  4. Admin startet nicht mehr
    5.5k
111 Beiträge 9 Kommentatoren 19.0k Aufrufe 8 Beobachtet
  • DJMarc75D DJMarc75
    @iced112 Bitte immer mit Ein- und Ausgaben in Codetags posten...
    Fehlt noch die Ausgabe zu:
    iobroker diag
    Edit: und Dein Admin läuft ja auch nicht !
    I Offline
    I Offline
    IceD112
    @djmarc75
    Skript v.2022-12-13
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     20:11:20 up 10:42,  2 users,  load average: 1.18, 1.03, 0.69
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Dec 25 19:11:20 UTC 2022
    Sun Dec 25 20:11:20 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            1.9G        1.2G        224M        0.0K        468M        703M
    Swap:            99M         29M         70M
    Total:          2.0G        1.2G        295M
             1872 M total memory
             1179 M used memory
              266 M active memory
             1244 M inactive memory
              224 M free memory
               96 M buffer memory
              372 M swap cache
               99 M total swap
               29 M used swap
               70 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.2G   22G  22% /
    devtmpfs       devtmpfs  776M     0  776M   0% /dev
    tmpfs          tmpfs     937M     0  937M   0% /dev/shm
    tmpfs          tmpfs     375M  828K  374M   1% /run
    /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.5G    /var/
    2.2G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
    2.2G    /var/log
    138M    /var/cache
    /opt/iobroker/backups:
    74M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    618M    /opt/iobroker/iobroker-data/
    294M    /opt/iobroker/iobroker-data/files
    249M    /opt/iobroker/iobroker-data/backup-objects
    74M     /opt/iobroker/iobroker-data/files/vis.0
    48M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/states.jsonl
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.0M    /opt/iobroker/iobroker-data/backup-objects/2022-12-24_18-41_states.jsonl.gz
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.16.0
    /usr/bin/node           v16.16.0
    /usr/bin/npm            8.11.0
    nodejs:
      Installed: 16.16.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
         16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
     *** 16.16.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u1 500
    Temp directories causing npm8 problem: 125
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! extraneous: decimal.js@10.4.1 /opt/iobroker/node_modules/decimal.js
    npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
    npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
    npm ERR! invalid: iobroker.javascript@6.1.4 /opt/iobroker/node_modules/iobroker.javascript
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR!     /home/pi/.npm/_logs/2022-12-25T19_11_31_254Z-debug-0.log
    Adapters from github:   0
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
    + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    ioBroker-Repositories
    Active repo(s): stable
    ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.4
    Adapter    "admin"        : 6.3.5    , installed 6.2.23 [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
    Adapter    "followthesun" : 0.4.0    , installed 0.4.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "heos"         : 1.10.0   , installed 1.10.0
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "socketio"     : 4.2.0    , installed 6.1.8
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.2
    Adapter    "telegram"     : 1.15.2   , installed 1.14.1 [Updatable]
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
    Adapter    "web"          : 4.3.0    , installed 5.2.4
    Adapter    "ws"           : 1.3.0    , installed 2.1.3
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        26610
    States:         22287
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 99
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13689      539/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       197095     13947/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       197102     13947/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13691      539/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       200063     14693/io.harmony.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       202865     14934/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       199809     14596/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10653      358/avahi-daemon: r
    udp        0      0 0.0.0.0:57775           0.0.0.0:*                           1001       199230     14708/io.heos.0
    udp        0      0 0.0.0.0:51737           0.0.0.0:*                           108        10655      358/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       200064     14693/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       198355     14399/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11806      765/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        10654      358/avahi-daemon: r
    udp6       0      0 :::57307                :::*                                108        10656      358/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13742      765/dhcpcd
    iob diag has finished.
    • I IceD112
      @djmarc75
      Skript v.2022-12-13
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         29M         70M
               1872 M total memory
               1179 M used memory
                266 M active memory
                224 M free memory
                 96 M buffer memory
                372 M swap cache
                 99 M total swap
                 29 M used swap
                 70 M free swap
      *** FILESYSTEM ***
      /var:
      2.5G    /var/
      2.2G    /var/log
      138M    /var/cache
      /usr/bin/npm            8.11.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.2.23
      ioBroker-Instances
      Objects and States
      Objects:        26610
      States:         22287
      Pending Updates: 99
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @iced112
      iobroker start admin
      Lehrling seit 1975 !!!
      I 1 Antwort Letzte Antwort
        iobroker diag
        I Offline
        I Offline
        IceD112
        @djmarc75 Ja, das hatte ich ja eingangs erklärt. Gestern ein Update des Adatber gestartet, was wohl nicht korrekt durchgegangen ist
          @iced112
          I Offline
          I Offline
          IceD112
          @djmarc75
          Super, das wusste ich nämlich nicht, wie bzw. dass ´man über die ssh die einzelen Adapter neustarten kann.
          Auf die Adminoberfläche komm ich schonmal rauf
          • I IceD112
            @djmarc75
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @iced112
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            I 2 Antworten Letzte Antwort
            -1
              @iced112
              sudo apt update
              sudo reboot
              I Offline
              I Offline
              IceD112
              @djmarc75
              wird durchgeführt...
                @iced112
                sudo apt update
                sudo reboot
                I Offline
                I Offline
                IceD112
                @djmarc75
                Alle adapter, bis auf den Javascript adapter sind gestartet...
                • I IceD112
                  @djmarc75
                  @iced112
                  Der Javaskript-Adapter läuft ja auch nicht in der Spur:
                  Installier den nochmal drüber.
                    @iced112
                    I Offline
                    I Offline
                    IceD112
                    schrieb am zuletzt editiert von IceD112
                    @thomas-braun wie mache ich das? Einfach ne Instanz mit + hinzufügen?
                    • I IceD112
                      @iced112
                      cd /opt/iobroker/node_modules/iobroker.javascript
                      sudo -u iobroker npm install
                        @iced112
                        I Offline
                        I Offline
                        IceD112
                        pi@ioBroker:~ $ cd /opt/iobroker/node_modules/iobroker.javascript
                        pi@ioBroker:/opt/iobroker/node_modules/iobroker.javascript $ sudo -u iobroker npm install
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                        npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-12-25T20_12_39_802Z-debug-0.log
                        da hab ich aber was nicht korrekt gemacht?
                        • I IceD112
                          npm ERR! errno -39
                          @iced112
                          https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                            @iced112
                            I Offline
                            I Offline
                            IceD112
                            for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%/}; done
                            und hier nach dann nochmal den?
                            • I IceD112
                              @iced112
                              Ja. Aber pass auf das du im richtigen Verzeichnis stehst!
                                @iced112
                                I Offline
                                I Offline
                                IceD112
                                npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
                                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                > iobroker.javascript@6.1.4 postinstall
                                > node ./install/installTypings.js
                                Installing NodeJS typings...
                                latest @types: 18, installed node: 16
                                added 106 packages, removed 108 packages, changed 94 packages, and audited 876 packages in 54s
                                64 packages are looking for funding
                                  run `npm fund` for details
                                11 vulnerabilities (1 low, 3 moderate, 6 high, 1 critical)
                                To address issues that do not require attention, run:
                                  npm audit fix
                                To address all issues possible (including breaking changes), run:
                                  npm audit fix --force
                                Some issues need review, and may require choosing
                                a different dependency.
                                Run `npm audit` for details.
                                sieht schon anders aus
                                • I IceD112
                                    npm audit fix
                                  I Offline
                                  I Offline
                                  IceD112
                                  Startet immer noch nicht und die Version die hier steht, stimmt auch nicht mit der überein, die bei der diagnose ausgegeben wurde
                                  • I IceD112
                                    @iced112
                                    iobroker update
                                    iobroker upgrade all --debug
                                      @iced112
                                      iobroker update
                                      I Offline
                                      I Offline
                                      IceD112
                                      Ach, guck an. das hat beim zweiten versuch funktioniert. Beim ersten mal hat er noch die scheinbar neue version als "installtiert" angezeigt und als ich das zweite mal update ausgeführt habe war Java auf dem alten stand. Dann hat die installation, bzw. das update geklappt. Jetzt ist der Adapter auch wieder gestartet... und funktioniert auch wieder :-)
                                      Vielen liebe Dank dir/euch
                                      • I IceD112
                                        @iced112
                                        Dann zeig jetzt nochmal die Ausgabe von
                                        iobroker diag
                                          @iced112
                                          iobroker diag
                                          I Offline
                                          I Offline
                                          IceD112
                                          *** ioBroker Diagnosis ***
                                          Please stretch the window of your terminal programm (puTTY) as wide as possible        or switch to full screen
                                          The following checks may give hints to potential malconfigurations or errors, pl        ease post them in our forum:
                                          Just copy and paste the Summary Page, including the ``` characters at start and        end.
                                          It helps us to help you!
                                          Press any key to continue
                                          Skript v.2022-12-13
                                          *** BASE SYSTEM ***
                                          Docker:         false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=raspbian
                                          ID_LIKE=debian
                                           22:15:29 up  1:38,  2 users,  load average: 0.93, 0.51, 0.50
                                          CPU threads: 4
                                          Sun Dec 25 21:15:29 UTC 2022
                                          Sun Dec 25 22:15:29 CET 2022
                                          CET +0100
                                          Europe/Berlin
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            1.9G        1.5G        179M        0.0K        212M        418M
                                          Swap:            99M         99M        0.0K
                                          Total:          2.0G        1.6G        180M
                                                   1872 M total memory
                                                   1480 M used memory
                                                    190 M active memory
                                                   1391 M inactive memory
                                                    179 M free memory
                                                     35 M buffer memory
                                                    176 M swap cache
                                                     99 M total swap
                                                     99 M used swap
                                                      0 M free swap
                                          *** FILESYSTEM ***
                                          Filesystem                                Type      Size  Used Avail Use% Mounted on
                                          /dev/root                                 ext4       29G  6.2G   22G  23% /
                                          tmpfs                                     tmpfs     375M  812K  374M   1% /run
                                          //192.168.178.1/IceDBox/IOBROKER/ioBroker cifs      4.1G  176M  4.0G   5% /opt/iobroker/backups
                                          `-/opt/iobroker/backups //192.168.178.1/IceDBox/IOBROKER/ioBroker cifs   rw,relatime,vers=3.1.1,cache=strict,username=ioB_Backup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
                                          /var:
                                          2.6G    /var/
                                          2.2G    /var/log
                                          138M    /var/cache
                                          148M    /opt/iobroker/backups/
                                          751M    /opt/iobroker/iobroker-data/
                                          344M    /opt/iobroker/iobroker-data/files
                                          72M     /opt/iobroker/iobroker-data/files/telegram.admin
                                          139M    /opt/iobroker/iobroker-data/states.jsonl
                                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                                          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                                          /usr/bin/nodejs         v16.19.0
                                          /usr/bin/node           v16.19.0
                                          /usr/bin/npm            8.19.3
                                          nodejs:
                                            Installed: 16.19.0-deb-1nodesource1
                                            Version table:
                                           *** 16.19.0-deb-1nodesource1 500
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          ioBroker-Instances
                                          Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                                          Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                                          Objects and States
                                          Objects:        26616
                                          States:         22293
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14362      502/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14530      469/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14405      469/iobroker.js-con
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14364      502/sshd: /usr/sbin
                                          tcp6       0      0 :::61991                :::*                    LISTEN      1001       17777      1609/io.harmony.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19693      1786/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       80147      6245/io.admin.0
                                          udp        0      0 0.0.0.0:49103           0.0.0.0:*                           1001       19311      1624/io.heos.0
                                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       17778      1609/io.harmony.0
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15257      1121/io.shelly.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12953      755/dhcpcd
                                          udp        0      0 0.0.0.0:53431           0.0.0.0:*                           108        10238      344/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19009      1461/io.chromecast.
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10236      344/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          12964      755/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                108        10237      344/avahi-daemon: r
                                          udp6       0      0 :::47412                :::*                                108        10239      344/avahi-daemon: r
