  4. Update von admin 6.2.20 -> 6.2.22 Error code 45
    6.1k
28 Beiträge 5 Kommentatoren 2.1k Aufrufe 5 Beobachtet
    @glasfaser
    Das Tool ist ja auch nix gescheites... :-D
    Michael NiesteggeM Offline
    Michael Niestegge
    Beim letzten Update hatte ich das gleiche Problem, allerdings war es da ein größerer Sprung von 5.x.
    Ich habe das Update jetzt erfolgreich mit folgenden Schritten ausführen können.
    pi@raspberrypi:~ $ iobroker stop
    pi@raspberrypi:~ $ sudo npm uninstall iobroker.admin --error --prefix "/opt/iobroker"
    npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    removed 47 packages in 16.717s
    54 packages are looking for funding
      run `npm fund` for details
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo npm install iobroker.admin --error --prefix "/opt/iobroker"
    + iobroker.admin@6.2.22
    added 23 packages from 24 contributors in 33.149s
    56 packages are looking for funding
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iobroker upload admin
    upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    Update "system.adapter.admin.0"
    pi@raspberrypi:~ $ iob start
    Aber ich befürchte, dass der Fehler bestand hat und beim nächsten Update die gleiche Meldung kommen wird.
    • Michael NiesteggeM Michael Niestegge
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      @michael-niestegge sagte in Update von admin 6.2.20 -> 6.2.22 Error code 45:
      Ist rechtemäßig einfach falsch. Nie sudo mit iobroker oder npm zusammen verwenden.
      fix das:
      iobroker stop
      iobroker fix
      iobroker start
      Michael NiesteggeM 1 Antwort Letzte Antwort
        fix das:
        iobroker stop
        iobroker fix
        iobroker start
        Michael Niestegge
        Wie vermutet habe ich das Problem jetzt beim Update von admin 6.2.22 auf 6.3.4 auch wieder.
        Ausgeführt habe ich
        iobroker stop
        iobroker fix
        iobroker start
        iobroker update
        iobroker upgrade
        Folgende Meldung
        Would you like to upgrade admin from @6.2.22 to @6.3.4 now? [(y)es, (n)o]: y
        Update admin from @6.2.22 to @6.3.4
        Cannot upgrade: Cannot read property 'enabled' of undefined
        Wie bekomme ich das in den Griff? Ich wäre für Lösungsansätze sehr dankbar.
          Ausgeführt habe ich
          iobroker stop
          iobroker fix
          iobroker start
          iobroker update
          iobroker upgrade
          Folgende Meldung
          @michael-niestegge
          Ist da immer noch dieses Scheiß-Tool im Spiel?
            @michael-niestegge
            Michael Niestegge
            Das war nie im Spiel.
              @michael-niestegge
              Starte mal
              iobroker diag
                @michael-niestegge
                Starte mal
                iobroker diag
                Michael Niestegge
                                        v.2022-12-13
                Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                Installation:           Native
                Timezone:               Europe/Berlin
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     92
                Nodejs-Installation:    /usr/bin/nodejs         v14.20.0
                                        /usr/bin/node           v14.20.0
                                        /usr/bin/npm            6.14.17
                ioBroker Core:          js-controller           4.0.23
                                        admin                   6.2.22
                Objects type: jsonl
                States  type: jsonl
                Pending iob updates:    1
                Active repo(s): stable
                Objects:                9321
                States:                 3276
                Size of iob-Database:
                9.3M    /opt/iobroker/iobroker-data/objects.jsonl
                7.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                7.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                4.0K    /opt/iobroker/iobroker-data/objects.json.old
                2.7M    /opt/iobroker/iobroker-data/states.jsonl
                560K    /opt/iobroker/iobroker-data/states.json.migrated
                560K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                0       /opt/iobroker/iobroker-data/states.json.broken
                ====================== END OF SUMMARY ==================
                                          v.2022-12-13
                  User-ID:                1000
                  X-Server:               false
                                          admin                   6.2.22
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                9321
                  States:                 3276
                  @michael-niestegge
                  Zieh dein nodejs auf Version 16 hoch.
                    @michael-niestegge
                    Michael Niestegge
                    pi@raspberrypi:/opt/iobroker $ node -v
                    v16.19.0
                    pi@raspberrypi:/opt/iobroker $ npm -v
                    8.19.3
                    pi@raspberrypi:/opt/iobroker $ iob upgrade
                    This upgrade of "admin" will introduce the following changes:
                    -> 6.3.4:
                    Corrected crashes in object browser
                    -> 6.3.3:
                    Corrected icons in object browser
                    -> 6.3.2:
                    Added `useNative` option to `sendTo` JSON Config component
                    Added `checkLicense` and `uuid` components to JSON Config
                    Corrected the news handler
                    -> 6.2.23:
                    Prepare for future js-controller versions
                    Corrected deletion of objects
                    Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
                      v16.19.0
                      8.19.3
                      -> 6.3.4:
                      -> 6.3.3:
                      -> 6.3.2:
                      -> 6.2.23:
                      Michael Niestegge
                      schrieb am zuletzt editiert von Michael Niestegge
                      Noch jemand eine Idee? Was sagt der Fehler überhaupt aus? Bringt es etwas, den admin komplett zu entfernen und neu zu installieren?
                        @michael-niestegge
                        Mach das Upgrade mal mit --debug Option.
                          Wir sind hier nicht unter Windows...
                          Da mag das funktionieren, unter Linux i.d.R. nicht.
                            @michael-niestegge
                            Michael Niestegge
                            Keine zusätzlichen Ausgaben... :-/
                            pi@raspberrypi:~ $ iob upgrade --debug
                            -> 6.3.4:
                            -> 6.3.3:
                            -> 6.3.2:
                            -> 6.2.23:
                            pi@raspberrypi:~ $
                              -> 6.3.4:
                              -> 6.3.3:
                              -> 6.3.2:
                              -> 6.2.23:
                              pi@raspberrypi:~ $
                              @michael-niestegge
                              Und bring dein Betriebssystem in Reich der Lebenden.
                              'Buster' hat das End Of Life erreicht.
                                @michael-niestegge
                                Michael Niestegge
                                @thomas-braun said in Update von admin 6.2.20 -> 6.2.22 Error code 45:
                                @michael-niestegge
                                Ich verstehe die Aussage leider nicht?
                                  @michael-niestegge
                                  @michael-niestegge
                                  https://www.debian.org/News/2022/20220910
                                  Nach dieser Zwischenveröffentlichung werden Debians Security- und Release-Teams die Arbeit an Aktualisierungen für Debian 10 einstellen.
                                  Allerhöchste Zeit da auf den Nachfolger Debian 11 'Bullseye' zu gehen.
                                    @michael-niestegge
                                    Michael Niestegge
                                    @michael-niestegge
                                    Ok, danke für die Info. Aber das ändert dann nichts an der Situation oder?
                                      @michael-niestegge
                                      @michael-niestegge
                                      Das ändert zumindest die Basis.
                                      Ein bereits abgekündigtes Release zu maintainen wird mit jedem Tag schwieriger.
                                        @michael-niestegge
                                        Michael Niestegge
                                        @michael-niestegge
                                        Alles klar. Werde ich dann machen. Allerdings wohl erst zwischen den Feiertagen. Sollte das Problem weiterhin bestehen, melde ich mich :)
                                          @michael-niestegge
                                          @michael-niestegge
                                          Mach es danach:
                                          https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
