  4. Bullseye Neuinstallation von IoBroker nach ....
    5.6k
39 Beiträge 4 Kommentatoren 3.5k Aufrufe 3 Beobachtet
    @snupy
    Wie schaut das System aus?
    https://forum.iobroker.net/topic/59549/iob-diag-skript
    Mal bitte das Skript laufen lassen.
    Snupy
    hmm ... um den Admin habe ich mich ehrlich gesagt nicht gekümmert, ging davon aus das wird wieder mit hergestellt ...
    das Ergebniss des Skripts
    Skript v.0.0.7
    *** BASE SYSTEM ***
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     17:56:18 up  6:06,  3 users,  load average: 1.19, 1.48, 1.90
    CPU threads: 4
    *** Time and Time Zones ***
    Wed Nov 30 16:56:18 UTC 2022
    Wed Nov 30 17:56:18 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    root
    /root
    root lpadmin
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            3.8G        365M        1.6G         34M        1.9G        3.3G
    Swap:            99M         99M        0.0K
    Total:          3.9G        464M        1.6G
             3838 M total memory
              365 M used memory
              279 M active memory
             1771 M inactive memory
             1554 M free memory
               46 M buffer memory
             1872 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       59G   57G     0 100% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
    tmpfs          tmpfs     768M  1.2M  767M   1% /run
    /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
    tmpfs          tmpfs     384M   20K  384M   1% /run/user/1000
    /dev/sda2      ext4       29G  7.5G   21G  28% /media/pi/rootfs
    /dev/sda1      vfat      253M   49M  204M  20% /media/pi/boot
    TARGET             SOURCE         FSTYPE OPTIONS
    /                  /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot            /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/media/pi/rootfs /dev/sda2      ext4   rw,nosuid,nodev,relatime,errors=remount-ro
    `-/media/pi/boot   /dev/sda1      vfat   rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,fl
    /var:
    53G     /var/
    52G     /var/log
    473M    /var/log/journal/2a3c09b134cf4ebdbf6f8d8059f6b422
    359M    /var/cache
    /opt/iobroker/backups:
    13M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    187M    /opt/iobroker/iobroker-data/
    144M    /opt/iobroker/iobroker-data/files
    32M     /opt/iobroker/iobroker-data/files/javascript.admin
    23M     /opt/iobroker/iobroker-data/files/echarts.admin
    17M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    28M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b7bbd921.chunk.js.map
    9.8M    /opt/iobroker/iobroker-data/states.jsonl
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.18.1
    /usr/bin/node           v16.18.1
    /usr/bin/npm            8.19.2
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    Calling 'npm doctor' for you. Please be patient!
    npm ERR! code ENOSPC
    npm ERR! syscall write
    npm ERR! errno -28
    npm ERR! nospc ENOSPC: no space left on device, write
    npm ERR! nospc There appears to be insufficient space on your system to finish.
    npm ERR! nospc Clear up some disk space and try again.
    npm ERR!     /home/iobroker/.npm/_logs/2022-11-30T16_56_23_331Z-debug-0.log
    The recommended versions for ioBroker are nodeJS v16 / npm v8!
    Don't trust the doctor if he recommends different versions!
    *** ioBroker-Installation ***
    ioBroker Status
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    Adapters from github:   3
    ioBroker-Repositories
    ioBroker-Instances
    Objects and States
    Objects:        1
    States:         1
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.org/raspbian bullseye InRelease: Splitting up /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_bullseye_InRelease into data and signature failed
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
    W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:84:1e0::1 80]
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Err:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Err:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Err:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          14553      620/motion
    tcp        0      0 0.0.0.0:4531            0.0.0.0:*               LISTEN      0          14548      620/motion
    tcp        0      0 0.0.0.0:4530            0.0.0.0:*               LISTEN      0          14547      620/motion
    tcp        0      0 0.0.0.0:4535            0.0.0.0:*               LISTEN      0          14552      620/motion
    tcp        0      0 0.0.0.0:4534            0.0.0.0:*               LISTEN      0          14551      620/motion
    tcp        0      0 0.0.0.0:4533            0.0.0.0:*               LISTEN      0          14550      620/motion
    tcp        0      0 0.0.0.0:4532            0.0.0.0:*               LISTEN      0          14549      620/motion
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          17483      429/python2
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16359      1467/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14027      555/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16358      1467/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14029      555/sshd: /usr/sbin
    udp        0      0 0.0.0.0:39610           0.0.0.0:*                           108        11152      380/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11150      380/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15646      548/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16379      1469/cups-browsed
    udp6       0      0 :::48258                :::*                                108        11153      380/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11151      380/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15723      548/dhcpcd
    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
    • S Snupy
      Skript v.0.0.7
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      root
      /root
      root lpadmin
      X-Server:       true
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            99M         99M        0.0K
               3838 M total memory
                365 M used memory
                279 M active memory
               1554 M free memory
                 46 M buffer memory
               1872 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      53G     /var/
      52G     /var/log
      359M    /var/cache
      /usr/bin/npm            8.19.2
      nodejs:
        Version table:
      npm ERR! errno -28
      ioBroker Status
      admin:          6.2.23
      ioBroker-Instances
      Objects and States
      Objects:        1
      States:         1
      Pending Updates: 1
      @snupy
      Nicht als root herumhampeln, keinen Desktop laufen lassen.
      • S Snupy
        Skript v.0.0.7
        *** BASE SYSTEM ***
        Docker:         false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        CET +0100
        Europe/Berlin
        root
        /root
        root lpadmin
        X-Server:       true
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                 3838 M total memory
                  365 M used memory
                  279 M active memory
                 1554 M free memory
                   46 M buffer memory
                 1872 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        53G     /var/
        52G     /var/log
        359M    /var/cache
        /usr/bin/npm            8.19.2
        nodejs:
          Version table:
        npm ERR! errno -28
        ioBroker Status
        admin:          6.2.23
        ioBroker-Instances
        Objects and States
        Objects:        1
        States:         1
        Pending Updates: 1
        @snupy Karte voll!
        @snupy sagte in Bullseye Neuinstallation von IoBroker nach ....:
          @snupy
          Snupy
          nach neustart und npm abfrage kommt das ...
          root@raspberrypi:/opt/iobroker# npm -v
          npm ERR! errno -28
          npm ERR! /home/iobroker/.npm/_logs/2022-11-30T17_05_35_839Z-debug-0.log
          kannst du mir genauer sagen was du mit nicht als root rumhampeln und keine Desktop laufen lassen meinst ? sorry ich bin hier nicht so schlau ... lief ja alles seit Jahren :(
          • S Snupy
            npm ERR! errno -28
            siehste!
            no Space left on device
              @snupy Karte voll!
              Snupy
              @homoran said in Bullseye Neuinstallation von IoBroker nach ....:
              @snupy Karte voll!
              Karte voll ???? ist ne 64Gb ... Image erstellt mit Rasperry Imager
              E 1 Antwort Letzte Antwort
              • S Snupy
                @snupy Karte voll!
                Einstein67
                @snupy Hast du das Dateisystem auch expandiert?
                HomoranH S 2 Antworten Letzte Antwort
                • E Einstein67
                  @einstein67 hat er! sind 57GB belegt.
                  Womit auch immer
                  • E Einstein67
                    Snupy
                    @einstein67
                    Ich habe die mit Raspery Imager (oder wie das Ding heißt) erstellt ... und ab damit in den Raspberry (ich hatte mich aber schon gewundert als ich mir die im Partitionsmanger angesehen habe)
                    • S Snupy
                      @einstein67
                      Snupy
                      Der hat die FAT ... dann gerade so groß gemacht das Bullseye drauf gepasst hat ... :(
                      gut muß ich sehen wie ich die Partition größer bekomme
                      • S Snupy
                        Skript v.0.0.7
                        *** BASE SYSTEM ***
                        Docker:         false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        CET +0100
                        Europe/Berlin
                        root
                        /root
                        root lpadmin
                        X-Server:       true
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Swap:            99M         99M        0.0K
                                 3838 M total memory
                                  365 M used memory
                                  279 M active memory
                                 1554 M free memory
                                   46 M buffer memory
                                 1872 M swap cache
                                   99 M total swap
                                   99 M used swap
                                    0 M free swap
                        *** FILESYSTEM ***
                        /var:
                        53G     /var/
                        52G     /var/log
                        359M    /var/cache
                        /usr/bin/npm            8.19.2
                        nodejs:
                          Version table:
                        npm ERR! errno -28
                        ioBroker Status
                        admin:          6.2.23
                        ioBroker-Instances
                        Objects and States
                        Objects:        1
                        States:         1
                        Pending Updates: 1
                        /var:
                        53G     /var/
                        52G     /var/log
                        da schreit aber was um Hilfe
                          /var:
                          53G     /var/
                          52G     /var/log
                          Snupy
                          könntet ihr ewas mehr für Dumme reden ;)
                          mir sagt das garnichts
                          • S Snupy
                            da gibt es nix zu vergrößern. Die ist bereits maximal!
                            allerdings rappelvoll mit irgendwelchen Systemlogs
                            • S Snupy
                              Einstein67
                              schrieb am zuletzt editiert von Einstein67
                              @snupy Also grundsätzlich wird die SD mit einer minimal notwendigen Partitionsgröße beschrieben. Die wird entweder manuell oder automatisch bei ersten Systemstart auf die maximale Größe (der SD-Karte) erweitert.
                              Dass das nicht passiert ist war mein falscher Verdacht.
                              Bei dir ist das /var/log Verzeichnis voll(gemüllt)
                                Snupy
                                wie löse ich das problem ?
                                • S Snupy
                                  Einstein67
                                  @snupy Was kommt bei:
                                  ls -lah /var/log
                                  als Ergebnis?
                                  • E Einstein67
                                    ls -lah /var/log
                                    als Ergebnis?
                                    Snupy
                                    @einstein67
                                    probier ich dann gleich
                                    habe jetzt erstmal gelöscht ... 25Gb System.log 25GB kernel.log
                                    warum und wer ... legt diese logs an ? bzw. wie verhindere ich das ?
                                    E HomoranH 2 Antworten Letzte Antwort
                                    • S Snupy
                                      @einstein67
                                      Einstein67
                                      @snupy said in Bullseye Neuinstallation von IoBroker nach ....:
                                      Vor dem löschen hättest du ja mal reinsehen können/sollen was da drinnen steht ....
                                      • S Snupy
                                        @einstein67
                                        😨 warum??? 😨
                                        was stand denn drin??
                                        @homoran sagte in Bullseye Neuinstallation von IoBroker nach ....:
                                        Systemlogs
                                        indem man die darin genannten Ursachen ausschaltet
                                          😨 warum??? 😨
                                          Systemlogs
                                          Snupy
                                          da war ich wohl zu schnell 😠
                                          dann werde ich jetzt mal ein Backup des Images auf die SD machen und mich dann morgen wieder melden ;) sorry für meine dummheit
