  4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    6.1k
391 Beiträge 33 Kommentatoren 105.1k Aufrufe 33 Beobachtet
  • F Fauli85
    und zu Punkt 2
    ubiobr2021@ds1618:~$ sudo apt update
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Get:2 https://deb.nodesource.com/node_14.x jammy InRelease [4563 B]
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Get:7 https://deb.nodesource.com/node_14.x jammy/main amd64 Packages [773 B]
    Hit:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
    Fetched 5336 B in 2s (2981 B/s)
    Reading package lists... Done
    All packages are up to date.
    #135
    @fauli85 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
    Achso, nee, in der nodesource.list bitte noch aus
    node_14.x
    node_16.x
    machen.
    iob stop
    sudo apt update
    sudo apt full-upgrade
    iob start
    • F Fauli85
      Also Terminal neu startet und leider kommt die Meldung immer noch :(
      98 updates could not be installed automatically. For more details,
      see /var/log/unattended-upgrades/unattended-upgrades.log
      #136
      Dann schau da mal rein:
      less -R /var/log/unattended-upgrades/unattended-upgrades.log
      • F Offline
        Fauli85
        schrieb am zuletzt editiert von Fauli85
        #137
        die 4 Befehle habe ich gemacht
        hier die liste var
        ubiobr2021@ds1618:~$ less -R /var/log/unattended-upgrades/unattended-upgrades.lo                             g
        2023-01-04 06:26:31,048 INFO Package python3-simplejson is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,053 INFO Package python3-systemd is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,061 INFO Package python3-yaml is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,062 INFO Package python3-zope.interface is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,105 INFO Package rsyslog is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,136 INFO Package sed is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,152 INFO Package sudo is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,157 INFO Package systemd is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,158 INFO Package systemd-sysv is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,159 INFO Package systemd-timesyncd is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,161 INFO Package tar is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,184 INFO Package udev is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,190 INFO Package util-linux is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,201 INFO Package vim is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,210 INFO Package vim-common is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,219 INFO Package vim-runtime is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 06:26:31,228 INFO Package vim-tiny is kept back because a related package is kept back or due to local apt_preferences(5).
        2023-01-04 09:35:17,043 INFO Starting unattended upgrades script
        2023-01-04 09:35:17,046 INFO Allowed origins are: o=Ubuntu,a=jammy, o=Ubuntu,a=jammy-security, o=UbuntuESMApps,a=jammy-apps-security, o=UbuntuESM,a=jammy-infra-security
        2023-01-04 09:35:17,047 INFO Initial blacklist:
        2023-01-04 09:35:17,048 INFO Initial whitelist (not strict):
        jetzt steht da Ende und ich kann nix eingeben :(
        stop kommt gleich noch mehr - nein kommt nicht mehr.
        Komme aus dem END nicht raus lacht das wäre jetzt ein Grund für mich das Terminal neu so öffnen
        und wieder was gelernt "q" einfach tippen
          Die beiden für ioBroker verfügbaren Adapter um Speedtests zu monitoren haben die Eigenschaft an meinem Gigabit-Anschluss über Kabel sehr unbeständige Werte abzuliefern. Ein Flot-Chart sieht dann aus wie ein Kamm, dem ein paar Zinken fehlen.
          Sehr viel beständigere und realistischere Werte liefert mir ein skript von https://www.kreyenborg.koeln/speedtest-fuer-iobroker/
          Ich dokumentiere hier mal, wie ich das etwas abweichend von Stephan Kreyenborgs Anleitung auf meinem System eingerichtet habe.
          Zunächst habe ich sowohl den webspeedy wie auch den vofo-speedtest-Adapter im ioBroker deinstalliert.
          Dann habe ich per
          sudo apt remove speedtest-cli speedtest
          den bisherigen Kommandozeilen-Speedtest deinstalliert.
          Dann per
          sudo apt install curl
          curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
          sudo apt update
          sudo apt install speedtest
          das aktuelle Repo von ookla/speedtest.net eingespielt.
          [EXKURS]
          Falls das skript nicht durchläuft kann man 'zu Fuß' eine passende Datei unter /etc/apt/sources.list.d/ookla_speedtest-cli.list für Debian Bullseye mit folgendem Inhalt angelegen:
          # this file was generated by packagecloud.io for
          # the repository at https://packagecloud.io/ookla/speedtest-cli
          deb [signed-by=/etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
          deb-src [signed-by=/etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
          Dann noch den Schlüssel importieren:
          curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
          Andere Distributionen wie z. B. ubuntu dann analog (DISTRIBUTION und RELEASE entsprechend ersetzen):
          deb https://packagecloud.io/ookla/speedtest-cli/DISTRIBUTION/ RELEASE main
          deb-src https://packagecloud.io/ookla/speedtest-cli/DISTRIBUTION/ RELEASE main
          Ein
          sudo apt update
          spült die gewünschte Version dann in mein System.
          [EXKURS ENDE]
          Erster Test in der Kommandozeile liefert:
          echad@chet:/opt/iobroker $ speedtest
             Speedtest by Ookla
               Server: fiberONE - Darmstadt (id = 25942)
                  ISP: Vodafone Germany Cable
              Latency:    11.86 ms   (1.27 ms jitter)
             Download:   930.24 Mbps (data used: 1.2 GB)
               Upload:    51.74 Mbps (data used: 25.9 MB)
          Packet Loss:     0.0%
           Result URL: https://www.speedtest.net/result/c/
          Prima, funktioniert.
          Dann das skript von kreyenborg.koeln in den javaskript-Adapter geladen und in Zeile 210 oder 217 die Zeile
          var kommando = "/etc/speedtest/speedtest -f json --accept-license --accept-gdpr";
          an den anderen Pfad angepasst:
          var kommando = "/usr/bin/speedtest -f json --accept-license --accept-gdpr";
          Danach lief das skript und ich kann per eCharts so ein Diagramm bewundern:
          Tip am Rande:
          Per
          https://c.speedtest.net/speedtest-servers-static.php
          sollte man eine ID (hier z. B. 12345) eines zuverlässigen Servers identifizieren und im skript in Zeile 32 fix eintragen.
          var fav_server = 12345;
          SegwayS Offline
          SegwayS Offline
          Segway
          #138
          Ich schaue auch hin und wieder mal nach Spendetest, aber alles was ich anpacke gibt so furchtbar unterschiedliche Ergebnisse.
          Gerade nochmal mit meinem Laptop getestet der direkt am Hauptrouter hängt!
          Bei 1000MBit gab es 2x 170 Mbps, einmal 700 und einmal 360
          alles über den Edge browser mal eben schnell gemacht.
          Ist das alles wirklich aussagekräftig ?
          Gruß Dirk
          Thomas BraunT F 2 Antworten Letzte Antwort
          • SegwayS Segway
            #139
            @segway sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
            Hier passt es. Ich habe mir einen stabilen Server in meiner Nähe gesucht und den fix eingetragen. Mit der Voreinstellung 'such den besten Server alleine' hatte ich auch äußerst schwankende Graphen. Mittlerweile ist das aber sehr stabil:
            50MBit upload (hellgrau)
            1000MBit down (dunkelgrau)
            SegwayS 1 Antwort Letzte Antwort
            • F Fauli85
              hier die liste var
              #140
              apt policy sudo
              sagt?
              F 1 Antwort Letzte Antwort
              • SegwayS Segway
                Fauli85
                #141
                @segway
                ich habe auch ne feste ID
                   Speedtest by Ookla
                      Server: Net-D-Sign GmbH - Munich (id: 52143)
                Idle Latency:    10.49 ms   (jitter: 2.06ms, low: 6.43ms, high: 12.53ms)
                    Download:   927.10 Mbps (data used: 899.3 MB)
                                 21.36 ms   (jitter: 6.89ms, low: 6.04ms, high: 316.66ms)
                      Upload:    49.66 Mbps (data used: 43.7 MB)
                                 14.87 ms   (jitter: 5.36ms, low: 4.71ms, high: 278.77ms)
                 Packet Loss:     0.0%
                  Result URL: https://www.speedtest.net/result/c/55c43e6a-54df-4e5a-9914-aa8a5a7027f9
                  apt policy sudo
                  sagt?
                  Fauli85
                  #142
                  sagt
                  ubiobr2021@ds1618:~$ apt policy sudo
                  sudo:
                    Installed: 1.9.9-1ubuntu2.1
                    Candidate: 1.9.9-1ubuntu2.1
                    Version table:
                   *** 1.9.9-1ubuntu2.1 500
                          500 http://de.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
                       1.9.9-1ubuntu2 500
                          500 http://de.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
                    SegwayS Offline
                    SegwayS Offline
                    Segway
                    #143
                    @thomas-braun & @Fauli85
                    Und wie habt ihr den besten Server herausgefunden ?
                    Ich mach das grad per console
                    Gruß Dirk
                    Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                    • SegwayS Segway
                      #144
                      @segway
                      Tip am Rande:
                      Per
                      Da einfach mal mit verschiedenen IDs fix eingetragen herumexperimentieren.
                      In der Konsole konnte man aber auch über eine Option einen Server fix übergeben.
                      man speedtest hilft gerne weiter.
                      • SegwayS Segway
                        CodierknechtC Online
                        Codierknecht
                        #145
                        Wenn Du bei Ookla einen gut funktionierenden Server gefunden hast, brauchst Du nur mit der Maus über den Servernamen fahren. Der angezeigte Link endet mit der ID des Servers.
                        HmIP|ZigBee|Tasmota|Unifi
                        Zabbix Certified Specialist
                        • CodierknechtC Codierknecht
                          SegwayS Offline
                          SegwayS Offline
                          Segway
                          #146
                          @codierknecht
                          Ja hab da so ziemlich alle schon durch. aber komme nicht über 350 MBit. Da kämpfe ich schon immer mit.
                          Keine Ahnung was da los ist.
                          Gruß Dirk
                          • SegwayS Segway
                            @codierknecht
                            #147
                            Über WLAN?
                            • F Fauli85
                              sagt
                              sudo:
                                Version table:
                                   1.9.9-1ubuntu2 500
                              #148
                              @fauli85
                              Sollte eigentlich jetzt passen.
                              Was sagt
                              ls -lAh /etc/apt/preferences.d/
                              • SegwayS Segway
                                @codierknecht
                                Fauli85
                                #149
                                @segway
                                Router mal neu gestartet?
                                Ich hatte auch lange Zeit Vodafon Cabel nur 350 etc nie höher.
                                Alle Netzwerkkabel getauscht
                                Neuste Fritzbox
                                Dann war ich schon mal bei 500 von 1000.
                                Am Schluss kam ein neuer Rechner und seit dem bin ich bei 950
                                  Über WLAN?
                                  SegwayS Offline
                                  SegwayS Offline
                                  Segway
                                  #150
                                  Ne per Lan angeschlossen direkt am Hauptswitch
                                  Gruß Dirk
                                  F Thomas BraunT 2 Antworten Letzte Antwort
                                    @fauli85
                                    Was sagt
                                    Fauli85
                                    #151
                                    nicht viel :)
                                    ubiobr2021@ds1618:~$ ls -lAh /etc/apt/preferences.d/
                                    total 0
                                    • SegwayS Segway
                                      Fauli85
                                      #152
                                      @segway said in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                      Hauptswitch
                                      Ach und die habe ich auch alle getauscht.
                                      • SegwayS Segway
                                        #153
                                        @segway
                                        Könnte halt auch lokal bei dir was sein.
                                        Aber Speedtests sind auch sehr mit Vorsicht zu genießen. Insbesondere mit den ganz dicken Leitungen kommen dann doch viele Server nicht dauerhaft hinterher.
                                        SegwayS 2 Antworten Letzte Antwort
                                          @segway
                                          SegwayS Offline
                                          SegwayS Offline
                                          Segway
                                          #154
                                          @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                          Deswegen hab ich es eher immer ignoriert und für nicht gut befunden.
                                          Aber momentan scheint da echt einer auf der Leitung zu stehen ! Eine 5Gb Datei runtergezogen vom Telekom server und komme nicht über 12 MB/s
                                          mhhhhh .... was ist da los komische Sache
                                          Hauptswitch
                                          Ist ein neuer 24 Port Unifi Switch drin !
                                          Gruß Dirk
