  4. Update von admin 6.2.20 -> 6.2.22 Error code 45
    6.1k
28 Beiträge 5 Kommentatoren 2.1k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @thomas-braun sagte in Update von admin 6.2.20 -> 6.2.22 Error code 45:
    Fällt mir nix gescheites zu ein.
    https://forum.iobroker.net/topic/53194/probleme-bei-update-von-admin-und-zigbee-adapter/2?_=1663671312863
    @glasfaser
    Das Tool ist ja auch nix gescheites... :-D
    Michael NiesteggeM 1 Antwort Letzte Antwort
      @glasfaser
      Michael NiesteggeM Offline
      Michael Niestegge
      Beim letzten Update hatte ich das gleiche Problem, allerdings war es da ein größerer Sprung von 5.x.
      Ich habe das Update jetzt erfolgreich mit folgenden Schritten ausführen können.
      pi@raspberrypi:~ $ iobroker stop
      pi@raspberrypi:~ $ sudo npm uninstall iobroker.admin --error --prefix "/opt/iobroker"
      npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      removed 47 packages in 16.717s
      54 packages are looking for funding
        run `npm fund` for details
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ sudo npm install iobroker.admin --error --prefix "/opt/iobroker"
      + iobroker.admin@6.2.22
      added 23 packages from 24 contributors in 33.149s
      56 packages are looking for funding
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ iobroker upload admin
      upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      Update "system.adapter.admin.0"
      pi@raspberrypi:~ $ iob start
      Aber ich befürchte, dass der Fehler bestand hat und beim nächsten Update die gleiche Meldung kommen wird.
      • Michael NiesteggeM Michael Niestegge
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $
        @michael-niestegge sagte in Update von admin 6.2.20 -> 6.2.22 Error code 45:
        Ist rechtemäßig einfach falsch. Nie sudo mit iobroker oder npm zusammen verwenden.
        fix das:
        iobroker stop
        iobroker fix
        iobroker start
          fix das:
          iobroker stop
          iobroker fix
          iobroker start
          Michael Niestegge
          Wie vermutet habe ich das Problem jetzt beim Update von admin 6.2.22 auf 6.3.4 auch wieder.
          Ausgeführt habe ich
          iobroker stop
          iobroker fix
          iobroker start
          iobroker update
          iobroker upgrade
          Folgende Meldung
          Would you like to upgrade admin from @6.2.22 to @6.3.4 now? [(y)es, (n)o]: y
          Update admin from @6.2.22 to @6.3.4
          Cannot upgrade: Cannot read property 'enabled' of undefined
          Wie bekomme ich das in den Griff? Ich wäre für Lösungsansätze sehr dankbar.
            Ausgeführt habe ich
            iobroker stop
            iobroker fix
            iobroker start
            iobroker update
            iobroker upgrade
            Folgende Meldung
            @michael-niestegge
            Ist da immer noch dieses Scheiß-Tool im Spiel?
              @michael-niestegge
              Michael Niestegge
              Das war nie im Spiel.
                @michael-niestegge
                Starte mal
                iobroker diag
                  @michael-niestegge
                  Starte mal
                  iobroker diag
                  Michael Niestegge
                                          v.2022-12-13
                  Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                  Installation:           Native
                  Timezone:               Europe/Berlin
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     92
                  Nodejs-Installation:    /usr/bin/nodejs         v14.20.0
                                          /usr/bin/node           v14.20.0
                                          /usr/bin/npm            6.14.17
                  ioBroker Core:          js-controller           4.0.23
                                          admin                   6.2.22
                  Objects type: jsonl
                  States  type: jsonl
                  Pending iob updates:    1
                  Active repo(s): stable
                  Objects:                9321
                  States:                 3276
                  Size of iob-Database:
                  9.3M    /opt/iobroker/iobroker-data/objects.jsonl
                  7.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                  7.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  4.0K    /opt/iobroker/iobroker-data/objects.json.old
                  2.7M    /opt/iobroker/iobroker-data/states.jsonl
                  560K    /opt/iobroker/iobroker-data/states.json.migrated
                  560K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                  0       /opt/iobroker/iobroker-data/states.json.broken
                  ====================== END OF SUMMARY ==================
                                            v.2022-12-13
                    User-ID:                1000
                    X-Server:               false
                                            admin                   6.2.22
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                9321
                    States:                 3276
                    @michael-niestegge
                    Zieh dein nodejs auf Version 16 hoch.
                      @michael-niestegge
                      Michael Niestegge
                      pi@raspberrypi:/opt/iobroker $ node -v
                      v16.19.0
                      pi@raspberrypi:/opt/iobroker $ npm -v
                      8.19.3
                      pi@raspberrypi:/opt/iobroker $ iob upgrade
                      This upgrade of "admin" will introduce the following changes:
                      -> 6.3.4:
                      Corrected crashes in object browser
                      -> 6.3.3:
                      Corrected icons in object browser
                      -> 6.3.2:
                      Added `useNative` option to `sendTo` JSON Config component
                      Added `checkLicense` and `uuid` components to JSON Config
                      Corrected the news handler
                      -> 6.2.23:
                      Prepare for future js-controller versions
                      Corrected deletion of objects
                      Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
                        v16.19.0
                        8.19.3
                        -> 6.3.4:
                        -> 6.3.3:
                        -> 6.3.2:
                        -> 6.2.23:
                        Michael Niestegge
                        schrieb am zuletzt editiert von Michael Niestegge
                        Noch jemand eine Idee? Was sagt der Fehler überhaupt aus? Bringt es etwas, den admin komplett zu entfernen und neu zu installieren?
                          @michael-niestegge
                          Mach das Upgrade mal mit --debug Option.
                            Wir sind hier nicht unter Windows...
                            Da mag das funktionieren, unter Linux i.d.R. nicht.
                              @michael-niestegge
                              Michael Niestegge
                              Keine zusätzlichen Ausgaben... :-/
                              pi@raspberrypi:~ $ iob upgrade --debug
                              -> 6.3.4:
                              -> 6.3.3:
                              -> 6.3.2:
                              -> 6.2.23:
                              pi@raspberrypi:~ $
                                -> 6.3.4:
                                -> 6.3.3:
                                -> 6.3.2:
                                -> 6.2.23:
                                pi@raspberrypi:~ $
                                @michael-niestegge
                                Und bring dein Betriebssystem in Reich der Lebenden.
                                'Buster' hat das End Of Life erreicht.
                                  @michael-niestegge
                                  Michael Niestegge
                                  @thomas-braun said in Update von admin 6.2.20 -> 6.2.22 Error code 45:
                                  @michael-niestegge
                                  Ich verstehe die Aussage leider nicht?
                                    @michael-niestegge
                                    @michael-niestegge
                                    https://www.debian.org/News/2022/20220910
                                    Nach dieser Zwischenveröffentlichung werden Debians Security- und Release-Teams die Arbeit an Aktualisierungen für Debian 10 einstellen.
                                    Allerhöchste Zeit da auf den Nachfolger Debian 11 'Bullseye' zu gehen.
                                      @michael-niestegge
                                      Michael Niestegge
                                      @michael-niestegge
                                      Ok, danke für die Info. Aber das ändert dann nichts an der Situation oder?
                                        @michael-niestegge
                                        @michael-niestegge
                                        Das ändert zumindest die Basis.
                                        Ein bereits abgekündigtes Release zu maintainen wird mit jedem Tag schwieriger.
                                          @michael-niestegge
                                          Michael Niestegge
                                          @michael-niestegge
                                          Alles klar. Werde ich dann machen. Allerdings wohl erst zwischen den Feiertagen. Sollte das Problem weiterhin bestehen, melde ich mich :)
