  4. Probleme nach Update
    5.6k
45 Beiträge 5 Kommentatoren 6.5k Aufrufe 4 Beobachtet
    @bobbypin bitte keine Screenshots sondern als text in code-tags posten
    EDIT:
    Fehlt da das + vor dem admin?
    dann mach mal iobroker start admin
    Bobbypin
    @homoran said in Probleme nach Update:
    Sorry habe den Code jetzt eingefügt, wusste das nicht
    Last login: Fri Dec 16 17:17:11 2022
    pi@raspberry:~ $ iob status
    Objects type: jsonl
    States  type: jsonl
    pi@raspberry:~ $ iob list instances
      system.adapter.admin.0                  : admin                 : raspberry        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                                           n
      system.adapter.alexa2.0                 : alexa2                : raspberry        - disabled
    + system.adapter.backitup.0               : backitup              : raspberry        -  enabled
    + system.adapter.daikin.0                 : daikin                : raspberry        -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberry        - disabled
    + system.adapter.deconz.0                 : deconz                : raspberry        -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : raspberry        -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberry        - disabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberry        -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : raspberry        -  enabled
      system.adapter.habpanel.0               : habpanel              : raspberry        -  enabled
      system.adapter.hs100.0                  : hs100                 : raspberry        - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberry        -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberry        -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ras                                           pberry                                -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberry        -  enabled
    + system.adapter.info.0                   : info                  : raspberry        -  enabled
    + system.adapter.iot.0                    : iot                   : raspberry        -  enabled
      system.adapter.iqontrol.0               : iqontrol              : raspberry        - disabled
    + system.adapter.javascript.0             : javascript            : raspberry        -  enabled
      system.adapter.sayit.0                  : sayit                 : raspberry        - disabled, port: 0
      system.adapter.simple-api.0             : simple-api            : raspberry        - disabled, port: 8087, bind: 0.0.0.0, run as: admi                                           n
      system.adapter.solaredge.0              : solaredge             : raspberry        -  enabled
      system.adapter.solaredge.1              : solaredge             : raspberry        -  enabled
    + system.adapter.sonos.0                  : sonos                 : raspberry        -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberry        -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberry        -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberry        -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberry        -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberry        -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberry        -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberry        -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberry        -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberry        -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberry        -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberry        -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberry        -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberry        -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberry        -  enabled
      system.adapter.vis.0                    : vis                   : raspberry        -  enabled
    + system.adapter.web.0                    : web                   : raspberry        -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as                                           : admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/ttyACM0
    + instance is alive
    habe start admin ausgeführt, aber keine Veränderung
    • B Bobbypin
      Objects type: jsonl
      States  type: jsonl
      + instance is alive
      @bobbypin sagte in Probleme nach Update:
      wo steht das?
      Konsolenein- ind Ausgabe bitte!
      und log dazu
      zweite Session mit putty und iobroker logs --watch
      B 2 Antworten Letzte Antwort
        wo steht das?
        und log dazu
        Bobbypin
        pi@raspberry:~ $ iobroker start admin
        pi@raspberry:~ $
        Blöde Frage
        wie kann ich den Log komplett kopieren
        , da er sich ständig fortschreibt??
          wo steht das?
          und log dazu
          Bobbypin
          Hier mal der Code Block der sich wiederholt:
          odules/axios/package.json.
          2022-12-18 12:06:54.105  - error: host.raspberry Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1172:13)
          2022-12-18 12:06:54.106  - error: host.raspberry Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:1000:32)
          2022-12-18 12:06:54.107  - error: host.raspberry Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:899:14)
          2022-12-18 12:06:54.107  - error: host.raspberry Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1042:19)
          2022-12-18 12:06:54.107  - error: host.raspberry Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
          2022-12-18 12:06:54.108  - error: host.raspberry Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:17:15)
          2022-12-18 12:06:54.108  - error: host.raspberry Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1156:30)
          2022-12-18 12:06:54.108  - error: host.raspberry Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
          2022-12-18 12:06:54.109  - error: host.raspberry Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:1000:32)
          2022-12-18 12:06:54.109  - error: host.raspberry Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:899:14) {
          2022-12-18 12:06:54.109  - error: host.raspberry Caught by controller[0]:   code: 'ERR_REQUIRE_ESM'
          2022-12-18 12:06:54.110  - error: host.raspberry Caught by controller[0]: }
          2022-12-18 12:06:54.110  - error: host.raspberry instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2022-12-18 12:06:54.111  - info: host.raspberry Restart adapter system.adapter.admin.0 because enabled
          • B Bobbypin
            ERR_REQUIRE_ESM
            dagt mir gar nichts!
            wäre ggf. ein Fall für @thomas-braun
            -1
              ERR_REQUIRE_ESM
              Bobbypin
              OK trotzdem Danke und ein schönes WE
              Werde mal weiter probieren
              • B Bobbypin
                nee, lass das.
                Lass da erst jemanden draufsehen, der davon Ahnung hat.
                Sonst besteht die Gefahr dass noch mehr verbogen wird.
                • B Bobbypin
                  @crunchip
                  Habe ein Update der Iobroker Konsole machen wollen.
                  Hier der Status
                  und hier die Instanzen
                  crunchipC Abwesend
                  crunchipC Abwesend
                  das heisst genau?
                    das heisst genau?
                    Bobbypin
                    @crunchip
                    Ich wollte ganz normal über die adapter eine aktualisierung des Iobrokers machen. Hatte eine ältere Version und habe auf aktualisieren geclickt, wie ich es immer gemacht habe
                      das heisst genau?
                      Bobbypin
                      @crunchip
                      Hat sich gerade erledigt, habe über Putty iobroker fix ausgeführt.
                      Nun läuft es wieder.
                      Trau mich jetzt allerdings nicht wieder den Admin Adapter zu aktualisieren.
                      • B Bobbypin
                        @crunchip
                        @bobbypin
                        Check die node version schon mal.
                        Oder auch per iob diag:
                        iob stop
                        iob fix
                        iob start
                        iob diag
                        • B Bobbypin
                          @crunchip
                          iob update
                          sagt?
                            iob update
                            sagt?
                            Bobbypin
                            pi@raspberry:~ $ iob update
                            Used repository: default
                            hash unchanged, use cached sources
                            update done
                            Adapter    "accuweather"   : 1.2.1
                            Adapter    "adb"           : 0.0.7
                            Adapter    "adguard"       : 0.0.8
                            Adapter    "admin"         : 6.3.3    , installed 4.0.10 [Updateable]
                            Adapter    "aio"           : 0.1.1
                            Adapter    "airconwithme"  : 0.0.4
                            Adapter    "airzone"       : 2.0.3
                            Adapter    "alarm"         : 3.1.1
                            Adapter    "alexa2"        : 3.23.2   , installed 3.3.1 [Updateable]
                            Adapter    "alias-manager" : 1.2.4
                            Adapter    "alpha2"        : 1.0.0
                            Adapter    "amazon-dash"   : 1.1.0
                            Adapter    "anelhut"       : 1.0.13
                            Adapter    "apcups"        : 1.0.8
                            Adapter    "apple-find-me" : 0.0.14
                            Adapter    "artnet"        : 1.2.2
                            Adapter    "asterisk"      : 1.0.6
                            Adapter    "asuswrt"       : 1.0.1
                            Adapter    "awattar"       : 1.0.6
                            Adapter    "b-control-em"  : 0.2.1
                            Adapter    "backitup"      : 2.5.9
                            Adapter    "beckhoff"      : 1.5.0
                            Adapter    "benchmark"     : 1.1.0
                            Adapter    "benq"          : 0.2.5
                            Adapter    "bestway"       : 0.0.3
                            Adapter    "bidirectional-counter": 2.0.8
                            Adapter    "binance"       : 1.1.3
                            Adapter    "birthdays"     : 2.1.0
                            Adapter    "ble"           : 0.13.0
                            Adapter    "blebox"        : 1.0.0
                            Adapter    "bluelink"      : 2.2.5
                            Adapter    "bmw"           : 2.5.7
                            Adapter    "bosch-ebike"   : 0.0.3
                            Adapter    "bosesoundtouch": 0.10.3
                            Adapter    "botvac"        : 1.0.0
                            Adapter    "bring"         : 1.8.1
                            Adapter    "broadlink2"    : 2.1.5
                            Adapter    "bsblan"        : 0.2.2
                            Adapter    "bshb"          : 0.2.1
                            Adapter    "bwt"           : 0.0.4
                            Adapter    "bydbatt"       : 1.0.8
                            Adapter    "bydhvs"        : 1.3.0
                            Adapter    "canbus"        : 1.3.1
                            Adapter    "chromecast"    : 2.3.1
                            Adapter    "cloud"         : 4.3.0    , installed 3.0.3 [Updateable]
                            Adapter    "comfoair"      : 1.1.5
                            Adapter    "contactid"     : 1.0.2
                            Adapter    "coronavirus-statistics": 0.8.7   , installed 0.5.9 [Updateable]
                            Adapter    "countdown"     : 1.2.5
                            Adapter    "cul"           : 2.0.2
                            Adapter    "daikin"        : 1.4.2    , installed 1.0.5 [Updateable]
                            Adapter    "daikin-cloud"  : 0.2.3
                            Adapter    "daswetter"     : 3.1.4    , installed 3.0.4 [Updateable]
                            Adapter    "deconz"        : 1.3.21   , installed 1.3.11 [Updateable]
                            Adapter    "denon"         : 1.13.4
                            Adapter    "device-reminder": 1.2.9
                            Adapter    "device-watcher": 2.0.3
                            Adapter    "devices"       : 1.1.2
                            Adapter    "digitalstrom"  : 2.3.0    , installed 0.5.5 [Updateable]
                            Adapter    "discord"       : 1.1.6
                            Adapter    "discovergy"    : 0.5.8
                            Adapter    "discovery"     : 3.1.0    , installed 2.3.7 [Updateable]
                            Adapter    "divera247"     : 0.2.0
                            Adapter    "doorio"        : 2.1.4
                            Adapter    "drag-indicator": 2.0.9
                            Adapter    "ds18b20"       : 1.6.1
                            Adapter    "dwd"           : 2.8.3
                            Adapter    "dysonairpurifier": 2.5.7
                            Adapter    "e3dc-rscp"     : 1.0.8
                            Adapter    "easee"         : 1.0.7
                            Adapter    "ebus"          : 3.0.7
                            Adapter    "echarts"       : 1.0.12
                            Adapter    "ecovacs-deebot": 1.4.8
                            Adapter    "egigeozone"    : 0.1.2
                            Adapter    "ekey"          : 1.2.3
                            Adapter    "email"         : 1.1.4
                            Adapter    "emby"          : 1.0.2
                            Adapter    "ems-esp"       : 1.15.0
                            Adapter    "energymanager" : 1.3.4
                            Adapter    "enet"          : 1.0.1
                            Adapter    "epson_ecotank_et_2750": 0.0.12
                            Adapter    "epson_stylus_px830": 0.2.1
                            Adapter    "epson_xp540"   : 1.0.6
                            Adapter    "eusec"         : 0.9.8
                            Adapter    "exchangerates" : 0.0.14
                            Adapter    "fahrplan"      : 1.2.2
                            Adapter    "fakeroku"      : 0.2.1
                            Adapter    "fb-checkpresence": 1.1.20  , installed 1.0.4 [Updateable]
                            Adapter    "feiertage"     : 1.1.0
                            Adapter    "fhem"          : 1.6.3
                            Adapter    "fiat"          : 0.0.7
                            Adapter    "firetv"        : 1.0.0
                            Adapter    "fitbit-fitness": 0.4.6
                            Adapter    "flot"          : 1.11.0
                            Adapter    "followthesun"  : 0.4.0
                            Adapter    "foobar2000"    : 2.0.4
                            Adapter    "ford"          : 0.0.14
                            Adapter    "fritzbox"      : 0.2.1
                            Adapter    "fritzdect"     : 2.2.6    , installed 0.2.4 [Updateable]
                            Adapter    "froeling"      : 0.0.7
                            Adapter    "fronius"       : 1.1.3
                            Adapter    "fronius-solarweb": 0.0.3
                            Adapter    "frontier_silicon": 0.0.10
                            Adapter    "fuelpricemonitor": 0.3.1
                            Adapter    "fullcalendar"  : 1.2.0    , installed 1.1.0 [Updateable]
                            Adapter    "fullybrowser"  : 2.1.2
                            Adapter    "g-homa"        : 0.5.3
                            Adapter    "geofency"      : 1.2.4
                            Adapter    "go-e"          : 1.0.23
                            Adapter    "growatt"       : 2.0.0
                            Adapter    "gruenbeck"     : 0.0.42
                            Adapter    "haassohn"      : 1.0.7
                            Adapter    "habpanel"      : 0.5.0    , installed 0.4.3 [Updateable]
                            Adapter    "haier"         : 1.0.4
                            Adapter    "ham"           : 5.3.0
                            Adapter    "ham-wemo"      : 3.0.2
                            Adapter    "harmony"       : 1.2.2
                            Adapter    "hass"          : 1.3.0
                            Adapter    "hausbus_de"    : 1.1.2
                            Adapter    "heatingcontrol": 2.9.3
                            Adapter    "heizoel"       : 1.0.3
                            Adapter    "hekr"          : 0.0.6
                            Adapter    "helios"        : 0.0.3
                            Adapter    "heos"          : 1.10.0
                            Adapter    "heytech"       : 1.0.6
                            Adapter    "hid"           : 0.1.17
                            Adapter    "hikvision-alarmserver": 0.0.6
                            Adapter    "history"       : 2.2.0
                            Adapter    "hm-rega"       : 3.0.40
                            Adapter    "hm-rpc"        : 1.15.12
                            Adapter    "hmip"          : 1.18.0
                            Adapter    "homeconnect"   : 1.1.0
                            Adapter    "homee"         : 1.2.0
                            Adapter    "homekit-controller": 0.5.1
                            Adapter    "homepilot"     : 1.1.6
                            Adapter    "hoover"        : 0.0.4
                            Adapter    "hp-ilo"        : 1.0.6
                            Adapter    "hs100"         : 2.1.2    , installed 2.0.0 [Updateable]
                            Adapter    "hue"           : 3.7.1
                            Adapter    "hue-extended"  : 2.0.0
                            Adapter    "huum-sauna"    : 0.4.2
                            Adapter    "i2c"           : 1.2.1
                            Adapter    "ical"          : 1.13.1
                            Adapter    "ico-cloud"     : 1.0.0
                            Adapter    "icons-addictive-flavour-png": 0.1.0
                            Adapter    "icons-fatcow-hosting": 0.1.0
                            Adapter    "icons-icons8"  : 0.0.1
                            Adapter    "icons-material-png": 0.1.0
                            Adapter    "icons-material-svg": 0.1.0
                            Adapter    "icons-mfd-png" : 1.1.0    , installed 1.0.2 [Updateable]
                            Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.0.2 [Updateable]
                            Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
                            Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                            Adapter    "ikettle2"      : 1.0.1
                            Adapter    "imow"          : 0.0.2
                            Adapter    "influxdb"      : 3.1.8
                            Adapter    "info"          : 1.9.19   , installed 1.7.2 [Updateable]
                            Adapter    "innogy-smarthome": 0.3.7
                            Adapter    "intex"         : 0.0.7
                            Adapter    "iogopro"       : 0.2.6
                            Adapter    "iot"           : 1.11.9   , installed 1.5.3 [Updateable]
                            Adapter    "iqontrol"      : 2.0.0    , installed 1.3.3 [Updateable]
                            Adapter    "iwg-vpn"       : 0.11.4
                            Adapter    "janitza-gridvis": 2.1.25
                            Adapter    "jarvis"        : 3.1.2
                            Adapter    "javascript"    : 6.0.3    , installed 4.8.4 [Updateable]
                            Adapter    "jeelink"       : 0.1.4
                            Controller "js-controller" : 4.0.23   , installed 2.2.9 [Updateable]
                            Adapter    "judoisoft"     : 1.0.15
                            Adapter    "kecontact"     : 1.5.2
                            Adapter    "klf200"        : 1.0.1
                            Adapter    "km200"         : 2.0.3
                            Adapter    "knmi-weather"  : 1.0.2
                            Adapter    "knx"           : 2.0.13   , installed 1.0.39 [Updateable]
                            Adapter    "kodi"          : 2.0.8
                            Adapter    "kostal-piko-ba": 2.1.0
                            Adapter    "lametric"      : 2.0.0
                            Adapter    "landroid"      : 1.0.3
                            Adapter    "lcn"           : 1.0.4
                            Adapter    "legrand-ecocompteur": 1.0.0
                            Adapter    "letrika_comgw" : 0.0.6
                            Adapter    "lg-ess-home"   : 0.2.3
                            Adapter    "lg-thinq"      : 0.1.4
                            Adapter    "lgtv"          : 1.1.10
                            Adapter    "lgtv-rs"       : 0.1.1
                            Adapter    "lgtv11"        : 1.0.5
                            Adapter    "libre"         : 0.0.2
                            Adapter    "lifx"          : 0.1.1
                            Adapter    "lightify"      : 0.2.16
                            Adapter    "link"          : 0.5.11
                            Adapter    "linkeddevices" : 1.5.5
                            Adapter    "linktap"       : 0.2.1
                            Adapter    "linux-control" : 1.1.3
                            Adapter    "logparser"     : 1.1.0
                            Adapter    "loqed"         : 0.2.1
                            Adapter    "lovelace"      : 3.0.1
                            Adapter    "lowpass-filter": 2.0.5
                            Adapter    "loxone"        : 3.0.0
                            Adapter    "luftdaten"     : 2.2.4
                            Adapter    "lupusec"       : 1.3.6
                            Adapter    "luxtronik1"    : 0.3.5
                            Adapter    "material"      : 1.1.2
                            Adapter    "matrix-org"    : 0.1.3
                            Adapter    "maveo"         : 0.0.5
                            Adapter    "maxcube"       : 1.0.4
                            Adapter    "maxcul"        : 1.3.1
                            Adapter    "mbus"          : 2.4.0
                            Adapter    "mclighting"    : 0.1.2
                            Adapter    "megad"         : 1.2.1
                            Adapter    "megadd"        : 0.2.0
                            Adapter    "megaesp"       : 0.1.0
                            Adapter    "melcloud"      : 1.1.6
                            Adapter    "mercedesme"    : 0.1.0
                            Adapter    "mercury"       : 0.1.5
                            Adapter    "meross"        : 1.14.0
                            Adapter    "meteoalarm"    : 2.3.1
                            Adapter    "midea"         : 0.0.7
                            Adapter    "miele"         : 0.1.5    , installed 0.1.5
                            Adapter    "mielecloudservice": 6.4.0   , installed 2.0.0 [Updateable]
                            Adapter    "mihome"        : 1.4.0
                            Adapter    "mihome-lamp"   : 1.1.0
                            Adapter    "mihome-plug"   : 0.2.1
                            Adapter    "mihome-vacuum" : 3.8.6    , installed 2.0.7 [Updateable]
                            Adapter    "mikrotik"      : 1.0.16
                            Adapter    "milight"       : 0.3.6
                            Adapter    "milight-smart-light": 1.2.2
                            Adapter    "minuvis"       : 2.2.0
                            Adapter    "mobile"        : 1.0.1
                            Adapter    "modbus"        : 5.0.5    , installed 3.0.0 [Updateable]
                            Adapter    "moma"          : 1.2.9
                            Adapter    "mpd"           : 1.0.6
                            Adapter    "mqtt"          : 4.0.7
                            Adapter    "mqtt-client"   : 1.6.3
                            Adapter    "musiccast"     : 0.1.5
                            Adapter    "mydlink"       : 1.1.12
                            Adapter    "mysensors"     : 3.0.0
                            Adapter    "mystrom"       : 0.0.14
                            Adapter    "nanoleaf-lightpanels": 1.3.1
                            Adapter    "net-tools"     : 0.2.0
                            Adapter    "netatmo"       : 2.0.5
                            Adapter    "netatmo-crawler": 0.8.1
                            Adapter    "netatmo-energy": 1.3.1
                            Adapter    "nibeuplink"    : 1.2.1
                            Adapter    "nina"          : 0.0.25
                            Adapter    "nissan"        : 0.0.12
                            Adapter    "niu"           : 0.0.3
                            Adapter    "node-red"      : 4.0.0    , installed 1.13.0 [Updateable]
                            Adapter    "nsclient"      : 0.1.2
                            Adapter    "nuki"          : 1.6.0
                            Adapter    "nuki-extended" : 2.3.1
                            Adapter    "nut"           : 1.5.1
                            Adapter    "ocpp"          : 0.4.0
                            Adapter    "octoprint"     : 4.0.0
                            Adapter    "odl"           : 2.0.5
                            Adapter    "oilfox"        : 4.1.2
                            Adapter    "omnicomm-lls"  : 0.0.7
                            Adapter    "onkyo"         : 2.1.2
                            Adapter    "onvif"         : 0.4.4
                            Adapter    "openhab"       : 1.1.0
                            Adapter    "openknx"       : 0.2.5
                            Adapter    "openligadb"    : 1.2.4
                            Adapter    "openweathermap": 0.3.0
                            Adapter    "operating-hours": 0.0.19
                            Adapter    "opi"           : 0.1.1
                            Adapter    "oppoplayer"    : 0.2.4
                            Adapter    "owfs"          : 0.7.0
                            Adapter    "owntracks"     : 1.0.3
                            Adapter    "panasonic-comfort-cloud": 2.1.0
                            Adapter    "panasonic-viera": 2.0.0
                            Adapter    "parcel"        : 0.0.23
                            Adapter    "parser"        : 1.1.8
                            Adapter    "paw"           : 0.3.2
                            Adapter    "pegelalarm"    : 1.2.8
                            Adapter    "ph803w"        : 1.1.1
                            Adapter    "phantomjs"     : 1.1.3
                            Adapter    "philips-air"   : 0.1.7
                            Adapter    "pi-hole"       : 1.3.4
                            Adapter    "piface"        : 1.0.0
                            Adapter    "pimatic"       : 0.3.0
                            Adapter    "ping"          : 1.5.3    , installed 1.4.7 [Updateable]
                            Adapter    "pixelit"       : 0.2.0
                            Adapter    "places"        : 1.1.2
                            Adapter    "plenticore"    : 2.2.0
                            Adapter    "plex"          : 0.9.1
                            Adapter    "plexconnect"   : 0.0.7
                            Adapter    "pollenflug"    : 1.0.6
                            Adapter    "porsche"       : 0.0.3
                            Adapter    "powerfox2"     : 0.0.12
                            Adapter    "proxmox"       : 1.3.4
                            Adapter    "proxy"         : 1.3.1
                            Adapter    "psa"           : 0.0.11
                            Adapter    "puppeteer"     : 0.2.6
                            Adapter    "pushbullet"    : 0.0.11
                            Adapter    "pushover"      : 3.0.3
                            Adapter    "pushsafer"     : 1.0.3
                            Adapter    "pvforecast"    : 2.3.0
                            Adapter    "pvoutputorg"   : 1.8.5
                            Adapter    "radar2"        : 2.0.3
                            Adapter    "radiohead"     : 1.3.0
                            Adapter    "renault"       : 0.0.14
                            Adapter    "resol"         : 1.1.6
                            Adapter    "rest-api"      : 1.0.1
                            Adapter    "rflink"        : 2.1.6
                            Adapter    "rickshaw"      : 1.0.0
                            Adapter    "ring"          : 3.2.2
                            Adapter    "robonect"      : 0.1.4
                            Adapter    "roomba"        : 1.1.4
                            Adapter    "rpi2"          : 1.3.2
                            Adapter    "rssfeed"       : 2.6.1
                            Adapter    "s7"            : 1.3.13
                            Adapter    "sainlogic"     : 0.9.0
                            Adapter    "samsung"       : 0.5.8
                            Adapter    "sanext"        : 0.0.5
                            Adapter    "sayit"         : 1.12.3   , installed 1.9.8 [Updateable]
                            Adapter    "sbfspot"       : 4.1.2
                            Adapter    "scenes"        : 2.3.9
                            Adapter    "schoolfree"    : 1.0.1
                            Adapter    "schwoerer-ventcube": 1.4.2   , installed 1.3.0 [Updateable]
                            Adapter    "seko"          : 0.0.1
                            Adapter    "selverf"       : 0.6.2
                            Adapter    "seq"           : 0.2.10
                            Adapter    "shelly"        : 6.0.0
                            Adapter    "shuttercontrol": 1.4.18
                            Adapter    "sia"           : 1.0.4
                            Adapter    "siegenia"      : 1.1.1
                            Adapter    "signal-cmb"    : 0.2.3
                            Adapter    "simple-api"    : 2.7.0    , installed 2.4.8 [Updateable]
                            Adapter    "smappee"       : 0.2.6
                            Adapter    "smart-eq"      : 0.0.3
                            Adapter    "smartcontrol"  : 1.2.1
                            Adapter    "smartgarden"   : 2.0.0
                            Adapter    "smartmeter"    : 3.3.4
                            Adapter    "smartthings"   : 0.0.4
                            Adapter    "snips"         : 1.5.1
                            Adapter    "snmp"          : 2.2.1
                            Adapter    "socketio"      : 4.2.0    , installed 3.0.13 [Updateable]
                            Adapter    "solarlog"      : 2.2.2    , installed 2.0.0 [Updateable]
                            Adapter    "solarviewdatareader": 1.0.6
                            Adapter    "solarwetter"   : 1.0.0
                            Adapter    "solax"         : 0.5.7
                            Adapter    "sonnen"        : 1.13.0
                            Adapter    "sonoff"        : 2.5.1
                            Adapter    "sonos"         : 2.2.3    , installed 2.1.0 [Updateable]
                            Adapter    "sony-bravia"   : 1.0.9
                            Adapter    "spotify-premium": 1.2.1
                            Adapter    "sprinklecontrol": 0.2.13
                            Adapter    "sql"           : 2.1.8
                            Adapter    "squeezeboxrpc" : 1.3.9
                            Adapter    "starline"      : 1.1.3
                            Adapter    "statistics"    : 2.2.0
                            Adapter    "stiebel-isg"   : 1.7.5
                            Adapter    "sureflap"      : 1.1.5
                            Adapter    "swiss-weather-api": 1.0.4
                            Adapter    "synochat"      : 1.2.1
                            Adapter    "synology"      : 2.1.13
                            Adapter    "systeminfo"    : 0.3.1
                            Adapter    "tado"          : 0.4.3
                            Adapter    "tahoma"        : 0.7.1
                            Adapter    "tankerkoenig"  : 2.1.1    , installed 2.0.5 [Updateable]
                            Adapter    "tapo"          : 0.0.8
                            Adapter    "telegram"      : 1.14.1
                            Adapter    "terminal"      : 0.2.6
                            Adapter    "tesla-motors"  : 1.3.1
                            Adapter    "text2command"  : 2.2.2
                            Adapter    "tinker"        : 1.1.1
                            Adapter    "toyota"        : 0.0.3
                            Adapter    "tr-064"        : 4.2.16   , installed 4.0.3 [Updateable]
                            Adapter    "traccar"       : 0.0.12
                            Adapter    "tradfri"       : 3.1.3    , installed 2.6.2 [Updateable]
                            Adapter    "trashschedule" : 2.0.3
                            Adapter    "trivum"        : 0.0.5
                            Adapter    "tronity"       : 1.1.1
                            Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                            Adapter    "tuya"          : 3.9.4
                            Adapter    "tvprogram"     : 1.1.2
                            Adapter    "tvspielfilm"   : 2.0.4
                            Adapter    "twinkly"       : 1.0.11
                            Adapter    "unifi"         : 0.5.10
                            Adapter    "upnp"          : 1.0.21
                            Adapter    "uv-protect"    : 0.3.6
                            Adapter    "vaillant"      : 0.1.0
                            Adapter    "valloxmv"      : 1.2.0
                            Adapter    "vcard"         : 0.0.9
                            Adapter    "velux"         : 0.0.7
                            Adapter    "viessmann"     : 1.3.7
                            Adapter    "viessmannapi"  : 2.0.9
                            Adapter    "virtualpowermeter": 1.4.6
                            Adapter    "vis"           : 1.4.15   , installed 1.2.12 [Updateable]
                            Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                            Adapter    "vis-canvas-gauges": 0.1.5
                            Adapter    "vis-colorpicker": 1.2.0   , installed 1.1.1 [Updateable]
                            Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                            Adapter    "vis-google-fonts": 1.0.3
                            Adapter    "vis-history"   : 1.0.0
                            Adapter    "vis-hqwidgets" : 1.3.0    , installed 1.1.4 [Updateable]
                            Adapter    "vis-icontwo"   : 0.90.0
                            Adapter    "vis-inventwo"  : 3.3.1    , installed 1.3.8 [Updateable]
                            Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                            Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                            Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                            Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
                            Adapter    "vis-map"       : 1.0.4
                            Adapter    "vis-material-advanced": 1.7.2
                            Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
                            Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                            Adapter    "vis-plumb"     : 1.0.2
                            Adapter    "vis-rgraph"    : 0.0.2
                            Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
                            Adapter    "vis-weather"   : 2.5.6    , installed 2.5.2 [Updateable]
                            Adapter    "volumio"       : 0.1.2
                            Adapter    "volvo"         : 0.0.6
                            Adapter    "vr200"         : 1.0.0
                            Adapter    "vw-connect"    : 0.0.56
                            Adapter    "warp"          : 1.2.2
                            Adapter    "weatherflow_udp": 0.1.2
                            Adapter    "weatherunderground": 3.4.2   , installed 3.2.1 [Updateable]
                            Adapter    "web"           : 4.3.0    , installed 3.0.12 [Updateable]
                            Adapter    "webuntis"      : 0.3.4
                            Adapter    "weishaupt-wem" : 0.0.13
                            Adapter    "whatsapp-cmb"  : 0.2.2
                            Adapter    "wiegand-tcpip" : 0.4.6
                            Adapter    "wiffi-wz"      : 2.2.1
                            Adapter    "wifilight"     : 1.1.4
                            Adapter    "windows-control": 0.1.5
                            Adapter    "wiobrowser"    : 1.1.4
                            Adapter    "wireguard"     : 1.3.1
                            Adapter    "wireless-mbus" : 0.8.2
                            Adapter    "withings"      : 0.0.13
                            Adapter    "wlanthermo-nano": 0.2.1
                            Adapter    "wled"          : 0.6.7
                            Adapter    "wmswebcontrol" : 0.0.5
                            Adapter    "wolf"          : 1.5.0
                            Adapter    "wolf-smartset" : 1.0.0
                            Adapter    "worx"          : 2.0.3
                            Adapter    "ws"            : 1.3.0
                            Adapter    "xbox"          : 1.0.1
                            Adapter    "xs1"           : 1.0.2
                            Adapter    "xterm"         : 0.3.2
                            Adapter    "yahka"         : 0.13.1
                            Adapter    "yamaha"        : 0.5.3
                            Adapter    "yeelight-2"    : 1.1.2
                            Adapter    "youtube"       : 4.0.0
                            Adapter    "yr"            : 5.3.0
                            Adapter    "zehnder-cloud" : 0.0.7
                            Adapter    "zigbee"        : 1.7.6    , installed 1.2.1 [Updateable]
                            Adapter    "zont"          : 0.5.4
                            Adapter    "zwave2"        : 3.0.3
                            pi@raspberry:~ $
                              iob update
                              sagt?
                              Bobbypin
                              @thomas-braun said in Probleme nach Update:
                              iob update
                              sagt?
                              Dabei hat sich gestern morgen mein System weggehangen
                              • B Bobbypin
                                @crunchip
                                crunchipC Abwesend
                                crunchipC Abwesend
                                du meinst den Adapter admin?
                                eine Aktualisierung des iobrokers wäre der js-controller
                                • B Bobbypin
                                  update done
                                  pi@raspberry:~ $
                                  @bobbypin
                                  2er js-controller... Das ist aber massivster Update-Stau!
                                  Ran da!
                                  Betriebssystem ist dann vermutlich auch ein 'Vorkriegsmodell'.
                                    @bobbypin
                                    Ran da!
                                    Bobbypin
                                    Hatte vor dem Fix eigentlich alles aktuell.
                                    Jetzt bekomme ich meine Backups auch nicht über den Backupit adapter wieder hergestellt da ich diesen jetzt nicht mehr habe und er sich auch nicht installieren lässt. (Fehlercode 25)
                                    Thomas BraunT crunchipC 4 Antworten Letzte Antwort
                                    • B Bobbypin
                                      Dann hat dir der Fixer den ollen Kram eingespielt? Sorry, glaube ich dir nicht.
                                      • B Bobbypin
                                        @bobbypin
                                        iob diag
                                        sagt?
                                        • B Bobbypin
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          wenn ich die Ausgabe von https://forum.iobroker.net/post/911933 vergleiche, mit https://forum.iobroker.net/post/912083
                                          fehlen doch da einige Instanzen, da stimmt doch was nicht?
                                          hab das mal zusammengefasst
                                          Objects type: jsonl
                                          States  type: jsonl
                                          + instance is alive
                                          update done
                                          pi@raspberry:~ $
