  3. Einsteigerfragen
  4. Installation
  5. Installation Iobroker auf Debian 11
14 Beiträge 7 Kommentatoren 6.3k Aufrufe 5 Beobachtet
  • P Pass3de
    die pure Verzweifelung mit der Hoffnung auf Hilfe.😵
    Leider geling mir die Installation von iobroker auf einer aktuellen Debian 11 Version auf VMware nicht. Die Debian Installation habe ich x mal neu gemacht...
    Der Befehl:
    curl -v -sLf https://iobroker.net/install.sh | bash -
    Bringt immer das gleiche Ergebniss! nichts...
    deb@deb-iob-03:~$ curl -v -sLf https://iobroker.net/install.sh | bash -
    • Trying 82.165.135.239:443...
    • Connected to iobroker.net (82.165.135.239) port 443 (#0)
    • ALPN, offering h2
    • ALPN, offering http/1.1
    • successfully set certificate verify locations:
    • CAfile: /etc/ssl/certs/ca-certificates.crt
    • CApath: /etc/ssl/certs
      } [5 bytes data]
    • TLSv1.3 (OUT), TLS handshake, Client hello (1):
      } [512 bytes data]
    • TLSv1.3 (IN), TLS handshake, Server hello (2):
      { [108 bytes data]
    • TLSv1.2 (IN), TLS handshake, Certificate (11):
      { [4016 bytes data]
    • TLSv1.2 (IN), TLS handshake, Server key exchange (12):
      { [365 bytes data]
    • TLSv1.2 (IN), TLS handshake, Server finished (14):
      { [4 bytes data]
    • TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
      } [102 bytes data]
    • TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
      } [1 bytes data]
    • TLSv1.2 (OUT), TLS handshake, Finished (20):
      } [16 bytes data]
    • TLSv1.2 (IN), TLS handshake, Finished (20):
      { [16 bytes data]
    • SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
    • ALPN, server accepted to use http/1.1
    • Server certificate:
    • subject: CN=iobroker.net
    • start date: Sep 15 00:00:15 2022 GMT
    • expire date: Dec 14 00:00:14 2022 GMT
    • subjectAltName: host "iobroker.net" matched cert's "iobroker.net"
    • issuer: C=US; O=Let's Encrypt; CN=R3
    • SSL certificate verify ok.
      } [5 bytes data]
    GET /install.sh HTTP/1.1
    Host: iobroker.net
    User-Agent: curl/7.74.0
    Accept: /
    { [5 bytes data]
    • Mark bundle as not supporting multiuse
      < HTTP/1.1 301 Moved Permanently
      < Server: nginx/1.10.3
      < Date: Sat, 12 Nov 2022 00:21:42 GMT
      < Content-Type: text/plain; charset=utf-8
      < Content-Length: 65
      < Connection: keep-alive
      < X-Powered-By: Express
      < Location: http://iobroker.live/install.sh
      < Vary: Accept
    • Ignoring the response-body
      { [65 bytes data]
    • Connection #0 to host iobroker.net left intact
    • Clear auth, redirects to port from 443 to 80Issue another request to this URL: 'http://iobroker.live/install.sh'
    • Trying 217.160.0.211:80...
    • Connected to iobroker.live (217.160.0.211) port 80 (#1)
    Host: iobroker.live
    Accept: /
    • Empty reply from server
    • Connection #1 to host iobroker.live left intact
      deb@deb-iob-03:~$
    Ich kann:
    nicht mehr sehen.
    Wer kann helfen?
    FredFF Offline
    FredFF Offline
    FredF
    Most Active Forum Testing
    @pass3de
    Kenne VM Ware nicht, aber der Befehl zur Installation von ioBroker lautet:
    curl -sLf https://iobroker.net/install.sh | bash --
    P 1 Antwort Letzte Antwort
    • P Offline
      Pass3de
      Ah ja, Code habe ich nicht gefunden...
      deb@deb-iob-03:~$ curl -v -sLf https://iobroker.net/install.sh | bash --
      *   Trying 82.165.135.239:443...
      * Connected to iobroker.net (82.165.135.239) port 443 (#0)
      * ALPN, offering h2
      * ALPN, offering http/1.1
      * successfully set certificate verify locations:
      *  CAfile: /etc/ssl/certs/ca-certificates.crt
      *  CApath: /etc/ssl/certs
      } [5 bytes data]
      * TLSv1.3 (OUT), TLS handshake, Client hello (1):
      } [512 bytes data]
      * TLSv1.3 (IN), TLS handshake, Server hello (2):
      { [108 bytes data]
      * TLSv1.2 (IN), TLS handshake, Certificate (11):
      { [4016 bytes data]
      * TLSv1.2 (IN), TLS handshake, Server key exchange (12):
      { [365 bytes data]
      * TLSv1.2 (IN), TLS handshake, Server finished (14):
      { [4 bytes data]
      * TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
      } [102 bytes data]
      * TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
      } [1 bytes data]
      * TLSv1.2 (OUT), TLS handshake, Finished (20):
      } [16 bytes data]
      * TLSv1.2 (IN), TLS handshake, Finished (20):
      { [16 bytes data]
      * SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
      * ALPN, server accepted to use http/1.1
      * Server certificate:
      *  subject: CN=iobroker.net
      *  start date: Sep 15 00:00:15 2022 GMT
      *  expire date: Dec 14 00:00:14 2022 GMT
      *  subjectAltName: host "iobroker.net" matched cert's "iobroker.net"
      *  issuer: C=US; O=Let's Encrypt; CN=R3
      *  SSL certificate verify ok.
      } [5 bytes data]
      > Host: iobroker.net
      > Accept: */*
      { [5 bytes data]
      * Mark bundle as not supporting multiuse
      < Date: Sat, 12 Nov 2022 09:36:53 GMT
      < Vary: Accept
      * Ignoring the response-body
      { [65 bytes data]
      * Connection #0 to host iobroker.net left intact
      * Clear auth, redirects to port from 443 to 80Issue another request to this URL: 'http://iobroker.live/install.sh'
      *   Trying 217.160.0.211:80...
      * Connected to iobroker.live (217.160.0.211) port 80 (#1)
      > Host: iobroker.live
      > Accept: */*
      * Empty reply from server
      * Connection #1 to host iobroker.live left intact
      deb@deb-iob-03:~$
      • FredFF FredF
        @pass3de
        Pass3de
        @fredf
        Hi fredf,
        das funktioniert leider auch nicht, dass hat mit ESX vorraussichtlich auch nichts zu tun.
        Trotzdem vielen Dank.
        • P Pass3de
          @fredf
          Hi fredf,
          @pass3de
          Versuchs so:
          curl -L https://iobroker.net/install.sh | bash -
            @pass3de
            Versuchs so:
            Pass3de
            Hi Thomas,
            leider auch nicht.
            deb@deb-iob-03:~$ curl -L https://iobroker.net/install.sh | bash -
              % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                             Dload  Upload   Total   Spent    Left  Speed
            100    65  100    65    0     0    439      0 --:--:-- --:--:-- --:--:--   439
              0     0    0     0    0     0      0      0 --:--:--  0:00:10 --:--:--     0
            curl: (52) Empty reply from server
            deb@deb-iob-03:~$
            • P Pass3de
              Hi Thomas,
              leider auch nicht.
              deb@deb-iob-03:~$
              @pass3de sagte in Installation Iobroker auf Debian 11:
              Das deutet auf eine Fehleinstellung im Server hin, bei mir wird das skript allerdings heruntergeladen, könnte also auch etwas bei dir im Netz sein.
              Sowas wie PiHole oder ähnliches im Einsatz?
              • ? Offline
                mhh ich habe heute morgen noch eine frische Debian 11 installation ( minimalinstall ) in VBOX installiert und dann einfach das Script geladen und ausgeführt.
                Was für mich grad aber nicht ersichtlich ist : Ist der Accound unter dem du das Script ausführt in der gruppe sudo oder als root mit berechtigungen in /etc/sudoers eingetragen ?
                Wenn nicht versuch die Zeile als root auszuführen :
                sudo su
                  sudo su
                  HomoranH Offline
                  HomoranH Offline
                  @itoss sagte in Installation Iobroker auf Debian 11:
                  WARUM???
                  Sollen alle Rechte verbogen werden, damit der User iobroker da nicht mehr ran kann?
                    sudo su
                    @itoss
                    Weder noch. Das Skript hat natürlich nur die Rechte vom ausführenden User. Wenn der keine sudo Rechte erwerben kann dann kann es das Skript auch nicht.
                    Direkt als root führt man das nicht aus, wozu auch?
                    • P Offline
                      Pass3de
                      danke für eure Ideen und Unterstützung.
                      Wartezimmer Wunderheilung.
                      Einfach mal ein paar Tage liegen lassen und schon geht´s...
                      Ich habe in der Tat eine ziemlich scharf eingestellte Sophos UTM laufen, habe aber über ein "anderes" GW den Weg frei nach draußen gelassen.
                      LG
                      Andre
                      • P Pass3de
                        Der Befehl:
                        • ALPN, offering h2
                          } [5 bytes data]
                          } [512 bytes data]
                          { [108 bytes data]
                          { [4016 bytes data]
                          { [365 bytes data]
                          { [4 bytes data]
                          } [102 bytes data]
                          } [1 bytes data]
                          } [16 bytes data]
                          { [16 bytes data]
                          } [5 bytes data]
                        Host: iobroker.net
                        Accept: /
                        { [5 bytes data]
                          < Vary: Accept
                          { [65 bytes data]
                        Host: iobroker.live
                        Accept: /
                          deb@deb-iob-03:~$
                        Ich kann:
                        nicht mehr sehen.
                        Wer kann helfen?
                        guggu
                        @pass3de
                        ich hab's auf Oracle VirtualBox installiert. War schwierig.
                        Falls Du (noch) interessiert bist, schicke ich die Installationsanleitung.
                        CCS
                        • G guggu
                          @pass3de
                          CCS
                          @guggu sagte in Installation Iobroker auf Debian 11:
                          War schwierig.
                          Inwiefern? Sollte in einer VM überhaupt kein Problem sein, ist halt eine Standardinstallation.
