  4. Bullseye Neuinstallation von IoBroker nach ....
    5.6k
39 Beiträge 4 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • S Snupy
    hmm ... um den Admin habe ich mich ehrlich gesagt nicht gekümmert, ging davon aus das wird wieder mit hergestellt ...
    das Ergebniss des Skripts
    Skript v.0.0.7
    *** BASE SYSTEM ***
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     17:56:18 up  6:06,  3 users,  load average: 1.19, 1.48, 1.90
    CPU threads: 4
    *** Time and Time Zones ***
    Wed Nov 30 16:56:18 UTC 2022
    Wed Nov 30 17:56:18 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    root
    /root
    root lpadmin
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            3.8G        365M        1.6G         34M        1.9G        3.3G
    Swap:            99M         99M        0.0K
    Total:          3.9G        464M        1.6G
             3838 M total memory
              365 M used memory
              279 M active memory
             1771 M inactive memory
             1554 M free memory
               46 M buffer memory
             1872 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       59G   57G     0 100% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
    tmpfs          tmpfs     768M  1.2M  767M   1% /run
    /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
    tmpfs          tmpfs     384M   20K  384M   1% /run/user/1000
    /dev/sda2      ext4       29G  7.5G   21G  28% /media/pi/rootfs
    /dev/sda1      vfat      253M   49M  204M  20% /media/pi/boot
    TARGET             SOURCE         FSTYPE OPTIONS
    /                  /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot            /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/media/pi/rootfs /dev/sda2      ext4   rw,nosuid,nodev,relatime,errors=remount-ro
    `-/media/pi/boot   /dev/sda1      vfat   rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,fl
    /var:
    53G     /var/
    52G     /var/log
    473M    /var/log/journal/2a3c09b134cf4ebdbf6f8d8059f6b422
    359M    /var/cache
    /opt/iobroker/backups:
    13M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    187M    /opt/iobroker/iobroker-data/
    144M    /opt/iobroker/iobroker-data/files
    32M     /opt/iobroker/iobroker-data/files/javascript.admin
    23M     /opt/iobroker/iobroker-data/files/echarts.admin
    17M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    28M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b7bbd921.chunk.js.map
    9.8M    /opt/iobroker/iobroker-data/states.jsonl
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.18.1
    /usr/bin/node           v16.18.1
    /usr/bin/npm            8.19.2
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    Calling 'npm doctor' for you. Please be patient!
    npm ERR! code ENOSPC
    npm ERR! syscall write
    npm ERR! errno -28
    npm ERR! nospc ENOSPC: no space left on device, write
    npm ERR! nospc There appears to be insufficient space on your system to finish.
    npm ERR! nospc Clear up some disk space and try again.
    npm ERR!     /home/iobroker/.npm/_logs/2022-11-30T16_56_23_331Z-debug-0.log
    The recommended versions for ioBroker are nodeJS v16 / npm v8!
    Don't trust the doctor if he recommends different versions!
    *** ioBroker-Installation ***
    ioBroker Status
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    Adapters from github:   3
    ioBroker-Repositories
    ioBroker-Instances
    Objects and States
    Objects:        1
    States:         1
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.org/raspbian bullseye InRelease: Splitting up /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_bullseye_InRelease into data and signature failed
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:84:1e0::1 80]
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Err:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Err:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Err:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          14553      620/motion
    tcp        0      0 0.0.0.0:4531            0.0.0.0:*               LISTEN      0          14548      620/motion
    tcp        0      0 0.0.0.0:4530            0.0.0.0:*               LISTEN      0          14547      620/motion
    tcp        0      0 0.0.0.0:4535            0.0.0.0:*               LISTEN      0          14552      620/motion
    tcp        0      0 0.0.0.0:4534            0.0.0.0:*               LISTEN      0          14551      620/motion
    tcp        0      0 0.0.0.0:4533            0.0.0.0:*               LISTEN      0          14550      620/motion
    tcp        0      0 0.0.0.0:4532            0.0.0.0:*               LISTEN      0          14549      620/motion
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          17483      429/python2
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16359      1467/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14027      555/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16358      1467/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14029      555/sshd: /usr/sbin
    udp        0      0 0.0.0.0:39610           0.0.0.0:*                           108        11152      380/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11150      380/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15646      548/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16379      1469/cups-browsed
    udp6       0      0 :::48258                :::*                                108        11153      380/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11151      380/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15723      548/dhcpcd
    @snupy sagte in Bullseye Neuinstallation von IoBroker nach ....:
    /var:
    53G     /var/
    52G     /var/log
    da schreit aber was um Hilfe
      /var:
      53G     /var/
      52G     /var/log
      Snupy
      könntet ihr ewas mehr für Dumme reden ;)
      mir sagt das garnichts
      E 1 Antwort Letzte Antwort
      • S Snupy
        Der hat die FAT ... dann gerade so groß gemacht das Bullseye drauf gepasst hat ... :(
        gut muß ich sehen wie ich die Partition größer bekomme
        da gibt es nix zu vergrößern. Die ist bereits maximal!
        allerdings rappelvoll mit irgendwelchen Systemlogs
        • S Snupy
          Einstein67
          schrieb am zuletzt editiert von Einstein67
          @snupy Also grundsätzlich wird die SD mit einer minimal notwendigen Partitionsgröße beschrieben. Die wird entweder manuell oder automatisch bei ersten Systemstart auf die maximale Größe (der SD-Karte) erweitert.
          Dass das nicht passiert ist war mein falscher Verdacht.
          Bei dir ist das /var/log Verzeichnis voll(gemüllt)
            Snupy
            wie löse ich das problem ?
            • S Snupy
              Einstein67
              @snupy Was kommt bei:
              ls -lah /var/log
              als Ergebnis?
              • E Einstein67
                ls -lah /var/log
                als Ergebnis?
                Snupy
                @einstein67
                probier ich dann gleich
                habe jetzt erstmal gelöscht ... 25Gb System.log 25GB kernel.log
                warum und wer ... legt diese logs an ? bzw. wie verhindere ich das ?
                E HomoranH 2 Antworten Letzte Antwort
                • S Snupy
                  @einstein67
                  Einstein67
                  @snupy said in Bullseye Neuinstallation von IoBroker nach ....:
                  Vor dem löschen hättest du ja mal reinsehen können/sollen was da drinnen steht ....
                  • S Snupy
                    @einstein67
                    😨 warum??? 😨
                    was stand denn drin??
                    @homoran sagte in Bullseye Neuinstallation von IoBroker nach ....:
                    Systemlogs
                    indem man die darin genannten Ursachen ausschaltet
                      😨 warum??? 😨
                      Systemlogs
                      Snupy
                      da war ich wohl zu schnell 😠
                      dann werde ich jetzt mal ein Backup des Images auf die SD machen und mich dann morgen wieder melden ;) sorry für meine dummheit
                      • S Snupy
                        warum??
                        dann dürfte sowieso wieder was im log stehen.
                        einfach nur machen was wir sagen!
                        hier jetzt insbes. Teil 2!
                        • S Snupy
                          Am besten mit einem von Grund auf gescheit aufgesetzen System.
                          root login musst du dir freigebuddelt haben, das ist in einer Standardinstallation gar nicht vorgesehen. Dann nimmt man für einen Server immer die 'Lite'-Version ohne graphische Oberfläche.
                          Und systemlogs löscht man auch nicht so rabiat, man schreibt da allenfalls aus /dev/null was rein. Aber auch erst, nachdem man mal reingeschaut hat was da überhaupt Phase ist.
                            Snupy
                            Auslöser des Problems ist der mihome-vaccum adapter für meinen Roborock 7.
                            Sobald der Adapter getartet wird und der Saugroboter losfährt beginnen sich die Logdateien unter
                            /var/log/syslog und /var/log/kern.log zu füllen und das extrem schnell.
                            Der Adapter ist dabei nicht immer grün (weiß nicht ob das was damit zu tun hat).
                            Ich habe auch noch nicht probiert ob das auch passiert, wenn er er keinen zugriff mehr auf
                            /mihome-vacuum.admin/actualMap_0.png hat.
                            Wenn man den mihome-vacuum Adapter wieder stoppt ändert das nichts an der rasanten vergößerung der beiden log Dateien.
                            Die Auslastung des System ist während dessen so hoch das auch ein "iobroker stop" ewig braucht um ausgeführt zu werden.
                            Auch ein erneutes einloggen mittels Putty auf dem Rasperry ist aufgrund der hohen Auslastung nicht oder nur schwer möglich.
                            Erst ein Neustart des Raspberry bringt wieder ruhe ins System (solange der mihome Adapter aus ist)
                            dann habe ich hier noch eine warn Meldung im protokoll das ioBrokers ....
                            Die beiden Log Dateien würde ich gern noch "hochladen/einbinden" allerdings sind die jetzt schon wieder bei jeweils 3,5Gb ...
                            • S Snupy
                              Snupy
                              so ... Moin
                              ich habe dann letztens Buster in der Light Version neu aufgesetzt ... Backup eingespielt und siehe da, es ging ... bis heute ... wäre ja auch zu einfach gewesen.
                              Ich schicke den Sauger los und in Windeseile füllen sich /var/log/syslog und /var/log/kern.log
                              So schnell kann man gar nicht gucken hatten die beide 80Mb
                              die syslog
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970709] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970747] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970785] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970823] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970860] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970898] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970936] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.970974] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971012] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971050] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971087] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971125] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971163] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971201] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971238] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971276] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971314] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971351] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971389] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971427] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971465] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971503] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971541] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971579] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971617] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:08 raspberrypi kernel: [ 9215.971654] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              die kern.log
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.669981] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670069] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670115] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670158] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670199] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670242] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670284] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670325] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670365] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670407] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670449] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670490] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670531] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670572] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670612] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670652] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670694] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670735] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670775] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670815] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670855] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670895] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670935] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.670976] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671017] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671057] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671096] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671136] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671176] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671217] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671258] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671299] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              Dec  4 22:54:00 raspberrypi kernel: [ 9208.671340] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                              • S Snupy
                                so ... Moin
                                die syslog
                                die kern.log
                                Warum eine abgekündigte Version? Buster hat im September sein End of Life erreicht.
                                  Snupy
                                  @thomas-braun spielt das zur Fehlerbehebung eine Rolle und wäre nicht eher nützlich wenn man weiß das es sowohl mit buster und bullseye gleichermaßen passiert ?
                                  die bullseye version habe ich ja ebenfalls noch auf SD ;)
                                  • S Snupy
                                    Womöglich.
                                    Ist für abgekündigte Releases komplett uninteressant.
                                    • S Snupy
                                      @snupy
                                      Schau was in
                                      dmesg -T
                                      so drin steht.
                                        @snupy
                                        Schau was in
                                        dmesg -T
                                        so drin steht.
                                        Snupy
                                        @thomas-braun said in Bullseye Neuinstallation von IoBroker nach ....:
                                        dmesg -T
                                        während er unterwegs ist ? danach ? egal wann ?
                                        [Sun Dec  4 22:55:00 2022] Booting Linux on physical CPU 0x0
                                        [Sun Dec  4 22:55:00 2022] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux                                       -gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for                                        Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
                                        [Sun Dec  4 22:55:00 2022] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), c                                       r=30c5383d
                                        [Sun Dec  4 22:55:00 2022] CPU: div instructions available: patching division co                                       de
                                        [Sun Dec  4 22:55:00 2022] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruc                                       tion cache
                                        [Sun Dec  4 22:55:00 2022] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.                                       4
                                        [Sun Dec  4 22:55:00 2022] random: fast init done
                                        [Sun Dec  4 22:55:00 2022] Memory policy: Data cache writealloc
                                        [Sun Dec  4 22:55:00 2022] Reserved memory: created CMA memory pool at 0x0000000                                       01ac00000, size 320 MiB
                                        [Sun Dec  4 22:55:00 2022] OF: reserved mem: initialized node linux,cma, compati                                       ble id shared-dma-pool
                                        [Sun Dec  4 22:55:00 2022] Zone ranges:
                                        [Sun Dec  4 22:55:00 2022]   DMA      [mem 0x0000000000000000-0x000000002fffffff                                       ]
                                        [Sun Dec  4 22:55:00 2022]   Normal   empty
                                        [Sun Dec  4 22:55:00 2022]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff                                       ]
                                        [Sun Dec  4 22:55:00 2022] Movable zone start for each node
                                        [Sun Dec  4 22:55:00 2022] Early memory node ranges
                                        [Sun Dec  4 22:55:00 2022]   node   0: [mem 0x0000000000000000-0x000000003b3ffff                                       f]
                                        [Sun Dec  4 22:55:00 2022]   node   0: [mem 0x0000000040000000-0x00000000fbfffff                                       f]
                                        [Sun Dec  4 22:55:00 2022] Initmem setup node 0 [mem 0x0000000000000000-0x000000                                       00fbffffff]
                                        [Sun Dec  4 22:55:00 2022] On node 0 totalpages: 1012736
                                        [Sun Dec  4 22:55:00 2022]   DMA zone: 1728 pages used for memmap
                                        [Sun Dec  4 22:55:00 2022]   DMA zone: 0 pages reserved
                                        [Sun Dec  4 22:55:00 2022]   DMA zone: 196608 pages, LIFO batch:63
                                        [Sun Dec  4 22:55:00 2022]   HighMem zone: 816128 pages, LIFO batch:63
                                        [Sun Dec  4 22:55:00 2022] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81                                       920
                                        [Sun Dec  4 22:55:00 2022] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
                                        [Sun Dec  4 22:55:00 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                        [Sun Dec  4 22:55:00 2022] Built 1 zonelists, mobility grouping on.  Total pages                                       : 1011008
                                        [Sun Dec  4 22:55:00 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0                                        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4                                       :5F:01:1C:FA:B1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=t                                       tyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=dead                                       line fsck.repair=yes rootwait
                                        [Sun Dec  4 22:55:00 2022] Kernel parameter elevator= does not have any effect a                                       nymore.
        Please use sysfs to set IO scheduler for individual d                                       evices.
                                        [Sun Dec  4 22:55:00 2022] Dentry cache hash table entries: 131072 (order: 7, 52                                       4288 bytes, linear)
                                        [Sun Dec  4 22:55:00 2022] Inode-cache hash table entries: 65536 (order: 6, 2621                                       44 bytes, linear)
                                        [Sun Dec  4 22:55:00 2022] mem auto-init: stack:off, heap alloc:off, heap free:o                                       ff
                                        [Sun Dec  4 22:55:00 2022] software IO TLB: mapped [mem 0x0000000014890000-0x000                                       0000018890000] (64MB)
                                        [Sun Dec  4 22:55:00 2022] Memory: 3601140K/4050944K available (10240K kernel co                                       de, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 122124K reserved, 327680K                                        cma-reserved, 3264512K highmem)
                                        [Sun Dec  4 22:55:00 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, No                                       des=1
                                        [Sun Dec  4 22:55:00 2022] ftrace: allocating 34355 entries in 101 pages
                                        [Sun Dec  4 22:55:00 2022] ftrace: allocated 101 pages with 4 groups
                                        [Sun Dec  4 22:55:00 2022] rcu: Hierarchical RCU implementation.
                                        [Sun Dec  4 22:55:00 2022]      Rude variant of Tasks RCU enabled.
                                        [Sun Dec  4 22:55:00 2022]      Tracing variant of Tasks RCU enabled.
                                        [Sun Dec  4 22:55:00 2022] rcu: RCU calculated value of scheduler-enlistment del                                       ay is 10 jiffies.
                                        [Sun Dec  4 22:55:00 2022] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                                        [Sun Dec  4 22:55:00 2022] GIC: Using split EOI/Deactivate mode
                                        [Sun Dec  4 22:55:00 2022] random: get_random_bytes called from start_kernel+0x3                                       c8/0x59c with crng_init=1
                                        [Sun Dec  4 22:55:00 2022] sched_clock: 32 bits at 1000kHz, resolution 1000ns, w                                       raps every 2147483647500ns
                                        [Sun Dec  4 22:55:00 2022] clocksource: timer: mask: 0xffffffff max_cycles: 0xff                                       ffffff, max_idle_ns: 1911260446275 ns
                                        [Sun Dec  4 22:55:00 2022] bcm2835: system timer (irq = 25)
                                        [Sun Dec  4 22:55:00 2022] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                        [Sun Dec  4 22:55:00 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff                                        max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                        [Sun Dec  4 22:55:00 2022] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps                                        every 4398046511102ns
                                        [Sun Dec  4 22:55:00 2022] Switching to timer-based delay loop, resolution 18ns
                                        [Sun Dec  4 22:55:00 2022] Console: colour dummy device 80x30
                                        [Sun Dec  4 22:55:00 2022] printk: console [tty1] enabled
                                        [Sun Dec  4 22:55:00 2022] Calibrating delay loop (skipped), value calculated us                                       ing timer frequency.. 108.00 BogoMIPS (lpj=540000)
                                        [Sun Dec  4 22:55:00 2022] pid_max: default: 32768 minimum: 301
                                        [Sun Dec  4 22:55:00 2022] LSM: Security Framework initializing
                                        [Sun Dec  4 22:55:00 2022] Mount-cache hash table entries: 2048 (order: 1, 8192                                        bytes, linear)
                                        [Sun Dec  4 22:55:00 2022] Mountpoint-cache hash table entries: 2048 (order: 1,                                        8192 bytes, linear)
                                        [Sun Dec  4 22:55:00 2022] cgroup: Disabling memory control group subsystem
                                        [Sun Dec  4 22:55:00 2022] CPU: Testing write buffer coherency: ok
                                        [Sun Dec  4 22:55:00 2022] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                        [Sun Dec  4 22:55:00 2022] Setting up static identity map for 0x200000 - 0x20003                                       c
                                        [Sun Dec  4 22:55:00 2022] rcu: Hierarchical SRCU implementation.
                                        [Sun Dec  4 22:55:00 2022] smp: Bringing up secondary CPUs ...
                                        [Sun Dec  4 22:55:00 2022] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                        [Sun Dec  4 22:55:00 2022] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                                        [Sun Dec  4 22:55:00 2022] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                                        [Sun Dec  4 22:55:00 2022] smp: Brought up 1 node, 4 CPUs
                                        [Sun Dec  4 22:55:00 2022] SMP: Total of 4 processors activated (432.00 BogoMIPS                                       ).
                                        [Sun Dec  4 22:55:00 2022] CPU: All CPU(s) started in HYP mode.
                                        [Sun Dec  4 22:55:00 2022] CPU: Virtualization extensions available.
                                        [Sun Dec  4 22:55:00 2022] devtmpfs: initialized
                                        [Sun Dec  4 22:55:00 2022] VFP support v0.3: implementor 41 architecture 3 part                                        40 variant 8 rev 0
                                        [Sun Dec  4 22:55:00 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0x                                       ffffffff, max_idle_ns: 19112604462750000 ns
                                        [Sun Dec  4 22:55:00 2022] futex hash table entries: 1024 (order: 4, 65536 bytes                                       , linear)
                                        [Sun Dec  4 22:55:00 2022] pinctrl core: initialized pinctrl subsystem
                                        [Sun Dec  4 22:55:00 2022] NET: Registered protocol family 16
                                        [Sun Dec  4 22:55:00 2022] DMA: preallocated 1024 KiB pool for atomic coherent a                                       llocations
                                        [Sun Dec  4 22:55:00 2022] audit: initializing netlink subsys (disabled)
                                        [Sun Dec  4 22:55:00 2022] audit: type=2000 audit(0.030:1): state=initialized au                                       dit_enabled=0 res=1
                                        [Sun Dec  4 22:55:00 2022] thermal_sys: Registered thermal governor 'step_wise'
                                        [Sun Dec  4 22:55:00 2022] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4                                        watchpoint registers.
                                        [Sun Dec  4 22:55:00 2022] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                        [Sun Dec  4 22:55:00 2022] Serial: AMBA PL011 UART driver
                                        [Sun Dec  4 22:55:00 2022] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                                        [Sun Dec  4 22:55:00 2022] raspberrypi-firmware soc:firmware: Attached to firmwa                                       re from 2021-12-01T15:01:54, variant start
                                        [Sun Dec  4 22:55:00 2022] raspberrypi-firmware soc:firmware: Firmware hash is 7                                       1bd3109023a0c8575585ba87cbb374d2eeb038f
                                        [Sun Dec  4 22:55:00 2022] Kprobes globally optimized
                                        [Sun Dec  4 22:55:00 2022] bcm2835-dma fe007000.dma: DMA legacy API manager, dma                                       chans=0x1
                                        [Sun Dec  4 22:55:00 2022] vgaarb: loaded
                                        [Sun Dec  4 22:55:00 2022] SCSI subsystem initialized
                                        [Sun Dec  4 22:55:00 2022] usbcore: registered new interface driver usbfs
                                        [Sun Dec  4 22:55:00 2022] usbcore: registered new interface driver hub
                                        [Sun Dec  4 22:55:00 2022] usbcore: registered new device driver usb
                                        [Sun Dec  4 22:55:00 2022] usb_phy_generic phy: supply vcc not found, using dumm                                       y regulator
                                        [Sun Dec  4 22:55:00 2022] clocksource: Switched to clocksource arch_sys_counter
                                        [Sun Dec  4 22:55:01 2022] VFS: Disk quotas dquot_6.6.0
                                        [Sun Dec  4 22:55:01 2022] VFS: Dquot-cache hash table entries: 1024 (order 0, 4                                       096 bytes)
                                        [Sun Dec  4 22:55:01 2022] FS-Cache: Loaded
                                        [Sun Dec  4 22:55:01 2022] CacheFiles: Loaded
                                        [Sun Dec  4 22:55:01 2022] NET: Registered protocol family 2
                                        [Sun Dec  4 22:55:01 2022] IP idents hash table entries: 16384 (order: 5, 131072                                        bytes, linear)
                                        [Sun Dec  4 22:55:01 2022] tcp_listen_portaddr_hash hash table entries: 512 (ord                                       er: 0, 6144 bytes, linear)
                                        [Sun Dec  4 22:55:01 2022] TCP established hash table entries: 8192 (order: 3, 3                                       2768 bytes, linear)
                                        [Sun Dec  4 22:55:01 2022] TCP bind hash table entries: 8192 (order: 4, 65536 by                                       tes, linear)
                                        [Sun Dec  4 22:55:01 2022] TCP: Hash tables configured (established 8192 bind 81                                       92)
                                        [Sun Dec  4 22:55:01 2022] UDP hash table entries: 512 (order: 2, 16384 bytes, l                                       inear)
                                        [Sun Dec  4 22:55:01 2022] UDP-Lite hash table entries: 512 (order: 2, 16384 byt                                       es, linear)
                                        [Sun Dec  4 22:55:01 2022] NET: Registered protocol family 1
                                        [Sun Dec  4 22:55:01 2022] RPC: Registered named UNIX socket transport module.
                                        [Sun Dec  4 22:55:01 2022] RPC: Registered udp transport module.
                                        [Sun Dec  4 22:55:01 2022] RPC: Registered tcp transport module.
                                        [Sun Dec  4 22:55:01 2022] RPC: Registered tcp NFSv4.1 backchannel transport mod                                       ule.
                                        [Sun Dec  4 22:55:01 2022] PCI: CLS 0 bytes, default 64
                                        [Sun Dec  4 22:55:01 2022] Initialise system trusted keyrings
                                        [Sun Dec  4 22:55:01 2022] workingset: timestamp_bits=14 max_order=20 bucket_ord                                       er=6
                                        [Sun Dec  4 22:55:01 2022] zbud: loaded
                                        [Sun Dec  4 22:55:01 2022] FS-Cache: Netfs 'nfs' registered for caching
                                        [Sun Dec  4 22:55:01 2022] NFS: Registering the id_resolver key type
                                        [Sun Dec  4 22:55:01 2022] Key type id_resolver registered
                                        [Sun Dec  4 22:55:01 2022] Key type id_legacy registered
                                        [Sun Dec  4 22:55:01 2022] nfs4filelayout_init: NFSv4 File Layout Driver Registe                                       ring...
                                        [Sun Dec  4 22:55:01 2022] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver                                        Registering...
                                        [Sun Dec  4 22:55:01 2022] Key type asymmetric registered
                                        [Sun Dec  4 22:55:01 2022] Asymmetric key parser 'x509' registered
                                        [Sun Dec  4 22:55:01 2022] bounce: pool size: 64 pages
                                        [Sun Dec  4 22:55:01 2022] Block layer SCSI generic (bsg) driver version 0.4 loa                                       ded (major 249)
                                        [Sun Dec  4 22:55:01 2022] io scheduler mq-deadline registered
                                        [Sun Dec  4 22:55:01 2022] io scheduler kyber registered
                                        [Sun Dec  4 22:55:01 2022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d5000                                       00 ranges:
                                        [Sun Dec  4 22:55:01 2022] brcm-pcie fd500000.pcie:   No bus range found for /sc                                       b/pcie@7d500000, using [bus 00-ff]
                                        [Sun Dec  4 22:55:01 2022] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063                                       fffffff -> 0x00c0000000
                                        [Sun Dec  4 22:55:01 2022] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00b                                       fffffff -> 0x0400000000
                                        [Sun Dec  4 22:55:01 2022] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (S                                       SC)
                                        [Sun Dec  4 22:55:01 2022] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:                                       00
                                        [Sun Dec  4 22:55:01 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
                                        [Sun Dec  4 22:55:01 2022] pci_bus 0000:00: root bus resource [mem 0x600000000-0                                       x63fffffff] (bus address [0xc0000000-0xffffffff])
                                        [Sun Dec  4 22:55:01 2022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                        [Sun Dec  4 22:55:01 2022] pci 0000:00:00.0: PME# supported from D0 D3hot
                                        [Sun Dec  4 22:55:01 2022] PCI: bus0: Fast back to back transfers disabled
                                        [Sun Dec  4 22:55:01 2022] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                        [Sun Dec  4 22:55:01 2022] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000ff                                       f 64bit]
                                        [Sun Dec  4 22:55:01 2022] pci 0000:01:00.0: PME# supported from D0 D3hot
                                        [Sun Dec  4 22:55:01 2022] PCI: bus1: Fast back to back transfers disabled
                                        [Sun Dec  4 22:55:01 2022] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x                                       6000fffff]
                                        [Sun Dec  4 22:55:01 2022] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x                                       600000fff 64bit]
                                        [Sun Dec  4 22:55:01 2022] pci 0000:00:00.0: PCI bridge to [bus 01]
                                        [Sun Dec  4 22:55:01 2022] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x                                       6000fffff]
                                        [Sun Dec  4 22:55:01 2022] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                                        [Sun Dec  4 22:55:01 2022] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                                        [Sun Dec  4 22:55:01 2022] iproc-rng200 fe104000.rng: hwrng registered
                                        [Sun Dec  4 22:55:01 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_                                       size:0x40000000(1024 MiB)
                                        [Sun Dec  4 22:55:01 2022] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Regist                                       ers at 0xfe200000
                                        [Sun Dec  4 22:55:01 2022] brd: module loaded
                                        [Sun Dec  4 22:55:01 2022] loop: module loaded
                                        [Sun Dec  4 22:55:01 2022] Loading iSCSI transport class v2.0-870.
                                        [Sun Dec  4 22:55:01 2022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                        [Sun Dec  4 22:55:01 2022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                        [Sun Dec  4 22:55:01 2022] usbcore: registered new interface driver r8152
                                        [Sun Dec  4 22:55:01 2022] usbcore: registered new interface driver lan78xx
                                        [Sun Dec  4 22:55:01 2022] usbcore: registered new interface driver smsc95xx
                                        [Sun Dec  4 22:55:01 2022] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                        [Sun Dec  4 22:55:01 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assign                                       ed bus number 1
                                        [Sun Dec  4 22:55:01 2022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci vers                                       ion 0x100 quirks 0x0000060000000890
                                        [Sun Dec  4 22:55:01 2022] usb usb1: New USB device found, idVendor=1d6b, idProd                                       uct=0002, bcdDevice= 5.10
                                        [Sun Dec  4 22:55:01 2022] usb usb1: New USB device strings: Mfr=3, Product=2, S                                       erialNumber=1
                                        [Sun Dec  4 22:55:01 2022] usb usb1: Product: xHCI Host Controller
                                        [Sun Dec  4 22:55:01 2022] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
                                        [Sun Dec  4 22:55:01 2022] usb usb1: SerialNumber: 0000:01:00.0
                                        [Sun Dec  4 22:55:01 2022] hub 1-0:1.0: USB hub found
                                        [Sun Dec  4 22:55:01 2022] hub 1-0:1.0: 1 port detected
                                        [Sun Dec  4 22:55:01 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assign                                       ed bus number 2
                                        [Sun Dec  4 22:55:01 2022] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpe                                       ed
                                        [Sun Dec  4 22:55:01 2022] usb usb2: New USB device found, idVendor=1d6b, idProd                                       uct=0003, bcdDevice= 5.10
                                        [Sun Dec  4 22:55:01 2022] usb usb2: New USB device strings: Mfr=3, Product=2, S                                       erialNumber=1
                                        [Sun Dec  4 22:55:01 2022] usb usb2: Product: xHCI Host Controller
                                        [Sun Dec  4 22:55:01 2022] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
                                        [Sun Dec  4 22:55:01 2022] usb usb2: SerialNumber: 0000:01:00.0
                                        [Sun Dec  4 22:55:01 2022] hub 2-0:1.0: USB hub found
                                        [Sun Dec  4 22:55:01 2022] hub 2-0:1.0: 4 ports detected
                                        [Sun Dec  4 22:55:01 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                        [Sun Dec  4 22:55:01 2022] dwc_otg: FIQ enabled
                                        [Sun Dec  4 22:55:01 2022] dwc_otg: NAK holdoff enabled
                                        [Sun Dec  4 22:55:01 2022] dwc_otg: FIQ split-transaction FSM enabled
                                        [Sun Dec  4 22:55:01 2022] Module dwc_common_port init
                                        [Sun Dec  4 22:55:01 2022] usbcore: registered new interface driver uas
                                        [Sun Dec  4 22:55:01 2022] usbcore: registered new interface driver usb-storage
                                        [Sun Dec  4 22:55:01 2022] mousedev: PS/2 mouse device common for all mice
                                        [Sun Dec  4 22:55:01 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog ti                                       mer
                                        [Sun Dec  4 22:55:01 2022] sdhci: Secure Digital Host Controller Interface drive                                       r
                                        [Sun Dec  4 22:55:01 2022] sdhci: Copyright(c) Pierre Ossman
                                        [Sun Dec  4 22:55:01 2022] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferr                                       ing probe
                                        [Sun Dec  4 22:55:01 2022] sdhci-pltfm: SDHCI platform and OF driver helper
                                        [Sun Dec  4 22:55:01 2022] ledtrig-cpu: registered to indicate activity on CPUs
                                        [Sun Dec  4 22:55:01 2022] hid: raw HID events driver (C) Jiri Kosina
                                        [Sun Dec  4 22:55:01 2022] usbcore: registered new interface driver usbhid
                                        [Sun Dec  4 22:55:01 2022] usbhid: USB HID core driver
                                        [Sun Dec  4 22:55:01 2022] Initializing XFRM netlink socket
                                        [Sun Dec  4 22:55:01 2022] NET: Registered protocol family 17
                                        [Sun Dec  4 22:55:01 2022] Key type dns_resolver registered
                                        [Sun Dec  4 22:55:01 2022] Registering SWP/SWPB emulation handler
                                        [Sun Dec  4 22:55:01 2022] registered taskstats version 1
                                        [Sun Dec  4 22:55:01 2022] Loading compiled-in X.509 certificates
                                        [Sun Dec  4 22:55:01 2022] Key type ._fscrypt registered
                                        [Sun Dec  4 22:55:01 2022] Key type .fscrypt registered
                                        [Sun Dec  4 22:55:01 2022] Key type fscrypt-provisioning registered
                                        [Sun Dec  4 22:55:01 2022] uart-pl011 fe201000.serial: there is not valid maps f                                       or state default
                                        [Sun Dec  4 22:55:01 2022] uart-pl011 fe201000.serial: cts_event_workaround enab                                       led
                                        [Sun Dec  4 22:55:01 2022] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36                                       , base_baud = 0) is a PL011 rev2
                                        [Sun Dec  4 22:55:01 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power d                                       omains driver
                                        [Sun Dec  4 22:55:01 2022] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                        [Sun Dec  4 22:55:01 2022] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                        [Sun Dec  4 22:55:01 2022] of_cfs_init
                                        [Sun Dec  4 22:55:01 2022] of_cfs_init: OK
                                        [Sun Dec  4 22:55:01 2022] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                        [Sun Dec  4 22:55:01 2022] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                        [Sun Dec  4 22:55:01 2022] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                        [Sun Dec  4 22:55:01 2022] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc]                                        using ADMA
                                        [Sun Dec  4 22:55:01 2022] Waiting for root device PARTUUID=738a4d67-02...
                                        [Sun Dec  4 22:55:01 2022] mmc1: new high speed SDIO card at address 0001
                                        [Sun Dec  4 22:55:01 2022] mmc0: new ultra high speed DDR50 SDXC card at address                                        0001
                                        [Sun Dec  4 22:55:01 2022] mmcblk0: mmc0:0001 EC2QT 59.6 GiB
                                        [Sun Dec  4 22:55:01 2022]  mmcblk0: p1 p2
                                        [Sun Dec  4 22:55:01 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on reado                                       nly filesystem
                                        [Sun Dec  4 22:55:01 2022] EXT4-fs (mmcblk0p2): write access will be enabled dur                                       ing recovery
                                        [Sun Dec  4 22:55:01 2022] usb 1-1: new high-speed USB device number 2 using xhc                                       i_hcd
                                        [Sun Dec  4 22:55:01 2022] usb 1-1: New USB device found, idVendor=2109, idProdu                                       ct=3431, bcdDevice= 4.21
                                        [Sun Dec  4 22:55:01 2022] usb 1-1: New USB device strings: Mfr=0, Product=1, Se                                       rialNumber=0
                                        [Sun Dec  4 22:55:01 2022] usb 1-1: Product: USB2.0 Hub
                                        [Sun Dec  4 22:55:01 2022] hub 1-1:1.0: USB hub found
                                        [Sun Dec  4 22:55:01 2022] hub 1-1:1.0: 4 ports detected
                                        [Sun Dec  4 22:55:02 2022] usb 1-1.2: new high-speed USB device number 3 using x                                       hci_hcd
                                        [Sun Dec  4 22:55:02 2022] usb 1-1.2: New USB device found, idVendor=0781, idPro                                       duct=5571, bcdDevice= 1.00
                                        [Sun Dec  4 22:55:02 2022] usb 1-1.2: New USB device strings: Mfr=1, Product=2,                                        SerialNumber=3
                                        [Sun Dec  4 22:55:02 2022] usb 1-1.2: Product: Cruzer Fit
                                        [Sun Dec  4 22:55:02 2022] usb 1-1.2: Manufacturer: SanDisk
                                        [Sun Dec  4 22:55:02 2022] usb 1-1.2: SerialNumber: 4C530102010813116330
                                        [Sun Dec  4 22:55:02 2022] usb-storage 1-1.2:1.0: USB Mass Storage device detect                                       ed
                                        [Sun Dec  4 22:55:02 2022] scsi host0: usb-storage 1-1.2:1.0
                                        [Sun Dec  4 22:55:03 2022] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Fit                                              1.00 PQ: 0 ANSI: 6
                                        [Sun Dec  4 22:55:03 2022] sd 0:0:0:0: [sda] 62521344 512-byte logical blocks: (                                       32.0 GB/29.8 GiB)
                                        [Sun Dec  4 22:55:03 2022] sd 0:0:0:0: [sda] Write Protect is off
                                        [Sun Dec  4 22:55:03 2022] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
                                        [Sun Dec  4 22:55:03 2022] sd 0:0:0:0: [sda] Write cache: disabled, read cache:                                        enabled, doesn't support DPO or FUA
                                        [Sun Dec  4 22:55:03 2022]  sda: sda1 sda2
                                        [Sun Dec  4 22:55:03 2022] sd 0:0:0:0: [sda] Attached SCSI removable disk
                                        [Sun Dec  4 22:55:05 2022] EXT4-fs (mmcblk0p2): recovery complete
                                        [Sun Dec  4 22:55:07 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered                                        data mode. Opts: (null)
                                        [Sun Dec  4 22:55:07 2022] VFS: Mounted root (ext4 filesystem) readonly on devic                                       e 179:2.
                                        [Sun Dec  4 22:55:07 2022] devtmpfs: mounted
                                        [Sun Dec  4 22:55:07 2022] Freeing unused kernel memory: 2048K
                                        [Sun Dec  4 22:55:07 2022] Run /sbin/init as init process
                                        [Sun Dec  4 22:55:07 2022]   with arguments:
                                        [Sun Dec  4 22:55:07 2022]     /sbin/init
                                        [Sun Dec  4 22:55:07 2022]   with environment:
                                        [Sun Dec  4 22:55:07 2022]     HOME=/
                                        [Sun Dec  4 22:55:07 2022]     TERM=linux
                                        [Sun Dec  4 22:55:07 2022] systemd[1]: System time before build time, advancing                                        clock.
                                        [Sun Dec  4 22:55:08 2022] NET: Registered protocol family 10
                                        [Sun Dec  4 22:55:08 2022] Segment Routing with IPv6
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: systemd 241 running in system mode. (+PAM                                        +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +G                                       NUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hi                                       erarchy=hybrid)
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Detected architecture arm.
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Set hostname to <raspberrypi>.
                                        [Sun Dec  4 22:55:08 2022] random: systemd: uninitialized urandom read (16 bytes                                        read)
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Created slice User and Session Slice.
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Listening on Journal Socket.
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Condition check resulted in Huge Pages Fi                                       le System being skipped.
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Mounting POSIX Message Queue File System.                                       ..
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Condition check resulted in Kernel Module                                        supporting RPCSEC_GSS being skipped.
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Mounting RPC Pipe File System...
                                        [Sun Dec  4 22:55:08 2022] systemd[1]: Listening on Journal Socket (/dev/log).
                                        [Sun Dec  4 22:55:09 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                        [Sun Dec  4 22:55:09 2022] systemd-journald[130]: Received request to flush runt                                       ime journal from PID 1
                                        [Sun Dec  4 22:55:10 2022] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem init                                       ialised: Registers at 0xfeb00000 length 0x00010000
                                        [Sun Dec  4 22:55:10 2022] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem                                        initialised: Registers at 0xfeb10000 length 0x00001000
                                        [Sun Dec  4 22:55:10 2022] rpivid-mem feb20000.h264-decoder: rpivid-h264mem init                                       ialised: Registers at 0xfeb20000 length 0x00010000
                                        [Sun Dec  4 22:55:10 2022] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initia                                       lised: Registers at 0xfeb30000 length 0x00010000
                                        [Sun Dec  4 22:55:10 2022] vc_sm_cma: module is from the staging directory, the                                        quality is unknown, you have been warned.
                                        [Sun Dec  4 22:55:10 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory driv                                       er
                                        [Sun Dec  4 22:55:10 2022] [vc_sm_connected_init]: start
                                        [Sun Dec  4 22:55:10 2022] [vc_sm_connected_init]: installed successfully
                                        [Sun Dec  4 22:55:10 2022] mc: Linux media interface: v0.10
                                        [Sun Dec  4 22:55:10 2022] videodev: Linux video capture interface: v2.00
                                        [Sun Dec  4 22:55:10 2022] snd_bcm2835: module is from the staging directory, th                                       e quality is unknown, you have been warned.
                                        [Sun Dec  4 22:55:10 2022] bcm2835_mmal_vchiq: module is from the staging direct                                       ory, the quality is unknown, you have been warned.
                                        [Sun Dec  4 22:55:10 2022] bcm2835_codec: module is from the staging directory,                                        the quality is unknown, you have been warned.
                                        [Sun Dec  4 22:55:10 2022] bcm2835_v4l2: module is from the staging directory, t                                       he quality is unknown, you have been warned.
                                        [Sun Dec  4 22:55:10 2022] bcm2835_audio bcm2835_audio: card created with 8 chan                                       nels
                                        [Sun Dec  4 22:55:10 2022] bcm2835_isp: module is from the staging directory, th                                       e quality is unknown, you have been warned.
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Device registered as /de                                       v/video10
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Device registered as /de                                       v/video11
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                        [Sun Dec  4 22:55:10 2022] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d                                        on minor 0
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Device registered as /de                                       v/video12
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Device registered as /de                                       v/video18
                                        [Sun Dec  4 22:55:10 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Device node output[0] regist                                       ered as /dev/video13
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Device node capture[0] regis                                       tered as /dev/video14
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Device node capture[1] regis                                       tered as /dev/video15
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registe                                       red as /dev/video16
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Register output node 0 with                                        media controller
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Register capture node 1 with                                        media controller
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Register capture node 2 with                                        media controller
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Register capture node 3 with                                        media controller
                                        [Sun Dec  4 22:55:10 2022] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                        [Sun Dec  4 22:55:10 2022] cfg80211: Loading compiled-in X.509 certificates for                                        regulatory database
                                        [Sun Dec  4 22:55:10 2022] [drm] No displays found. Consider forcing hotplug if                                        HDMI is attached
                                        [Sun Dec  4 22:55:10 2022] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms                                       _ops [vc4])
                                        [Sun Dec  4 22:55:10 2022] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor                                        1
                                        [Sun Dec  4 22:55:10 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9                                       cea7'
                                        [Sun Dec  4 22:55:10 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
                                        [Sun Dec  4 22:55:10 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac                                       43455-sdio for chip BCM4345/6
                                        [Sun Dec  4 22:55:10 2022] usbcore: registered new interface driver brcmfmac
                                        [Sun Dec  4 22:55:11 2022] sd 0:0:0:0: Attached scsi generic sg0 type 0
                                        [Sun Dec  4 22:55:11 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac                                       43455-sdio for chip BCM4345/6
                                        [Sun Dec  4 22:55:11 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6                                        wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                                        [Sun Dec  4 22:55:13 2022] random: crng init done
                                        [Sun Dec  4 22:55:13 2022] random: 7 urandom warning(s) missed due to ratelimiti                                       ng
                                        [Sun Dec  4 22:55:13 2022] uart-pl011 fe201000.serial: no DMA platform data
                                        [Sun Dec  4 22:55:13 2022] 8021q: 802.1Q VLAN Support v1.8
                                        [Sun Dec  4 22:55:13 2022] Adding 102396k swap on /var/swap.  Priority:-2 extent                                       s:1 across:102396k SSFS
                                        [Sun Dec  4 22:55:13 2022] bcmgenet fd580000.ethernet: configuring instance for                                        external RGMII (RX delay)
                                        [Sun Dec  4 22:55:13 2022] bcmgenet fd580000.ethernet eth0: Link is Down
                                        [Sun Dec  4 22:55:17 2022] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/F                                       ull - flow control rx/tx
                                        [Sun Dec  4 22:55:17 2022] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes rea                                       dy
                                        [Sun Dec  4 22:55:19 2022] ICMPv6: process `dhcpcd' is using deprecated sysctl (                                       syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time                                       _ms instead
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: Core ver 2.22
                                        [Sun Dec  4 22:55:20 2022] NET: Registered protocol family 31
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: HCI device and connection manager initiali                                       zed
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: HCI socket layer initialized
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: L2CAP socket layer initialized
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: SCO socket layer initialized
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: HCI UART driver ver 2.3
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: HCI UART protocol H4 registered
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: HCI UART protocol Three-wire (H5) register                                       ed
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: HCI UART protocol Broadcom registered
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: BNEP filters: protocol multicast
                                        [Sun Dec  4 22:55:20 2022] Bluetooth: BNEP socket layer initialized
                                        root@raspberrypi:/#
                                        • S Snupy
                                          dmesg -T
                                          root@raspberrypi:/#
                                          @snupy
                                          Mach das Fenster vom puTTY breiter.
