  4. Test Adapter micronova easy connect plus
    apollon77A
80 Beiträge 9 Kommentatoren 16.0k Aufrufe 8 Beobachtet
  • K Kusi
    @tombox Es ist "Easy Connect Plus" gewählt.
    Es ist auch nur 1 Instanz installiert.
    Beim Start der Instanz sieht es wie folgt aus:
    micronova.0
    2022-11-29 22:05:48.326	info	Login successful
    micronova.0
    2022-11-29 22:04:47.738	info	receive 401 error. Refresh Token in 60 seconds
    micronova.0
    2022-11-29 22:01:34.332	info	Found 1 devices
    micronova.0
    2022-11-29 22:01:34.236	info	Login successful
    micronova.0
    2022-11-29 22:01:33.505	info	Login to Easy Connect Plus
    micronova.0
    2022-11-29 22:01:33.276	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#d30070c23d7dddf88f05ee9138d14e1ab9d66816) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
    Hier die Installation des neuen Adapters:
    micronova.0
    2022-11-29 22:08:57.019	error	Cannot check object existence of "micronova.0.AF217968-77DC-420C-9D55-7521B6D67497.register.33021.app_image_name": Connection is closed.
    micronova.0
    2022-11-29 22:08:57.018	error	Error: Could not check object existence of micronova.0.AF217968-77DC-420C-9D55-7521B6D67497.register.33021: Cannot check object existence of "micronova.0.AF217968-77DC-420C-9D55-7521B6D67497.register.33021": Connection is closed.
    micronova.0
    2022-11-29 22:08:57.016	error	Cannot check object existence of "micronova.0.AF217968-77DC-420C-9D55-7521B6D67497.register.33021": Connection is closed.
    micronova.0
    2022-11-29 22:08:57.014	error	Error: DB closed
    micronova.0
    2022-11-29 22:08:57.013	error	Error extract keys: AF217968-77DC-420C-9D55-7521B6D67497.register.33020 {"app_image_name":"default","reg_key":"calendar_month_set","reg_name":"Mese","reg_name_app":"Mese","reg_key_group":"calendar_month","reg_type":"SET","offset":33020,"eeprom":true,"is_word":false,"big_endian":false,"formula":"#","formula_inverse":"#","format_string":"{0}","set_min":1,"set_max":12,"readonly":false,"mask":65535,"is_hex":true,"is_temperature":false,"use_app":true,"display_dashboard":false,"display_manage":false,"display_info":false,"use_cat":true,"display_order":0,"step":1,"use_history":true,"use_history_output":true,"with_sign":false,"from_char_code":false,"notify_on_change":false,"is_test":false}
    micronova.0
    2022-11-29 22:08:57.011	warn	get state error: Connection is closed.
    micronova.0
    2022-11-29 22:08:57.010	warn	Could not perform strict object check of state micronova.0.AF217968-77DC-420C-9D55-7521B6D67497.register.33020.app_image_name: DB closed
    micronova.0
    2022-11-29 22:08:57.003	error	Error: DB closed
    micronova.0
    2022-11-29 22:08:57.002	error	Error extract keys: AF217968-77DC-420C-9D55-7521B6D67497.register.33016 {"app_image_name":"default","reg_key":"calendar_day_week_set","reg_name":"Giorno Settimana","reg_name_app":"Giorno sett.","reg_key_group":"calendar_day_week","reg_type":"SET","offset":33016,"eeprom":true,"is_word":false,"big_endian":false,"formula":"#","formula_inverse":"#","format_string":"{0}","set_min":1,"set_max":7,"readonly":false,"mask":255,"is_hex":false,"is_temperature":false,"use_app":true,"display_dashboard":false,"display_manage":false,"display_info":false,"use_cat":true,"display_order":0,"step":1,"use_history":true,"use_history_output":true,"with_sign":false,"from_char_code":false,"notify_on_change":false,"is_test":false,"enc_val":[{"value":1,"lang":"ITA","description":"Lun"},{"value":2,"lang":"ITA","description":"Mar"},{"value":3,"lang":"ITA","description":"Mer"},{"value":4,"lang":"ITA","description":"Gio"},{"value":5,"lang":"ITA","description":"Ven"},{"value":6,"lang":"ITA","description":"Sab"},{"value":7,"lang":"ITA","description":"Dom"}]}
    micronova.0
    2022-11-29 22:08:57.000	warn	get state error: Connection is closed.
    micronova.0
    2022-11-29 22:08:56.494	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    micronova.0
    2022-11-29 22:08:56.491	info	terminating
    micronova.0
    2022-11-29 22:08:56.488	info	Got terminate signal TERMINATE_YOURSELF
    micronova.0
    2022-11-29 22:08:55.199	info	Found 1 devices
    micronova.0
    2022-11-29 22:08:55.102	info	Login successful
    micronova.0
    2022-11-29 22:08:54.396	info	Login to Easy Connect Plus
    micronova.0
    2022-11-29 22:08:54.152	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#96339ac28b8c858c327cc2a8e4773d7b48831b0a) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
    Und nun folgendes beim Start der Instanz (nach Update):
    micronova.0
    2022-11-29 22:17:05.945	error	{"Success":false,"Error":"1106","Text":"UNAUTHORIZED"}
    micronova.0
    2022-11-29 22:17:05.944	error	AxiosError: Request failed with status code 401
    micronova.0
    2022-11-29 22:14:23.353	info	Login successful
    micronova.0
    2022-11-29 22:13:52.819	info	receive 401 error. Refresh Token in 30 seconds
    micronova.0
    2022-11-29 22:10:39.372	info	Found 1 devices
    micronova.0
    2022-11-29 22:10:39.271	info	Login successful
    micronova.0
    2022-11-29 22:10:38.553	info	Login to Easy Connect Plus
    micronova.0
    2022-11-29 22:10:38.358	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#96339ac28b8c858c327cc2a8e4773d7b48831b0a) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
    T
    T
    tombox
    @kusi sollte jetzt kein Problem sein denn Daten müssten trotzdem kommen aber irgendwas loggt sich parallel ein
    • T tombox
      K
      K
      Kusi
      @tombox sagte in Test Adapter micronova easy connect plus:
      Wenn dem so ist, sage ich dem Bruder er soll das Passwort ändern und die App auf allen Geräten deinstallieren...
      • K Kusi
        K
        K
        Kusi
        @tombox
        Wiederholend den ganzen Tag folgende Meldungen:
        micronova.0
        2022-11-30 20:10:04.775	info	receive 401 error. Refresh Token in 30 seconds
        micronova.0
        2022-11-30 20:09:17.845	error	{"Success":false,"Error":"1106","Text":"UNAUTHORIZED"}
        micronova.0
        2022-11-30 20:09:17.845	error	AxiosError: Request failed with status code 401
        micronova.0
        2022-11-30 20:06:35.303	info	Login successful
        • K Kusi
          @tombox
          micronova.0
          micronova.0
          micronova.0
          micronova.0
          T
          T
          tombox
          @kusi Ok und Passwort geändert und kein Zugriff via App.
          • T tombox
            K
            K
            Kusi
            schrieb am zuletzt editiert von Kusi
            @tombox korrekt.
            Passwort geändert und dieses NUR beim Adapter eingegeben.
            Habe die Instanz nochmals neu gestartet und kurz gewartet und nochmals probiert.
            Jetzt hat es geklappt.
            micronova.0
            2022-11-30 21:20:12.475	info	Update devices
            micronova.0
            2022-11-30 21:20:02.473	info	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"58d237f5-e966-4172-a034-80cec9298981"}
            micronova.0
            2022-11-30 21:20:02.378	info	Send data: {"id_product":"B99F243F-CD0B-4D25-BE52-19D193F685F1","id_device":"AF217968-77DC-420C-9D55-7521B6D67497","Protocol":"RWMSmaster","BitData":[8],"Endianess":["L"],"Items":[232],"Masks":[65535],"Values":[170]}
            micronova.0
            2022-11-30 21:17:20.721	info	Found 1 devices
            micronova.0
            2022-11-30 21:17:20.624	info	Login successful
            micronova.0
            2022-11-30 21:17:19.923	info	Login to Easy Connect Plus
            micronova.0
            2022-11-30 21:17:19.731	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#96339ac28b8c858c327cc2a8e4773d7b48831b0a) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
            Kurz darauf erschien wieder der Fehler "receive 401" und kommt seither alle 4 Minuten.
            micronova.0
            2022-11-30 21:22:05.063	info	Login successful
            micronova.0
            2022-11-30 21:21:34.150	info	receive 401 error. Refresh Token in 30 seconds
            • T tombox
              Hi ich habe ein neuen Adapter für Micronova geschrieben.
              Unterstütze Apps:
              EvaCalòr - PuntoFuoco
              Elfire Wifi
              Karmek Wifi
              Easy Connect
              Easy Connect Plus
              Easy Connect Poêle
              Lorflam Home
              LMX Remote Control
              Boreal Home
              Bronpi Home
              EOSS WIFI
              LAMINOXREM REMOTE CONTROL 2.0
              Jolly Mec Wi Fi
              Globe-fire
              TS Smart
              Stufe a pellet Italia
              My Corisit
              Fonte Flamme contrôle 1
              Klover Home
              Nordic Fire 2.0
              GO HEAT
              Wi-Phire
              Thermoflux
              Darwin Evolution
              Moretti design
              Fontana Forni
              MyPiazzetta (MySuperior?)
              Alfaplam
              Nina
              Zum Installieren:
              https://github.com/TA2k/ioBroker.micronova
              Steuern
              Es gibt micronova.0.id.remote.setMethod da muss der offset des register, value von enc_val eingegeben
              Zb zum starten 232,85
              offset von status_manged und für Value ON ist 85 OFF ist 170 also 232,170
              setzen der Temperatur auf 38Grad (temp_air = 32893 formular= /2 = 76/2 = 38
              32893, 76
              .status.Values19 Heizstufe
              32895,Wert für Heizstufe
              Zustand der Heizung
              Values02":
              0 = Ausgeschaltet
              1 = Zündung
              2 = Warten auf Flamme
              3 = Anlaufen
              4 = Heizen
              5 = Reinigung
              6 = Auskühlen/Abkühlen
              9 = keine Pellets vorhanden
              Unter Adapter Experten Modus aktivieren:
              Unter Adapter das Github Icon klicken:
              Benutzerdefiniert auswählen und die Url einfügen.
              Dann unter Adapter den Micronova Adapter suchen und ganz rechts auf das Plus klicken.
              Loginablauf:
              Die App Zugangsdaten eingeben und die jeweilige App auswählen
              P
              P
              picky
              @tombox Seitdem ich die Easy Connect Plus App nicht mehr anfasse, läuft es ohne Probleme seit fast 2 Tagen bei mir, Danke für Deine Mühe.
              Wie macht Ihr das mit der Statusanzeige?
              Gibt es eine Möglichkeit die Bedeutung des Codes des Status mit Anzeigen zu lassen in VIS. zB. Values02 = 0 (was glaube ich ausgeschaltet heißt), oder merkt Ihr Euch den Code und was es Bedeutet ;-)
              K 2 Antworten Letzte Antwort
              • P picky
                K
                K
                Kusi
                @picky
                Anbei die States vom Datenpunkt
                "micronova.0.*.status.Values02":
                0 = Ausgeschaltet
                1 = Zündung
                3 = Anlaufen
                4 = Heizen
                5 = Reinigung
                9 = keine Pellets vorhanden ??? (oder genereller Fehler?)
                Ich schreibe die States in den selben erstellten Datenpunkt
                "0_userdata.0.Eigene_Datenpunkte.Pelletofen.Zustand"
                • P picky
                  K
                  K
                  Kusi
                  @picky
                  Hast du folgenden Log-Eintrag auch?
                  micronova.0
                  2022-12-01 18:53:19.628	info	receive 401 error. Refresh Token in 30 seconds
                  T P 2 Antworten Letzte Antwort
                  • K Kusi
                    @picky
                    micronova.0
                    T
                    T
                    tombox
                    @kusi Installier nochmal ich nutze jetzt die id von Android was anscheinend stabiler ist
                    • T tombox
                      K
                      K
                      Kusi
                      Installier nochmal
                      Ich komme nicht in die Konfiguration der Instanz!
                      • K Kusi
                        Installier nochmal
                        T
                        T
                        tombox
                        @kusi nochmal
                        • T tombox
                          @kusi nochmal
                          K
                          K
                          Kusi
                          @tombox
                          Instanz gestartet.
                          Sehe ich eigentlich richtig dass der Datenpunkt
                          "micronova.0.*.remote.Refresh" auf TRUE gesetzt werden muss? Ansonsten aktualisiert sich der Status nicht?
                          • K Kusi
                            @tombox
                            Instanz gestartet.
                            T
                            T
                            tombox
                            @kusi nein aktualisiert sich automatisch. kannst du auch im log level debug sehen
                            • T tombox
                              K
                              K
                              Kusi
                              @tombox
                              Die Instanz läuft nun seit 55 Minuten, und es ist kein Fehler aufgetaucht!! 👍
                              • T tombox
                                K
                                K
                                Kusi
                                Das Problem lag also bei iOS?
                                • K Kusi
                                  T
                                  T
                                  tombox
                                  @kusi Ja wenn man sich als iOS app ausgibt kommt es zu den login Problemen
                                  • T tombox
                                    K
                                    K
                                    Kusi
                                    @tombox Achso, ich verstehe es langsam.
                                    Mich würde sehr interessieren, wie man einen solchen Adapter erstellt...
                                    • K Kusi
                                      @picky
                                      micronova.0
                                      P
                                      P
                                      picky
                                      schrieb am zuletzt editiert von picky
                                      #66
                                      @kusi said in Test Adapter micronova easy connect plus:
                                      @picky
                                      micronova.0
                                      Die Fehlermeldungen hatte ich nur als ich parallel die App benutzt habe.
                                      Das Log zeigt mir im Augenblick nur an im Debug Modus.
                                      micronova.0
                                      3085	2022-12-02 08:40:17.908	debug	{"Success":true,"Text":"DEVICE_JOB_STATUS_OK","jobRequestStatus":"completed","jobAnswerStatus":"completed","jobAnswerPayload":{"id":1669966804755,"jid":"C8C9A3C50204","pl":{"BufferId":1,"cmd":"GetBufferReading"},"type":"node"},"jobAnswerData":{"BufferId":1,"Items":[32894,33,33017,32893,6,52,33016,1,33020,32798,33021,32823,232,32795,33018,33019,2,32845,32895,51],"Values":[0,9,16,44,0,8,5,37,18,1,34,20,8,20,37,2,0,1,3,16],"cmd":"GetBufferReading"}}
                                      micronova.0
                                      3085	2022-12-02 08:40:17.774	debug	Waiting for response
                                      micronova.0
                                      3085	2022-12-02 08:40:04.772	debug	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"4576f259-607a-4a2d-9e31-e95b560fc32d"}
                                      micronova.0
                                      3085	2022-12-02 08:36:17.948	debug	{"Success":true,"Text":"DEVICE_JOB_STATUS_OK","jobRequestStatus":"completed","jobAnswerStatus":"completed","jobAnswerPayload":{"id":1669966564797,"jid":"C8C9A3C50204","pl":{"BufferId":1,"cmd":"GetBufferReading"},"type":"node"},"jobAnswerData":{"BufferId":1,"Items":[32894,33,33017,32893,6,52,33016,1,33020,32798,33021,32823,232,32795,33018,33019,2,32845,32895,51],"Values":[51,9,16,44,0,8,5,37,18,1,34,20,8,20,33,2,0,1,3,16],"cmd":"GetBufferReading"}}
                                      micronova.0
                                      3085	2022-12-02 08:36:17.816	debug	Waiting for response
                                      micronova.0
                                      3085	2022-12-02 08:36:04.814	debug	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"ec0e9b50-4523-490b-8f31-f6e8f1625451"}
                                      • T tombox
                                        K
                                        K
                                        Kusi
                                        #67
                                        @tombox
                                        Über Nacht kein einziger Logeintrag.
                                        Um 06.55 Uhr wurde der Pelletofen von einem Skript gestartet (gut so).
                                        Seit 10.50 Uhr erscheinen wiederkehrende Log-Einträge, fortlaufend bis jetzt...
                                        micronova.0
                                        2022-12-02 10:52:07.377	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
                                        micronova.0
                                        2022-12-02 10:50:37.956	info	Login successful
                                        micronova.0
                                        2022-12-02 10:50:07.404	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
                                        micronova.0
                                        2022-12-02 10:32:07.741	info	Login successful
                                        micronova.0
                                        2022-12-02 06:56:02.191	info	Update devices
                                        Habe nun die Instanz neu gestartet, der Fehler bleibt allerdings.
                                        micronova.0
                                        2022-12-02 11:15:31.101	info	Login successful
                                        micronova.0
                                        2022-12-02 11:15:00.533	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
                                        micronova.0
                                        2022-12-02 11:11:31.077	info	Login successful
                                        micronova.0
                                        2022-12-02 11:11:00.515	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
                                        micronova.0
                                        2022-12-02 11:08:47.111	info	Found 1 devices
                                        micronova.0
                                        2022-12-02 11:08:47.016	info	Login successful
                                        micronova.0
                                        2022-12-02 11:08:46.339	info	Login to Easy Connect Plus
                                        micronova.0
                                        2022-12-02 11:08:46.273	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#173e3f3601ff0ca61c776329702007e75e45703e) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
                                        Das Skript (Blockly) hat soeben den Pelletofen ausgeschaltet, was einwandfrei funktioniert. Auch die Rückmeldung (Values02) funktioniert einwandfrei, trotz Log-Meldungen.
                                        micronova.0
                                        2022-12-02 12:59:31.108	info	Login successful
                                        micronova.0
                                        2022-12-02 12:59:00.537	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
                                        micronova.0
                                        2022-12-02 12:57:32.425	info	Update devices
                                        micronova.0
                                        2022-12-02 12:57:22.424	info	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"fb17950d-d7a8-4d3a-a9b7-1a9dfac03694"}
                                        micronova.0
                                        2022-12-02 12:57:22.338	info	Send data: {"id_product":"B99F243F-CD0B-4D25-BE52-19D193F685F1","id_device":"AF217968-77DC-420C-9D55-7521B6D67497","Protocol":"RWMSmaster","BitData":[8],"Endianess":["L"],"Items":[232],"Masks":[65535],"Values":[170]}
                                        micronova.0
                                        2022-12-02 12:55:31.096	info	Login successful
                                        micronova.0
                                        2022-12-02 12:55:00.533	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
                                        micronova.0
                                        2022-12-02 12:51:31.150	info	Login successful
                                        P K 2 Antworten Letzte Antwort
                                        • K Kusi
                                          @tombox
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          micronova.0
                                          P
                                          P
                                          picky
                                          #68
                                          @kusi Mit der neuen Version, logt er sich immer aus, aber scheinbar keine Fehler.
                                          micronova.0
                                          3348	2022-12-02 11:54:08.987	info	Login successful
                                          micronova.0
                                          3348	2022-12-02 11:53:38.393	info	Adapter is logged out. Relogin in 30seconds.
                                          micronova.0
                                          3348	2022-12-02 11:50:31.241	info	Update devices
                                          micronova.0
                                          3348	2022-12-02 11:50:21.237	info	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"30cf0532-9138-495c-9c95-ef6d1dd47d54"}
                                          micronova.0
                                          3348	2022-12-02 11:50:21.087	info	Send data: {"id_product":"C13DA328-6288-4931-A6B0-878F53417223","id_device":"D35FD861-42D2-4C5B-92AA-EDB0E3A2D53B","Protocol":"RWMSmaster","BitData":[8],"Endianess":["L"],"Items":[232],"Masks":[65535],"Values":[170]}
                                          micronova.0
                                          3348	2022-12-02 11:50:09.138	info	Login successful
                                          micronova.0
                                          3348	2022-12-02 11:49:38.394	info	Adapter is logged out. Relogin in 30seconds.
                                          micronova.0
                                          3348	2022-12-02 11:46:09.034	info	Login successful
                                          micronova.0
                                          3348	2022-12-02 11:45:38.432	info	Adapter is logged out. Relogin in 30seconds.
                                          micronova.0
                                          3348	2022-12-02 11:42:09.077	info	Login successful
                                          micronova.0
                                          3348	2022-12-02 11:41:38.407	info	Adapter is logged out. Relogin in 30seconds.
                                          micronova.0
                                          3348	2022-12-02 11:37:24.710	info	Found 1 devices
                                          micronova.0
                                          3348	2022-12-02 11:37:24.558	info	Login successful
                                          micronova.0
                                          3348	2022-12-02 11:37:23.835	info	Login to Easy Connect Plus
                                          micronova.0
                                          3348	2022-12-02 11:37:23.790	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#7f72c1f4bba2109671773d2caae11a7b9a3e12b4) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
                                          Was mir aber aufgefallen ist, wenn ich die Relogzeit von 4 auf 2 Minuten runter setze, bekomme ich auch Errors, also der Relog darf nicht zu schnell sein.
                                          micronova.0
                                          1081	2022-12-02 11:35:32.315	error	{"Success":false,"Error":"1106","Text":"UNAUTHORIZED"}
                                          micronova.0
                                          1081	2022-12-02 11:35:32.313	error	AxiosError: Request failed with status code 401
                                          micronova.0
                                          1081	2022-12-02 11:33:49.814	info	Login successful
                                          micronova.0
                                          1081	2022-12-02 11:33:19.220	info	Adapter is logged out. Relogin in 30seconds.
                                          micronova.0
                                          1081	2022-12-02 11:31:32.298	error	{"Success":false,"Error":"1106","Text":"UNAUTHORIZED"}
                                          micronova.0
                                          1081	2022-12-02 11:31:32.297	error	AxiosError: Request failed with status code 401
                                          micronova.0
                                          1081	2022-12-02 11:29:49.770	info	Login successful
                                          83.9k
