  4. Update von admin 6.2.20 -> 6.2.22 Error code 45
    6.1k
28 Beiträge 5 Kommentatoren 2.1k Aufrufe 5 Beobachtet
  • Michael NiesteggeM Michael Niestegge
    Das war nie im Spiel.
    @michael-niestegge
    Starte mal
    iobroker diag
    Michael NiesteggeM 1 Antwort Letzte Antwort
      @michael-niestegge
      Starte mal
      iobroker diag
      Michael NiesteggeM Offline
      Michael Niestegge
                              v.2022-12-13
      Operatingsystem:        Raspbian GNU/Linux 10 (buster)
      Installation:           Native
      Timezone:               Europe/Berlin
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     92
      Nodejs-Installation:    /usr/bin/nodejs         v14.20.0
                              /usr/bin/node           v14.20.0
                              /usr/bin/npm            6.14.17
      ioBroker Core:          js-controller           4.0.23
                              admin                   6.2.22
      Objects type: jsonl
      States  type: jsonl
      Pending iob updates:    1
      Active repo(s): stable
      Objects:                9321
      States:                 3276
      Size of iob-Database:
      9.3M    /opt/iobroker/iobroker-data/objects.jsonl
      7.0M    /opt/iobroker/iobroker-data/objects.json.migrated
      7.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.0K    /opt/iobroker/iobroker-data/objects.json.old
      2.7M    /opt/iobroker/iobroker-data/states.jsonl
      560K    /opt/iobroker/iobroker-data/states.json.migrated
      560K    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      ====================== END OF SUMMARY ==================
                                v.2022-12-13
        User-ID:                1000
        X-Server:               false
                                admin                   6.2.22
        Objects type: jsonl
        States  type: jsonl
        Objects:                9321
        States:                 3276
        @michael-niestegge
        Zieh dein nodejs auf Version 16 hoch.
          @michael-niestegge
          Michael Niestegge
          pi@raspberrypi:/opt/iobroker $ node -v
          v16.19.0
          pi@raspberrypi:/opt/iobroker $ npm -v
          8.19.3
          pi@raspberrypi:/opt/iobroker $ iob upgrade
          This upgrade of "admin" will introduce the following changes:
          -> 6.3.4:
          Corrected crashes in object browser
          -> 6.3.3:
          Corrected icons in object browser
          -> 6.3.2:
          Added `useNative` option to `sendTo` JSON Config component
          Added `checkLicense` and `uuid` components to JSON Config
          Corrected the news handler
          -> 6.2.23:
          Prepare for future js-controller versions
          Corrected deletion of objects
          Would you like to upgrade admin from @6.2.22 to @6.3.4 now? [(y)es, (n)o]: y
          Update admin from @6.2.22 to @6.3.4
          Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
            v16.19.0
            8.19.3
            -> 6.3.4:
            -> 6.3.3:
            -> 6.3.2:
            -> 6.2.23:
            Michael Niestegge
            schrieb am zuletzt editiert von Michael Niestegge
            Noch jemand eine Idee? Was sagt der Fehler überhaupt aus? Bringt es etwas, den admin komplett zu entfernen und neu zu installieren?
              @michael-niestegge
              Mach das Upgrade mal mit --debug Option.
                @michael-niestegge sagte in Update von admin 6.2.20 -> 6.2.22 Error code 45:
                Wir sind hier nicht unter Windows...
                Da mag das funktionieren, unter Linux i.d.R. nicht.
                  @michael-niestegge
                  Michael Niestegge
                  Keine zusätzlichen Ausgaben... :-/
                  pi@raspberrypi:~ $ iob upgrade --debug
                  -> 6.3.4:
                  -> 6.3.3:
                  -> 6.3.2:
                  -> 6.2.23:
                  pi@raspberrypi:~ $
                    -> 6.3.4:
                    -> 6.3.3:
                    -> 6.3.2:
                    -> 6.2.23:
                    pi@raspberrypi:~ $
                    @michael-niestegge
                    Und bring dein Betriebssystem in Reich der Lebenden.
                    'Buster' hat das End Of Life erreicht.
                      @michael-niestegge
                      Michael Niestegge
                      @thomas-braun said in Update von admin 6.2.20 -> 6.2.22 Error code 45:
                      @michael-niestegge
                      Ich verstehe die Aussage leider nicht?
                        @michael-niestegge
                        @michael-niestegge
                        https://www.debian.org/News/2022/20220910
                        Nach dieser Zwischenveröffentlichung werden Debians Security- und Release-Teams die Arbeit an Aktualisierungen für Debian 10 einstellen.
                        Allerhöchste Zeit da auf den Nachfolger Debian 11 'Bullseye' zu gehen.
                          @michael-niestegge
                          Michael Niestegge
                          @michael-niestegge
                          Ok, danke für die Info. Aber das ändert dann nichts an der Situation oder?
                            @michael-niestegge
                            @michael-niestegge
                            Das ändert zumindest die Basis.
                            Ein bereits abgekündigtes Release zu maintainen wird mit jedem Tag schwieriger.
                              @michael-niestegge
                              Michael Niestegge
                              @michael-niestegge
                              Alles klar. Werde ich dann machen. Allerdings wohl erst zwischen den Feiertagen. Sollte das Problem weiterhin bestehen, melde ich mich :)
                                @michael-niestegge
                                @michael-niestegge
                                Mach es danach:
                                https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                • Andreas StürzerA Offline
                                  Andreas Stürzer
                                  @Michael-Niestegge Konntest du dein Problem lösen? Ich stehe vor einem ähnlichen Problem mit einem anderen Adapter
                                  • Andreas StürzerA Andreas Stürzer
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @andreas-stürzer sagte in Update von admin 6.2.20 -> 6.2.22 Error code 45:
                                    Keine Infos um welchen Adapter und um welches Problem es sich handelt ?
                                    So kann man hier im Forum nicht helfen.
                                    Und mach bitte einen neuen Beitrag auf mit ALLEN Infos ;)
                                    Lehrling seit 1975 !!!
