  4. Test Javascript-Adapter 5.0.7 - RULES
    apollon77A
rules
113 Beiträge 25 Kommentatoren 31.6k Aufrufe 31 Beobachtet
  • F firebowl
    @apollon77
    let cond0 = false;
    on({id: "zigbee.0.00158d0008ab3a82.temperature", change: "ne"}, async function (obj) {
        _sendToFrontEnd(1665724678070, {val: obj.state.val, ack: obj.state.ack, valOld: obj.oldState && obj.oldState.val, ackOld: obj.oldState && obj.oldState.ack});
        const subCondVar1665724734367 = obj.state.val;
        const subCond1665724734367 = subCondVar1665724734367 >= -18;
        const _cond = (subCond1665724734367);
        _sendToFrontEnd(1665724734367, {result: subCond1665724734367, value: subCondVar1665724734367, compareWith: -18});
        if (cond0 === false && _cond) {
            cond0 = true;
    		// Pushover Hello
    		const subActionVar1665727500241 = "Hello".replace(/%s/g, obj.state.val).replace(/%id/g, obj.id).replace(/%name/g, obj.common && obj.common.name).replace(/%old/g, obj.oldState.val);
    		_sendToFrontEnd(1665727500241, {text: subActionVar1665727500241});`;
    		sendTo("pushover.0", "send", {
    		    message: subActionVar1665727500241,
    		    title: "ioBroker".replace(/%s/g, obj.state.val).replace(/%id/g, obj.id).replace(/%name/g, obj.common && obj.common.name).replace(/%old/g, obj.oldState.val),
    		    sound: "magic",
    		    priority: -1
        } else if (cond0 === true && !_cond) {
            cond0 = false;
    /*const demo = {
      "triggers": [
          "id": "TriggerState",
          "acceptedBy": "triggers",
          "_id": 1665724678070,
          "tagCard": "on change",
          "oid": "zigbee.0.00158d0008ab3a82.temperature",
          "oidRole": "value.temperature",
          "oidType": "number",
          "oidUnit": "°C",
          "oidWrite": false,
          "oidRead": true
      "conditions": [
            "id": "ConditionState",
            "acceptedBy": "conditions",
            "_id": 1665724734367,
            "tagCard": ">=",
            "oid": "",
            "value": "-18",
            "useTrigger": true
      "justCheck": false,
      "actions": {
        "then": [
            "id": "ActionPushover",
            "acceptedBy": "actions",
            "_id": 1665727500241,
            "instance": "pushover.0",
            "text": "Hello",
            "title": "ioBroker",
            "sound": "magic",
            "priority": -1
        "else": []
    //{"triggers":[{"id":"TriggerState","acceptedBy":"triggers","_id":1665724678070,"tagCard":"on change","oid":"zigbee.0.00158d0008ab3a82.temperature","oidRole":"value.temperature","oidType":"number","oidUnit":"°C","oidWrite":false,"oidRead":true}],"conditions":[[{"id":"ConditionState","acceptedBy":"conditions","_id":1665724734367,"tagCard":">=","oid":"","value":"-18","useTrigger":true}]],"justCheck":false,"actions":{"then":[{"id":"ActionPushover","acceptedBy":"actions","_id":1665727500241,"instance":"pushover.0","text":"Hello","title":"ioBroker","sound":"magic","priority":-1}],"else":[]}}
    Wenn ich anstatt Pushover einfach nen Logeintrag erzeugen lasse dann funktioniert das Script.
    Sorry für die späte Antwort, hab wohl die Benachrichtigung übersehen.
    apollon77A
    apollon77A
    #92
    @firebowl Bitte mit den Infos ein Issue im GitHub beim Telegram Adapter anlegen.
    F 1 Antwort Letzte Antwort
    • apollon77A apollon77
      F
      F
      firebowl
      #93
      @apollon77 Warum Telegram? Meinst Du Pushover? Telegram hab ich überhaupt nicht installiert.
      • F firebowl
        apollon77A
        apollon77A
        #94
        @firebowl Jaaa ..sorry Typo :-) (zu viele Themen parallel)
          F
          F
          firebowl
          #95
          @apollon77 Da gab es schon ein Issue, hab mich mal drangehängt. :)
          • N
            N
            niklasmader
            #96
            Hey,
            mag mir einer bei einem ganz einfachen Skript helfen? Ich möchte einfach nur bei Änderung von play' auf 'pause' die Lautstärke bei Sonos verstellen. Mit dem 'simple State' und dem Abgleich von 'true' und 'false' klappt das. Aber nicht mit dem String Value 'play' oder 'pause'. Ich habs schon mit Anführungszeichen doppelt oder einfach probiert.
            Danke euch!
            • N niklasmader
              Hey,
              Danke euch!
              apollon77A
              apollon77A
              #97
              @niklasmader Ist der Wert wirklich "pause"? wie Zeigt admin es an?
              N 1 Antwort Letzte Antwort
                N
                N
                niklasmader
                #98
                @apollon77 Ich hab's hier heraus gelesen. Ist dort nicht richtig zu schauen? Ich komme von Fhem und das ist auch schon etwas her, daher muss ich mich noch etwas einfinden.
                • N niklasmader
                  #99
                  @niklasmader sagte in Test Javascript-Adapter 5.0.7 - RULES:
                  geh mal auf den Bleistift und poste die Objektdaten
                    N
                    N
                    niklasmader
                    #100
                    @homoran Oh, interessant. Da gibt es ja sogar noch mehr. Aber "pause" müsste doch auch dabei sein, so wie ich das sehe.
                    • apollon77A
                      apollon77A
                      #101
                      Dann zeig mal im Javascript das Javascript was er aus deiner Rule generiert ... oben rechts auf das "Rules/JS" Logo klicken
                        N
                        N
                        niklasmader
                        #102
                        @apollon77 Ist anbei. Wofür ist eigentlich die aaskommentierte Sektion? Für die Simulation?
                        • N niklasmader
                          apollon77A
                          apollon77A
                          #103
                          @niklasmader das sieht aber korrekt aus. Wenn „pause“ dann setze 10. was genau tut nicht?
                            N
                            N
                            niklasmader
                            #104
                            @apollon77 Leider genau das nicht. Hier auch nochmal der Fehler im Log "Pause is not defined". Der komplette rote Log Teil ist aus dem Skript. Wenn ich "pause" in einzelne Anführungszeichen setze, also so 'pause', dann kommt kein Fehler im Log, aber es passiert auch nichts.
                            • N niklasmader
                              apollon77A
                              apollon77A
                              #105
                              @niklasmader Aahhhhbdas ist das Porblem ... dann hatte ich das falsch verstanden. Ja das hab ich im generieten code gesehen ...
                              Bitte GitHub issue auf machen mit Rule Screenshot UND dem vom generierten JS Code. Alternativ manuell den generierten Code editieren, da ist eine stelle wo "pause" ohne Anführungszeichen steht ... da müssen welche drum rum. Ist ein Code-Generator Bug
                                N
                                N
                                niklasmader
                                #106
                                @apollon77 Ich habe erst jetzt geschafft mich weiter damit zu beschäftigen. Das habe ich mir auch schon gedacht, aber man kann den Code doch gar nicht manuell editieren, oder? Auch, wenn ich im 'Expert Mode' bin und dann auf den Debug Button oben links neben dem 'Rules/JS' Logo klicke, kann ich nichts ändern, obwohl das ja eigentlich dafür da sein sollte. Auch die 'verbose' und 'debug' Buttons oben rechts neben dem 'Rules/JS' Logo haben bei mir keine Funktion. Ich bin immer im 'read-only mode'.
                                • N niklasmader
                                  apollon77A
                                  apollon77A
                                  #107
                                  @niklasmader hm … Mist. Ich dachte das geht. Der meets workaround wäre das Skript Objekt direkt zu bearbeiten. Da wäre über Objekte Tab. Dann expertenmodus aktivieren. Dann Script.Js.Name vom Skript raussuchen und auf das Stift Symbol gehen. Dann siehst du das Skript als json. Da die Stelle suchen und editieren (am besten vorher rauskopieren zur Sicherheit). Musst dann aber einfache Anführungszeichen nehmen und keine doppelten!
                                  Absoluter Hack aber so ginge es.
                                  • M
                                    M
                                    Mike Hellracer
                                    #108
                                    wollte mich jetzt auch mal an ein paar Rules versuchen.
                                    Ich habe Javascript 6.0.3 installiert, kann auch eine "Rule" anlegen, aber leider erscheint bei mir der Editor nicht.
                                    Weder bei gestartetetem noch gestoppten Script.
                                    Hoffe jemand kann mir sagen, was ich da falsch mache, bzw. ob ich noch etwas nachinstallieren muss?
                                    Danke zusammen
                                    apollon77A C M 3 Antworten Letzte Antwort
                                    • M Mike Hellracer
                                      Danke zusammen
                                      apollon77A
                                      apollon77A
                                      #109
                                      @mike-hellracer Steht irgendwas in der Browser Fehlerkonsole?
                                      • M Mike Hellracer
                                        Danke zusammen
                                        C
                                        C
                                        conslinger
                                        #110
                                        @mike-hellracer Bei mir das gleiche Problem, anbei was die Browser Console bei mir so sagt. Bin auf Stable, alle Adapter aktuell. Node.js: v16.18.0, NPM: 8.19.2.
                                        bootstrap.jsx:19 iobroker.admin@6.2.23
                                        instrument.ts:123 [2022-12-04T08:01:18.207Z] Try to connect
                                        instrument.ts:123 Stored version: , new version: 6.2.23
                                        instrument.ts:123 Connected: true
                                        bootstrap.jsx:26 iobroker.javascript@6.0.3 using theme "light"
                                        Prompt.js:15
                                        Prompt.js:16 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
                                        Prompt.js:17 Help us to create open source project with reactJS!
                                        Prompt.js:18 See you :)
                                        socket.io.js:66 [2022-12-04T08:01:24.464Z] Try to connect
                                        sentry.iobroker.net/api/56/envelope/?sentry_key=504499a725eb4898930d3b9e9da95740&sentry_version=7&sentry_client=sentry.javascript.browser%2F7.12.1:1          Failed to load resource: the server responded with a status of 403 ()
                                        instrument.ts:123 Detected custom blockly: iot
                                        instrument.ts:123 Detected custom blockly: iqontrol
                                        instrument.ts:123 Detected custom blockly: telegram
                                        instrument.ts:123 Translation for word "Instance:" in "de" was ignored: existing = "Beispiel:", new = Instanz:
                                        (anonymous) @ instrument.ts:123
                                        instrument.ts:123 Translation for word "Sends message via telegram" in "de" was ignored: existing = "Sendet eine Nachricht per telegram", new = Sendet Nachricht per Telegramm
                                        19instrument.ts:123 Detected an editable field that was not serializable. Please define SERIALIZABLE property as true on all editable custom fields. Proceeding with serialization.
                                        :8081/adapter/telegr…stomRuleBlocks.js:1 Uncaught SyntaxError: Cannot use import statement outside a module
                                        index.jsx:37 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading '__initialized')
                                            at index.jsx:37:37
                                            at Generator.next (<anonymous>)
                                            at 62.c2f8b616.chunk.js:178:1797
                                            at new Promise (<anonymous>)
                                            at gs (62.c2f8b616.chunk.js:178:1617)
                                            at HTMLScriptElement.o (index.jsx:35:40)
                                        DevTools failed to load source map: Could not load content for chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/browser-polyfill.js.map: System error: net::ERR_FILE_NOT_FOUND
                                        DevTools failed to load source map: Could not load content for http://192.168.178.41:8081/adapter/min-maps/vs/loader.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                        DevTools failed to load source map: Could not load content for http://192.168.178.41:8081/adapter/min-maps/vs/editor/editor.main.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                        DevTools failed to load source map: Could not load content for http://192.168.178.41:8081/adapter/min-maps/vs/editor/editor.main.nls.de.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                        • C conslinger
                                          Prompt.js:15
                                              at index.jsx:37:37
                                          apollon77A
                                          apollon77A
                                          #111
                                          @conslinger bitte github issue im javascript Projekt anlegen. Inkl Liste von installierten adaptern
                                          84.0k
