  3. Einsteigerfragen
  4. Installation
  5. Kein Zugriff auf Anwendungen
26 Beiträge 3 Kommentatoren 2.9k Aufrufe 2 Beobachtet
    @mellus
    Im Log steht dazu was?
    Ich vermute dass da keine gültige Lizenz gefunden wird.
    mellus
    @thomas-braun wie komme ich an die log Datei ohne Zugriff auf die Admin-Oberfläche?
    • M mellus
      @mellus
      Über die Kommandozeile:
      iob logs
        @mellus
        iob logs
        mellus
        @thomas-braun Dankeschön !
        pi@iobroker:~ $ iobroker logs
        2022-12-11 10:17:10.722 - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
        2022-12-11 10:17:10.728 - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-12-11 10:17:10.730 - info: host.iobroker hostname: iobroker, node: v16.18.1
        2022-12-11 10:17:10.731 - info: host.iobroker ip addresses: fe80::3f68:ee45:fc73:8604
        2022-12-11 10:17:13.240 - info: host.iobroker connected to Objects and States
        2022-12-11 10:17:13.283 - info: host.iobroker added notifications configuration of host
        2022-12-11 10:17:14.407 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
        2022-12-11 10:17:14.418 - info: host.iobroker 3 instances found
        2022-12-11 10:17:14.433 - info: host.iobroker starting 3 instances
        2022-12-11 10:17:14.549 - info: host.iobroker instance system.adapter.admin.0 started with pid 945
        2022-12-11 10:17:14.566 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
        2022-12-11 10:17:14.659 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
        2022-12-11 10:17:14.687 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
        2022-12-11 10:17:14.717 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
        2022-12-11 10:17:14.746 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
        2022-12-11 10:17:14.776 - info: host.iobroker Some obsolete host states deleted.
        2022-12-11 10:30:17.673 - error: admin.0 (945) admin.0 already running
        2022-12-11 10:30:17.679 - warn: admin.0 (945) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-12-11 10:30:18.239 - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-12-11 10:30:18.240 - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
        2022-12-11 10:30:18.711 - info: host.iobroker instance system.adapter.discovery.0 started with pid 1378
        2022-12-11 10:30:20.184 - error: discovery.0 (1378) discovery.0 already running
        2022-12-11 10:30:20.190 - warn: discovery.0 (1378) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-12-11 10:30:20.745 - error: host.iobroker instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-12-11 10:30:20.747 - info: host.iobroker Restart adapter system.adapter.discovery.0 because enabled
        2022-12-11 10:30:22.694 - info: host.iobroker instance system.adapter.backitup.0 started with pid 1852
        2022-12-11 10:30:24.182 - error: backitup.0 (1852) backitup.0 already running
        2022-12-11 10:30:24.186 - warn: backitup.0 (1852) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2022-12-11 10:30:24.734 - error: host.iobroker instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2022-12-11 10:30:24.735 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
        2022-12-11 10:30:48.306 - info: host.iobroker instance system.adapter.admin.0 started with pid 1876
        2022-12-11 10:30:50.164 - info: admin.0 (1876) starting. Version 6.2.23 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.1, js-controller: 4.0.23
        2022-12-11 10:30:50.218 - info: admin.0 (1876) requesting all states
        2022-12-11 10:30:50.219 - info: admin.0 (1876) requesting all objects
        2022-12-11 10:30:50.675 - info: admin.0 (1876) received all objects
        2022-12-11 10:30:50.782 - info: host.iobroker instance system.adapter.discovery.0 started with pid 1899
        2022-12-11 10:30:50.840 - info: admin.0 (1876) Request actual repository...
        2022-12-11 10:30:50.906 - info: admin.0 (1876) http server listening on port 8081
        2022-12-11 10:30:50.907 - info: admin.0 (1876) Use link "http://localhost:8081" to configure.
        2022-12-11 10:30:50.918 - info: admin.0 (1876) socket.io server listening on port 8081
        2022-12-11 10:30:51.232 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2022-12-11 10:30:53.852 - info: admin.0 (1876) Repository received successfully.
        2022-12-11 10:30:54.158 - info: discovery.0 (1899) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.1, js-controller: 4.0.23
        2022-12-11 10:30:54.780 - info: host.iobroker instance system.adapter.backitup.0 started with pid 1918
        2022-12-11 10:30:56.392 - info: backitup.0 (1918) starting. Version 2.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
        2022-12-11 10:30:56.459 - info: backitup.0 (1918) [iobroker] backup was activated at 02:40 every 1 day(s)
        2022-12-11 16:15:06.041 - info: admin.0 (1876) terminating http server on port 8081
        2022-12-11 16:15:06.042 - info: backitup.0 (1918) cleaned everything up...
        2022-12-11 16:15:06.055 - info: host.iobroker received SIGTERM
        2022-12-11 16:15:06.062 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
        2022-12-11 16:15:06.063 - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
        2022-12-11 16:15:06.063 - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-12-11 16:15:06.077 - info: admin.0 (1876) Got terminate signal TERMINATE_YOURSELF
        2022-12-11 16:15:06.080 - info: backitup.0 (1918) Got terminate signal TERMINATE_YOURSELF
        2022-12-11 16:15:06.082 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
        2022-12-11 16:15:06.082 - info: admin.0 (1876) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-12-11 16:15:06.084 - info: backitup.0 (1918) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-12-11 16:15:06.085 - info: discovery.0 (1899) Got terminate signal TERMINATE_YOURSELF
        2022-12-11 16:15:06.096 - info: discovery.0 (1899) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-12-11 16:15:06.124 - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
        2022-12-11 16:15:06.125 - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
        2022-12-11 16:15:06.653 - info: host.iobroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-12-11 16:15:06.666 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-12-11 16:15:06.709 - info: host.iobroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-12-11 16:15:06.710 - info: host.iobroker All instances are stopped.
        2022-12-11 16:15:06.901 - info: host.iobroker terminated
        2022-12-11 16:15:08.993 - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
        2022-12-11 16:15:09.000 - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-12-11 16:15:09.001 - info: host.iobroker hostname: iobroker, node: v16.18.1
        2022-12-11 16:15:09.002 - info: host.iobroker ip addresses: 192.168.178.94 2a02:908:d80:aa80:e25b:e951:5000:a86f fe80::3f68:ee45:fc73:8604 192.168.178.189 2a02:908:d80:aa80:44b6:3b6a:e318:bf17 fe80::f8dd:f6dc:7e55:5a9f
        2022-12-11 16:15:09.878 - info: host.iobroker connected to Objects and States
        2022-12-11 16:15:09.901 - info: host.iobroker added notifications configuration of host
        2022-12-11 16:15:10.268 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
        2022-12-11 16:15:10.276 - info: host.iobroker 3 instances found
        2022-12-11 16:15:10.285 - info: host.iobroker starting 3 instances
        2022-12-11 16:15:10.334 - info: host.iobroker instance system.adapter.admin.0 started with pid 3386
        2022-12-11 16:15:10.362 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
        2022-12-11 16:15:10.377 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
        2022-12-11 16:15:10.391 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
        2022-12-11 16:15:10.405 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
        2022-12-11 16:15:10.420 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
        2022-12-11 16:15:10.434 - info: host.iobroker Some obsolete host states deleted.
        2022-12-11 16:15:12.276 - info: admin.0 (3386) starting. Version 6.2.23 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.1, js-controller: 4.0.23
        2022-12-11 16:15:12.325 - info: admin.0 (3386) requesting all states
        2022-12-11 16:15:12.326 - info: admin.0 (3386) requesting all objects
        2022-12-11 16:15:12.698 - info: admin.0 (3386) received all objects
        2022-12-11 16:15:12.898 - info: admin.0 (3386) Request actual repository...
        2022-12-11 16:15:12.937 - info: admin.0 (3386) http server listening on port 8081
        2022-12-11 16:15:12.938 - info: admin.0 (3386) Use link "http://localhost:8081" to configure.
        2022-12-11 16:15:12.950 - info: admin.0 (3386) socket.io server listening on port 8081
        2022-12-11 16:15:13.244 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2022-12-11 16:15:15.654 - info: host.iobroker instance system.adapter.discovery.0 started with pid 3413
        2022-12-11 16:15:15.835 - info: admin.0 (3386) Repository received successfully.
        2022-12-11 16:15:17.238 - info: discovery.0 (3413) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.1, js-controller: 4.0.23
        2022-12-11 16:15:18.322 - info: host.iobroker instance system.adapter.backitup.0 started with pid 3428
        2022-12-11 16:15:20.033 - info: backitup.0 (3428) starting. Version 2.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
        2022-12-11 16:15:20.098 - info: backitup.0 (3428) [iobroker] backup was activated at 02:40 every 1 day(s)
        pi@iobroker:~ $
        • M mellus
          pi@iobroker:~ $
          @mellus sagte in Kein Zugriff auf Anwendungen:
          mach mal rin reboot vom pi
            mellus
            @homoran Problem bleibt
            • M mellus
              @mellus
              iob list instances
              Da läuft ja auch gar nicht viel, wenn ich das richtig sehe .
              Bitte für Konsolentext die CodeTags verwenden.
                @mellus
                iob list instances
                mellus
                @thomas-braun Ja, ist ja auch ne taufrische Neuinstallation, weil das Problem besteht
                • M mellus
                  @mellus
                  Den iot bzw. cloud-Adapter brauchst du schon.
                    @mellus
                    mellus
                    @thomas-braun werden diese Adapter nicht automatisch mit aufgespielt bei einer Neuinstallation?
                    • M mellus
                      @mellus
                      Nein.
                        @mellus
                        Nein.
                        mellus
                        schrieb am zuletzt editiert von mellus
                        @thomas-braun ich habe noch nie nach einer Neuinstallation den Cloud-Adapter nachinstallieren müssen.
                        Vermutlich so:
                        npm install iobroker.cloud
                        und dann manuell starten?
                        • M mellus
                          Vermutlich so:
                          @mellus
                          Und wie soll die Synchronisation zu iobroker.net/pro dann funktionieren?
                          • M mellus
                            Vermutlich so:
                            der war noch nie in dem Installer dabei.
                            Vermutlich so:
                            nein.
                            iobroker add cloud
                              Vermutlich so:
                              nein.
                              iobroker add cloud
                              mellus
                              @homoran Ich habe mich hiernach gerichtet:
                              https://youtu.be/xb-S8pWtwu4
                              • M mellus
                                @mellus
                                Da wird doch gar nicht auf zusätzliche Adapter und die Anbindung an iobroker.pro eingegangen.
                                • M mellus
                                  dann ist ja gut
                                    dann ist ja gut
                                    mellus
                                    Vielen Dank für die intelligenten und überaus hilfreichen Antworten.
