  4. MQTT Bluetooth BLE Anwesenheitserkennung mit ESP32
242 Beiträge 26 Kommentatoren 57.5k Aufrufe 32 Beobachtet
  • G GiuseppeS
    @utze86
    Habe nun das Skript überarbeitet, sodass die RSSI Werte in States geschrieben werden. Anbei die aktuellen Stände:
    Skript Shelly:
    function scanCB(ev, res) {
        if (ev === BLE.Scanner.SCAN_RESULT) {
            let mac = res.addr;
            let rssi = res.rssi;
            let macType = res.addr_type;
            //print( JSON.stringify( res));
            if ( macType < 3){
              let JsonMsg = { "addr": mac, "rssi": rssi };
              //print(JSON.stringify( JsonMsg) );
              Shelly.emitEvent( "ShellyScanresult", JsonMsg);
    BLE.Scanner.Start({ duration_ms: -1}, scanCB);
    Skript iobroker:
    const {WebSocketServer, WebSocket} = require('ws');
    const port = 8085;
    const DEBUG = false;
     * Simple object check.
     * @param item
     * @returns {boolean}
    function isObject(item) {
        return (item && typeof item === 'object' && !Array.isArray(item));
     * Deep merge two objects.
     * @param target
     * @param ...sources
    function mergeDeep(target, ...sources) {
        if (!sources.length) return target;
        const source = sources.shift();
        if (isObject(target) && isObject(source)) {
            for (const key in source) {
                if (isObject(source[key])) {
                    if (!target[key]) Object.assign(target, { [key]: {} });
                    mergeDeep(target[key], source[key]);
                } else {
                    Object.assign(target, { [key]: source[key] });
        return mergeDeep(target, ...sources);
     * Shelly Outbound WebSocket
    class ShellyOWS {
        handlers = {};
        _idx = 0;
        httpServer = null;
        _clients = {};
        _statuses = {};
        _config = {};
        _requests = {};
        ws = null;
        sockets = [];
         * Init ShellyOWS with an existing httpServer
         * @param {http.Server} httpServer
        constructor(httpServer) {
            this.httpServer = httpServer;
            this.init();
         * Internal method that is called in constructor to initialize
         * @private
        init() {
            this.ws = new WebSocketServer({server: this.httpServer});
            this.ws.on('connection', async (webSocket, request, client) => {
                if (DEBUG) console.log('New device connected!');
                this.sockets.push( webSocket); // Added to force close ioBroker
                webSocket.on('message', async (message) => {
                    message = JSON.parse(message.toString());
                    this._clients[message.src] = webSocket;
                    webSocket.clientId = message.src;
                    let [model, deviceId] = message.src.split("-");
                    if (message.method) {
                        let method = message.method;
                        let params = message.params;
                        // console.log('New message', message, model, deviceId, method, params);
                        if (method === "NotifyFullStatus") {
                            this._statuses[message.src] = params;
                            let allConfig = await this.call(message.src, "Shelly.getconfig");
                            // console.error("allConfig", allConfig);
                            this._config[message.src] = allConfig;
                        else if (method === "NotifyStatus") {
                            this._statuses[message.src] = mergeDeep(this._statuses[message.src] || {}, params);
                        else if (method === "NotifyEvent") {
                            for (let event of params.events) {
                                if (event.event === "config_changed") {
                                    let config = await this.call(message.src, event.component + ".getconfig");
                                    // console.error("updated config:", config);
                                    this._config[message.src][event.component] = config;
                        // proceed to call handlers
                        if (this.handlers[method]) {
                            this._callHandler(method, message.src, params, webSocket);
                    else if (message.result) {
                        if (message.id && this._requests[message.id]) {
                            this._requests[message.id](message.result);
                        // TODO: log error/warning?
                await this.call(webSocket, "shelly.getdeviceinfo");
                // console.error("new connection", request.socket.remoteAddress);
            this.ws.on('close', (webSocket) => {
                this._callHandler("OWS::Disconnected", webSocket.clientId, undefined, webSocket);
                cld("Disconnected");
                delete this._clients[webSocket.clientId];
         * Internal.
         * @param {string} method
         * @param {string} id
         * @param {Object} params
         * @param {WebSocket} webSocket
         * @private
        _callHandler(method, id, params, webSocket) {
                let [model, deviceId] = id.split("-");
                for (let k of Object.keys(this.handlers[method])) {
                    let cb = this.handlers[method][k];
                    try {
                        cb.call(this, id, params, webSocket, model, deviceId);
                    } catch (ex) {
                        console.error("Handler", method, 'thrown error:', ex);
         * Add new handler
         * @param {Function} cb
         * @returns {number} ID of the handler, that can be used later with `removeHandler`
        addHandler(method, cb) {
            let id = this._idx++;
            if (!this.handlers[method]) {
                this.handlers[method] = {};
            this.handlers[method][id] = cb;
            return id;
         * Remove handler
         * @param {number} id
        removeHandler(method, id) {
            delete this.handlers[method][id];
         * Call a RPC on a target device id OR webSocket directly
         * @param {string|WebSocket} deviceIdOrWebSocket
         * @returns {Promise<never>|Promise<unknown>}
        call(deviceIdOrWebSocket, method, params) {
            let webSocket = deviceIdOrWebSocket instanceof WebSocket ?
                deviceIdOrWebSocket : this._clients[deviceIdOrWebSocket];
            if (!webSocket) {
                // console.error(this._clients);
                return Promise.reject(404);
            return new Promise((res, rej) => {
                this._requests[id] = (response) => {
                    res(response);
                // todo: timeout
                let req = {"jsonrpc":"2.0", "id": id, "src":"wsserver", "method": method};
                if (params) {
                    req['params'] = params;
                // console.debug("Calling:", deviceId, req);
                webSocket.send(JSON.stringify(req));
         * Return current (in-memory cached) device status
         * @param {string} clientId
         * @returns {*|{}}
        getState(clientId) {
           return this._statuses[clientId] || {};
         * Return current (in-memory cached) device config
         * @returns {*|{}}
        getConfig(clientId) {
            return this._config[clientId] || {};
         * Update config (also updates local cache)
         * @param {string} component
         * @param {Object} config
         * @returns {Promise<*>}
        async setConfig(clientId, component, config) {
            // Since response is returned before the notification, we need to sync our local config first, so that immediate
            // access to config would return the updated data.
            // If you don't want that to happen, feel free to .call Component.SetConfig directly.
            component = component.toLowerCase();
            await this.call(clientId, component + ".setconfig", {'config': config});
            this._config[clientId][component] = mergeDeep(this._config[clientId][component] || {}, config);
            return this._config[clientId][component];
         * Return ids of all clients currently connected.
         * @returns {string[]}
        getClients() {
            return Object.keys(this._clients);
     * ############ Merge from Server and Script  from page: https://github.com/ALLTERCO/shelly-outbound-websockets ############
    const http = require('http')
    console.log('WS server starting at port ' + port);
    const httpServer = http.createServer()
    let shellyOws = new ShellyOWS(httpServer);
    let idHandler = shellyOws.addHandler("NotifyEvent", async (clientId, params) => {
        if (DEBUG) console.log( clientId + " | " + JSON.stringify( params) );
        if ( params.events[0].event !== "ShellyScanresult") return
        let val = params.events[0].data.rssi;
        let StateDef = {
            initial: val,
            forceCreation: false,
            common: { role: "state", read: true, write: false, name: "RSSI", type: "number" },
            native: {}
        if ( existsState( `javascript.${instance}.${StateDef.id}`) ){
            setState( StateDef.id, val);
        } else {
            createState(StateDef.id, StateDef.initial, StateDef.forceCreation, StateDef.common, StateDef.native);
    httpServer.listen( port);
    function closeWS() {
        console.log("Close http server connection.");
        shellyOws.removeHandler( "NotifyEvent", idHandler);
        shellyOws.sockets.forEach( socket => {
            socket.close()
        httpServer.close();
    onStop(closeWS, 1000);
    Ich muss ernüchternd feststellen, dass mein MiBand 6 gerade gar nicht mehr vom Shelly erkannt wird. Zuletzt wurde es erkannt, wenn auch nur alle 10 - 15 Sekunden. Da hatte ich aber noch versucht meine Pixel Watch über iBeacon zu erkennen (erfolglos). Nun hatte ich den Test mit dem MiBand machen wollen, wird nicht angezeigt. Aber grundsätzlich funktioniert das Skript.
    Die Struktur der States schaut wie folgt aus:
    javascript.INSTANZ*.ShellyWebserver.ScanEvent.MAC*.SHELLYDEVICE*
    INSTANZ: Entspricht Instanz des Skripts in ioBroker
    MAC: Gefundene Mac Adresse während des Scans
    SHELLYDEVICE: Jeder Shelly schreibt seinen RSSI Wert unter seinem eigenen State
    Ich werde, nach jetzigem Stand, das Scannen mit der aktuellen original Shelly Firmware nicht mehr weiter verfolgen. Habe das Gefühl dass das Thema bei Shelly nicht ausgereift ist. Vor allem wird meine MiBand nicht konsequent gefunden. Was ich absolut nicht verstehen kann. Über den Android Scanner meines Handys oder über Espresense funktioniert es einwandfrei.
    Ich werde mich wahrscheinlich in Tasmota nochmals versuchen. Zuletzt hatte die Schaltererkennung evtl. nicht funktioniert, weil mein Shelly einer aktuelleren Hardware entspricht.
    U Offline
    U Offline
    Utze86
    #176
    @giuseppes Danke für die Skripte. Leider kann ich auch keine positive Rückmeldung geben. Mit der Shelly Firmware erhalte ich im Durchschnitt nur alle 7-8 Sekunden ein Signal von meinem Mi Band. Das Ergebnis ist also wesentlich schlechter als die Auswertung über Tasmota. Ich werde im nächsten Schritt ein paar Shellys mit Tasmota flashen und mich um die Umsetzung der Anwesenheitserkennung kümmern.
    G 1 Antwort Letzte Antwort
    • U Utze86
      GiuseppeS
      #177
      @utze86
      Tasmota wäre aktuell auch meine erste Wahl. Werde im Testaufbau aber noch prüfen müssen, wieso die Schaltereingänge im detached Modus teilweise so spät erkannt werden. Benötige ich für zwei Fälle.
      U 1 Antwort Letzte Antwort
      • stolly82S Offline
        stolly82S Offline
        stolly82
        schrieb am zuletzt editiert von stolly82
        #178
        @giuseppes
        Wie bekommen ich den Websocket im JavaScript Adapter zum laufen?
        20:55:37.971	info	javascript.1 (30342) Start javascript script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly
        20:55:38.124	info	javascript.1 (30342) script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly: WS server starting at port 8085
        20:55:38.132	info	javascript.1 (30342) script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly: registered 0 subscriptions and 0 schedules
        20:55:38.176	error	javascript.1 (30342) script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly: TypeError: WebSocketServer is not a constructor
        20:55:38.179	error	javascript.1 (30342) at ShellyOWS.init (script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly:70:19)
        20:55:38.181	error	javascript.1 (30342) at new ShellyOWS (script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly:61:14)
        20:55:38.183	error	javascript.1 (30342) at script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly:282:17
        20:55:38.184	error	javascript.1 (30342) at script.js.Rules.Allgemein.Lokalisierung.Indoor_-_Shelly:324:3
        Zusätzliche NPM Module ws oder websocket läuft leider nicht :(
        G 2 Antworten Letzte Antwort
        • stolly82S stolly82
          @giuseppes
          GiuseppeS
          #179
          @stolly82
          Woher weißt du, dass der Server nicht richtig läuft? Ich sehe keine Fehlermeldungen. Port 8085 sollte frei sein, dieser wird vom Server verwendet.
          Hast du den Shelly auch korrekt auf den Server eingerichtet?
            @giuseppes
            GiuseppeS
            #180
            @stolly82
            Nur ws ist als Modul notwendig
            • G GiuseppeS
              @utze86
              U Offline
              U Offline
              Utze86
              schrieb am zuletzt editiert von Utze86
              #181
              @giuseppes Nochmal eine kleine Rückmeldung zum Shelly. Ich habe das Skript nochmal mit der aktuellen stable Firmware von Shelly getestet. Diesen letzten Test wollte ich dann noch nochmal durchführen als ich gesehen habe, dass es ein Update gibt. Hier habe ich allerdings ein ähnliches Problem wie du: Das Mi Band wird komischer Weise gar nicht mehr erkannt. Keine Ahnung ob es am BLE in Kombi mit dem Band und dem Shelly liegt. Andere Geräte werden teils mehrfach die Sekunde erkannt. Der Trend geht also weiter zu Tasmota.
              Hast du eigentlich inzwischen eine Möglichkeit gefunden die Shelly Firmware wieder zurück auf den Shelly zu bekommen wenn dort einmal Tasmota installiert wurde? Bisher konnte ich online keine original Firmware finden. Die Firmware von einem anderen Shelly runter ziehen fällt aktuell leider Flach da mein USB/Serial Adapter scheinbar den Geist aufgegeben hat. Aber ich habe gesehen, dass die Shellys sich inzwischen OTA mit verschiedenen Firmwaren flashen lassen. Was natürlich mega praktisch ist, vorallem wenn die Dinger bereits verbaut sind. Also falls du eine originale Firmware hast wäre es cool wenn du sie mir zur Verfügung stellen könntest.
              EDIT: OTA geht natürlich nicht von Original FW zu Tasmota :-(
              • U Utze86
                GiuseppeS
                #182
                @utze86
                Habe selbst noch keine original Firmware finden können, daher ist ein Flashen zurück auf original auch für mich nicht möglich. Über die Möglichkeit, die Firmware von einem anderem Gerät zu ziehen, hatte ich noch gar nicht nachgedacht.
                Ich habe übrigens meine Pixel Watch verkauft und mir die Amazfit GTS 4 Mini geholt. Diese sendet, wie das Mi Band, konstant Advertisements. Aber auch diese wird vom Shelly nicht gefunden, egal ob original Firmware oder Tasmota. Daher habe ich nun meine zwei Test-Shelly auf Facebook zum Verkauf angeboten. Ich überlege nun original esp32 mit espresense zu verwenden. Ich hatte versucht espresense für die Shelly zu kompilieren, funktionierte anscheinend, aber irgendwas führt dann zu einem kritischen Fehler und der Shelly bootet. Hatte schon einen Schaltereingang zu Testzwecken im espresense Code integriert... überlege nun worauf ich mich konzentrieren soll. Zeit ist ein begrenztes Gut.
                Werde mich mal schlau machen, wie ich Firmware von einem Shelly downloaden kann und melde mich wenn erfolgreich.
                U 2 Antworten Letzte Antwort
                • G GiuseppeS
                  @utze86
                  U Offline
                  U Offline
                  Utze86
                  #183
                  @giuseppes
                  Das klingt ja sehr ernüchternd. Sobald das bei mir mit dem flashen wieder funktioniert. Probiere ich nochmal die Variante mit Tasmota. Aber ist halt blöd zu wissen, dass wenn ich das Mi Band irgendwann durch ein anderes Armband tausche ich eventuell wieder Probleme mit dem Scannen bekomme. Der Wechsel zu "richtigen" ESP`s mir Espresence wäre wahrscheinlich die effektivste Lösung würde mich aber wieder vor das Problem stellen keine Unterputzlösung zu haben. Eventuell müsste ich mir hier nochmal Gedanken machen. Ich mache es davon abhängig wie es final mit Tasmota läuft. Allerdings würde ich auch langsam ganz gerne mal was umsetzen und nicht immer nur testen, wie du schon sagst die Zeit ist immer begrenzt...
                  Dein Angebot bei Facebook habe ich gestern übrigens verfolgt :-)
                  Bezüglich zurückflashen der Firmware bin ich übrigens vor einiger Zeit auf dieses Video gestoßen. Möglicherweise funktioniert es über den gleichen weg mit den Shellys Gen. 2, müsste man mal testen. Ich persönlich kenne mich nicht wirklich mit Python aus, scheint mir jetzt aber auch nicht all zu komplex zu sein wenn man die Anleitung nutzt.
                  https://haus-automatisierung.com/projekt/2018/10/25/projekt-esp-firmware-klonen.html
                  • U Utze86
                    @giuseppes
                    GiuseppeS
                    #184
                    @utze86
                    Original Firmware:
                    Hatte heute die Firmware von einem Shelly gezogen und auf einem Tasmotized Shelly geflashed, hatte geklappt. Durch verschiedene Tests habe ich die Firmware aber unbrauchbar gemacht. Morgen lade ich die wieder und melde mich.
                    Scanner:
                    Auch mein mi band wurde zum Teil von Tasmota nicht erkannt und phasenweise, wenn es erkannt wurde, kamen die rssi mal nach 2s, mal nach 15s.
                    Das mit espresense (crash) hatte mich so geärgert, dass ich keine Lust mehr darauf hatte. Hatte heute zwei Einstellungen korrigiert und trotzdem =crash.
                    Aber die Komplexität von espresense benötige ich nicht, ebenso ist tasmota eigentlich zu viel. Daher schreibe ich jetzt etwas von Grund auf neu.
                    Habe die bluetooth Bibliothek im shelly ohne crash getestet: Uhr wird sogar sekündlich (!!!) gefunden. Hoffe, dass es sich nicht verschlechtert, wenn die Wifi Verbindung dazu kommt.
                    Nächsten Schritte:
                    • Erkennung der Schaltereingänge
                    • Schalten der Relais
                    • Übertragung der Werte über mqtt. Hier muss ich schauen, was alles übertragen wird. Es wäre sonst sehr viel. Zunächst nur MAC + RSSI + Status Eingänge
                    • Schalten der Relais über mqtt
                    • wenn noch Zeit und Motivation übrig: OTA Update ermöglichen
                    Meine minimal Idee für die Umsetzung hinsichtlich Shelly: die Statis der Schalter-Eingänge werden immer über mqtt übermittelt. Somit kann die Intelligenz (Schalter, Taster, mit Relay verknüpft, Rollladen oder Licht, etc.) vollständig über ioBroker umgesetzt werden.
                    • G GiuseppeS
                      @utze86
                      Original Firmware:
                      Scanner:
                      Nächsten Schritte:
                      U Offline
                      U Offline
                      Utze86
                      #185
                      @giuseppes
                      Hört sich mal wieder vielversprechend an ich bin gespannt was du berichtest. Morgen müsste mein neuer Controller zum flashen kommen. Dann teste ich mich nochmal parallel mit Tasmota und werde mal ein paar Shellys verbauen. Bin gespannt wie stabil das dann auch läuft. Nach deinem letzten Post bin ich da etwas skeptisch, dass das dauerhaft und stabil läuft.
                      • U Offline
                        U Offline
                        Utze86
                        #186
                        @GiuseppeS
                        Wie laufen deine Versuche mit der bluetooth Bibliothek? Bist du schon weiter?
                        Ich habe inzwischen zwei Shellys mit Tasmota verbaut und die Signale vom MiBand kommen nach wie vor recht regelmäßig an. Neben dem Mi Band versuche ich grade noch ein weiteres BLE Gerät zu tracken. Hierzu nehme ich ein Gigaset BLE Beacon. Beide Geräte werden vom Shelly zuverlässig empfangen und im Tasmota Main Menu angezeigt. Allerdings habe ich das Problem, dass beide RSSI Werte in nur einen Datenpunkt IBEACON_RSSI im iobroker geschrieben werden. Das heißt ich kann bei meiner Auswertung im iobroker nicht mehr differenzieren ob das Signal vom Mi Band oder vom BLE Tag kommt. Hast du eine Idee wie ich es gelöst bekomme, dass Tasmota zwei Datenpunkte an den iobroker sendet, also bspw. IBEACON_RSSI_MiBand und IBEACON_RSSI_GigasetBeacon? Zur Auswertung nutze ich den Sonoff Adapter aber eventuell gibt es ja eine andere Möglichkeit.
                        Die zwei Geräte bekommt man übrigens einfach gescannt und gefiltert wenn man in der Tasmota-Konsole die Regel für zwei Geräte hintereinander weg eingibt, danke für den Tipp:
                        Rule2 ON System#Boot DO BLEAlias MACadresse1=Name1 MACAdresse2=Name2 endon
                        • U Utze86
                          @GiuseppeS
                          GiuseppeS
                          #187
                          @utze86
                          Wenn der Gigaset Tag immer mit der selben MAC sendet, kannst Du das so machen. Spätestens, wenn das Smartphone über iBeacon Simulator hinzukommt, klappt das Filtern nicht mehr, da dann die UUID verwendet werden müsste, Tasmota aber nur mac filtern kann. Zumindest habe ich nichts anderes gefunden.
                          Leider funktioniert der Sonoff Adapter nicht optimal mit den Scanner Werten. Du kannst alternativ den MQTT Client Adapter testen. Dann müsstest du alles über MQTT selbst steuern.
                          Zu meiner Implementierung für den Shelly
                          Bisher umgesetzt:
                          • BLE Scanner für eine hinterlegte MAC. Werte kommen meist alle 1-2 Sekunden. Manchmal dauert es 3-4s.
                          • Erkennen der Schaltereingänge
                          • Schalten der Ausgänge
                          • Modus für Licht und Rollladen umschaltbar
                          • Rollladen über Positionsvorgabe steuerbar (bisher einfache Kalibrierung über manuelle Zeitmessung)
                          • OTA Updates möglich über PlatformIO
                          Bisher fest codiert, nicht optimal für Endanwender:
                          • WLAN und MQTT Server Konfiguration
                          • Konfiguration der Ein- und Ausgänge
                          • Filter für eine MAC
                          Geplant (in dieser Reihenfolge)
                          • Konfiguration der Ein- und Ausgänge über MQTT
                          • Filter erweitern auf mehrere MAC und über MQTT
                          • Filter erweitern auf iBeacon UUIDs
                          • Auf Github inkl Doku veröffentlichen
                          • Leistungsmessung für Shelly 2PM integrieren und darüber automatische Kalibrierung der Rollläden
                          • Leistungsmessung für Shelly 1PM
                          Die Leistungsmessungen sind absolut optional, wenn ich Langeweile haben sollte.
                          Einzig Wifi und Mqtt werde ich wahrscheinlich nicht zeitnah über WebUI implementieren können, da ich kein funktionierendes Beispiel habe. Bedeutet, jeder Endanwender muss selbst über PlatformIO kompilieren.
                          Es wurden zuletzt Shelly Plus 2PM mit DualCore gesichtet. Wenn ich eins davon in die Finger bekomme, würde ich versuchen, die Shelly Funktionalität in Espresense zu integrieren.
                          • G GiuseppeS
                            @utze86
                            Bisher umgesetzt:
                            U Offline
                            U Offline
                            Utze86
                            #188
                            @giuseppes
                            Ich bin gespannt was daraus wird. Willst du deine Arbeit in Form eines eigenen Adapters oder eines Skripts veröffentlichen oder wie hast du das geplant?
                            Was mein Problem mit den Datenpunkten angeht habe ich mir jetzt ein Workaround gebastelt. Und zwar kann man bei den Einstellungen im Sonoff Adapter einen Haken bei "für Tele/SENSOR" setzen. Daraufhin werde weitere Datenpunkte angelegt. In einem der Datenpunkte wird die Mac Adresse und in einem Datenpunkt wird der Gerätename zum soeben aktualisierten RSSI Wert geschrieben. Mit einem einfachen Blockly kann ich nun nach meinen Geräten filtern und den zugehörigen RSSI-Wert in einen eigens angelegten Datenpunkt mit meinem Gerätenamen schreiben. Je mehr Geräte und Shellys ich verwende desto umfangreicher wird das ganze natürlich aber mit 2 Shellys und 3 BLE-Geräten funktioniert das aktuell zuverlässig und noch übersichtlich. Da der Scan meiner Gtags zuverlässig funktioniert bin ich übrigens nicht darauf angewiesen zusätzlich mein Handy zu Scannen, dieses Problem umgehe ich somit. Über das Gtag will ich erstmal global erkennen ob jemand zuhause ist. Die Raumanwesenheit will ich dann wie geplant über das MiBand realisieren.
                            Ich denke mit deiner Lösung wird es alles einfach werden aber so versuche ich jetzt erstmal einen Start für mich zu finden. Wenn es bei dir dann läuft werde ich später sicherlich umswitchen. Als nächstes werde ich aber erstmal versuchen die originale Shelly Firmware von einer meiner originalen Shelly zu speichern, damit ich per Flash auch wieder zurück in den Ur-Zustand komme, bevor ich jetzt alle meine Shellys mit Tasmota bespiele. Somit könnte ich dann auch im Nachgang deine Lösung in mein System einbinden.
                            • U Utze86
                              @giuseppes
                              GiuseppeS
                              #189
                              @utze86
                              Das mit den zusätzlichen States im Sonoff Adapter hatte ich auch gefunden. Nur bekam ich dort sync Probleme, manchmal stimmte die MAC bzw der Name nicht zum rssi. Aber da hatte ich noch nicht gefiltert.
                              Das was ich gerade programmiere, wird über den mqtt Adapter von ioBroker absolut simpel nutzbar sein. Das funktioniert auch schon einwandfrei. Ich persönlich könnte es jetzt schon verwenden. Wenn ich es aber zur Verfügung stelle, dann müssen noch die oben genannten Punkte rein. Wifi Config wird dann auch über Access Point einstellbar sein. Hatte den allgemeinen Programmieraufwand etwas unterschätzt, daher komme ich gerade in einen zeitlichen Engpass. Ab Freitag fahre ich für knapp zwei Wochen weg. Danach kann ich weiter machen. Versuche den morgigen Tag noch effizient zu nutzen.
                              • G GiuseppeS
                                @utze86
                                U Offline
                                U Offline
                                Utze86
                                #190
                                @giuseppes
                                Na dann wünsche ich dir in dem Sinne schöne Feiertage und eine erholsame Reise.
                                • G GiuseppeS
                                  @utze86
                                  U Offline
                                  U Offline
                                  Utze86
                                  #191
                                  @giuseppes
                                  Hi, ich habe mir vor Weihnachten ein MiBand 7 bestellt, was ich bisher leider nicht per Bluetooth über Tasmota mit den Shellys finden konnte. Nach etwas Recherche bin ich auf das hier gestoßen:
                                  Wenn ich den Befehl BLEAddrFilter 1 in die Console eingeben wird das MiBand 7 ohne Probleme gefunden. Die Info kommt sicherlich etwas spät aber möglicherweise hilft dir das ebenfalls bei deiner Problematik weiter, dass du deine Pixel Watch bzw. die Amazfit GTS 4 Mini nicht findest.
                                  Morgen werde ich "BLEAddrFilter 1" als Rule anlegen und dann wird das MiBand 7 hoffentlich regulär nach jedem Boot gefunden. Ich habe bisher keine Messung durchgeführt, aber das MiBand 7 wird gefühlt genau so häufig erkannt wie das MiBand 4
                                  VG und einen guten Rutsch!
                                  • U Utze86
                                    @giuseppes
                                    GiuseppeS
                                    #192
                                    @utze86
                                    Das wird wahrscheinlich die Ursache sein. Müsste ich mal testen, wenn ich wieder daheim bin. Wäre tatsächlich "etwas spät", aber natürlich danke für diese Info. Meine Pixel Watch habe ich ja inzwischen verkauft, da wäre es aber wie beim Smartphone eine random MAC Adresse. Die wurde über UUID gefunden, da kann man aber nicht filtern. Für meine aktuelle Uhr, die GTS4 Mini, könnte es aber sehr wahrscheinlich helfen. Ich hatte allerdings bei Tasmota das Problem, dass der Schalter Eingang sehr spät auslöste, wenn dieser als "detached" eingestellt wurde. Aber da, wo ich die Shelly für Rollläden einsetze, könnte ich evtl Tasmota reaktivieren.
                                    Müsste nochmals testen, wie synchron alle Signale eingehen, sodass dann der Sonoff Adapter für die Steuerung genutzt werden kann.
                                    Ich gehe aber davon aus, dass ich mein angefangenes Projekt für die Shelly trotzdem zu Ende bringe. Da fehlt nicht mehr viel...
                                    Danke für die Info und auch dir schonmal einen guten Rutsch.
                                    • U Utze86
                                      @giuseppes
                                      GiuseppeS
                                      #193
                                      @utze86
                                      Wie nun erwartet, hatte es mit Tasmota und "BLEAddrFilter 1" funktioniert. Meine GTS4 Mini wird alle 3-7 Sekunden gefunden. Werde aber zwei Nachmittage darauf verwenden, mein Tool fertigzustellen. Da klappt's deutlich häufiger und meine Hoffnung ist, dass ich für Rollläden eine Auto-Kalibrierung integrieren kann.
                                      • G GiuseppeS
                                        @utze86
                                        U Offline
                                        U Offline
                                        Utze86
                                        #194
                                        @giuseppes
                                        Gut, dass das schonmal klappt. Ich habe inzwischen weitere Shellys mit Tasmota verbaut und Werte aktuell die Signale aus. Das klappt bei 4 Stk. soweit schon ganz gut. Ich habe allerdings noch keine Abhängigkeiten festgelegt um meine Geräte/Beleuchtung hier zu steuern.
                                        Ich bin gespannt wie dein Tool läuft. Sag mal Bescheid wenn du soweit bist. Ich habe es inzwischen geschafft die Firmware von einer meiner Shellys zu sichern. Allerdings konnte ich dann von einem anschließend zurück geflashten Shelly nicht wieder auf Tasmota zurück. Der ESP Flasher zeigt mir hier immer eine Fehlermeldung. Ich kann mir aber gut vorstellen, dass die Anschlüsse am Shelly durch des gefummel mittlerweile so genudelt sind, dass ich kein anständigen Kontakt mehr zum flashen hinbekomme. Grundsätzlich komme ich aber wieder auf die originale FW zurück und bin daher schon sehr auf dein Tool gespannt. Ließe sich das Tool denn auf die Plus 1 Shellys anwenden/übertragen oder wird das "nur" auf deinen Plus 2 PM laufen?
                                        • U Utze86
                                          @giuseppes
                                          GiuseppeS
                                          #195
                                          @utze86
                                          Grundsätzlich müsste das Tool auch auf Plus 1pm Modelle laufen. Es geht ja um den esp32, dieser ist in allen Plus Modellen verbaut. Konfiguration der Pins (Ein- und Ausgänge) sind simpel zu konfigurieren. Habe selbst keinen Plus 1pm, daher wäre es praktisch, wenn du es dann für mich testen könntest. Denke, dass ich diese Woche fertig werde. Komme nicht immer dazu zu programmieren, daher zieht sich das etwas.
