  4. BLE Adapter funktioniert nach Node Update auf v16 nicht mehr
20 Beiträge 8 Kommentatoren 1.9k Aufrufe 7 Beobachtet
  • T tiego
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Raspian
    Node-Version: v16.18.1
    Nodejs-Version: v16.18.1
    NPM-Version: 8.19.2
    Installationsart: Skript
    Image genutzt: Nein
    Hallo, Habe heute von der Node Version 10 auf die Version 16 geupdatet laut Anleitung.
    Alle Adapter funktionieren ohne Problem nur der BLE 0.13 läst sich nicht mehr starten bzw. installieren.
    Log:
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@8.19.2
    2 info using node@v16.18.1
    3 timing npm:load:whichnode Completed in 0ms
    4 timing config:load:defaults Completed in 5ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
    6 timing config:load:builtin Completed in 5ms
    7 timing config:load:cli Completed in 5ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
    10 timing config:load:project Completed in 4ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
    12 timing config:load:user Completed in 1ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:validate Completed in 2ms
    16 timing config:load:credentials Completed in 3ms
    17 timing config:load:setEnvs Completed in 3ms
    18 timing config:load Completed in 31ms
    19 timing npm:load:configload Completed in 31ms
    20 timing npm:load:mkdirpcache Completed in 3ms
    21 timing npm:load:mkdirplogs Completed in 1ms
    22 verbose title npm install AlCalzone/ioBroker.ble
    23 verbose argv "install" "AlCalzone/ioBroker.ble"
    24 timing npm:load:setTitle Completed in 3ms
    25 timing config:load:flatten Completed in 9ms
    26 timing npm:load:display Completed in 12ms
    27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
    28 verbose logfile /home/iobroker/.npm/_logs/2022-12-13T21_49_12_357Z-debug-0.log
    29 timing npm:load:logFile Completed in 19ms
    30 timing npm:load:timers Completed in 0ms
    31 timing npm:load:configScope Completed in 0ms
    32 timing npm:load Completed in 73ms
    33 timing arborist:ctor Completed in 3ms
    34 silly logfile start cleaning logs, removing 3 files
    35 silly logfile done cleaning log files
    36 timing idealTree:init Completed in 1946ms
    37 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    38 timing idealTree:userRequests Completed in 2932ms
    39 silly idealTree buildDeps
    40 silly fetch manifest iobroker.ble@AlCalzone/ioBroker.ble
    41 silly placeDep ROOT iobroker.ble@0.13.0 OK for: iobroker.inst@3.0.0 want: AlCalzone/ioBroker.ble
    42 silly fetch manifest @abandonware/noble@^1.9.2-15
    43 silly fetch manifest iobroker-react-components@^1.0.0
    44 http fetch GET 200 https://registry.npmjs.org/iobroker-react-components 1071ms (cache revalidated)
    45 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fnoble 1829ms (cache revalidated)
    46 timing idealTree:#root Completed in 3155ms
    47 silly placeDep ROOT @abandonware/noble@1.9.2-15 OK for: iobroker.ble@0.13.0 want: ^1.9.2-15
    48 silly placeDep ROOT iobroker-react-components@1.0.0 OK for: iobroker.ble@0.13.0 want: ^1.0.0
    49 silly fetch manifest debug@^4.3.1
    50 silly fetch manifest node-addon-api@^3.2.0
    51 silly fetch manifest @abandonware/bluetooth-hci-socket@^0.5.3-8
    52 http fetch GET 200 https://registry.npmjs.org/debug 97ms (cache revalidated)
    53 http fetch GET 200 https://registry.npmjs.org/node-addon-api 796ms (cache revalidated)
    54 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fbluetooth-hci-socket 1749ms (cache revalidated)
    55 timing idealTree:node_modules/iobroker.ble Completed in 1791ms
    56 silly placeDep ROOT @abandonware/bluetooth-hci-socket@0.5.3-8 OK for: @abandonware/noble@1.9.2-15 want: ^0.5.3-8
    57 silly placeDep node_modules/@abandonware/noble debug@4.3.4 OK for: @abandonware/noble@1.9.2-15 want: ^4.3.1
    58 silly placeDep node_modules/@abandonware/noble node-addon-api@3.2.1 OK for: @abandonware/noble@1.9.2-15 want: ^3.2.0
    59 silly fetch manifest @mapbox/node-pre-gyp@^1.0.5
    60 silly fetch manifest debug@^4.3.2
    61 silly fetch manifest ms@2.1.2
    62 http fetch GET 200 https://registry.npmjs.org/ms 84ms (cache revalidated)
    63 http fetch GET 200 https://registry.npmjs.org/@mapbox%2fnode-pre-gyp 1750ms (cache revalidated)
    64 timing idealTree:node_modules/@abandonware/noble Completed in 1822ms
    65 silly placeDep ROOT @mapbox/node-pre-gyp@1.0.10 OK for: @abandonware/bluetooth-hci-socket@0.5.3-8 want: ^1.0.5
    66 silly placeDep node_modules/@abandonware/bluetooth-hci-socket debug@4.3.4 OK for: @abandonware/bluetooth-hci-socket@0.5.3-8 want: ^4.3.2
    67 silly fetch manifest detect-libc@^2.0.0
    68 silly fetch manifest make-dir@^3.1.0
    69 silly fetch manifest nopt@^5.0.0
    70 silly fetch manifest npmlog@^5.0.1
    71 silly fetch manifest rimraf@^3.0.2
    72 http fetch GET 200 https://registry.npmjs.org/nopt 109ms (cache revalidated)
    73 http fetch GET 200 https://registry.npmjs.org/detect-libc 116ms (cache revalidated)
    74 http fetch GET 200 https://registry.npmjs.org/npmlog 176ms (cache revalidated)
    75 http fetch GET 200 https://registry.npmjs.org/rimraf 191ms (cache revalidated)
    76 http fetch GET 200 https://registry.npmjs.org/make-dir 902ms (cache revalidated)
    77 timing idealTree:node_modules/@abandonware/bluetooth-hci-socket Completed in 929ms
    78 silly placeDep ROOT detect-libc@2.0.1 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^2.0.0
    79 silly placeDep ROOT make-dir@3.1.0 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^3.1.0
    80 silly placeDep ROOT nopt@5.0.0 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^5.0.0
    81 silly placeDep ROOT npmlog@5.0.1 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^5.0.1
    82 silly placeDep ROOT rimraf@3.0.2 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^3.0.2
    83 silly fetch manifest semver@^6.0.0
    84 silly fetch manifest abbrev@1
    85 silly fetch manifest are-we-there-yet@^2.0.0
    86 silly fetch manifest console-control-strings@^1.1.0
    87 silly fetch manifest gauge@^3.0.0
    88 silly fetch manifest set-blocking@^2.0.0
    89 silly fetch manifest glob@^7.1.3
    90 http fetch GET 200 https://registry.npmjs.org/abbrev 127ms (cache revalidated)
    91 http fetch GET 200 https://registry.npmjs.org/semver 132ms (cache revalidated)
    92 http fetch GET 200 https://registry.npmjs.org/console-control-strings 140ms (cache revalidated)
    93 http fetch GET 200 https://registry.npmjs.org/glob 164ms (cache revalidated)
    94 http fetch GET 200 https://registry.npmjs.org/gauge 187ms (cache revalidated)
    95 http fetch GET 200 https://registry.npmjs.org/are-we-there-yet 316ms (cache revalidated)
    96 http fetch GET 200 https://registry.npmjs.org/set-blocking 331ms (cache revalidated)
    97 timing idealTree:node_modules/@mapbox/node-pre-gyp Completed in 396ms
    98 timing idealTree:node_modules/detect-libc Completed in 0ms
    99 timing idealTree:node_modules/iobroker-react-components Completed in 0ms
    100 silly placeDep node_modules/make-dir semver@6.3.0 OK for: make-dir@3.1.0 want: ^6.0.0
    101 timing idealTree:node_modules/make-dir Completed in 5ms
    102 silly placeDep ROOT abbrev@1.1.1 OK for: nopt@5.0.0 want: 1
    103 timing idealTree:node_modules/nopt Completed in 5ms
    104 timing idealTree:node_modules/abbrev Completed in 0ms
    105 silly placeDep ROOT are-we-there-yet@2.0.0 OK for: npmlog@5.0.1 want: ^2.0.0
    106 silly placeDep ROOT console-control-strings@1.1.0 OK for: npmlog@5.0.1 want: ^1.1.0
    107 silly placeDep ROOT gauge@3.0.2 OK for: npmlog@5.0.1 want: ^3.0.0
    108 silly placeDep ROOT set-blocking@2.0.0 OK for: npmlog@5.0.1 want: ^2.0.0
    109 silly fetch manifest delegates@^1.0.0
    110 silly fetch manifest readable-stream@^3.6.0
    111 silly fetch manifest aproba@^1.0.3 || ^2.0.0
    112 silly fetch manifest color-support@^1.1.2
    113 silly fetch manifest has-unicode@^2.0.1
    114 silly fetch manifest wide-align@^1.1.2
    115 http fetch GET 200 https://registry.npmjs.org/delegates 143ms (cache revalidated)
    116 http fetch GET 200 https://registry.npmjs.org/has-unicode 153ms (cache revalidated)
    117 http fetch GET 200 https://registry.npmjs.org/color-support 161ms (cache revalidated)
    118 http fetch GET 200 https://registry.npmjs.org/wide-align 158ms (cache revalidated)
    119 http fetch GET 200 https://registry.npmjs.org/readable-stream 171ms (cache revalidated)
    120 http fetch GET 200 https://registry.npmjs.org/aproba 810ms (cache revalidated)
    121 timing idealTree:node_modules/npmlog Completed in 836ms
    122 silly placeDep ROOT delegates@1.0.0 OK for: are-we-there-yet@2.0.0 want: ^1.0.0
    123 silly placeDep node_modules/are-we-there-yet readable-stream@3.6.0 OK for: are-we-there-yet@2.0.0 want: ^3.6.0
    124 silly fetch manifest string_decoder@^1.1.1
    125 http fetch GET 200 https://registry.npmjs.org/string_decoder 65ms (cache revalidated)
    126 timing idealTree:node_modules/are-we-there-yet Completed in 87ms
    127 timing idealTree:node_modules/console-control-strings Completed in 0ms
    128 timing idealTree:node_modules/delegates Completed in 0ms
    129 silly placeDep ROOT aproba@2.0.0 OK for: gauge@3.0.2 want: ^1.0.3 || ^2.0.0
    130 silly placeDep ROOT color-support@1.1.3 OK for: gauge@3.0.2 want: ^1.1.2
    131 silly placeDep ROOT has-unicode@2.0.1 OK for: gauge@3.0.2 want: ^2.0.1
    132 silly placeDep ROOT wide-align@1.1.5 OK for: gauge@3.0.2 want: ^1.1.2
    133 timing idealTree:node_modules/gauge Completed in 27ms
    134 timing idealTree:node_modules/aproba Completed in 0ms
    135 timing idealTree:node_modules/color-support Completed in 0ms
    136 timing idealTree:node_modules/has-unicode Completed in 0ms
    137 silly placeDep node_modules/rimraf glob@7.2.3 OK for: rimraf@3.0.2 want: ^7.1.3
    138 silly fetch manifest minimatch@^3.1.1
    139 http fetch GET 200 https://registry.npmjs.org/minimatch 52ms (cache revalidated)
    140 timing idealTree:node_modules/rimraf Completed in 63ms
    141 timing idealTree:node_modules/set-blocking Completed in 0ms
    142 timing idealTree:node_modules/wide-align Completed in 0ms
    143 silly placeDep node_modules/@abandonware/bluetooth-hci-socket ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    144 timing idealTree:node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug Completed in 5ms
    145 timing idealTree:node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms Completed in 0ms
    146 silly placeDep node_modules/@abandonware/noble ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    147 timing idealTree:node_modules/@abandonware/noble/node_modules/debug Completed in 4ms
    148 timing idealTree:node_modules/@abandonware/noble/node_modules/ms Completed in 0ms
    149 timing idealTree:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 0ms
    150 silly placeDep node_modules/are-we-there-yet string_decoder@1.3.0 OK for: readable-stream@3.6.0 want: ^1.1.1
    151 silly fetch manifest safe-buffer@~5.2.0
    152 http fetch GET 200 https://registry.npmjs.org/safe-buffer 48ms (cache revalidated)
    153 timing idealTree:node_modules/are-we-there-yet/node_modules/readable-stream Completed in 55ms
    154 silly placeDep node_modules/are-we-there-yet safe-buffer@5.2.1 OK for: string_decoder@1.3.0 want: ~5.2.0
    155 timing idealTree:node_modules/are-we-there-yet/node_modules/string_decoder Completed in 5ms
    156 timing idealTree:node_modules/are-we-there-yet/node_modules/safe-buffer Completed in 0ms
    157 timing idealTree:node_modules/make-dir/node_modules/semver Completed in 0ms
    158 silly placeDep node_modules/rimraf minimatch@3.1.2 OK for: glob@7.2.3 want: ^3.1.1
    159 silly fetch manifest brace-expansion@^1.1.7
    160 http fetch GET 200 https://registry.npmjs.org/brace-expansion 54ms (cache revalidated)
    161 timing idealTree:node_modules/rimraf/node_modules/glob Completed in 62ms
    162 silly placeDep node_modules/rimraf brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
    163 timing idealTree:node_modules/rimraf/node_modules/minimatch Completed in 6ms
    164 timing idealTree:node_modules/rimraf/node_modules/brace-expansion Completed in 1ms
    165 timing idealTree:buildDeps Completed in 9265ms
    166 timing idealTree:fixDepFlags Completed in 18ms
    167 timing idealTree Completed in 14195ms
    168 timing reify:loadTrees Completed in 14198ms
    169 timing reify:diffTrees Completed in 55ms
    170 silly reify moves {}
    171 timing reify:retireShallow Completed in 3ms
    172 timing reify:createSparse Completed in 48ms
    173 timing reify:loadBundles Completed in 0ms
    174 verbose reify failed optional dependency /opt/iobroker/node_modules/xpc-connection
    175 silly reify mark deleted [ '/opt/iobroker/node_modules/xpc-connection' ]
    176 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
    177 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
    178 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
    179 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
    180 timing reifyNode:node_modules/xpc-connection Completed in 40ms
    181 timing reifyNode:node_modules/osx-temperature-sensor Completed in 39ms
    182 timing reifyNode:node_modules/fsevents Completed in 39ms
    183 timing reifyNode:node_modules/wide-align Completed in 804ms
    184 timing reifyNode:node_modules/has-unicode Completed in 804ms
    185 timing reifyNode:node_modules/abbrev Completed in 806ms
    186 timing reifyNode:node_modules/rimraf/node_modules/brace-expansion Completed in 812ms
    187 timing reifyNode:node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms Completed in 812ms
    188 timing reifyNode:node_modules/@abandonware/noble/node_modules/ms Completed in 812ms
    189 timing reifyNode:node_modules/rpi-gpio/node_modules/ms Completed in 813ms
    190 timing reifyNode:node_modules/aproba Completed in 820ms
    191 timing reifyNode:node_modules/set-blocking Completed in 820ms
    192 timing reifyNode:node_modules/console-control-strings Completed in 821ms
    193 timing reifyNode:node_modules/npmlog Completed in 821ms
    194 timing reifyNode:node_modules/make-dir Completed in 821ms
    195 timing reifyNode:node_modules/button-events Completed in 827ms
    196 timing reifyNode:node_modules/async-retry Completed in 827ms
    197 timing reifyNode:node_modules/color-support Completed in 838ms
    198 timing reifyNode:node_modules/are-we-there-yet/node_modules/string_decoder Completed in 848ms
    199 timing reifyNode:node_modules/rimraf/node_modules/minimatch Completed in 855ms
    200 timing reifyNode:node_modules/rimraf Completed in 858ms
    201 timing reifyNode:node_modules/rpi-gpio-buttons Completed in 858ms
    202 timing reifyNode:node_modules/are-we-there-yet/node_modules/safe-buffer Completed in 865ms
    203 timing reifyNode:node_modules/delegates Completed in 870ms
    204 timing reifyNode:node_modules/detect-libc Completed in 867ms
    205 timing reifyNode:node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug Completed in 873ms
    206 timing reifyNode:node_modules/@abandonware/noble/node_modules/debug Completed in 873ms
    207 timing reifyNode:node_modules/are-we-there-yet Completed in 877ms
    208 timing reifyNode:node_modules/nopt Completed in 876ms
    209 timing reifyNode:node_modules/async-retry/node_modules/retry Completed in 878ms
    210 timing reifyNode:node_modules/rimraf/node_modules/glob Completed in 887ms
    211 timing reifyNode:node_modules/make-dir/node_modules/semver Completed in 896ms
    212 timing reifyNode:node_modules/rpi-gpio/node_modules/debug Completed in 895ms
    213 timing reifyNode:node_modules/unix-dgram Completed in 898ms
    214 timing reifyNode:node_modules/rpi-gpio Completed in 898ms
    215 timing reifyNode:node_modules/diskusage Completed in 903ms
    216 timing reifyNode:node_modules/iobroker-react-components Completed in 931ms
    217 timing reifyNode:node_modules/bluetooth-hci-socket Completed in 937ms
    218 timing reifyNode:node_modules/gauge Completed in 944ms
    219 timing reifyNode:node_modules/node-dht-sensor Completed in 962ms
    220 timing reifyNode:node_modules/@abandonware/bluetooth-hci-socket Completed in 997ms
    221 timing reifyNode:node_modules/are-we-there-yet/node_modules/readable-stream Completed in 1012ms
    222 timing reifyNode:node_modules/epoll Completed in 1019ms
    223 timing reifyNode:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 1036ms
    224 timing reifyNode:node_modules/usb/node_modules/node-addon-api Completed in 1036ms
    225 timing reifyNode:node_modules/@mapbox/node-pre-gyp Completed in 1048ms
    226 timing reifyNode:node_modules/es6-promise Completed in 1049ms
    227 timing reifyNode:node_modules/node-dht-sensor/node_modules/node-addon-api Completed in 1152ms
    228 timing reifyNode:node_modules/@abandonware/noble Completed in 1168ms
    229 timing reifyNode:node_modules/usb Completed in 1914ms
    230 http fetch GET 200 https://codeload.github.com/AlCalzone/ioBroker.ble/tar.gz/a9201048d6bfa5e27f82ea083f70903e858cf0e7 1262ms (cache miss)
    231 timing reify:rollback:createSparse Completed in 230ms
    232 timing reify:rollback:retireShallow Completed in 0ms
    233 timing command:install Completed in 289616ms
    234 verbose stack Error: git dep preparation failed
    234 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
    234 verbose stack     at ChildProcess.emit (node:events:513:28)
    234 verbose stack     at maybeClose (node:internal/child_process:1100:16)
    234 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
    235 verbose cwd /opt/iobroker
    236 verbose Linux 5.10.103-v7l+
    237 verbose node v16.18.1
    238 verbose npm  v8.19.2
    239 error code 1
    240 error git dep preparation failed
    241 error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
    242 error npm WARN using --force Recommended protections disabled.
    242 error npm WARN deprecated uuid@3.3.3: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    242 error npm ERR! code 1
    242 error npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonexcYOzD/node_modules/@abandonware/noble
    242 error npm ERR! command failed
    242 error npm ERR! command sh -c -- node-gyp rebuild
    242 error npm ERR! node:internal/modules/cjs/loader:988
    242 error npm ERR!   throw err;
    242 error npm ERR!   ^
    242 error npm ERR!
    242 error npm ERR! Error: Cannot find module 'object-assign'
    242 error npm ERR! Require stack:
    242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
    242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
    242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
    242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
    242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
    242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
    242 error npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
    242 error npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:833:27)
    242 error npm ERR!     at Module.require (node:internal/modules/cjs/loader:1057:19)
    242 error npm ERR!     at require (node:internal/modules/cjs/helpers:103:18)
    242 error npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
    242 error npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1155:14)
    242 error npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
    242 error npm ERR!     at Module.load (node:internal/modules/cjs/loader:1033:32)
    242 error npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:868:12)
    242 error npm ERR!     at Module.require (node:internal/modules/cjs/loader:1057:19) {
    242 error npm ERR!   code: 'MODULE_NOT_FOUND',
    242 error npm ERR!   requireStack: [
    242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
    242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
    242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
    242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
    242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
    242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
    242 error npm ERR!   ]
    242 error npm ERR! }
    242 error
    242 error npm ERR! A complete log of this run can be found in:
    242 error npm ERR!     /home/iobroker/.npm/_logs/2022-12-13T21_49_30_437Z-debug-0.log
    243 verbose exit 1
    244 timing npm Completed in 290011ms
    245 verbose unfinished npm timer reify 1670968152752
    246 verbose unfinished npm timer reify:unpack 1670968167097
    247 verbose unfinished npm timer reifyNode:node_modules/iobroker.ble 1670968167103
    248 verbose code 1
    249 error A complete log of this run can be found in:
    249 error     /home/iobroker/.npm/_logs/2022-12-13T21_49_12_357Z-debug-0.log
    Könnt Ihr mir bitte helfen den Fehler zu finden und zu beheben?
    danke
    Thomas BraunT Offline
    @tiego
    cd /opt/iobroker
    npm ls object-assign
    sagt?
    Bei nodejs schaut's wie aus?
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Edit: Typo
    H 1 Antwort Letzte Antwort
      @tiego
      cd /opt/iobroker
      sagt?
      Edit: Typo
      holgerwolf
      schrieb am zuletzt editiert von holgerwolf
      @tiego
      Ich muss das mal von tiego wieder hochholen. Er hat sich ja nicht mehr gemeldet. Aber ich laufe mit BLE 0.13 und Node 16.x auch in das obige Problem.
      Hier die Ausgabe:
       npm la object-assign
      npm ERR! Cannot read properties of undefined (reading 'description')
      npm ERR!     /home/iobroker/.npm/_logs/2022-12-20T07_49_59_077Z-debug-0.log
      0 verbose cli /usr/local/bin/node /usr/local/bin/npm
      1 info using npm@8.19.3
      2 info using node@v16.19.0
      3 timing npm:load:whichnode Completed in 3ms
      4 timing config:load:defaults Completed in 39ms
      5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 20m
      s
      6 timing config:load:builtin Completed in 24ms
      7 timing config:load:cli Completed in 39ms
      8 timing config:load:env Completed in 7ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 26ms
      10 timing config:load:project Completed in 47ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 4ms
      12 timing config:load:user Completed in 10ms
      13 timing config:load:file:/usr/local/etc/npmrc Completed in 2ms
      14 timing config:load:global Completed in 4ms
      15 timing config:load:validate Completed in 29ms
      16 timing config:load:credentials Completed in 20ms
      17 timing config:load:setEnvs Completed in 21ms
      18 timing config:load Completed in 252ms
      19 timing npm:load:configload Completed in 256ms
      20 timing npm:load:mkdirpcache Completed in 22ms
      21 timing npm:load:mkdirplogs Completed in 6ms
      22 verbose title npm la object-assign
      23 verbose argv "la" "object-assign"
      24 timing npm:load:setTitle Completed in 23ms
      25 timing config:load:flatten Completed in 68ms
      26 timing npm:load:display Completed in 111ms
      28 verbose logfile /home/iobroker/.npm/_logs/2022-12-20T07_49_59_077Z-debug-0.lo
      g
      29 timing npm:load:logFile Completed in 123ms
      30 timing npm:load:timers Completed in 1ms
      31 timing npm:load:configScope Completed in 1ms
      32 timing npm:load Completed in 568ms
      33 timing config:load:flatten Completed in 25ms
      34 timing arborist:ctor Completed in 17ms
      35 silly logfile start cleaning logs, removing 3 files
      36 silly logfile done cleaning log files
      , updated: node_modules/iobroker.discovery
      38 timing command:la Completed in 20984ms
      39 verbose stack TypeError: Cannot read properties of undefined (reading 'descri
      ption')
      39 verbose stack     at getHumanOutputItem (/usr/local/lib/node_modules/npm/lib/
      commands/ls.js:339:35)
      39 verbose stack     at visit (/usr/local/lib/node_modules/npm/lib/commands/ls.j
      s:160:15)
      39 verbose stack     at visitNode (/usr/local/lib/node_modules/npm/node_modules/
      treeverse/lib/breadth.js:37:25)
      39 verbose stack     at next (/usr/local/lib/node_modules/npm/node_modules/treev
      erse/lib/breadth.js:23:19)
      39 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/treeverse/l
      ib/breadth.js:25:31
      39 verbose stack     at processTicksAndRejections (node:internal/process/task_qu
      eues:96:5)
      39 verbose stack     at async LL.exec (/usr/local/lib/node_modules/npm/lib/comma
      nds/ls.js:122:20)
      39 verbose stack     at async module.exports (/usr/local/lib/node_modules/npm/li
      b/cli.js:78:5)
      40 verbose cwd /opt/iobroker
      41 verbose Linux 5.15.76+
      42 verbose node v16.19.0
      43 verbose npm  v8.19.3
      44 error Cannot read properties of undefined (reading 'description')
      45 verbose exit 1
      46 timing npm Completed in 24052ms
      47 verbose code 1
      48 error A complete log of this run can be found in:
      48 error     /home/iobroker/.npm/_logs/2022-12-20T07_49_59_077Z-debug-0.log
      armv6l
      Kein Docker
      /usr/local/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v16.19.0
      v16.19.0
      8.19.3
      4.0.23
      iobroker
      iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
      tty
      /etc/apt/sources.list.d
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Reading package lists... Done
      All packages are up to date.
      nodejs:
        Installed: (none)
        Candidate: 12.22.12~dfsg-1~deb11u1
        Version table:
           12.22.12~dfsg-1~deb11u1 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package
      Bin kurzzeit mal wieder zurück auf ne alte Node Version. Da gehts dann wieder. Noch ne Idee?
      CodierknechtC GlasfaserG 2 Antworten Letzte Antwort
      • H holgerwolf
        @tiego
        Hier die Ausgabe:
        s
        g
        ption')
        s:160:15)
        ib/breadth.js:25:31
        eues:96:5)
        nds/ls.js:122:20)
        b/cli.js:78:5)
        45 verbose exit 1
        47 verbose code 1
        armv6l
        Kein Docker
        /usr/local/bin/node
        /usr/local/bin/npm
        v16.19.0
        v16.19.0
        8.19.3
        4.0.23
        iobroker
        tty
        nodejs:
          Installed: (none)
          Version table:
        CodierknechtC Offline
        Codierknecht
        @holgerwolf sagte in BLE Adapter funktioniert nach Node Update auf v16 nicht mehr:
        Wie alt?
        Das aktuelle Docker-Image wird z.B. mit Node.js 16.18 ausgeliefert.
        Die 16.19 könnte etwas zu neu sein.
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • H holgerwolf
          @tiego
          Hier die Ausgabe:
          s
          g
          ption')
          s:160:15)
          ib/breadth.js:25:31
          eues:96:5)
          nds/ls.js:122:20)
          b/cli.js:78:5)
          45 verbose exit 1
          47 verbose code 1
          armv6l
          Kein Docker
          /usr/local/bin/node
          /usr/local/bin/npm
          v16.19.0
          v16.19.0
          8.19.3
          4.0.23
          iobroker
          tty
          nodejs:
            Installed: (none)
            Version table:
          GlasfaserG Offline
          GlasfaserG Offline
          /usr/local/bin/node
          /usr/local/bin/npm
          Noch ne Idee?
          alles im falschen Verzeichniss installiert .
          siehe im HowTo von Thomas wie man es beseitigt .
          H Thomas BraunT 2 Antworten Letzte Antwort
          • GlasfaserG Glasfaser
            /usr/local/bin/node
            /usr/local/bin/npm
            Noch ne Idee?
            holgerwolf
            @glasfaser Das ist mein Slave System nur für BLE und läuft auf nem Raspi Zero. Sorry, die Info hatte ich vergessen.
              /usr/local/bin/node
              /usr/local/bin/npm
              Noch ne Idee?
              @glasfaser
              Ist der Sonderfall für armv6. Das passt.
                @glasfaser
                holgerwolf
                Ich habs so nicht hinbekommen.
                Dachte ich installier jetzt erstmal die neuen node.js Versionen und dann den ble Adapter.
                Jetzt bringt der aber beim Starten den Error "noble.on is not a function". Die zusätzlich benötigten Libraries (bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin) hatte vorab installiert. rebuild habe ich auch ohne Fehler erneut ausgeführt.
                Zu dem noble.on Fehler finde ich überhaupt nix...
                  TDCroPower
                  ich häng mich mal hier dran, meine BLE Datenpunkte werden aktuell ebenfalls nicht aktualisiert.
                  Nutze aktuell auch das Docker Image 7.2.0 mit NodeJS v16.18.1
                  root@rpi4-8GB:/opt/iobroker# npm la object-assign
                  npm ERR!     /opt/iobroker/.npm/_logs/2022-12-20T23_31_09_035Z-debug-0.log
                  root@rpi4-8GB:/opt/iobroker# uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  aarch64
                  Docker-Installation
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.18.1
                  v16.18.1
                  8.19.2
                  4.0.24
                  root
                  root
                  /opt/iobroker
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                  1 package can be upgraded. Run 'apt list --upgradable' to see it.
                  nodejs:
                    Installed: 16.18.1-deb-1nodesource1
                    Candidate: 16.19.0-deb-1nodesource1
                    Version table:
                       16.19.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                   *** 16.18.1-deb-1nodesource1 100
                          500 http://deb.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.5~dfsg-2~11u1 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  • T TDCroPower
                    aarch64
                    Docker-Installation
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.18.1
                    v16.18.1
                    8.19.2
                    4.0.24
                    root
                    root
                    /opt/iobroker
                    nodejs:
                      Version table:
                    @tdcropower
                    Und warum Docker auf einem Raspberry 4? Manche Dinge werde ich wohl nie verstehen...
                    Meld dich wenigstens nicht als root an, beim Raspberry gibt es ja eine User-Verwaltung.
                    • H holgerwolf
                      holgerwolf
                      @AlCalzone
                      Hast du noch ne Idee zu dem noble Error? Habe das Gefühl, dass durch die Neuinstallation direkt mit 16.x irgendwas fehlt. Vielleicht installier ich nochmal neu mit ner alten Node Version und dann erst die Updates... Betrifft zum Glück nur den Slave für den Aussensensor.
                      • H holgerwolf
                        @AlCalzone
                        holgerwolf
                        Da am wohl Einiges durch das node Update durcheinander. Es gibt eine neue Version vom ble Adapter auf Guthub:
                        https://github.com/AlCalzone/ioBroker.ble
                        • H holgerwolf
                          Naja, alte Deps wohl. Muss natürlich auch regelmäßig nachgezogen werden.
                            @tdcropower
                            TDCroPower
                            schrieb am zuletzt editiert von TDCroPower
                            @thomas-braun ganz einfach, durch Docker bleibt das Raspberry OS soweit fast komplett original und kann ohne Probleme aktualisiert werden ohne das irgendwie was zerschoßen wird.
                            Hatte damals einen OrangePi auf dem Unifi Controller nicht installiert werden konnte, da einige Abhängigkeiten auf Armbian nicht vorhanden sind/waren... welche habe nicht mehr im Kopf, war aber ein Krampf diese zu lösen.
                            Da bin ich damals auf Docker umgestiegen und will es NIE mehr missen.
                            Ich kann meine docker-compose Config auf jeden Host/OS umziehen und es läuft sofort.
                            Gerade bei ioBroker ist es so simpel vor einem Update ein Fullbackup zu erstellen, indem man einfach den Container stoppt, das Container Verzeichnis kopiert und dann seine Spielereien testet... falls was kaputt geht einfach das Verzeichnis wieder zurück rollen und alles ist prima... dauert nur einige Sekunden!
                            Vertrau dem BackItUp Adapter bei sowas nicht mehr zu 100%, hat oft mal nicht alles funktioniert, wenn man ein Backup wieder einspielen wollte (das Yahka Adapter Files Problem zum Beispiel ;) ).
                            Zum User root, dieser ist nur im Container eingeloggt, ist der default wenn man per Portainer in den Container sich einloggt... aber für dich gerne als iobroker User der im Container eigentlich genutzt wird...
                            iobroker@rpi4-8GB:~$ pwd
                            /opt/iobroker
                            iobroker@rpi4-8GB:~$ ls -l
                            total 672
                            drwxrwxr-x   2 iobroker iobroker   4096 Apr  6  2022 backups
                            -rwxrwxrwx   1 iobroker iobroker    131 Mär 30  2022 INSTALLER_INFO.txt
                            lrwxrwxrwx   1 iobroker iobroker     22 Mär 30  2022 iob -> /opt/iobroker/iobroker
                            -rwxr-xr-x   1 iobroker iobroker    178 Dez 21 01:06 iobroker
                            -rwxr-xr-x   1 iobroker iobroker    178 Dez 20 23:54 iobroker.bak
                            drwxrwxr-x  11 iobroker iobroker   4096 Dez 21 16:04 iobroker-data
                            drwxrwxr-x   2 iobroker iobroker   4096 Dez 21 16:30 log
                            drwxrwxr-x 593 iobroker iobroker  24576 Dez 21 01:12 node_modules
                            -rw-rwxr--   1 iobroker iobroker    987 Dez 21 01:12 package.json
                            -rw-rwxr--   1 iobroker iobroker 633949 Dez 21 01:12 package-lock.json
                            iobroker@rpi4-8GB:~$ npm ls object-assign
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├─┬ iobroker.ble@0.13.1
                            │ └─┬ @abandonware/noble@1.9.2-18
                            │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-9
                            │     └─┬ @mapbox/node-pre-gyp@1.0.10
                            │       └─┬ npmlog@5.0.1
                            │         └─┬ gauge@3.0.2
                            │           └── object-assign@4.1.1 deduped
                            └─┬ iobroker.zigbee@1.8.9
                              └─┬ zigbee-herdsman@0.14.80
                                └─┬ mz@2.7.0
                            • SpikeNbgS Offline
                              SpikeNbgS Offline
                              SpikeNbg
                              @tdcropower Dein Post ist zwar schon älter, aber ich hab grad das gleiche Problem und bin durch die Suche drauf gestoßen.. Bei mir werden ebenfalls die Werte (z.B. Temperatur, Luftfeuchtigkeit) vom ble nicht aktualisiert, wobei der rssi Wert z.B. schon aktualisiert wird.
                              Habe dazu jetzt gesehen, dass es einen Bug gibt: https://github.com/AlCalzone/ioBroker.ble/issues/518
                              (hier nur zur Info, wenn jemand ebenfalls auf das Problem stößt und sich, wie ich, an den Bug für Updates dran hängen will) 🍻
                              werner2000xW 1 Antwort Letzte Antwort
                              • SpikeNbgS SpikeNbg
                                werner2000xW Offline
                                werner2000x
                                @spikenbg Ich habe jetzt auch nach update auf bullseye und Node auf v16 Probleme mit dem BLE Adapter.
                                Es kommen keine Geräte herein. der "driverstate steht auf "powerOff" und connection auf "fail".
                                ble_log.txt
                                Raspi4 8 GB mit Aqara Zigbee USB, iob
                                Innogy Smarthome
                                Bosch Bridge 2
                                HUE Bridge
                                OpenWB Wallbox mit EVU Kit
                                Google Nest Pro Hub
                                HA auf uGreen dxp4800
                                • werner2000xW werner2000x
                                  ble_log.txt
                                  @werner2000x
                                  setcap durchgeführt? Siehe Readme des Adapters.
                                  rfkill
                                  sagt?
                                    @werner2000x
                                    rfkill
                                    sagt?
                                    werner2000x
                                    @thomas-braun ```
                                    rfkill
                                    ID TYPE DEVICE SOFT HARD
                                    0 wlan phy0 blocked unblocked
                                    1 bluetooth hci0 blocked unblocked
                                    Innogy Smarthome
                                    Bosch Bridge 2
                                    HUE Bridge
                                    Google Nest Pro Hub
                                      @thomas-braun ```
                                      rfkill
                                      @werner2000x
                                      rfkill unblock bluetooth
                                      ggf. mit
                                      sudo rfkill unblock bluetooth
                                        @werner2000x
                                        ggf. mit
                                        werner2000x
                                        @thomas-braun sagte in BLE Adapter funktioniert nach Node Update auf v16 nicht mehr:
                                        Ja, Danke. Der Adapter ist jetzt grün und sucht nach Geräten. ;-)
                                        Innogy Smarthome
                                        Bosch Bridge 2
                                        HUE Bridge
                                        Google Nest Pro Hub
