  4. kein adapter lässt sich mehr update oder installieren
    5.6k
33 Beiträge 5 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • P. HegmarP P. Hegmar
    @thomas-braun ah ok danke, kenn mich mit linux nicht so wirklich aus.. was meinst mit angepinnte threads? hast auch ein link?
    @p-hegmar
    Im Kopf des Forums stehen drei Threads, besonders hervorgehoben.
    P. HegmarP 1 Antwort Letzte Antwort
      @p-hegmar
      P. HegmarP Offline
      P. HegmarP Offline
      P. Hegmar
      @thomas-braun aja danke ... ls -a ;)
      1 info using npm@8.19.2
      2 info using node@v16.18.1
      3 timing npm:load:whichnode Completed in 1ms
      4 timing config:load:defaults Completed in 5ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
      6 timing config:load:builtin Completed in 3ms
      7 timing config:load:cli Completed in 7ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
      10 timing config:load:project Completed in 7ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:validate Completed in 1ms
      16 timing config:load:credentials Completed in 3ms
      17 timing config:load:setEnvs Completed in 3ms
      18 timing config:load Completed in 35ms
      19 timing npm:load:configload Completed in 36ms
      20 timing npm:load:mkdirpcache Completed in 3ms
      21 timing npm:load:mkdirplogs Completed in 1ms
      22 verbose title npm install iobroker.backitup@2.5.6
      23 verbose argv "install" "--save-exact" "iobroker.backitup@2.5.6"
      24 timing npm:load:setTitle Completed in 5ms
      25 timing config:load:flatten Completed in 10ms
      26 timing npm:load:display Completed in 12ms
      27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
      28 verbose logfile /home/iobroker/.npm/_logs/2022-11-20T10_34_16_549Z-debug-0.log
      29 timing npm:load:logFile Completed in 18ms
      30 timing npm:load:timers Completed in 1ms
      31 timing npm:load:configScope Completed in 0ms
      32 timing npm:load Completed in 79ms
      33 timing arborist:ctor Completed in 2ms
      34 silly logfile start cleaning logs, removing 4 files
      35 silly logfile done cleaning log files
      36 timing idealTree:init Completed in 3621ms
      37 timing idealTree:userRequests Completed in 34ms
      38 silly idealTree buildDeps
      39 silly fetch manifest iobroker.backitup@2.5.6
      40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      41 http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 4889ms (cache revalidated)
      42 silly placeDep ROOT iobroker.backitup@2.5.6 REPLACE for: iobroker.inst@3.0.0 want: 2.5.6
      43 timing idealTree:#root Completed in 4979ms
      44 timing idealTree:node_modules/iobroker.backitup Completed in 1ms
      45 timing idealTree:buildDeps Completed in 4983ms
      46 timing idealTree:fixDepFlags Completed in 68ms
      47 timing idealTree Completed in 8761ms
      48 timing reify:loadTrees Completed in 8764ms
      49 timing reify:diffTrees Completed in 159ms
      50 silly reify mark retired [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
      51 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.backitup' ]
      52 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript' ]
      53 silly reify moves {
      53 silly reify   '/opt/iobroker/node_modules/osx-temperature-sensor': '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv',
      53 silly reify   '/opt/iobroker/node_modules/iobroker.backitup': '/opt/iobroker/node_modules/.iobroker.backitup-ZZHwpo6A',
      53 silly reify   '/opt/iobroker/node_modules/iobroker.javascript': '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      53 silly reify }
      54 timing reify:rollback:retireShallow Completed in 5ms
      55 timing command:install Completed in 9013ms
      56 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      57 verbose cwd /opt/iobroker
      58 verbose Linux 5.10.103-v7l+
      59 verbose node v16.18.1
      60 verbose npm  v8.19.2
      61 error code ENOTEMPTY
      62 error syscall rename
      63 error path /opt/iobroker/node_modules/iobroker.javascript
      64 error dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
      65 error errno -39
      66 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      67 verbose exit -39
      68 timing npm Completed in 9395ms
      69 verbose unfinished npm timer reify 1668940456925
      70 verbose unfinished npm timer reify:retireShallow 1668940465910
      71 verbose code -39
      72 error A complete log of this run can be found in:
      72 error     /home/iobroker/.npm/_logs/2022-11-20T10_34_16_549Z-debug-0.log
        53 silly reify }
        65 error errno -39
        67 verbose exit -39
        71 verbose code -39
        P. HegmarP Offline
        P. HegmarP Offline
        P. Hegmar
        @p-hegmar keiner eine Idee?
          @p-hegmar
          iobroker update
          iobroker upgrade all --debug
          sagt?
          Da sind offenbar noch Verzeichnisse die gelöscht werden sollten.
          Hast du den Thread gelesen und umgesetzt?
          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
            @p-hegmar
            iobroker update
            sagt?
            P. HegmarP Offline
            P. HegmarP Offline
            P. Hegmar
            schrieb am zuletzt editiert von P. Hegmar
            @thomas-braun ```
            0 verbose cli /usr/bin/node /usr/bin/npm
            4 timing config:load:defaults Completed in 11ms
            10 timing config:load:project Completed in 8ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            17 timing config:load:setEnvs Completed in 2ms
            18 timing config:load Completed in 42ms
            19 timing npm:load:configload Completed in 43ms
            22 verbose title npm install iobroker.info@1.9.22
            23 verbose argv "install" "--save-exact" "iobroker.info@1.9.22"
            24 timing npm:load:setTitle Completed in 4ms
            25 timing config:load:flatten Completed in 11ms
            26 timing npm:load:display Completed in 14ms
            28 verbose logfile /home/iobroker/.npm/_logs/2022-11-25T22_27_02_222Z-debug-0.log
            29 timing npm:load:logFile Completed in 19ms
            30 timing npm:load:timers Completed in 0ms
            32 timing npm:load Completed in 89ms
            34 silly logfile start cleaning logs, removing 21 files
            35 timing idealTree:init Completed in 3478ms
            36 timing idealTree:userRequests Completed in 22ms
            37 silly idealTree buildDeps
            38 silly fetch manifest iobroker.info@1.9.22
            39 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
            40 silly logfile done cleaning log files
            41 http fetch GET 200 https://registry.npmjs.org/iobroker.info 5853ms (cache updated)
            42 silly placeDep ROOT iobroker.info@1.9.22 REPLACE for: iobroker.inst@3.0.0 want: 1.9.22
            43 timing idealTree:#root Completed in 5907ms
            44 timing idealTree:node_modules/iobroker.info Completed in 0ms
            45 timing idealTree:buildDeps Completed in 5911ms
            46 timing idealTree:fixDepFlags Completed in 36ms
            47 timing idealTree Completed in 9544ms
            48 timing reify:loadTrees Completed in 9545ms
            49 timing reify:diffTrees Completed in 173ms
            51 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.info' ]
            53 silly reify   '/opt/iobroker/node_modules/iobroker.info': '/opt/iobroker/node_modules/.iobroker.info-OtqXm2hx',
            53 silly reify }
            54 timing reify:rollback:retireShallow Completed in 3ms
            55 timing command:install Completed in 9768ms
            65 error errno -39
            67 verbose exit -39
            68 timing npm Completed in 10228ms
            69 verbose unfinished npm timer reify 1669415222667
            70 verbose unfinished npm timer reify:retireShallow 1669415232402
            71 verbose code -39
            72 error     /home/iobroker/.npm/_logs/2022-11-25T22_27_02_222Z-debug-0.log
            du meinst ? error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript'?
              @thomas-braun ```
              53 silly reify }
              65 error errno -39
              67 verbose exit -39
              71 verbose code -39
              @p-hegmar
              Natürlich. Hast du das jetzt ausgeführt oder nicht?
                @p-hegmar
                P. HegmarP Offline
                P. HegmarP Offline
                P. Hegmar
                @thomas-braun nachdem ich das Verzeichnis unbenannt hab, läuft jetzt das upgrade ewig und hört nicht auf :/
                NACHTRAG: oops jetzt nach ewigen zeiten rührt sich was 🙄
                  @p-hegmar
                  Du sollst das nicht umbenennen, sondern
                  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                  ausführen. Darüber hinaus bitte immer vollständige Ein- wie Ausgaben posten.
                  iobroker update
                  sagt?
                    @p-hegmar
                    iobroker update
                    sagt?
                    P. HegmarP Offline
                    P. HegmarP Offline
                    P. Hegmar
                    @thomas-braun said in kein adapter lässt sich mehr update oder installieren:
                    strange... jetzt dürfts laufen... updates erfolgreich 🙄 ich sag einstweilen mal danke
                      @p-hegmar
                      iobroker update
                      sagt...
                      • H Offline
                        hoaloha
                        schrieb am zuletzt editiert von hoaloha
                        Hallo, ich bekomme nach update auf v16.18.1 auch admin und backitup (diese beiden werden mir angeboten) nicht aktualisiert. Habe
                        iobroker update
                        ausgeführt und das debug wirft folgendes aus.
                        iobroker@iobroker-nuc:~$ iobroker upgrade all --debug
                        This upgrade of "admin" will introduce the following changes:
                        -> 6.3.2:
                        Added `useNative` option to `sendTo` JSON Config component
                        Added `checkLicense` and `uuid` components to JSON Config
                        Corrected the news handler
                        Would you like to upgrade admin from @6.2.23 to @6.3.2 now? [(y)es, (n)o]: y
                        Update admin from @6.2.23 to @6.3.2
                        host.iobroker-nuc Adapter "system.adapter.admin.0" is stopped.
                        NPM version: 8.19.2
                        Installing iobroker.admin@6.3.2... (System call)
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.sma-em.git
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/MartinH1982/ioBroker.km200.git
                        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                        npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        npm WARN deprecated tough-cookie@0.12.1: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
                        npm ERR! code 1
                        npm ERR! path /opt/iobroker/node_modules/@abandonware/noble
                        npm ERR! command failed
                        npm ERR! command sh -c -- node-gyp rebuild
                        npm ERR! gyp info it worked if it ends with ok
                        npm ERR! gyp info using node-gyp@9.1.0
                        npm ERR! gyp info using node@16.18.1 | linux | x64
                        npm ERR! gyp ERR! find Python
                        npm ERR! gyp ERR! find Python Python is not set from command line or npm configuration
                        npm ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
                        npm ERR! gyp ERR! find Python checking if "python3" can be used
                        npm ERR! gyp ERR! find Python - executable path is "/usr/bin/python3"
                        npm ERR! gyp ERR! find Python - version is "3.5.3"
                        npm ERR! gyp ERR! find Python - version is 3.5.3 - should be >=3.6.0
                        npm ERR! gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED
                        npm ERR! gyp ERR! find Python checking if "python" can be used
                        npm ERR! gyp ERR! find Python - executable path is "/usr/bin/python"
                        npm ERR! gyp ERR! find Python - version is "2.7.13"
                        npm ERR! gyp ERR! find Python - version is 2.7.13 - should be >=3.6.0
                        npm ERR! gyp ERR! find Python **********************************************************
                        npm ERR! gyp ERR! find Python You need to install the latest version of Python.
                        npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
                        npm ERR! gyp ERR! find Python you can try one of the following options:
                        npm ERR! gyp ERR! find Python - Use the switch --python="/path/to/pythonexecutable"
                        npm ERR! gyp ERR! find Python   (accepted by both node-gyp and npm)
                        npm ERR! gyp ERR! find Python - Set the environment variable PYTHON
                        npm ERR! gyp ERR! find Python - Set the npm configuration variable python:
                        npm ERR! gyp ERR! find Python   npm config set python "/path/to/pythonexecutable"
                        npm ERR! gyp ERR! find Python For more information consult the documentation at:
                        npm ERR! gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
                        npm ERR! gyp ERR! configure error
                        npm ERR! gyp ERR! stack Error: Could not find any Python installation to use
                        npm ERR! gyp ERR! stack     at PythonFinder.fail (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:330:47)
                        npm ERR! gyp ERR! stack     at PythonFinder.runChecks (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:159:21)
                        npm ERR! gyp ERR! stack     at PythonFinder.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:266:16)
                        npm ERR! gyp ERR! stack     at PythonFinder.execFileCallback (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:297:7)
                        npm ERR! gyp ERR! stack     at ChildProcess.exithandler (node:child_process:394:7)
                        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
                        npm ERR! gyp ERR! stack     at maybeClose (node:internal/child_process:1100:16)
                        npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                        npm ERR! gyp ERR! System Linux 4.9.0-18-amd64
                        npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
                        npm ERR! gyp ERR! node -v v16.18.1
                        npm ERR! gyp ERR! node-gyp -v v9.1.0
                        npm ERR! gyp ERR! not ok
                        npm ERR!     /home/iobroker/.npm/_logs/2022-12-14T18_08_26_401Z-debug-0.log
                        Update "system.adapter.admin.0"
                        upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                        host.iobroker-nuc Adapter "system.adapter.admin.0" is started
                        This upgrade of "backitup" will introduce the following changes:
                        -> 2.5.9:
                        dependencies dropbox-v2-api updated
                        Fix Zigbee Restore
                        Fix Yahka Restore
                        Fix Javascript Restore
                        Fix Dropbox Error Messages
                        -> 2.5.8:
                        Fix iobroker Backup
                        dependencies updated
                        -> 2.5.7:
                        Axios 1.1.3 added
                        Added ukrainian language
                        -> 2.5.6:
                        Fix Grafana Backup
                        Fix Downloadserver
                        Translation updated
                        -> 2.5.5:
                        Design Fix
                        Docker DB Support added
                        Would you like to upgrade backitup from @2.5.4 to @2.5.9 now? [(y)es, (n)o]: y
                        Update backitup from @2.5.4 to @2.5.9
                        NPM version: 8.19.2
                        Installing iobroker.backitup@2.5.9... (System call)
                        npm ERR! code 1
                        npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
                        npm ERR! command sh -c -- prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                        npm ERR! prebuild-install warn install /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node)
                        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
                        npm ERR!     /home/iobroker/.npm/_logs/2022-12-14T18_18_36_518Z-debug-0.log
                        upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                        upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                        upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                        upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                        Hier sind so viele verweise drin, dass ich jetzt etwas überfordert bin.
                        Ist das LINK auch der Lösungsansatz für mein Problem? Oder ist hier der ERR Phyton die Richtung?
                        Danke vorab.
                        Intel NUC mit Proxmox
                        • H hoaloha
                          iobroker update
                          -> 6.3.2:
                          NPM version: 8.19.2
                          npm ERR! code 1
                          -> 2.5.9:
                          Fix Zigbee Restore
                          Fix Yahka Restore
                          -> 2.5.8:
                          Fix iobroker Backup
                          -> 2.5.7:
                          Axios 1.1.3 added
                          -> 2.5.6:
                          Fix Grafana Backup
                          Fix Downloadserver
                          Translation updated
                          -> 2.5.5:
                          Design Fix
                          NPM version: 8.19.2
                          npm ERR! code 1
                          Danke vorab.
                          @hoaloha
                          Was haste denn da installiert?
                          cat /etc/debian_version
                          sagt?
                          H 1 Antwort Letzte Antwort
                            @hoaloha
                            sagt?
                            hoaloha
                            9.13
                            • H hoaloha
                              9.13
                              @hoaloha sagte in kein adapter lässt sich mehr update oder installieren:
                              9.13
                              Stretch?? 😱
                              wirklich?
                              • H hoaloha
                                9.13
                                @hoaloha
                                Bring das mal aus der Kreidezeit in die Gegenwart.
                                Mittlerweile sind wir bei Debian 11.5.
                                Und dein 9er ist schon so lange tot, das stinkt nichtmal mehr.
                                  @hoaloha
                                  ist der Rest genauso alt?
                                  was sagt iobroker update -i ?
                                    @hoaloha
                                    hoaloha
                                    @homoran said in kein adapter lässt sich mehr update oder installieren:
                                    iobroker update -i
                                    iobroker@iobroker-nuc:~$ iobroker update -i
                                    Adapter    "admin"        : 6.3.2    , installed 6.2.23 [Updatable]
                                    Adapter    "backitup"     : 2.5.9    , installed 2.5.4  [Updatable]
                                    Adapter    "bmw"          : 2.5.7    , installed 2.5.7
                                    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
                                    Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
                                    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                                    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                    Adapter    "e3dc-rscp"    : 1.0.7    , installed 1.0.7
                                    Adapter    "ems-esp"      : 1.15.0   , installed 1.15.0
                                    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                    Adapter    "go-e"         : 1.0.23   , installed 1.0.23
                                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                    Adapter    "history"      : 2.2.0    , installed 2.2.0
                                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                    Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                                    Adapter    "hue"          : 3.7.1    , installed 3.7.1
                                    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                    Adapter    "ical"         : 1.13.1   , installed 1.13.1
                                    Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
                                    Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
                                    Adapter    "javascript"   : 6.0.3    , installed 6.1.3
                                    Controller "js-controller": 4.0.23   , installed 4.0.23
                                    Adapter    "km200"        : 2.0.3    , installed 2.0.3
                                    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                    Adapter    "mercedesme"   : 0.1.0    , installed 0.1.0
                                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                    Adapter    "mihome-vacuum": 3.8.6    , installed 3.8.6
                                    Adapter    "modbus"       : 5.0.5    , installed 5.0.5
                                    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                                    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                                    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
                                    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                                    Adapter    "robonect"     : 0.1.4    , installed 0.1.4
                                    Adapter    "sbfspot"      : 4.1.2    , installed 4.1.2
                                    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                    Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
                                    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                                    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                                    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                    Adapter    "statistics"   : 2.2.0    , installed 2.2.0
                                    Adapter    "synology"     : 2.1.13   , installed 2.1.13
                                    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                                    Adapter    "terminal"     : 0.2.6    , installed 0.2.6
                                    Adapter    "tesla-motors" : 1.3.1    , installed 1.3.1
                                    Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
                                    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                    Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                                    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                                    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                    Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                    Adapter    "zigbee"       : 1.7.6    , installed 1.7.6
                                      @hoaloha
                                      @homoran sagte in kein adapter lässt sich mehr update oder installieren:
                                      Nutzt halt nix, wenn der Unterbau schon 5x abgekündigt wurde und jetzt nichtmal mehr Extended LTS ist.
                                        hoaloha
                                        Dachte eigentlich ich bin immer gut dabei mit den Updates, aber habe mich mit der VM und Debian hier nicht weiter beschäftigt. Muss ich mir wohl mal anschauen. Stehe da gerade etwas ratlos.
                                        Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                                        • H hoaloha
                                          Beim iobroker schon. Beim Betriebssystem haste alles verpennt. Mittlerweile ist der Nachfolger (Debian 10) schon zur letzten Ruhestätte geleitet worden.
