroy@1.2.0
            │ │ ├─┬ http-errors@2.0.0
            │ │ │ ├── depd@2.0.0 deduped
            │ │ │ ├── inherits@2.0.4
            │ │ │ ├── setprototypeof@1.2.0 deduped
            │ │ │ ├── statuses@2.0.1 deduped
            │ │ │ └── toidentifier@1.0.1
            │ │ ├─┬ iconv-lite@0.4.24
            │ │ │ └── safer-buffer@2.1.2
            │ │ ├─┬ on-finished@2.4.1
            │ │ │ └── ee-first@1.1.1
            │ │ ├─┬ qs@6.11.0
            │ │ │ └── side-channel@1.0.4 deduped
            │ │ ├─┬ raw-body@2.5.1
            │ │ │ ├── bytes@3.1.2 deduped
            │ │ │ ├── http-errors@2.0.0 deduped
            │ │ │ ├── iconv-lite@0.4.24 deduped
            │ │ │ └── unpipe@1.0.0 deduped
            │ │ ├─┬ type-is@1.6.18
            │ │ │ ├── media-typer@0.3.0
            │ │ │ └── mime-types@2.1.27 deduped
            │ ├─┬ compression@1.7.4
            │ │ ├─┬ accepts@1.3.7
            │ │ │ ├── mime-types@2.1.27 deduped
            │ │ │ └── negotiator@0.6.2
            │ │ ├── bytes@3.0.0
            │ │ ├─┬ compressible@2.0.18
            │ │ │ └── mime-db@1.44.0
            │ │ ├─┬ debug@2.6.9
            │ │ │ └── ms@2.0.0
            │ │ ├── on-headers@1.0.2
            │ │ ├── safe-buffer@5.1.2
            │ │ └── vary@1.1.2
            │ ├── connect-flash@0.1.1
            │ ├─┬ cookie-parser@1.4.6
            │ │ ├── cookie@0.4.1
            │ │ └── cookie-signature@1.0.6
            │ ├─┬ express@4.18.2
            │ │ ├─┬ accepts@1.3.8
            │ │ │ ├─┬ mime-types@2.1.35
            │ │ │ │ └── mime-db@1.52.0
            │ │ │ └── negotiator@0.6.3
            │ │ ├── array-flatten@1.1.1
            │ │ ├── body-parser@1.20.1 deduped
            │ │ ├─┬ content-disposition@0.5.4
            │ │ │ └── safe-buffer@5.2.1 deduped
            │ │ ├── content-type@1.0.4 deduped
            │ │ ├── cookie@0.5.0
            │ │ ├── cookie-signature@1.0.6 deduped
            │ │ ├── encodeurl@1.0.2
            │ │ ├── escape-html@1.0.3
            │ │ ├── etag@1.8.1
            │ │ ├─┬ finalhandler@1.2.0
            │ │ │ ├── debug@2.6.9 deduped
            │ │ │ ├── encodeurl@1.0.2 deduped
            │ │ │ ├── escape-html@1.0.3 deduped
            │ │ │ ├── on-finished@2.4.1 deduped
            │ │ │ ├── parseurl@1.3.3 deduped
            │ │ ├── fresh@0.5.2
            │ │ ├── merge-descriptors@1.0.1
            │ │ ├── methods@1.1.2
            │ │ ├── path-to-regexp@0.1.7
            │ │ ├─┬ proxy-addr@2.0.7
            │ │ │ ├── forwarded@0.2.0
            │ │ │ └── ipaddr.js@1.9.1
            │ │ ├── qs@6.11.0 deduped
            │ │ ├── range-parser@1.2.1
            │ │ ├── safe-buffer@5.2.1
            │ │ ├─┬ send@0.18.0
            │ │ │ ├── destroy@1.2.0 deduped
            │ │ │ ├── etag@1.8.1 deduped
            │ │ │ ├── fresh@0.5.2 deduped
            │ │ │ ├── mime@1.6.0
            │ │ │ ├── ms@2.1.3
            │ │ │ ├── range-parser@1.2.1 deduped
            │ │ │ └── statuses@2.0.1 deduped
            │ │ ├─┬ serve-static@1.15.0
            │ │ │ └── send@0.18.0 deduped
            │ │ ├── type-is@1.6.18 deduped
            │ │ ├── utils-merge@1.0.1
            │ │ └── vary@1.1.2 deduped
            │ ├─┬ express-fileupload@1.4.0
            │ │ └─┬ busboy@1.6.0
            │ │   └── streamsearch@1.1.0
            │ ├─┬ express-session@1.17.3
            │ │ ├── cookie@0.4.2
            │ │ ├── depd@2.0.0
            │ │ ├── on-headers@1.0.2 deduped
            │ │ └─┬ uid-safe@2.1.5
            │ │   └── random-bytes@1.0.0
            │ ├── mime@3.0.0
            │ ├─┬ passport@0.6.0
            │ │ ├── passport-strategy@1.0.0
            │ │ ├── pause@0.0.1
            │ │ └── utils-merge@1.0.1 deduped
            │ ├─┬ passport-local@1.0.0
            │ │ └── passport-strategy@1.0.0 deduped
            │ ├─┬ semver@7.3.8
            │ │ └─┬ lru-cache@6.0.0
            │ │   └── yallist@4.0.0 deduped
            │ └── ws@8.11.0
            ├─┬ iobroker.alexa2@3.23.2
            │ ├─┬ @sentry/integrations@7.27.0
            │ │ ├── @sentry/types@7.27.0
            │ │ ├─┬ @sentry/utils@7.27.0
            │ │ │ ├── @sentry/types@7.27.0 deduped
            │ │ │ └── tslib@1.13.0 deduped
            │ │ ├─┬ localforage@1.8.1
            │ │ │ └─┬ lie@3.1.1
            │ │ │   └── immediate@3.0.6 deduped
            │ ├─┬ @sentry/node@7.27.0
            │ │ ├─┬ @sentry/core@7.27.0
            │ │ │ ├── @sentry/utils@7.27.0 deduped
            │ │ ├─┬ https-proxy-agent@5.0.0
            │ │ │ ├── agent-base@6.0.2 deduped
            │ │ │ └─┬ debug@4.3.1
            │ │ │   └── ms@2.1.2
            │ │ ├── lru_map@0.3.3
            │ ├─┬ alexa-remote2@5.10.1
            │ │ ├─┬ alexa-cookie2@4.1.3
            │ │ │ ├── cookie@0.5.0
            │ │ │ ├─┬ express@4.18.2
            │ │ │ │ ├─┬ accepts@1.3.8
            │ │ │ │ │ ├─┬ mime-types@2.1.35
            │ │ │ │ │ │ └── mime-db@1.52.0
            │ │ │ │ │ └── negotiator@0.6.3
            │ │ │ │ ├── array-flatten@1.1.1 deduped
            │ │ │ │ ├─┬ body-parser@1.20.1
            │ │ │ │ │ ├── bytes@3.1.2
            │ │ │ │ │ ├── content-type@1.0.4 deduped
            │ │ │ │ │ ├── debug@2.6.9 deduped
            │ │ │ │ │ ├── depd@2.0.0 deduped
            │ │ │ │ │ ├── destroy@1.2.0
            │ │ │ │ │ ├── http-errors@2.0.0 deduped
            │ │ │ │ │ ├── iconv-lite@0.4.24 deduped
            │ │ │ │ │ ├── on-finished@2.4.1 deduped
            │ │ │ │ │ ├── qs@6.11.0 deduped
            │ │ │ │ │ ├─┬ raw-body@2.5.1
            │ │ │ │ │ │ ├── bytes@3.1.2 deduped
            │ │ │ │ │ │ ├── http-errors@2.0.0 deduped
            │ │ │ │ │ │ ├── iconv-lite@0.4.24 deduped
            │ │ │ │ │ │ └── unpipe@1.0.0 deduped
            │ │ │ │ │ ├── type-is@1.6.18 deduped
            │ │ │ │ ├─┬ content-disposition@0.5.4
            │ │ │ │ │ └── safe-buffer@5.2.1 deduped
            │ │ │ │ ├── cookie@0.5.0 deduped
            │ │ │ │ ├── cookie-signature@1.0.6 deduped
            │ │ │ │ ├── encodeurl@1.0.2 deduped
            │ │ │ │ ├── escape-html@1.0.3 deduped
            │ │ │ │ ├── etag@1.8.1 deduped
            │ │ │ │ ├─┬ finalhandler@1.2.0
            │ │ │ │ │ ├── encodeurl@1.0.2 deduped
            │ │ │ │ │ ├── escape-html@1.0.3 deduped
            │ │ │ │ │ ├── parseurl@1.3.3 deduped
            │ │ │ │ │ ├── statuses@2.0.1 deduped
            │ │ │ │ ├── fresh@0.5.2 deduped
            │ │ │ │ ├─┬ http-errors@2.0.0
            │ │ │ │ │ ├── inherits@2.0.4
            │ │ │ │ │ ├── setprototypeof@1.2.0 deduped
            │ │ │ │ │ └── toidentifier@1.0.1
            │ │ │ │ ├── merge-descriptors@1.0.1 deduped
            │ │ │ │ ├── methods@1.1.2 deduped
            │ │ │ │ ├─┬ on-finished@2.4.1
            │ │ │ │ │ └── ee-first@1.1.1 deduped
            │ │ │ │ ├── path-to-regexp@0.1.7 deduped
            │ │ │ │ ├─┬ proxy-addr@2.0.7
            │ │ │ │ │ ├── forwarded@0.2.0
            │ │ │ │ │ └── ipaddr.js@1.9.1 deduped
            │ │ │ │ ├─┬ qs@6.11.0
            │ │ │ │ │ └── side-channel@1.0.4 deduped
            │ │ │ │ ├── range-parser@1.2.1 deduped
            │ │ │ │ ├── safe-buffer@5.2.1
            │ │ │ │ ├─┬ send@0.18.0
            │ │ │ │ │ ├── destroy@1.2.0 deduped
            │ │ │ │ │ ├── etag@1.8.1 deduped
            │ │ │ │ │ ├── fresh@0.5.2 deduped
            │ │ │ │ │ ├── mime@1.6.0 deduped
            │ │ │ │ │ ├── ms@2.1.3
            │ │ │ │ │ ├── range-parser@1.2.1 deduped
            │ │ │ │ │ └── statuses@2.0.1 deduped
            │ │ │ │ ├─┬ serve-static@1.15.0
            │ │ │ │ │ └── send@0.18.0 deduped
            │ │ │ │ ├── utils-merge@1.0.1 deduped
            │ │ │ │ └── vary@1.1.2 deduped
            │ │ │ ├─┬ http-proxy-middleware@2.0.6
            │ │ │ │ ├─┬ @types/http-proxy@1.17.9
            │ │ │ │ │ └── @types/node@14.0.14 deduped
            │ │ │ │ ├─┬ http-proxy@1.18.1
            │ │ │ │ │ ├── eventemitter3@4.0.7
            │ │ │ │ │ ├── follow-redirects@1.5.10 deduped
            │ │ │ │ │ └── requires-port@1.0.0 deduped
            │ │ │ │ ├── is-glob@4.0.1 deduped
            │ │ │ │ ├── is-plain-obj@3.0.0
            │ │ │ │ └─┬ micromatch@4.0.5
            │ │ │ │   ├── braces@3.0.2 deduped
            │ │ │ │   └── picomatch@2.3.1
            │ │ │ ├─┬ http-proxy-response-rewrite@0.0.1
            │ │ │ │ ├── bufferhelper@0.2.1
            │ │ │ │ └─┬ concat-stream@1.6.2
            │ │ │ │   ├── buffer-from@1.1.1 deduped
            │ │ │ │   ├── inherits@2.0.3 deduped
            │ │ │ │   ├── readable-stream@2.3.7 deduped
            │ │ │ │   └── typedarray@0.0.6 deduped
            │ │ │ ├── https@1.0.0 deduped
            │ │ │ └── querystring@0.2.1
            │ │ ├── extend@3.0.2
            │ │ ├── querystring@0.2.1
            │ │ ├── uuid@9.0.0
            │ │ └── ws@8.11.0
            │ ├── https@1.0.0
            │ ├── nearest-color@0.4.4
            │ ├─┬ rrule@2.7.1
            │ │ └── tslib@2.4.1
            │ └─┬ source-map-support@0.5.21
            │   └── source-map@0.6.1
            ├─┬ iobroker.backitup@2.5.9
            │ ├─┬ @googleapis/drive@4.0.1
            │ │ └─┬ googleapis-common@6.0.4
            │ │   ├── extend@3.0.2 deduped
            │ │   ├── gaxios@5.0.2 deduped
            │ │   ├── google-auth-library@8.7.0 deduped
            │ │   ├── qs@6.7.0 deduped
            │ │   ├── url-template@2.0.8
            │ │   └── uuid@9.0.0
            │ ├─┬ axios@1.1.3
            │ │ ├─┬ form-data@4.0.0
            │ │ │ ├── asynckit@0.4.0 deduped
            │ │ │ ├── combined-stream@1.0.8 deduped
            │ │ └── proxy-from-env@1.1.0
            │ ├─┬ dropbox-v2-api@2.5.9
            │ │ ├── compress-json@2.1.2
            │ │ └── request@2.88.2 deduped
            │ │ ├── depd@2.0.0
            │ │ ├─┬ qs@6.11.0
            │ │ ├─┬ send@0.18.0
            │ │ │ ├── ms@2.1.3
              ├─┬ read-pkg-up@1.0.1
              │ ├─┬ find-up@1.1.2
              │ │ ├─┬ path-exists@2.1.0
              │ │ │ └── pinkie-promise@2.0.1 deduped
              │ │ └─┬ pinkie-promise@2.0.1
              │ │   └── pinkie@2.0.4
              │ └─┬ read-pkg@1.1.0
              │   ├─┬ load-json-file@1.1.0
              │   │ ├── graceful-fs@4.2.4 deduped
              │   │ ├─┬ parse-json@2.2.0
              │   │ │ └─┬ error-ex@1.3.2
              │   │ │   └── is-arrayish@0.2.1
              │   │ ├── pify@2.3.0
              │   │ ├── pinkie-promise@2.0.1 deduped
              │   │ └─┬ strip-bom@2.0.0
              │   │   └── is-utf8@0.2.1
              │   ├─┬ normalize-package-data@2.5.0
              │   │ ├── hosted-git-info@2.8.8
              │   │ ├─┬ resolve@1.17.0
              │   │ │ └── path-parse@1.0.6
              │   │ ├── semver@5.7.1 deduped
              │   │ └─┬ validate-npm-package-license@3.0.4
              │   │   ├─┬ spdx-correct@3.1.1
              │   │   │ ├── spdx-expression-parse@3.0.1 deduped
              │   │   │ └── spdx-license-ids@3.0.5
              │   │   └─┬ spdx-expression-parse@3.0.1
              │   │     ├── spdx-exceptions@2.3.0
              │   │     └── spdx-license-ids@3.0.5 deduped
              │   └─┬ path-type@1.1.0
              │     ├── pify@2.3.0 deduped
              ├── require-directory@2.1.1
              ├── require-main-filename@1.0.1
              ├── set-blocking@2.0.0
              ├─┬ string-width@1.0.2
              │ ├── code-point-at@1.1.0
              │ ├─┬ is-fullwidth-code-point@1.0.0
              │ │ └── number-is-nan@1.0.1
              │ └── strip-ansi@3.0.1 deduped
              ├── which-module@1.0.0
              ├── y18n@3.2.1
              └─┬ yargs-parser@5.0.0-security.0
                ├── camelcase@3.0.0 deduped
                └─┬ object.assign@4.1.0
                  ├─┬ define-properties@1.1.3
                  │ └── object-keys@1.1.1 deduped
                  ├── function-bind@1.1.1
                  ├── has-symbols@1.0.1
            Vielen Dank im Voraus!
            • Thomas SchulzeT Thomas Schulze
              6.14.17
              v14.21.1
              v14.21.1
              npm ls
              ├── colors@1.4.0
              ├─┬ fs-extra@7.0.1
              ├─┬ iobroker@2.0.3
              │ │ └── ws@8.7.0
              │ ├─┬ axios@0.27.2
              │ │ ├── bytes@3.1.2
              │ │ ├── depd@2.0.0
              │ │ ├─┬ qs@6.11.0
              │ │ ├── bytes@3.0.0
              │ │ ├─┬ debug@2.6.9
              │ │ │ └── ms@2.0.0
              │ │ └── vary@1.1.2
              │ │ ├── etag@1.8.1
              │ │ ├── fresh@0.5.2
              │ │ ├─┬ send@0.18.0
              │ │ │ ├── ms@2.1.3
              │ │ ├── depd@2.0.0
              │ ├── mime@3.0.0
              │ │ ├── pause@0.0.1
              │ ├─┬ semver@7.3.8
              │ └── ws@8.11.0
              │ │ │ └─┬ lie@3.1.1
              │ │ │   └── ms@2.1.2
              │ │ ├── uuid@9.0.0
              │ │ └── ws@8.11.0
              │ ├── https@1.0.0
              │ ├─┬ rrule@2.7.1
              │ │ └── tslib@2.4.1
              │ │   └── uuid@9.0.0
              │ ├─┬ axios@1.1.3
              │ │ ├── depd@2.0.0
              │ │ ├─┬ qs@6.11.0
              │ │ ├─┬ send@0.18.0
              │ │ │ ├── ms@2.1.3
                │ ├─┬ find-up@1.1.2
                │   │ ├── pify@2.3.0
                ├── y18n@3.2.1
              #504
              @thomas-schulze
              Sollte so funktionieren.
              H 1 Antwort Letzte Antwort
                @thomas-schulze
                haubada
                schrieb am zuletzt editiert von haubada
                #505
                ich habe seit längerem kein Update mehr gemacht und hatte das Problem, dass
                gestern mein Iobroker nicht mehr gestartet hatte.
                Nach der Eingabe von "Iobroker fix" kann starter er nun wieder.
                Allerdings kann ich keine Updates/Upgrade machen und habe gesehen, dass einige meiner Pfade nicht stimmen /local
                pi@raspberrypi:/opt/iobroker $ type -P nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                /usr/bin/nodejs
                /usr/local/bin/node
                /usr/local/bin/npm
                v10.24.0
                v14.18.0
                6.14.15
                nodejs:
                  Installiert:           10.24.0~dfsg-1~deb10u1
                  Installationskandidat: 10.24.0~dfsg-1~deb10u2
                  Versionstabelle:
                     10.24.0~dfsg-1~deb10u2 500
                 *** 10.24.0~dfsg-1~deb10u1 100
                     6.14.4-1nodesource1 500
                        500 https://deb.nodesource.com/node_6.x buster/main armhf Packages
                Wenn ich versuche die Adapter zu Updaten kommt keine Fehlermeldung, aber es bleibt immer die alte Version.
                Das brachte auch keinen Erfolg:
                sudo iobroker stop
                sudo iobroker update
                sudo iobroker upgrade self
                sudo iobroker start
                auch das nicht:
                sudo apt-get update
                sudo apt-get upgrade
                Letztendich hatte ich versucht, die Dinge aus der Anleitung dieses Themas einzugeben,
                aber schließlich startete gar nichts mehr und ich musste das alte Image auf die SD Karte kopieren.
                Die oberste Anzeige des Befehls ist von meiner aktuell zurückgespielten SD Karte, ohne dass ich irgendwelche Update/Upgrade Befehle eingegeben habe.
                Meine Installation ist auch in der Vergangenheit schon 2x abgestürzt, weshalb sie wohl verbogen ist.
                Da ich aber einige Skripte und History Daten und die Visualisierung drauf habe, möchte ich sie gerne wieder gerade biegen.
                Leider weiß ich aber nicht wie und bitte um Hilfe.
                • H haubada
                  /usr/bin/nodejs
                  /usr/local/bin/node
                  /usr/local/bin/npm
                  v10.24.0
                  v14.18.0
                  6.14.15
                  nodejs:
                    Versionstabelle:
                  sudo iobroker stop
                  sudo iobroker start
                  auch das nicht:
                  sudo apt-get update
                  #506
                  @haubada sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                  Andersherum wird ein Schuh draus.
                  Das ganze ist aber hinten und vorne schief aufgesetzt bei dir.
                  Setz es als 'Bullseye' / Debian 11 neu auf.
                  Und wie oft muss man das eigentlich noch lesen?
                  iobroker NIE, NIE, NIE, NIEMALS per sudo anpacken. NIE!
                  Und wo hattest du konkret Probleme mit der Anleitung?
                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                  steht eigentlich alles drin.
                    haubada
                    #507
                    Danke für die schnelle Antwort:
                    Ich konnte auch den Js-Controller nicht updaten und da stand in der Anweisung
                    erst alles ohne sudo drin und weiter unter bei manuell Installiert mit sudo.
                    Da es oben nicht funktioniert hatte, habe ich es irgendwann auch so probiert.
                    Bei mir kommt das:
                    pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                    npm ERR! missing: homebridge-tapo@^1.4.17, required by iobroker.ham@5.3.0
                    npm ERR! missing: homebridge-tp-link-tapo@^3.2.0, required by iobroker.ham@5.3.0
                    Sie deutlich anders aus als bei Dir.
                    Macht es bei mir Sinn die Anleitung so Schritt für Schritt ab Teil 1 durchzumachen,
                    da ja die Pfade usw. nicht passen? Besteht da überhaupt eine Chance?
                    Wenn ich alles neu aufsetze, kann ich dann ein Backup zurück lesen?
                    Mir ist nicht klar, was alles bleibt bzw. weg ist, wenn ich neu aufsetze.
                    • H haubada
                      Bei mir kommt das:
                      #508
                      Macht es bei mir Sinn die Anleitung so Schritt für Schritt ab Teil 1 durchzumachen, da ja die Pfade usw. nicht passen?
                      Kann man anpassen.
                      Wenn man es sauber macht sollte das funktionieren.
                      Wenn du eines hast, natürlich.
                      • H haubada
                        Bei mir kommt das:
                        #509
                        @haubada
                        Änder mal die nodesource.list auf 16 ab und lösch die Installation in den falschen Pfaden.
                        Dann 'Buster' voll durchpatchen und von dort aus zum 'Bullseye'-Release wechseln.
                        Den iobroker per Fix reparieren.
                          @haubada
                          haubada
                          #510
                          Hallo nochmal,
                          ich habe mich für eine Neuinstallation von Bullseye entschieden.
                          Nachdem ich das Backup zurück gespielt habe bekam ich auch einige Probleme.
                          Z.B. lief VIS nicht mehr, history adapter ließ sich nicht installieren usw...
                          --> In einem Forum habe ich gelesen, dass man vor dem Rückspielen des Backups evtl. erst die Adapter installieren sollte?
                          Welchen Weg soll ich gehen um meine history daten, Javascripte, smartmeter, visualisierungen usw. zu sichern, damit ich sie auf dem neuen Bullseye wieder zum laufen bekomme?
                          Gefunden habe ich:
                          https://forum.iobroker.net/topic/27271/howto-iobroker-restore-unter-linux-durchführen
                          Meine Fragen:
                          • Bisher habe ich alles in Backupit gesichert, passt das so?
                            (aktuell habe ich 3 Files:
                            historyDB_2023_01_12-12_16_09_backupiobroker.tar.gz
                            iobroker_2023_01_12-12_16_00_backupiobroker.tar.gz
                            javascripts_2023_01_12-12_16_11_backupiobroker.tar.gz)
                          • In der Anleitung steht nur viel über das Restore, aber was muss ich wie genau zum Sichern auswählen, damit nichts verloren geht?
                          • Ich möchte nicht, dass meine krumme Version auch mit gesichert wird
                            --> Werden hier nur Daten gesichert oder auch das System?!!?
                          • Bei mir steht kein redis und auch kein file (wie in der Anleitung) sondern jsonl
                          pi@raspberrypi:~ $ iobroker status
                          Objects type: jsonl
                          States  type: jsonl
                          • Muss ich nach der Neuinstallation auch gleich noch updates machen oder irgendwas?
                            Installiert habe ich mit:
                            curl -sLf https://iobroker.net/install.sh | bash -
                          Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                          • H haubada
                            Hallo nochmal,
                            Gefunden habe ich:
                            Meine Fragen:
                            Objects type: jsonl
                            States  type: jsonl
                            #511
                            @haubada
                            1. Ja.
                            2. Primär das iobroker-Backup. Das hat z. B. javascripts auch schon im Bauch.
                            3. Backitup sichert nur die ioBroker-Daten, mit dem System selber hat das nix am Hut.
                            4. Richtig, jsonl/jsonl ist die Standardeinstellung seit einiger Zeit.
                            5. Updates sind immer zeitnah einzuspielen.
                            • H haubada
                              Hallo nochmal,
                              Gefunden habe ich:
                              Meine Fragen:
                              Objects type: jsonl
                              States  type: jsonl
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #512
                              @thomas-braun sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                              Auf die Gefahr mich (mal wieder) unbeliebt zu machen:
                              Auf einem Serversystem welches nicht von aussen zugänglich ist müssen nicht alle Updates zeitnah eingespielt werden - ansonsten ist man alle paar Tage dabei Updates auf das System zu spielen
                              Wenn sowieso eine so grosse Aktion wie "Update auf neue NodeJS version gemacht wird macht es aber auf jeden Fall sinn das gesamte System auf den aktuellen Stand zu bringen - sprich damit auch die entsprechenden Updates einzuspielen.
                              A.
                              • AsgothianA Asgothian
                                A.
                                #513
                                @asgothian sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                Doch.
                                Ist mit dem üblichen Zweizeiler ja auch in kürzester Zeit erledigt.
                                  Doch.
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #514
                                  Doch.
                                  Optimist. Auf einem Produktivsystem muss vor jedem Update welches eingespielt wird sichergestellt werden das vorher und hinterher alles so läuft wie es soll. Das Einspielen ist oft die kleine Sache. Die Verifikation nicht.
                                  Und wenn etwas dann nicht passt hat man spass. Deswegen ist es üblich Updates gesammelt zu festen Zeiten einzuspielen, nicht jedes mal wenn ein Update heraus kommt.
                                  A.
                                    Doch.
                                    A.
                                    #515
                                    @asgothian
                                    Du sprichst von Kisten, die von einem Admin-(Team) betreut werden und wo es Downtimes in Off-Times gibt? Ja, da macht es Sinn.
                                    Aber bei den hier überwiegend anzutreffenden 'Hobby'-Installationen nicht. Da wird eh nichts verifiziert, weil dazu gar nicht die Expertise vorhanden ist.
                                    Besser zeitnah, bevor die Patches dann am Ende gar nicht eingespielt werden.
                                    Bei kleineren Updates kannst du auch viel besser sagen wo es ggf. klemmt. Bei mehreren Dutzend 'aufgestauter' Pakete geht das nicht mehr so einfach.
                                    R 1 Antwort Letzte Antwort
                                      @asgothian
                                      reutli
                                      #516
                                      Diese Einschätzung teile ich im Großen und Ganzen.
                                      Allerdings darf man trotz der Hobby-Installationen nicht vergessen, dass hier teilweise ganze Haussteuerungen dran hängen, die nicht einfach mal für ein paar Stunden ausfallen können (z.B. Heizungssteuerung, Zutrittskontrollen usw.).
                                      Deshalb bin ich auch ein Verfechter von "Patchdays" aber eben nicht nur einmal im Jahr, sondern einmal im Monat, aber nach definiertem Muster und mit einem festen Testplan nach den wichtigsten use-cases.
                                      Auch wenn das hier viele (oder die meisten) als Hobby betreiben, merken doch einige, dass es ein ziemlicher GAU ist, wenn der iobroker mal wegbricht und man morgens ein kaltes Haus hat und unter der ebenso kalten Dusche steht ;o)
                                      Tatsächlich haben viele user imho Respekt bis Angst davor, am laufenden System Updates zu machen, da
                                      1. die Doku nicht eindeutig und vielfältig ist (ausser Deine klaren Anleitungen)
                                      2. Vorgehensweisen ändern
                                      3. für viele der Mac- und Windows-Nutzer unnatürlich bis gefährlich anfühlt
                                      Das sind Aspekte, die ich aus den vielen Threads immer wieder mitnehme.
                                      Also: Alles richtig, System up-to-date halten, aber mit System, Backup, Verstand und Doku 😀
                                      Dir speziellen Dank für die unermüdliche Hilfe! Wenn Du hier in Sachen Linux nicht unterwegs wärest, dann würde es manchmal ziemlich "dünn" werden!
                                      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                      *Wer freundlich ist, dem wird freundlich geholfen *
                                      • R reutli
                                        #517
                                        @reutli
                                        Offengesagt habe ich in den letzten Jahren kein reguläres Update aus den Debian-Quellen gesehen das durch die Bank zu Systemausfällen geführt hätte. Da ist schon das sehr gute Testing-System bei debian vor. Zusammen mit der sehr konservativen Herangehensweise bei neuen Versionen. Da wird lieber was zurückportiert als eine komplett neue Software-Version auf ein System zu knallen. Die sprichwörtliche Debian-Robustheit.
                                        Ein schlankes System (ohne z. B. Desktop usw) benötigt auch naturgemäß weniger Patches. Was gar nicht erst installiert ist benötigt keine Aufmerksamkeit.
                                          @reutli
                                          reutli
                                          #518
                                          jupp erneut Zustimmung!
                                          Geht ja auch nicht nur um's OS sondern auch um Adapter-Updates etc.
